hal_gyroscope.h
18  * @file hal_gyroscope.h
19  * @brief Generic gyroscope interface header.
21  * @addtogroup HAL_GYROSCOPE
25 #ifndef HAL_GYROSCOPE_H
26 #define HAL_GYROSCOPE_H
28 #include "hal_sensors.h"
31 /* Driver constants. */
37
38 /*===========================================================================*/
39 /* Derived constants and error checks. */
40 /*===========================================================================*/
41
43 /* Driver data structures and types. */
45
46 /**
47  * @brief BaseGyroscope specific methods.
48  */
49 #define _base_gyroscope_methods_alone \
50  /* Invoke the sample bias procedure.*/ \
51  msg_t (*sample_bias)(void *instance); \
52  /* Invoke the set bias procedure.*/ \
53  msg_t (*set_bias)(void *instance, float biases[]); \
54  /* Remove bias stored data.*/ \
55  msg_t (*reset_bias)(void *instance); \
56  /* Invoke the set sensitivity procedure.*/ \
57  msg_t (*set_sensitivity)(void *instance, float sensitivities[]); \
58  /* Restore sensitivity stored data to default.*/ \
59  msg_t (*reset_sensitivity)(void *instance);
60
61
62 /**
63  * @brief BaseGyroscope specific methods with inherited ones.
64  */
65 #define _base_gyroscope_methods \
66  _base_sensor_methods \
67  _base_gyroscope_methods_alone
68
69 /**
70  * @brief @p BaseGyroscope virtual methods table.
71  */
74 };
75
76 /**
77  * @brief @p BaseGyroscope specific data.
78  */
79 #define _base_gyroscope_data \
80  _base_sensor_data
81
82 /**
83  * @extends BaseSensor
84  *
85  * @brief Base gyroscope class.
86  * @details This class represents a generic gyroscope.
87  */
88 typedef struct {
89  /** @brief Virtual Methods Table.*/
90  const struct BaseGyroscopeVMT *vmt;
93
94 /*===========================================================================*/
95 /* Driver macros. */
96 /*===========================================================================*/
97
98 /**
99  * @name Macro Functions (BaseGyroscope)
100  * @{
101  */
102 /**
103  * @brief Gyroscope get axes number.
104  *
105  * @param[in] ip pointer to a @p BaseGyroscope class.
106  * @return The number of axes of the BaseGyroscope
107  *
108  * @api
109  */
110 #define gyroscopeGetAxesNumber(ip) \
111  (ip)->vmt->get_channels_number(ip)
112
113 /**
114  * @brief Gyroscope read raw data.
115  *
116  * @param[in] ip pointer to a @p BaseGyroscope class.
117  * @param[in] dp pointer to a data array.
118  *
119  * @return The operation status.
120  * @retval MSG_OK if the function succeeded.
121  * @retval MSG_RESET if one or more errors occurred.
122  *
123  * @api
124  */
125 #define gyroscopeReadRaw(ip, dp) \
126  (ip)->vmt->read_raw(ip, dp)
127
128 /**
129  * @brief Gyroscope read cooked data.
130  *
131  * @param[in] ip pointer to a @p BaseGyroscope class.
132  * @param[in] dp pointer to a data array.
133  *
134  * @return The operation status.
135  * @retval MSG_OK if the function succeeded.
136  * @retval MSG_RESET if one or more errors occurred.
137  *
138  * @api
139  */
140 #define gyroscopeReadCooked(ip, dp) \
141  (ip)->vmt->read_cooked(ip, dp)
142
143 /**
144  * @brief Gyroscope bias sampling procedure.
145  * @note During this procedure gyroscope must be kept hold in the rest
146  * position. Sampled bias will be automatically removed after
147  * calling this procedure.
148  *
149  * @param[in] ip pointer to a @p BaseGyroscope class.
150  *
151  * @return The operation status.
152  * @retval MSG_OK if the function succeeded.
153  * @retval MSG_RESET if one or more errors occurred.
154  *
155  * @api
156  */
157 #define gyroscopeSampleBias(ip) \
158  (ip)->vmt->sample_bias(ip)
159
160 /**
161  * @brief Updates gyroscope bias data from received buffer.
162  * @note The bias buffer must have the same length of the
163  * the gyroscope axes number.
164  *
165  * @param[in] ip pointer to a @p BaseGyroscope class.
166  * @param[in] bp pointer to a buffer of bias values.
167  *
168  * @return The operation status.
169  * @retval MSG_OK if the function succeeded.
170  * @retval MSG_RESET if one or more errors occurred.
171  *
172  * @api
173  */
174 #define gyroscopeSetBias(ip, bp) \
175  (ip)->vmt->set_bias(ip, bp)
176
177 /**
178  * @brief Reset gyroscope bias data restoring it to zero.
179  *
180  * @param[in] ip pointer to a @p BaseGyroscope class.
181  *
182  * @return The operation status.
183  * @retval MSG_OK if the function succeeded.
184  * @retval MSG_RESET if one or more errors occurred.
185  *
186  * @api
187  */
188 #define gyroscopeResetBias(ip) \
189  (ip)->vmt->reset_bias(ip)
190
191 /**
192  * @brief Updates gyroscope sensitivity data from received buffer.
193  * @note The sensitivity buffer must have the same length of the
194  * the gyroscope axes number.
195  *
196  * @param[in] ip pointer to a @p BaseGyroscope class.
197  * @param[in] sp pointer to a buffer of sensitivity values.
198  *
199  * @return The operation status.
200  * @retval MSG_OK if the function succeeded.
201  * @retval MSG_RESET if one or more errors occurred.
202  *
203  * @api
204  */
205 #define gyroscopeSetSensitivity(ip, sp) \
206  (ip)->vmt->set_sensitivity(ip, sp)
207
208 /**
209  * @brief Reset gyroscope sensitivity data restoring it to its typical
210  * value.
211  *
212  * @param[in] ip pointer to a @p BaseGyroscope class.
213  *
214  * @return The operation status.
215  * @retval MSG_OK if the function succeeded.
216  * @retval MSG_RESET if one or more errors occurred.
217  *
218  * @api
219  */
220 #define gyroscopeResetSensitivity(ip) \
221  (ip)->vmt->reset_sensitivity(ip)
222 /** @} */
223
224 /*===========================================================================*/
225 /* External declarations. */
226 /*===========================================================================*/
227
228 #ifdef __cplusplus
229 extern "C" {
230 #endif
231
232 #ifdef __cplusplus
233 }
234 #endif
235
236 #endif /* HAL_GYROSCOPE_H */
237
238 /** @} */
Definition: hal_gyroscope.h:79
Definition: hal_gyroscope.h:72
Definition: hal_gyroscope.h:88
const struct BaseGyroscopeVMT * vmt
Definition: hal_gyroscope.h:90
Generic sensors interface header.
Definition: hal_gyroscope.h:65
