hal_dac_lld.c
18  * @file hal_dac_lld.c
19  * @brief PLATFORM DAC subsystem low level driver source.
21  * @addtogroup DAC
27 #if (HAL_USE_DAC == TRUE) || defined(__DOXYGEN__)
37 /** @brief DAC1 driver identifier.*/
38 #if (PLATFORM_DAC_USE_DAC1 == TRUE) || defined(__DOXYGEN__)
40 #endif
41
43 /* Driver local variables. */
45
47 /* Driver local functions. */
49
51 /* Driver interrupt handlers. */
53
55 /* Driver exported functions. */
57
58 /**
59  * @brief Low level DAC driver initialization.
60  *
61  * @notapi
62  */
63 void dac_lld_init(void) {
64
65 #if PLATFORM_DAC_USE_DAC1 == TRUE
66  dacObjectInit(&DACD1);
67 #endif
68 }
69
70 /**
71  * @brief Configures and activates the DAC peripheral.
72  *
73  * @param[in] dacp pointer to the @p DACDriver object
74  *
75  * @notapi
76  */
77 void dac_lld_start(DACDriver *dacp) {
78
79  /* If the driver is in DAC_STOP state then a full initialization is
80  required.*/
81  if (dacp->state == DAC_STOP) {
82  /* Enabling the clock source.*/
83 #if PLATFORM_DAC_USE_DAC1 == TRUE
84  if (&DACD1 == dacp) {
85
86  }
87 #endif
88  }
89 }
90
91 /**
92  * @brief Deactivates the DAC peripheral.
93  *
94  * @param[in] dacp pointer to the @p DACDriver object
95  *
96  * @notapi
97  */
98 void dac_lld_stop(DACDriver *dacp) {
99
100  /* If in ready state then disables the DAC clock.*/
101  if (dacp->state == DAC_READY) {
102
103 #if PLATFORM_DAC_USE_DAC1 == TRUE
104  if (&DACD1 == dacp) {
105
106  }
107 #endif
108  }
109 }
110
111 /**
112  * @brief Outputs a value directly on a DAC channel.
113  *
114  * @param[in] dacp pointer to the @p DACDriver object
115  * @param[in] channel DAC channel number
116  * @param[in] sample value to be output
117  *
118  * @api
119  */
121  dacchannel_t channel,
122  dacsample_t sample) {
123
124  (void)dacp;
125  (void)channel;
126  (void)sample;
127 }
128
129 /**
130  * @brief Starts a DAC conversion.
131  * @details Starts an asynchronous conversion operation.
132  * @note In @p DAC_DHRM_8BIT_RIGHT mode the parameters passed to the
133  * callback are wrong because two samples are packed in a single
134  * dacsample_t element. This will not be corrected, do not rely
135  * on those parameters.
136  * @note In @p DAC_DHRM_8BIT_RIGHT_DUAL mode two samples are treated
137  * as a single 16 bits sample and packed into a single dacsample_t
138  * element. The num_channels must be set to one in the group
139  * conversion configuration structure.
140  *
141  * @param[in] dacp pointer to the @p DACDriver object
142  *
143  * @notapi
144  */
146
147  (void)dacp;
148 }
149
150 /**
151  * @brief Stops an ongoing conversion.
152  * @details This function stops the currently ongoing conversion and returns
153  * the driver in the @p DAC_READY state. If there was no conversion
154  * being processed then the function does nothing.
155  *
156  * @param[in] dacp pointer to the @p DACDriver object
157  *
158  * @iclass
159  */
161
162  (void)dacp;
163 }
164
165 #endif /* HAL_USE_DAC == TRUE */
166
167 /** @} */
uint32_t dacchannel_t
Type of a DAC channel index.
Definition: hal_dac_lld.h:68
DACDriver DACD1
Definition: hal_dac_lld.c:39
void dacObjectInit(DACDriver *dacp)
Initializes the standard part of a DACDriver structure.
Definition: hal_dac.c:68
Definition: hal_dac_lld.c:77
Definition: hal_dac_lld.c:98
Structure representing a DAC driver.
Definition: hal_dac_lld.h:139
Definition: hal_dac_lld.c:63
dacstate_t state
Definition: hal_dac_lld.h:143
void dac_lld_put_channel(DACDriver *dacp, dacchannel_t channel, dacsample_t sample)
Definition: hal_dac_lld.c:120
void dac_lld_start_conversion(DACDriver *dacp)
Definition: hal_dac_lld.c:145
uint16_t dacsample_t
Type representing a DAC sample.
Definition: hal_dac_lld.h:78
void dac_lld_stop_conversion(DACDriver *dacp)
Definition: hal_dac_lld.c:160
