Differences
Link to this comparison view
Both sides previous revision Previous revision
Last revision Both sides next revision
chibios:articles:rt_integration_guide [2016/01/08 14:24]
giovanni
chibios:articles:rt_integration_guide [2016/01/08 14:31]
giovanni
Line 2: Line 2:
 ====== ChibiOS/RT Integration Guide ====== ====== ChibiOS/RT Integration Guide ======
-All the delivered ​ChibiOS/​RT ​demos are stand alone applications so if you just start your application ​from an existing demo there isn't any integration effort, you are simply using the existing makefiles, ​the default ​startup files etc, minimal effort.\\ +This guide describes what is needed in order to integrate ​ChibiOS/​RT ​or ChibiOS/NIL in a build environment different ​from the default ​one provided ​in ChibiOS distribution.
-The matter is very different if you are going to integrate the OS into a different runtime framework or if you want to use a different build system, ​in that case you have the problem to integrate the OS source code into your application.+
 === What this guide does not cover === === What this guide does not cover ===
