44 #define PORT_SUPPORTS_RT FALSE 50 #define PORT_NATURAL_ALIGN sizeof (void *) 56 #define PORT_STACK_ALIGN sizeof (stkalign_t) 62 #define PORT_WORKING_AREA_ALIGN sizeof (stkalign_t) 72 #define PORT_ARCHITECTURE_XXX 77 #define PORT_ARCHITECTURE_XXX_YYY 82 #define PORT_ARCHITECTURE_NAME "XXX Architecture" 87 #if defined(__GNUC__) || defined(__DOXYGEN__) 88 #define PORT_COMPILER_NAME "GCC " __VERSION__ 91 #error "unsupported compiler" 97 #define PORT_INFO "no info" 110 #if !defined(PORT_IDLE_THREAD_STACK_SIZE) || defined(__DOXYGEN__) 111 #define PORT_IDLE_THREAD_STACK_SIZE 32 119 #if !defined(PORT_INT_REQUIRED_STACK) || defined(__DOXYGEN__) 120 #define PORT_INT_REQUIRED_STACK 256 129 #if !defined(PORT_USE_ALT_TIMER) || defined(__DOXYGEN__) 130 #define PORT_USE_ALT_TIMER FALSE 136 #if !defined(PORT_XXX_WFI_SLEEP_IDLE) || defined(__DOXYGEN__) 137 #define PORT_XXX_ENABLE_WFI_IDLE FALSE 150 #if !defined(_FROM_ASM_) 200 #define PORT_SETUP_CONTEXT(tp, wbase, wtop, pf, arg) { \ 207 #define PORT_WA_SIZE(n) (sizeof(struct port_intctx) + \ 208 sizeof(struct port_extctx) + \ 209 ((size_t)(n)) + ((size_t)(PORT_INT_REQUIRED_STACK))) 219 #define PORT_WORKING_AREA(s, n) \ 220 stkalign_t s[THD_WORKING_AREA_SIZE(n) / sizeof (stkalign_t)] 225 #define PORT_IRQ_IS_VALID_PRIORITY(n) false 230 #define PORT_IRQ_IS_VALID_KERNEL_PRIORITY(n) false 237 #define PORT_IRQ_PROLOGUE() 244 #define PORT_IRQ_EPILOGUE() 251 #define PORT_IRQ_HANDLER(id) void id(void) 258 #define PORT_FAST_IRQ_HANDLER(id) void id(void) 270 #if !CH_DBG_ENABLE_STACK_CHECK || defined(__DOXYGEN__) 271 #define port_switch(ntp, otp) _port_switch(ntp, otp) 273 #define port_switch(ntp, otp) { \ 274 register struct port_intctx *sp asm ("%r1"); \ 275 if ((stkalign_t *)(sp - 1) < otp->wabase) \ 276 chSysHalt("stack overflow"); \ 277 _port_switch(ntp, otp); \ 287 #if !defined(_FROM_ASM_) 306 #if !defined(_FROM_ASM_) 416 #if PORT_XXX_ENABLE_WFI_IDLE 438 #if !defined(_FROM_ASM_) 440 #if CH_CFG_ST_TIMEDELTA > 0 441 #if !PORT_USE_ALT_TIMER 442 #include "chcore_timer.h" 444 #include "chcore_timer_alt.h" static void port_wait_for_interrupt(void)
Enters an architecture-dependent IRQ-waiting mode.
static void port_enable(void)
Enables all the interrupt sources.
void _port_init(void)
Port-related initialization code.
static rtcnt_t port_rt_get_counter_value(void)
Returns the current value of the realtime counter.
Platform dependent part of the thread_t structure.
static void port_disable(void)
Disables all the interrupt sources.
static void port_unlock(void)
Kernel-unlock action.
static void port_lock_from_isr(void)
Kernel-lock action from an interrupt handler.
void _port_switch(thread_t *ntp, thread_t *otp)
Performs a context switch between two threads.
static bool port_is_isr_context(void)
Determines the current execution context.
static void port_lock(void)
Kernel-lock action.
uint64_t stkalign_t
Type of stack and memory alignment enforcement.
static void port_unlock_from_isr(void)
Kernel-unlock action from an interrupt handler.
static syssts_t port_get_irq_status(void)
Returns a word encoding the current interrupts status.
static void port_suspend(void)
Disables the interrupt sources below kernel-level priority.
static bool port_irq_enabled(syssts_t sts)
Checks the interrupt status.
