Differences
Link to this comparison view
Both sides previous revision Previous revision
chibios:product:start [2015/07/26 10:57]
giovanni
chibios:product:start [2019/01/27 11:52] (current)
giovanni
Line 5: Line 5:
   * [[chibios:​product:​rt:​start|RT]],​ the fastest RTOS solution for embedded realtime systems.   * [[chibios:​product:​rt:​start|RT]],​ the fastest RTOS solution for embedded realtime systems.
   * [[chibios:​product:​nil:​start|NIL]],​ the smallest RTOS solution for embedded realtime systems.   * [[chibios:​product:​nil:​start|NIL]],​ the smallest RTOS solution for embedded realtime systems.
 +  * [[chibios:​product:​oslib:​start|OSLIB]],​ a package of advanced features that can be used on top of both [[chibios:​product:​rt:​start|RT]] and [[chibios:​product:​nil:​start|NIL]].
   * [[chibios:​product:​hal:​start|HAL]],​ a package containing a set of abstract device drivers allowing effective application portability across different architectures.   * [[chibios:​product:​hal:​start|HAL]],​ a package containing a set of abstract device drivers allowing effective application portability across different architectures.
   * [[chibios:​product:​chibistudio:​start|ChibiStudio]],​ a free development environment based on Eclipse, GNU compilers, OpenOCD debugger and all the ChibiOS components and demos. Everything is included into an easy-to-use package, just unzip and go, no installation required.   * [[chibios:​product:​chibistudio:​start|ChibiStudio]],​ a free development environment based on Eclipse, GNU compilers, OpenOCD debugger and all the ChibiOS components and demos. Everything is included into an easy-to-use package, just unzip and go, no installation required.
