chtm.h
18 */
19
20 /**
21  * @file chtm.h
22  * @brief Time Measurement module macros and structures.
23  *
24  * @addtogroup time_measurement
25  * @{
26  */
28 #ifndef CHTM_H
29 #define CHTM_H
30
31 #if (CH_CFG_USE_TM == TRUE) || defined(__DOXYGEN__)
34 /* Module constants. */
38 /* Module pre-compile time settings. */
42 /* Derived constants and error checks. */
45 #if PORT_SUPPORTS_RT == FALSE
46 #error "CH_CFG_USE_TM requires PORT_SUPPORTS_RT"
47 #endif
50 /* Module data structures and types. */
52
53 /**
54  * @brief Type of a time measurement calibration data.
55  */
56 typedef struct {
57  /**
58  * @brief Measurement calibration value.
59  */
62
63 /**
64  * @brief Type of a Time Measurement object.
65  * @note The maximum measurable time period depends on the implementation
66  * of the realtime counter and its clock frequency.
67  * @note The measurement is not 100% cycle-accurate, it can be in excess
68  * of few cycles depending on the compiler and target architecture.
69  * @note Interrupts can affect measurement if the measurement is performed
70  * with interrupts enabled.
71  */
72 typedef struct {
73  rtcnt_t best; /**< @brief Best measurement. */
74  rtcnt_t worst; /**< @brief Worst measurement. */
75  rtcnt_t last; /**< @brief Last measurement. */
76  ucnt_t n; /**< @brief Number of measurements. */
77  rttime_t cumulative; /**< @brief Cumulative measurement. */
79
80 /*===========================================================================*/
81 /* Module macros. */
82 /*===========================================================================*/
83
84 /*===========================================================================*/
85 /* External declarations. */
86 /*===========================================================================*/
87
88 #ifdef __cplusplus
89 extern "C" {
90 #endif
91  void _tm_init(void);
96  time_measurement_t *tmp2);
97 #ifdef __cplusplus
98 }
99 #endif
100
101 /*===========================================================================*/
102 /* Module inline functions. */
103 /*===========================================================================*/
104
105 #endif /* CH_CFG_USE_TM == TRUE */
106
107 #endif /* CHTM_H */
108
109 /** @} */
rtcnt_t worst
Worst measurement.
Definition: chtm.h:74
rtcnt_t best
Best measurement.
Definition: chtm.h:73
Definition: chtm.h:56
void _tm_init(void)
Initializes the time measurement unit.
Definition: chtm.c:77
uint64_t rttime_t
Definition: chtypes.h:44
Definition: chtm.h:72
#define NOINLINE
Makes functions not inlineable.
Definition: chtypes.h:70
uint32_t ucnt_t
Definition: chtypes.h:56
uint32_t rtcnt_t
Definition: chtypes.h:43
rtcnt_t offset
Definition: chtm.h:60
rtcnt_t last
Last measurement.
Definition: chtm.h:75
rttime_t cumulative
Definition: chtm.h:77
NOINLINE void chTMStartMeasurementX(time_measurement_t *tmp)
Starts a measurement.
Definition: chtm.c:114
NOINLINE void chTMChainMeasurementToX(time_measurement_t *tmp1, time_measurement_t *tmp2)
Stops a measurement and chains to the next one using the same time stamp.
Definition: chtm.c:144
ucnt_t n
Definition: chtm.h:76
void chTMObjectInit(time_measurement_t *tmp)
Initializes a TimeMeasurement object.
Definition: chtm.c:97
NOINLINE void chTMStopMeasurementX(time_measurement_t *tmp)
Stops a measurement.
Definition: chtm.c:127
