hal_flash.h File Reference
Generic flash driver class header. More...
struct  flash_sector_descriptor_t
 Flash sector descriptor. More...
struct  flash_descriptor_t
 Type of a flash device descriptor. More...
struct  BaseFlashVMT
 BaseFlash virtual methods table. More...
struct  BaseFlash
 Base flash class. More...
#define _base_flash_methods_alone
 BaseFlash specific methods. More...
 BaseFlash specific methods with inherited ones. More...
#define _base_flash_data
 BaseFlash specific data. More...
Flash attributes
#define FLASH_ATTR_ERASED_IS_ONE   0x00000001
#define FLASH_ATTR_MEMORY_MAPPED   0x00000002
#define FLASH_ATTR_REWRITABLE   0x00000004
#define FLASH_ATTR_READ_ECC_CAPABLE   0x00000008
#define FLASH_ATTR_SUSPEND_ERASE_CAPABLE   0x00000010
Macro Functions (BaseFlash)
#define getBaseFlash(ip)   ((BaseFlash *)&(ip)->vmt)
 Instance getter. More...
#define flashGetDescriptor(ip)   (ip)->vmt->get_descriptor(ip)
 Sensors get axes number. More...
#define flashRead(ip, offset, n, rp)   (ip)->vmt->read(ip, offset, n, rp)
 Read operation. More...
#define flashProgram(ip, offset, n, pp)   (ip)->vmt->program(ip, offset, n, pp)
 Program operation. More...
#define flashStartEraseAll(ip)   (ip)->vmt->start_erase_all(ip)
 Starts a whole-device erase operation. More...
#define flashStartEraseSector(ip, sector)   (ip)->vmt->start_erase_sector(ip, sector)
 Starts an sector erase operation. More...
#define flashQueryErase(ip, msec)   (ip)->vmt->query_erase(ip, msec)
 Queries the driver for erase operation progress. More...
#define flashVerifyErase(ip, sector)   (ip)->vmt->verify_erase(ip, sector)
 Returns the erase state of a sector. More...
typedef uint32_t flash_offset_t
 Type of a flash offset. More...
typedef uint32_t flash_sector_t
 Type of a flash sector number. More...
Enumerations
flash_error_t flashWaitErase (BaseFlash *devp)
 Waits until the current erase operation is finished. More...
flash_offset_t flashGetSectorOffset (BaseFlash *devp, flash_sector_t sector)
 Returns the offset of a sector. More...
uint32_t flashGetSectorSize (BaseFlash *devp, flash_sector_t sector)
 Returns the size of a sector. More...
Definition in file hal_flash.h.
