RT vs NIL
RT and NIL kernels share a common API but a different set of features, NIL can be seen as a subset of RT even if it is very different internally. The two RTOSes have very different architectures driver by their requirements.
Feature RT NIL LIB Notes
System Time yes yes - 16 or 32 bits system time counter.
High Resolution Time yes no - System time, timers and delays at very high resolutions.
Real Tick-less Mode yes yes - There is no periodic system tick for optimal power management.
Critical Zones yes yes - Critical zones abstraction.
IRQ Management yes yes - ISRs abstraction.
Zero Latency Interrupts yes yes - IRQs unaffected by the kernel and with no kernel-related added latency.
Virtual Timers yes no - Unlimited software one-shot timers with no IRQ overhead.
Timeouts yes yes yes Wait primitives with time-out specification.
Time Measurement yes no - Execution time measurement with clock-cycle precision.
Full Threads Paradigm yes no - Threads create/join functionality.
Threads Registry yes yes - Runtime tasks state structure for debuggers.
Preemption yes yes - Fully preemptive scheduling.
Round Robin Scheduling yes no - Round robin scheduling for threads at equal priority.
Messages yes no - Inter-thread synchronous messages.
Mailboxes + + yes Message queues.
Pipes + + yes Characters pipes.
Counter Semaphores yes yes - Semaphores with resources counter.
Binary Semaphores - - yes Semaphores with boolean state.
Mutexes yes no - Mutexes implementing the Priority Inheritance algorithm.
Condition Variables yes no - Condition Variables and Monitors.
Events yes yes - Events, Event Flags, Event Sources.
Dynamic Threading + - yes Dynamic threading.
Memory Allocators + + yes Various memory allocators (core, pools, heaps).
Objects FIFOs + + yes FIFOs of generic objects.
Objects Factory + + yes Handling of dynamic reference-counted objects accessible by a readable name.
Runtime Statistics yes no - Execution times of critical code paths with clock cycle resolution.
System State Checker yes yes - Development time call protocols check.
Parameter Checks yes yes - Development time function parameters checks.
Assertions yes yes - Development time kernel consistency checks.
Trace Buffer yes no - Storage for the latest N context switch events.
Stack Overflows Check yes yes - Runtime stack overflow checks.
Stack Fill yes yes - Stack pattern fill for usage measurement.
CMSIS RTOS yes no - CMSIS RTOS emulation layer.
Port Layer
Both RTOSes are very portable, architecture-dependent and compiler-dependent details are encapsulated in a “port” module. RT and NIL share ports, the port modules supports both RTOSes with no changes.
