hal_hygrometer.h
18  * @file hal_hygrometer.h
19  * @brief Generic hygrometer interface header.
21  * @addtogroup HAL_HYGROMETER
25 #ifndef HAL_HYGROMETER_H
26 #define HAL_HYGROMETER_H
28 #include "hal_sensors.h"
31 /* Driver constants. */
37
38 /*===========================================================================*/
39 /* Derived constants and error checks. */
40 /*===========================================================================*/
41
43 /* Driver data structures and types. */
45
46 /**
47  * @brief BaseHygrometer specific methods.
48  */
49 #define _base_hygrometer_methods_alone \
50  /* Invoke the set bias procedure.*/ \
51  msg_t (*set_bias)(void *instance, float biases[]); \
52  /* Remove bias stored data.*/ \
53  msg_t (*reset_bias)(void *instance); \
54  /* Invoke the set sensitivity procedure.*/ \
55  msg_t (*set_sensitivity)(void *instance, float sensitivities[]); \
56  /* Restore sensitivity stored data to default.*/ \
57  msg_t (*reset_sensitivity)(void *instance);
58
59
60 /**
61  * @brief BaseHygrometer specific methods with inherited ones.
62  */
63 #define _base_hygrometer_methods \
64  _base_sensor_methods \
65  _base_hygrometer_methods_alone
66
67 /**
68  * @brief @p BaseHygrometer virtual methods table.
69  */
72 };
73
74 /**
75  * @brief @p BaseHygrometer specific data.
76  */
77 #define _base_hygrometer_data \
78  _base_sensor_data
79
80 /**
81  * @extends BaseSensor
82  *
83  * @brief Base hygrometer class.
84  * @details This class represents a generic hygrometer.
85  */
86 typedef struct {
87  /** @brief Virtual Methods Table.*/
88  const struct BaseHygrometerVMT *vmt;
91
92 /*===========================================================================*/
93 /* Driver macros. */
94 /*===========================================================================*/
95 /**
96  * @name Macro Functions (BaseHygrometer)
97  * @{
98  */
99 /**
100  * @brief Hygrometer get channels number.
101  *
102  * @param[in] ip pointer to a @p BaseHygrometer class.
103  * @return The number of channels of the BaseHygrometer
104  *
105  * @api
106  */
107 #define hygrometerGetChannelsNumber(ip) \
108  (ip)->vmt->get_channels_number(ip)
109
110 /**
111  * @brief Hygrometer read raw data.
112  *
113  * @param[in] ip pointer to a @p BaseHygrometer class.
114  * @param[in] dp pointer to a data array.
115  *
116  * @return The operation status.
117  * @retval MSG_OK if the function succeeded.
118  * @retval MSG_RESET if one or more errors occurred.
119  *
120  * @api
121  */
122 #define hygrometerReadRaw(ip, dp) \
123  (ip)->vmt->read_raw(ip, dp)
124
125 /**
126  * @brief Hygrometer read cooked data.
127  *
128  * @param[in] ip pointer to a @p BaseHygrometer class.
129  * @param[in] dp pointer to a data array.
130  *
131  * @return The operation status.
132  * @retval MSG_OK if the function succeeded.
133  * @retval MSG_RESET if one or more errors occurred.
134  *
135  * @api
136  */
137 #define hygrometerReadCooked(ip, dp) \
138  (ip)->vmt->read_cooked(ip, dp)
139
140 /**
141  * @brief Updates hygrometer bias data from received buffer.
142  * @note The bias buffer must have the same length of the
143  * the hygrometer channels number.
144  *
145  * @param[in] ip pointer to a @p BaseHygrometer class.
146  * @param[in] bp pointer to a buffer of bias values.
147  *
148  * @return The operation status.
149  * @retval MSG_OK if the function succeeded.
150  * @retval MSG_RESET if one or more errors occurred.
151  *
152  * @api
153  */
154 #define hygrometerSetBias(ip, bp) \
155  (ip)->vmt->set_bias(ip, bp)
156
157 /**
158  * @brief Reset hygrometer bias data restoring it to zero.
159  *
160  * @param[in] ip pointer to a @p BaseHygrometer class.
161  *
162  * @return The operation status.
163  * @retval MSG_OK if the function succeeded.
164  * @retval MSG_RESET if one or more errors occurred.
165  *
166  * @api
167  */
168 #define hygrometerResetBias(ip) \
169  (ip)->vmt->reset_bias(ip)
170
171 /**
172  * @brief Updates hygrometer sensitivity data from received buffer.
173  * @note The sensitivity buffer must have the same length of the
174  * the hygrometer channels number.
175  *
176  * @param[in] ip pointer to a @p BaseHygrometer class.
177  * @param[in] sp pointer to a buffer of sensitivity values.
178  *
179  * @return The operation status.
180  * @retval MSG_OK if the function succeeded.
181  * @retval MSG_RESET if one or more errors occurred.
182  *
183  * @api
184  */
185 #define hygrometerSetSensitivity(ip, sp) \
186  (ip)->vmt->set_sensitivity(ip, sp)
187
188 /**
189  * @brief Reset hygrometer sensitivity data restoring it to its typical
190  * value.
191  *
192  * @param[in] ip pointer to a @p BaseHygrometer class.
193  *
194  * @return The operation status.
195  * @retval MSG_OK if the function succeeded.
196  * @retval MSG_RESET if one or more errors occurred.
197  *
198  * @api
199  */
200 #define hygrometerResetSensitivity(ip) \
201  (ip)->vmt->reset_sensitivity(ip)
202 /** @} */
203
204 /*===========================================================================*/
205 /* External declarations. */
206 /*===========================================================================*/
207
208 #ifdef __cplusplus
209 extern "C" {
210 #endif
211
212 #ifdef __cplusplus
213 }
214 #endif
215
216 #endif /* HAL_HYGROMETER_H */
217
218 /** @} */
Generic sensors interface header.
const struct BaseHygrometerVMT * vmt
