hal_can_lld.c
18  * @file hal_can_lld.c
19  * @brief PLATFORM CAN subsystem low level driver source.
21  * @addtogroup CAN
27 #if (HAL_USE_CAN == TRUE) || defined(__DOXYGEN__)
37 /**
38  * @brief CAN1 driver identifier.
39  */
40 #if (PLATFORM_CAN_USE_CAN1 == TRUE) || defined(__DOXYGEN__)
42 #endif
43
45 /* Driver local variables and types. */
47
49 /* Driver local functions. */
51
53 /* Driver interrupt handlers. */
55
57 /* Driver exported functions. */
59
60 /**
61  * @brief Low level CAN driver initialization.
62  *
63  * @notapi
64  */
65 void can_lld_init(void) {
66
67 #if PLATFORM_CAN_USE_CAN1 == TRUE
68  /* Driver initialization.*/
69  canObjectInit(&CAND1);
70 #endif
71 }
72
73 /**
74  * @brief Configures and activates the CAN peripheral.
75  *
76  * @param[in] canp pointer to the @p CANDriver object
77  *
78  * @notapi
79  */
80 void can_lld_start(CANDriver *canp) {
81
82  if (canp->state == CAN_STOP) {
83  /* Enables the peripheral.*/
84 #if PLATFORM_CAN_USE_CAN1 == TRUE
85  if (&CAND1 == canp) {
86
87  }
88 #endif
89  }
90  /* Configures the peripheral.*/
91
92 }
93
94 /**
95  * @brief Deactivates the CAN peripheral.
96  *
97  * @param[in] canp pointer to the @p CANDriver object
98  *
99  * @notapi
100  */
101 void can_lld_stop(CANDriver *canp) {
102
103  if (canp->state == CAN_READY) {
104  /* Resets the peripheral.*/
105
106  /* Disables the peripheral.*/
107 #if PLATFORM_CAN_USE_CAN1 == TRUE
108  if (&CAND1 == canp) {
109
110  }
111 #endif
112  }
113 }
114
115 /**
116  * @brief Determines whether a frame can be transmitted.
117  *
118  * @param[in] canp pointer to the @p CANDriver object
119  * @param[in] mailbox mailbox number, @p CAN_ANY_MAILBOX for any mailbox
120  *
121  * @return The queue space availability.
122  * @retval false no space in the transmit queue.
123  * @retval true transmit slot available.
124  *
125  * @notapi
126  */
127 bool can_lld_is_tx_empty(CANDriver *canp, canmbx_t mailbox) {
128
129  (void)canp;
130
131  switch (mailbox) {
132  case CAN_ANY_MAILBOX:
133  return false;
134  case 1:
135  return false;
136  case 2:
137  return false;
138  case 3:
139  return false;
140  default:
141  return false;
142  }
143 }
144
145 /**
146  * @brief Inserts a frame into the transmit queue.
147  *
148  * @param[in] canp pointer to the @p CANDriver object
149  * @param[in] ctfp pointer to the CAN frame to be transmitted
150  * @param[in] mailbox mailbox number, @p CAN_ANY_MAILBOX for any mailbox
151  *
152  * @notapi
153  */
155  canmbx_t mailbox,
156  const CANTxFrame *ctfp) {
157
158  (void)canp;
159  (void)mailbox;
160  (void)ctfp;
161
162 }
163
164 /**
165  * @brief Determines whether a frame has been received.
166  *
167  * @param[in] canp pointer to the @p CANDriver object
168  * @param[in] mailbox mailbox number, @p CAN_ANY_MAILBOX for any mailbox
169  *
170  * @return The queue space availability.
171  * @retval false no space in the transmit queue.
172  * @retval true transmit slot available.
173  *
174  * @notapi
175  */
177
178  (void)canp;
179  (void)mailbox;
180
181  switch (mailbox) {
182  case CAN_ANY_MAILBOX:
183  return false;
184  case 1:
185  return false;
186  case 2:
187  return false;
188  default:
189  return false;
190  }
191 }
192
193 /**
194  * @brief Receives a frame from the input queue.
195  *
196  * @param[in] canp pointer to the @p CANDriver object
197  * @param[in] mailbox mailbox number, @p CAN_ANY_MAILBOX for any mailbox
198  * @param[out] crfp pointer to the buffer where the CAN frame is copied
199  *
200  * @notapi
201  */
203  canmbx_t mailbox,
204  CANRxFrame *crfp) {
205
206  (void)canp;
207  (void)mailbox;
208  (void)crfp;
209
210 }
211
212 #if (CAN_USE_SLEEP_MODE == TRUE) || defined(__DOXYGEN__)
213 /**
214  * @brief Enters the sleep mode.
215  *
216  * @param[in] canp pointer to the @p CANDriver object
217  *
218  * @notapi
219  */
221
222  (void)canp;
223
224 }
225
226 /**
227  * @brief Enforces leaving the sleep mode.
228  *
229  * @param[in] canp pointer to the @p CANDriver object
230  *
231  * @notapi
232  */
234
235  (void)canp;
236
237 }
238 #endif /* CAN_USE_SLEEP_MOD == TRUEE */
239
240 #endif /* HAL_USE_CAN == TRUE */
241
242 /** @} */
uint32_t canmbx_t
Type of a transmission mailbox index.
Definition: hal_can_lld.h:78
void can_lld_transmit(CANDriver *canp, canmbx_t mailbox, const CANTxFrame *ctfp)
Definition: hal_can_lld.c:154
CAN transmission frame.
Definition: hal_can_lld.h:96
CAN received frame.
Definition: hal_can_lld.h:119
Definition: hal_can_lld.c:101
canstate_t state
Definition: hal_can_lld.h:154
Structure representing an CAN driver.
Definition: hal_can_lld.h:150
void can_lld_wakeup(CANDriver *canp)
Definition: hal_can_lld.c:233
CANDriver CAND1
Definition: hal_can_lld.c:41
void can_lld_receive(CANDriver *canp, canmbx_t mailbox, CANRxFrame *crfp)
Definition: hal_can_lld.c:202
void canObjectInit(CANDriver *canp)
Initializes the standard part of a CANDriver structure.
Definition: hal_can.c:68
void can_lld_sleep(CANDriver *canp)
Definition: hal_can_lld.c:220
bool can_lld_is_rx_nonempty(CANDriver *canp, canmbx_t mailbox)
Definition: hal_can_lld.c:176
Definition: hal_can_lld.c:80
Definition: hal_can_lld.c:127
Definition: hal_can_lld.c:65
#define CAN_ANY_MAILBOX
Special mailbox identifier.
Definition: hal_can.h:63
