hal_crypto_lld.c
18  * @file hal_crypto_lld.c
19  * @brief PLATFORM cryptographic subsystem low level driver source.
21  * @addtogroup CRYPTO
27 #if (HAL_USE_CRY == TRUE) || defined(__DOXYGEN__)
37 /** @brief CRY1 driver identifier.*/
38 #if PLATFORM_CRY_USE_CRY1 || defined(__DOXYGEN__)
40 #endif
41
43 /* Driver local variables and types. */
45
47 /* Driver local functions. */
49
51 /* Driver interrupt handlers. */
53
55 /* Driver exported functions. */
57
58 /**
59  * @brief Low level crypto driver initialization.
60  *
61  * @notapi
62  */
63 void cry_lld_init(void) {
64
65 }
66
67 /**
68  * @brief Configures and activates the crypto peripheral.
69  *
70  * @param[in] cryp pointer to the @p CRYDriver object
71  *
72  * @notapi
73  */
74 void cry_lld_start(CRYDriver *cryp) {
75
76  if (cryp->state == CRY_STOP) {
77
78  }
79 }
80
81 /**
82  * @brief Deactivates the crypto peripheral.
83  *
84  * @param[in] cryp pointer to the @p CRYDriver object
85  *
86  * @notapi
87  */
88 void cry_lld_stop(CRYDriver *cryp) {
89
90  if (cryp->state == CRY_READY) {
91
92  }
93 }
94
95 /**
96  * @brief Initializes the transient key for a specific algorithm.
97  *
98  * @param[in] cryp pointer to the @p CRYDriver object
99  * @param[in] algorithm the algorithm identifier
100  * @param[in] size key size in bytes
101  * @param[in] keyp pointer to the key data
102  * @return The operation status.
103  * @retval CRY_NOERROR if the operation succeeded.
104  * @retval CRY_ERR_INV_ALGO if the specified algorithm is unknown or
105  * unsupported.
106  * @retval CRY_ERR_INV_KEY_SIZE if the specified key size is invalid.
107  *
108  * @notapi
109  */
111  cryalgorithm_t algorithm,
112  size_t size,
113  const uint8_t *keyp) {
114
115  (void)cryp;
116  (void)algorithm;
117  (void)size;
118  (void)keyp;
119
120  return CRY_NOERROR;
121 }
122
123 /**
124  * @brief Encryption of a single block using AES.
125  * @note The implementation of this function must guarantee that it can
126  * be called from any context.
127  *
128  * @param[in] cryp pointer to the @p CRYDriver object
129  * @param[in] key_id the key to be used for the operation, zero is
130  * the transient key, other values are keys stored
131  * in an unspecified way
132  * @param[in] in buffer containing the input plaintext
133  * @param[out] out buffer for the output cyphertext
134  * @return The operation status.
135  * @retval CRY_NOERROR if the operation succeeded.
136  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
137  * device instance.
138  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
139  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
140  * or refers to an empty key slot.
141  *
142  * @notapi
143  */
145  crykey_t key_id,
146  const uint8_t *in,
147  uint8_t *out) {
148
149  (void)cryp;
150  (void)key_id;
151  (void)in;
152  (void)out;
153
154  return CRY_ERR_INV_ALGO;
155 }
156
157 /**
158  * @brief Decryption of a single block using AES.
159  * @note The implementation of this function must guarantee that it can
160  * be called from any context.
161  *
162  * @param[in] cryp pointer to the @p CRYDriver object
163  * @param[in] key_id the key to be used for the operation, zero is
164  * the transient key, other values are keys stored
165  * in an unspecified way
166  * @param[in] in buffer containing the input cyphertext
167  * @param[out] out buffer for the output plaintext
168  * @return The operation status.
169  * @retval CRY_NOERROR if the operation succeeded.
170  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
171  * device instance.
172  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
173  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
174  * or refers to an empty key slot.
175  *
176  * @notapi
177  */
179  crykey_t key_id,
180  const uint8_t *in,
181  uint8_t *out) {
182
183  (void)cryp;
184  (void)key_id;
185  (void)in;
186  (void)out;
187
188  return CRY_ERR_INV_ALGO;
189 }
190
191 /**
192  * @brief Encryption operation using AES-ECB.
193  * @note The function operates on data buffers whose lenght is a multiple
194  * of an AES block, this means that padding must be done by the
195  * caller.
196  *
197  * @param[in] cryp pointer to the @p CRYDriver object
198  * @param[in] key_id the key to be used for the operation, zero is
199  * the transient key, other values are keys stored
200  * in an unspecified way
201  * @param[in] size size of the plaintext buffer, this number must
202  * be a multiple of the selected key size
203  * @param[in] in buffer containing the input plaintext
204  * @param[out] out buffer for the output cyphertext
205  * @return The operation status.
206  * @retval CRY_NOERROR if the operation succeeded.
207  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
208  * device instance.
209  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
210  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
211  * or refers to an empty key slot.
212  *
213  * @notapi
214  */
216  crykey_t key_id,
217  size_t size,
218  const uint8_t *in,
219  uint8_t *out) {
220
221  (void)cryp;
222  (void)key_id;
223  (void)size;
224  (void)in;
225  (void)out;
226
227  return CRY_ERR_INV_ALGO;
228 }
229
230 /**
231  * @brief Decryption operation using AES-ECB.
232  * @note The function operates on data buffers whose lenght is a multiple
233  * of an AES block, this means that padding must be done by the
234  * caller.
235  *
236  * @param[in] cryp pointer to the @p CRYDriver object
237  * @param[in] key_id the key to be used for the operation, zero is
238  * the transient key, other values are keys stored
239  * in an unspecified way
240  * @param[in] size size of the plaintext buffer, this number must
241  * be a multiple of the selected key size
242  * @param[in] in buffer containing the input plaintext
243  * @param[out] out buffer for the output cyphertext
244  * @return The operation status.
245  * @retval CRY_NOERROR if the operation succeeded.
246  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
247  * device instance.
248  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
249  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
250  * or refers to an empty key slot.
251  *
252  * @notapi
253  */
255  crykey_t key_id,
256  size_t size,
257  const uint8_t *in,
258  uint8_t *out) {
259
260  (void)cryp;
261  (void)key_id;
262  (void)size;
263  (void)in;
264  (void)out;
265
266  return CRY_ERR_INV_ALGO;
267 }
268
269 /**
270  * @brief Encryption operation using AES-CBC.
271  * @note The function operates on data buffers whose lenght is a multiple
272  * of an AES block, this means that padding must be done by the
273  * caller.
274  *
275  * @param[in] cryp pointer to the @p CRYDriver object
276  * @param[in] key_id the key to be used for the operation, zero is
277  * the transient key, other values are keys stored
278  * in an unspecified way
279  * @param[in] size size of the plaintext buffer, this number must
280  * be a multiple of the selected key size
281  * @param[in] in buffer containing the input plaintext
282  * @param[out] out buffer for the output cyphertext
283  * @param[in] iv 128 bits initial vector
284  * @return The operation status.
285  * @retval CRY_NOERROR if the operation succeeded.
286  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
287  * device instance.
288  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
289  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
290  * or refers to an empty key slot.
291  *
292  * @notapi
293  */
295  crykey_t key_id,
296  size_t size,
297  const uint8_t *in,
298  uint8_t *out,
299  const uint8_t *iv) {
300
301  (void)cryp;
302  (void)key_id;
303  (void)size;
304  (void)in;
305  (void)out;
306  (void)iv;
307
308  return CRY_ERR_INV_ALGO;
309 }
310
311 /**
312  * @brief Decryption operation using AES-CBC.
313  * @note The function operates on data buffers whose lenght is a multiple
314  * of an AES block, this means that padding must be done by the
315  * caller.
316  *
317  * @param[in] cryp pointer to the @p CRYDriver object
318  * @param[in] key_id the key to be used for the operation, zero is
319  * the transient key, other values are keys stored
320  * in an unspecified way
321  * @param[in] size size of the plaintext buffer, this number must
322  * be a multiple of the selected key size
323  * @param[in] in buffer containing the input plaintext
324  * @param[out] out buffer for the output cyphertext
325  * @param[in] iv 128 bits initial vector
326  * @return The operation status.
327  * @retval CRY_NOERROR if the operation succeeded.
328  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
329  * device instance.
330  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
331  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
332  * or refers to an empty key slot.
333  *
334  * @notapi
335  */
337  crykey_t key_id,
338  size_t size,
339  const uint8_t *in,
340  uint8_t *out,
341  const uint8_t *iv) {
342
343  (void)cryp;
344  (void)key_id;
345  (void)size;
346  (void)in;
347  (void)out;
348  (void)iv;
349
350  return CRY_ERR_INV_ALGO;
351 }
352
353 /**
354  * @brief Encryption operation using AES-CFB.
355  * @note The function operates on data buffers whose lenght is a multiple
356  * of an AES block, this means that padding must be done by the
357  * caller.
358  *
359  * @param[in] cryp pointer to the @p CRYDriver object
360  * @param[in] key_id the key to be used for the operation, zero is
361  * the transient key, other values are keys stored
362  * in an unspecified way
363  * @param[in] size size of the plaintext buffer, this number must
364  * be a multiple of the selected key size
365  * @param[in] in buffer containing the input plaintext
366  * @param[out] out buffer for the output cyphertext
367  * @param[in] iv 128 bits initial vector
368  * @return The operation status.
369  * @retval CRY_NOERROR if the operation succeeded.
370  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
371  * device instance.
372  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
373  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
374  * or refers to an empty key slot.
375  *
376  * @notapi
377  */
379  crykey_t key_id,
380  size_t size,
381  const uint8_t *in,
382  uint8_t *out,
383  const uint8_t *iv) {
384
385  (void)cryp;
386  (void)key_id;
387  (void)size;
388  (void)in;
389  (void)out;
390  (void)iv;
391
392  return CRY_ERR_INV_ALGO;
393 }
394
395 /**
396  * @brief Decryption operation using AES-CFB.
397  * @note The function operates on data buffers whose lenght is a multiple
398  * of an AES block, this means that padding must be done by the
399  * caller.
400  *
401  * @param[in] cryp pointer to the @p CRYDriver object
402  * @param[in] key_id the key to be used for the operation, zero is
403  * the transient key, other values are keys stored
404  * in an unspecified way
405  * @param[in] size size of the plaintext buffer, this number must
406  * be a multiple of the selected key size
407  * @param[in] in buffer containing the input plaintext
408  * @param[out] out buffer for the output cyphertext
409  * @param[in] iv 128 bits initial vector
410  * @return The operation status.
411  * @retval CRY_NOERROR if the operation succeeded.
412  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
413  * device instance.
414  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
415  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
416  * or refers to an empty key slot.
417  *
418  * @notapi
419  */
421  crykey_t key_id,
422  size_t size,
423  const uint8_t *in,
424  uint8_t *out,
425  const uint8_t *iv) {
426
427  (void)cryp;
428  (void)key_id;
429  (void)size;
430  (void)in;
431  (void)out;
432  (void)iv;
433
434  return CRY_ERR_INV_ALGO;
435 }
436
437 /**
438  * @brief Encryption operation using AES-CTR.
439  * @note The function operates on data buffers whose lenght is a multiple
440  * of an AES block, this means that padding must be done by the
441  * caller.
442  *
443  * @param[in] cryp pointer to the @p CRYDriver object
444  * @param[in] key_id the key to be used for the operation, zero is
445  * the transient key, other values are keys stored
446  * in an unspecified way
447  * @param[in] size size of the plaintext buffer, this number must
448  * be a multiple of 16
449  * @param[in] in buffer containing the input plaintext
450  * @param[out] out buffer for the output cyphertext
451  * @param[in] iv 128 bits initial vector + counter, it contains
452  * a 96 bits IV and a 32 bits counter
453  * @return The operation status.
454  * @retval CRY_NOERROR if the operation succeeded.
455  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
456  * device instance.
457  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
458  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
459  * or refers to an empty key slot.
460  *
461  * @notapi
462  */
464  crykey_t key_id,
465  size_t size,
466  const uint8_t *in,
467  uint8_t *out,
468  const uint8_t *iv) {
469
470  (void)cryp;
471  (void)key_id;
472  (void)size;
473  (void)in;
474  (void)out;
475  (void)iv;
476
477  return CRY_ERR_INV_ALGO;
478 }
479
480 /**
481  * @brief Decryption operation using AES-CTR.
482  * @note The function operates on data buffers whose lenght is a multiple
483  * of an AES block, this means that padding must be done by the
484  * caller.
485  *
486  * @param[in] cryp pointer to the @p CRYDriver object
487  * @param[in] key_id the key to be used for the operation, zero is
488  * the transient key, other values are keys stored
489  * in an unspecified way
490  * @param[in] size size of the plaintext buffer, this number must
491  * be a multiple of 16
492  * @param[in] in buffer containing the input cyphertext
493  * @param[out] out buffer for the output plaintext
494  * @param[in] iv 128 bits initial vector + counter, it contains
495  * a 96 bits IV and a 32 bits counter
496  * @return The operation status.
497  * @retval CRY_NOERROR if the operation succeeded.
498  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
499  * device instance.
500  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
501  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
502  * or refers to an empty key slot.
503  *
504  * @notapi
505  */
507  crykey_t key_id,
508  size_t size,
509  const uint8_t *in,
510  uint8_t *out,
511  const uint8_t *iv) {
512
513  (void)cryp;
514  (void)key_id;
515  (void)size;
516  (void)in;
517  (void)out;
518  (void)iv;
519
520  return CRY_ERR_INV_ALGO;
521 }
522
523 /**
524  * @brief Encryption operation using AES-GCM.
525  * @note The function operates on data buffers whose lenght is a multiple
526  * of an AES block, this means that padding must be done by the
527  * caller.
528  *
529  * @param[in] cryp pointer to the @p CRYDriver object
530  * @param[in] key_id the key to be used for the operation, zero is
531  * the transient key, other values are keys stored
532  * in an unspecified way
533  * @param[in] size size of the text buffers, this number must be a
534  * multiple of 16
535  * @param[in] in buffer containing the input plaintext
536  * @param[out] out buffer for the output cyphertext
537  * @param[in] iv 128 bits initial vector + counter, it contains
538  * a 96 bits IV and a 32 bits counter
539  * @param[in] aadsize size of the authentication data, this number
540  * must be a multiple of 16
541  * @param[in] aad buffer containing the authentication data
542  * @param[in] authtag 128 bits buffer for the generated authentication
543  * tag
544  * @return The operation status.
545  * @retval CRY_NOERROR if the operation succeeded.
546  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
547  * device instance.
548  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
549  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
550  * or refers to an empty key slot.
551  *
552  * @notapi
553  */
555  crykey_t key_id,
556  size_t size,
557  const uint8_t *in,
558  uint8_t *out,
559  const uint8_t *iv,
560  size_t aadsize,
561  const uint8_t *aad,
562  uint8_t *authtag) {
563
564  (void)cryp;
565  (void)key_id;
566  (void)size;
567  (void)in;
568  (void)out;
569  (void)iv;
570  (void)aadsize;
571  (void)aad;
572  (void)authtag;
573
574  return CRY_ERR_INV_ALGO;
575 }
576
577 /**
578  * @brief Decryption operation using AES-GCM.
579  * @note The function operates on data buffers whose lenght is a multiple
580  * of an AES block, this means that padding must be done by the
581  * caller.
582  *
583  * @param[in] cryp pointer to the @p CRYDriver object
584  * @param[in] key_id the key to be used for the operation, zero is
585  * the transient key, other values are keys stored
586  * in an unspecified way
587  * @param[in] size size of the text buffers, this number must be a
588  * multiple of 16
589  * @param[in] in buffer for the output cyphertext
590  * @param[out] out buffer containing the input plaintext
591  * @param[in] iv 128 bits initial vector + counter, it contains
592  * a 96 bits IV and a 32 bits counter
593  * @param[in] aadsize size of the authentication data, this number
594  * must be a multiple of 16
595  * @param[in] aad buffer containing the authentication data
596  * @param[in] authtag 128 bits buffer for the generated authentication
597  * tag
598  * @return The operation status.
599  * @retval CRY_NOERROR if the operation succeeded.
600  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
601  * device instance.
602  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
603  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
604  * or refers to an empty key slot.
605  *
606  * @notapi
607  */
609  crykey_t key_id,
610  size_t size,
611  const uint8_t *in,
612  uint8_t *out,
613  const uint8_t *iv,
614  size_t aadsize,
615  const uint8_t *aad,
616  uint8_t *authtag) {
617
618  (void)cryp;
619  (void)key_id;
620  (void)size;
621  (void)in;
622  (void)out;
623  (void)iv;
624  (void)aadsize;
625  (void)aad;
626  (void)authtag;
627
628  return CRY_ERR_INV_ALGO;
629 }
630
631 /**
632  * @brief Encryption of a single block using (T)DES.
633  * @note The implementation of this function must guarantee that it can
634  * be called from any context.
635  *
636  * @param[in] cryp pointer to the @p CRYDriver object
637  * @param[in] key_id the key to be used for the operation, zero is
638  * the transient key, other values are keys stored
639  * in an unspecified way
640  * @param[in] in buffer containing the input plaintext
641  * @param[out] out buffer for the output cyphertext
642  * @return The operation status.
643  * @retval CRY_NOERROR if the operation succeeded.
644  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
645  * device instance.
646  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
647  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
648  * or refers to an empty key slot.
649  *
650  * @notapi
651  */
653  crykey_t key_id,
654  const uint8_t *in,
655  uint8_t *out) {
656
657  (void)cryp;
658  (void)key_id;
659  (void)in;
660  (void)out;
661
662  return CRY_ERR_INV_ALGO;
663 }
664
665 /**
666  * @brief Decryption of a single block using (T)DES.
667  * @note The implementation of this function must guarantee that it can
668  * be called from any context.
669  *
670  *
671  * @param[in] cryp pointer to the @p CRYDriver object
672  * @param[in] key_id the key to be used for the operation, zero is
673  * the transient key, other values are keys stored
674  * in an unspecified way
675  * @param[in] in buffer containing the input cyphertext
676  * @param[out] out buffer for the output plaintext
677  * @return The operation status.
678  * @retval CRY_NOERROR if the operation succeeded.
679  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
680  * device instance.
681  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
682  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
683  * or refers to an empty key slot.
684  *
685  * @notapi
686  */
688  crykey_t key_id,
689  const uint8_t *in,
690  uint8_t *out) {
691
692  (void)cryp;
693  (void)key_id;
694  (void)in;
695  (void)out;
696
697  return CRY_ERR_INV_ALGO;
698 }
699
700 /**
701  * @brief Encryption operation using (T)DES-ECB.
702  * @note The function operates on data buffers whose length is a multiple
703  * of an DES block, this means that padding must be done by the
704  * caller.
705  *
706  * @param[in] cryp pointer to the @p CRYDriver object
707  * @param[in] key_id the key to be used for the operation, zero is
708  * the transient key, other values are keys stored
709  * in an unspecified way
710  * @param[in] size size of the plaintext buffer, this number must
711  * be a multiple of 8
712  * @param[in] in buffer containing the input plaintext
713  * @param[out] out buffer for the output cyphertext
714  * @return The operation status.
715  * @retval CRY_NOERROR if the operation succeeded.
716  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
717  * device instance.
718  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
719  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
720  * or refers to an empty key slot.
721  *
722  * @notapi
723  */
725  crykey_t key_id,
726  size_t size,
727  const uint8_t *in,
728  uint8_t *out) {
729
730  (void)cryp;
731  (void)key_id;
732  (void)size;
733  (void)in;
734  (void)out;
735
736  return CRY_ERR_INV_ALGO;
737 }
738
739 /**
740  * @brief Decryption operation using (T)DES-ECB.
741  * @note The function operates on data buffers whose length is a multiple
742  * of an DES block, this means that padding must be done by the
743  * caller.
744  *
745  * @param[in] cryp pointer to the @p CRYDriver object
746  * @param[in] key_id the key to be used for the operation, zero is
747  * the transient key, other values are keys stored
748  * in an unspecified way
749  * @param[in] size size of the plaintext buffer, this number must
750  * be a multiple of 8
751  * @param[in] in buffer containing the input cyphertext
752  * @param[out] out buffer for the output plaintext
753  * @return T he operation status.
754  * @retval CRY_NOERROR if the operation succeeded.
755  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
756  * device instance.
757  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
758  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
759  * or refers to an empty key slot.
760  *
761  * @notapi
762  */
764  crykey_t key_id,
765  size_t size,
766  const uint8_t *in,
767  uint8_t *out) {
768
769  (void)cryp;
770  (void)key_id;
771  (void)size;
772  (void)in;
773  (void)out;
774
775  return CRY_ERR_INV_ALGO;
776 }
777
778 /**
779  * @brief Encryption operation using (T)DES-CBC.
780  * @note The function operates on data buffers whose length is a multiple
781  * of an DES block, this means that padding must be done by the
782  * caller.
783  *
784  * @param[in] cryp pointer to the @p CRYDriver object
785  * @param[in] key_id the key to be used for the operation, zero is
786  * the transient key, other values are keys stored
787  * in an unspecified way
788  * @param[in] size size of the plaintext buffer, this number must
789  * be a multiple of 8
790  * @param[in] in buffer containing the input plaintext
791  * @param[out] out buffer for the output cyphertext
792  * @param[in] iv 64 bits input vector
793  * @return The operation status.
794  * @retval CRY_NOERROR if the operation succeeded.
795  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
796  * device instance.
797  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
798  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
799  * or refers to an empty key slot.
800  *
801  * @notapi
802  */
804  crykey_t key_id,
805  size_t size,
806  const uint8_t *in,
807  uint8_t *out,
808  const uint8_t *iv) {
809
810  (void)cryp;
811  (void)key_id;
812  (void)size;
813  (void)in;
814  (void)out;
815  (void)iv;
816
817  return CRY_ERR_INV_ALGO;
818 }
819
820 /**
821  * @brief Decryption operation using (T)DES-CBC.
822  * @note The function operates on data buffers whose length is a multiple
823  * of an DES block, this means that padding must be done by the
824  * caller.
825  *
826  * @param[in] cryp pointer to the @p CRYDriver object
827  * @param[in] key_id the key to be used for the operation, zero is
828  * the transient key, other values are keys stored
829  * in an unspecified way
830  * @param[in] size size of the plaintext buffer, this number must
831  * be a multiple of 8
832  * @param[in] in buffer containing the input cyphertext
833  * @param[out] out buffer for the output plaintext
834  * @param[in] iv 64 bits input vector
835  * @return The operation status.
836  * @retval CRY_NOERROR if the operation succeeded.
837  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
838  * device instance.
839  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
840  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
841  * or refers to an empty key slot.
842  *
843  * @notapi
844  */
846  crykey_t key_id,
847  size_t size,
848  const uint8_t *in,
849  uint8_t *out,
850  const uint8_t *iv) {
851
852  (void)cryp;
853  (void)key_id;
854  (void)size;
855  (void)in;
856  (void)out;
857  (void)iv;
858
859  return CRY_ERR_INV_ALGO;
860 }
861
862 /**
863  * @brief Hash initialization using SHA1.
864  * @note Use of this algorithm is not recommended because proven weak.
865  *
866  * @param[in] cryp pointer to the @p CRYDriver object
867  * @param[out] sha1ctxp pointer to a SHA1 context to be initialized
868  * @retval CRY_NOERROR if the operation succeeded.
869  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
870  * device instance.
871  *
872  * @notapi
873  */
875
876  (void)cryp;
877  (void)sha1ctxp;
878
879  return CRY_ERR_INV_ALGO;
880 }
881
882 /**
883  * @brief Hash update using SHA1.
884  * @note Use of this algorithm is not recommended because proven weak.
885  *
886  * @param[in] cryp pointer to the @p CRYDriver object
887  * @param[in] sha1ctxp pointer to a SHA1 context
888  * @param[in] size size of input buffer
889  * @param[in] in buffer containing the input text
890  * @return The operation status.
891  * @retval CRY_NOERROR if the operation succeeded.
892  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
893  * device instance.
894  *
895  * @notapi
896  */
898  size_t size, const uint8_t *in) {
899
900  (void)cryp;
901  (void)sha1ctxp;
902  (void)size;
903  (void)in;
904
905  return CRY_ERR_INV_ALGO;
906 }
907
908 /**
909  * @brief Hash finalization using SHA1.
910  * @note Use of this algorithm is not recommended because proven weak.
911  *
912  * @param[in] cryp pointer to the @p CRYDriver object
913  * @param[in] sha1ctxp pointer to a SHA1 context
914  * @param[out] out 160 bits output buffer
915  * @return The operation status.
916  * @retval CRY_NOERROR if the operation succeeded.
917  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
918  * device instance.
919  *
920  * @notapi
921  */
923  uint8_t *out) {
924
925  (void)cryp;
926  (void)sha1ctxp;
927  (void)out;
928
929  return CRY_ERR_INV_ALGO;
930 }
931
932 /**
933  * @brief Hash initialization using SHA256.
934  *
935  * @param[in] cryp pointer to the @p CRYDriver object
936  * @param[out] sha256ctxp pointer to a SHA256 context to be initialized
937  * @retval CRY_NOERROR if the operation succeeded.
938  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
939  * device instance.
940  *
941  * @notapi
942  */
944
945  (void)cryp;
946  (void)sha256ctxp;
947
948  return CRY_ERR_INV_ALGO;
949 }
950
951 /**
952  * @brief Hash update using SHA256.
953  *
954  * @param[in] cryp pointer to the @p CRYDriver object
955  * @param[in] sha256ctxp pointer to a SHA256 context
956  * @param[in] size size of input buffer
957  * @param[in] in buffer containing the input text
958  * @return The operation status.
959  * @retval CRY_NOERROR if the operation succeeded.
960  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
961  * device instance.
962  *
963  * @notapi
964  */
966  size_t size, const uint8_t *in) {
967
968  (void)cryp;
969  (void)sha256ctxp;
970  (void)size;
971  (void)in;
972
973  return CRY_ERR_INV_ALGO;
974 }
975
976 /**
977  * @brief Hash finalization using SHA256.
978  *
979  * @param[in] cryp pointer to the @p CRYDriver object
980  * @param[in] sha256ctxp pointer to a SHA256 context
981  * @param[out] out 256 bits output buffer
982  * @return The operation status.
983  * @retval CRY_NOERROR if the operation succeeded.
984  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
985  * device instance.
986  *
987  * @notapi
988  */
990  uint8_t *out) {
991
992  (void)cryp;
993  (void)sha256ctxp;
994  (void)out;
995
996  return CRY_ERR_INV_ALGO;
997 }
998
999 /**
1000  * @brief Hash initialization using SHA512.
1001  *
1002  * @param[in] cryp pointer to the @p CRYDriver object
1003  * @param[out] sha512ctxp pointer to a SHA512 context to be initialized
1004  * @retval CRY_NOERROR if the operation succeeded.
1005  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1006  * device instance.
1007  *
1008  * @notapi
1009  */
1011
1012  (void)cryp;
1013  (void)sha512ctxp;
1014
1015  return CRY_ERR_INV_ALGO;
1016 }
1017
1018 /**
1019  * @brief Hash update using SHA512.
1020  *
1021  * @param[in] cryp pointer to the @p CRYDriver object
1022  * @param[in] sha512ctxp pointer to a SHA512 context
1023  * @param[in] size size of input buffer
1024  * @param[in] in buffer containing the input text
1025  * @return The operation status.
1026  * @retval CRY_NOERROR if the operation succeeded.
1027  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1028  * device instance.
1029  *
1030  * @notapi
1031  */
1033  size_t size, const uint8_t *in) {
1034
1035  (void)cryp;
1036  (void)sha512ctxp;
1037  (void)size;
1038  (void)in;
1039
1040  return CRY_ERR_INV_ALGO;
1041 }
1042
1043 /**
1044  * @brief Hash finalization using SHA512.
1045  *
1046  * @param[in] cryp pointer to the @p CRYDriver object
1047  * @param[in] sha512ctxp pointer to a SHA512 context
1048  * @param[out] out 512 bits output buffer
1049  * @return The operation status.
1050  * @retval CRY_NOERROR if the operation succeeded.
1051  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1052  * device instance.
1053  *
1054  * @notapi
1055  */
1057  uint8_t *out) {
1058
1059  (void)cryp;
1060  (void)sha512ctxp;
1061  (void)out;
1062
1063  return CRY_ERR_INV_ALGO;
1064 }
1065
1066 /**
1067  * @brief True random numbers generator.
1068  *
1069  * @param[in] cryp pointer to the @p CRYDriver object
1070  * @param[out] out 128 bits output buffer
1071  * @return The operation status.
1072  * @retval CRY_NOERROR if the operation succeeded.
1073  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1074  * device instance.
1075  *
1076  * @notapi
1077  */
1079
1080  (void)cryp;
1081  (void)out;
1082
1083  return CRY_ERR_INV_ALGO;
1084 }
1085
1086 #endif /* HAL_USE_CRY == TRUE */
1087
1088 /** @} */
cryerror_t cry_lld_SHA1_init(CRYDriver *cryp, SHA1Context *sha1ctxp)
cryerror_t cry_lld_decrypt_AES_GCM(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv, size_t aadsize, const uint8_t *aad, uint8_t *authtag)
cryerror_t cry_lld_decrypt_AES_CFB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
cryerror_t cry_lld_encrypt_AES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
cryerror_t cry_lld_SHA1_final(CRYDriver *cryp, SHA1Context *sha1ctxp, uint8_t *out)
cryerror_t cry_lld_SHA1_update(CRYDriver *cryp, SHA1Context *sha1ctxp, size_t size, const uint8_t *in)
Type of a SHA512 context.
Definition: hal_crypto.h:190
cryerror_t cry_lld_decrypt_DES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
cryerror_t cry_lld_TRNG(CRYDriver *cryp, uint8_t *out)
Structure representing an CRY driver.
cryerror_t cry_lld_encrypt_DES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
cryerror_t cry_lld_encrypt_AES_CFB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
cryerror_t
Driver error codes.
Definition: hal_crypto.h:94
cryerror_t cry_lld_encrypt_AES_GCM(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv, size_t aadsize, const uint8_t *aad, uint8_t *authtag)
cryerror_t cry_lld_decrypt_AES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
uint32_t crykey_t
CRY key identifier type.
cryerror_t cry_lld_decrypt_AES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
cryerror_t cry_lld_SHA512_init(CRYDriver *cryp, SHA512Context *sha512ctxp)
cryerror_t cry_lld_SHA512_final(CRYDriver *cryp, SHA512Context *sha512ctxp, uint8_t *out)
cryerror_t cry_lld_decrypt_AES_CTR(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
cryalgorithm_t
Type of an algorithm identifier.
Definition: hal_crypto.h:106
cryerror_t cry_lld_encrypt_AES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
CRYDriver CRYD1
cryerror_t cry_lld_decrypt_DES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
cryerror_t cry_lld_encrypt_DES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
cryerror_t cry_lld_decrypt_DES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
cryerror_t cry_lld_encrypt_AES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
cryerror_t cry_lld_SHA512_update(CRYDriver *cryp, SHA512Context *sha512ctxp, size_t size, const uint8_t *in)
USBInEndpointState in
IN EP0 state.
Definition: hal_usb_lld.c:57
cryerror_t cry_lld_SHA256_init(CRYDriver *cryp, SHA256Context *sha256ctxp)
cryerror_t cry_lld_decrypt_AES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
crystate_t state
Type of a SHA1 context.
Definition: hal_crypto.h:174
USBOutEndpointState out
OUT EP0 state.
Definition: hal_usb_lld.c:61
cryerror_t cry_lld_encrypt_DES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
cryerror_t cry_lld_loadkey(CRYDriver *cryp, cryalgorithm_t algorithm, size_t size, const uint8_t *keyp)
cryerror_t cry_lld_SHA256_update(CRYDriver *cryp, SHA256Context *sha256ctxp, size_t size, const uint8_t *in)
Type of a SHA256 context.
Definition: hal_crypto.h:182
cryerror_t cry_lld_SHA256_final(CRYDriver *cryp, SHA256Context *sha256ctxp, uint8_t *out)
cryerror_t cry_lld_encrypt_AES_CTR(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
