hal_jesd216_flash.c
18  * @file hal_jesd216_flash.c
19  * @brief JESD216 compliant flash driver class code.
21  * @addtogroup HAL_JESD216_FLASH
27 #include "hal_jesd216_flash.h"
38 /* Driver local variables and types. */
46 /* Driver exported functions. */
49 void jesd216_start(BUSDriver *busp, const BUSConfig *config) {
50
51 #if JESD216_BUS_MODE == JESD216_BUS_MODE_SPI
52  spiStart(busp, config);
53 #else
54  qspiStart(busp, config);
55 #endif
56 }
57
58 void jesd216_stop(BUSDriver *busp) {
59
60 #if JESD216_BUS_MODE == JESD216_BUS_MODE_SPI
61  spiStop(busp);
62 #else
63  qspiStop(busp);
64 #endif
65 }
66
67 void jesd216_cmd(BUSDriver *busp, uint32_t cmd) {
68 #if JESD216_BUS_MODE != JESD216_BUS_MODE_SPI
69  qspi_command_t mode;
70
71  mode.cfg = QSPI_CFG_CMD(cmd) |
72 #if JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI1L
73  QSPI_CFG_CMD_MODE_ONE_LINE;
74 #elif JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI2L
75  QSPI_CFG_CMD_MODE_TWO_LINES;
76 #else
77  QSPI_CFG_CMD_MODE_FOUR_LINES;
78 #endif
79  mode.addr = 0U;
80  mode.alt = 0U;
81  qspiCommand(busp, &mode);
82 #else
83  uint8_t buf[1];
84
85  spiSelect(busp);
86  buf[0] = cmd;
87  spiSend(busp, 1, buf);
88  spiUnselect(busp);
89 #endif
90 }
91
92 void jesd216_cmd_receive(BUSDriver *busp,
93  uint32_t cmd,
94  size_t n,
95  uint8_t *p) {
96 #if JESD216_BUS_MODE != JESD216_BUS_MODE_SPI
97  qspi_command_t mode;
98
99  mode.cfg = QSPI_CFG_CMD(cmd) |
100 #if JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI1L
101  QSPI_CFG_CMD_MODE_ONE_LINE |
102  QSPI_CFG_DATA_MODE_ONE_LINE;
103 #elif JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI2L
104  QSPI_CFG_CMD_MODE_TWO_LINES |
105  QSPI_CFG_DATA_MODE_TWO_LINES;
106 #else
107  QSPI_CFG_CMD_MODE_FOUR_LINES |
108  QSPI_CFG_DATA_MODE_FOUR_LINES;
109
110 #endif
111  mode.addr = 0U;
112  mode.alt = 0U;
113  qspiReceive(busp, &mode, n, p);
114 #else
115  uint8_t buf[1];
116
117  spiSelect(busp);
118  buf[0] = cmd;
119  spiSend(busp, 1, buf);
120  spiReceive(busp, n, p);
121  spiUnselect(busp);
122 #endif
123 }
124
125 void jesd216_cmd_send(BUSDriver *busp,
126  uint32_t cmd,
127  size_t n,
128  const uint8_t *p) {
129 #if JESD216_BUS_MODE != JESD216_BUS_MODE_SPI
130  qspi_command_t mode;
131
132  mode.cfg = QSPI_CFG_CMD(cmd) |
133 #if JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI1L
134  QSPI_CFG_CMD_MODE_ONE_LINE |
135  QSPI_CFG_DATA_MODE_ONE_LINE;
136 #elif JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI2L
137  QSPI_CFG_CMD_MODE_TWO_LINES |
138  QSPI_CFG_DATA_MODE_TWO_LINES;
139 #else
140  QSPI_CFG_CMD_MODE_FOUR_LINES |
141  QSPI_CFG_DATA_MODE_FOUR_LINES;
142
143 #endif
144  mode.addr = 0U;
145  mode.alt = 0U;
146  qspiSend(busp, &mode, n, p);
147 #else
148  uint8_t buf[1];
149
150  spiSelect(busp);
151  buf[0] = cmd;
152  spiSend(busp, 1, buf);
153  spiSend(busp, n, p);
154  spiUnselect(busp);
155 #endif
156 }
157
158 void jesd216_cmd_addr(BUSDriver *busp,
159  uint32_t cmd,
160  flash_offset_t offset) {
161 #if JESD216_BUS_MODE != JESD216_BUS_MODE_SPI
162  qspi_command_t mode;
163
164  mode.cfg = QSPI_CFG_CMD(cmd) |
165 #if JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI1L
166  QSPI_CFG_CMD_MODE_ONE_LINE |
167  QSPI_CFG_ADDR_MODE_ONE_LINE |
168  QSPI_CFG_ADDR_SIZE_24;
169 #elif JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI2L
170  QSPI_CFG_CMD_MODE_TWO_LINES |
171  QSPI_CFG_ADDR_MODE_TWO_LINES |
172  QSPI_CFG_ADDR_SIZE_24;
173 #else
174  QSPI_CFG_CMD_MODE_FOUR_LINES |
175  QSPI_CFG_ADDR_MODE_FOUR_LINES |
176  QSPI_CFG_ADDR_SIZE_24;
177
178 #endif
179  mode.addr = offset;
180  mode.alt = 0U;
181  qspiCommand(busp, &mode);
182 #else
183  uint8_t buf[4];
184
185  spiSelect(busp);
186  buf[0] = cmd;
187  buf[1] = (uint8_t)(offset >> 16);
188  buf[2] = (uint8_t)(offset >> 8);
189  buf[3] = (uint8_t)(offset >> 0);
190  spiSend(busp, 4, buf);
191  spiUnselect(busp);
192 #endif
193 }
194
195 void jesd216_cmd_addr_send(BUSDriver *busp,
196  uint32_t cmd,
197  flash_offset_t offset,
198  size_t n,
199  const uint8_t *p) {
200 #if JESD216_BUS_MODE != JESD216_BUS_MODE_SPI
201  qspi_command_t mode;
202
203  mode.cfg = QSPI_CFG_CMD(cmd & 0xFFU) |
204 #if JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI1L
205  QSPI_CFG_CMD_MODE_ONE_LINE |
206  QSPI_CFG_ADDR_MODE_ONE_LINE |
207  QSPI_CFG_DATA_MODE_ONE_LINE;
208 #elif JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI2L
209  QSPI_CFG_CMD_MODE_TWO_LINES |
210  QSPI_CFG_ADDR_MODE_TWO_LINES |
211  QSPI_CFG_DATA_MODE_TWO_LINES;
212 #else
213  QSPI_CFG_CMD_MODE_FOUR_LINES |
214  QSPI_CFG_ADDR_MODE_FOUR_LINES |
215  QSPI_CFG_DATA_MODE_FOUR_LINES;
216 #endif
217
218  /* Handling 32 bits addressing.*/
219  if ((cmd & JESD216_CMD_EXTENDED_ADDRESSING) == 0) {
220  mode .cfg |= QSPI_CFG_ADDR_SIZE_24;
221  }
222  else {
223  mode .cfg |= QSPI_CFG_ADDR_SIZE_32;
224  }
225
226  mode.addr = offset;
227  mode.alt = 0U;
228  qspiSend(busp, &mode, n, p);
229 #else
230  uint8_t buf[4];
231
232  spiSelect(busp);
233  buf[0] = cmd;
234  buf[1] = (uint8_t)(offset >> 16);
235  buf[2] = (uint8_t)(offset >> 8);
236  buf[3] = (uint8_t)(offset >> 0);
237  spiSend(busp, 4, buf);
238  spiSend(busp, n, p);
239  spiUnselect(busp);
240 #endif
241 }
242
243 void jesd216_cmd_addr_receive(BUSDriver *busp,
244  uint32_t cmd,
245  flash_offset_t offset,
246  size_t n,
247  uint8_t *p) {
248 #if JESD216_BUS_MODE != JESD216_BUS_MODE_SPI
249  qspi_command_t mode;
250
251  mode.cfg = QSPI_CFG_CMD(cmd & 0xFFU) |
252 #if JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI1L
253  QSPI_CFG_CMD_MODE_ONE_LINE |
254  QSPI_CFG_ADDR_MODE_ONE_LINE |
255  QSPI_CFG_DATA_MODE_ONE_LINE;
256 #elif JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI2L
257  QSPI_CFG_CMD_MODE_TWO_LINES |
258  QSPI_CFG_ADDR_MODE_TWO_LINES |
259  QSPI_CFG_ADDR_SIZE_24 |
260  QSPI_CFG_DATA_MODE_TWO_LINES;
261 #else
262  QSPI_CFG_CMD_MODE_FOUR_LINES |
263  QSPI_CFG_ADDR_MODE_FOUR_LINES |
264  QSPI_CFG_DATA_MODE_FOUR_LINES;
265 #endif
266
267  /* Handling 32 bits addressing.*/
268  if ((cmd & JESD216_CMD_EXTENDED_ADDRESSING) == 0) {
269  mode .cfg |= QSPI_CFG_ADDR_SIZE_24;
270  }
271  else {
272  mode .cfg |= QSPI_CFG_ADDR_SIZE_32;
273  }
274
275  mode.addr = offset;
276  mode.alt = 0U;
277  qspiReceive(busp, &mode, n, p);
278 #else
279  uint8_t buf[4];
280
281  spiSelect(busp);
282  buf[0] = cmd;
283  buf[1] = (uint8_t)(offset >> 16);
284  buf[2] = (uint8_t)(offset >> 8);
285  buf[3] = (uint8_t)(offset >> 0);
286  spiSend(busp, 4, buf);
287  spiReceive(busp, n, p);
288  spiUnselect(busp);
289 #endif
290 }
291
292 #if (JESD216_BUS_MODE != JESD216_BUS_MODE_SPI) || defined(__DOXYGEN__)
293 void jesd216_cmd_addr_dummy_receive(BUSDriver *busp,
294  uint32_t cmd,
295  flash_offset_t offset,
296  uint8_t dummy,
297  size_t n,
298  uint8_t *p) {
299  qspi_command_t mode;
300
301  mode.cfg = QSPI_CFG_CMD(cmd & 0xFFU) |
302 #if JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI1L
303  QSPI_CFG_CMD_MODE_ONE_LINE |
304  QSPI_CFG_ADDR_MODE_ONE_LINE |
305  QSPI_CFG_DUMMY_CYCLES(dummy) |
306  QSPI_CFG_DATA_MODE_ONE_LINE;
307 #elif JESD216_BUS_MODE == JESD216_BUS_MODE_QSPI2L
308  QSPI_CFG_CMD_MODE_TWO_LINES |
309  QSPI_CFG_ADDR_MODE_TWO_LINES |
310  QSPI_CFG_DUMMY_CYCLES(dummy) |
311  QSPI_CFG_DATA_MODE_TWO_LINES;
312 #else
313  QSPI_CFG_CMD_MODE_FOUR_LINES |
314  QSPI_CFG_ADDR_MODE_FOUR_LINES |
315  QSPI_CFG_DUMMY_CYCLES(dummy) |
316  QSPI_CFG_DATA_MODE_FOUR_LINES;
317 #endif
318
319  /* Handling 32 bits addressing.*/
320  if ((cmd & JESD216_CMD_EXTENDED_ADDRESSING) == 0) {
321  mode .cfg |= QSPI_CFG_ADDR_SIZE_24;
322  }
323  else {
324  mode .cfg |= QSPI_CFG_ADDR_SIZE_32;
325  }
326
327  mode.addr = offset;
328  mode.alt = 0U;
329  qspiReceive(busp, &mode, n, p);
330 }
331 #endif /* JESD216_BUS_MODE != JESD216_BUS_MODE_SPI */
332
333 #if ((JESD216_BUS_MODE != JESD216_BUS_MODE_SPI) && \
334  (JESD216_SHARED_BUS == TRUE)) || defined(__DOXYGEN__)
335 void jesd216_bus_acquire(BUSDriver *busp, const BUSConfig *config) {
336
337  (void)config;
338
339  qspiAcquireBus(busp);
340  if (busp->config != config) {
341  qspiStart(busp, config);
342  }
343 }
344
345 void jesd216_bus_release(BUSDriver *busp) {
346
347  qspiReleaseBus(busp);
348 }
349 #elif (JESD216_BUS_MODE == JESD216_BUS_MODE_SPI) && \
350  (JESD216_SHARED_BUS == TRUE)
351 void jesd216_bus_acquire(BUSDriver *busp, const BUSConfig *config) {
352
353  spiAcquireBus(busp);
354  if (busp->config != config) {
355  spiStart(busp, config);
356  }
357 }
358
359 void jesd216_bus_release(BUSDriver *busp) {
360
361  spiReleaseBus(busp);
362 }
363 #else
364 #define jesd216_bus_acquire(busp)
365 #define jesd216_bus_release(busp)
366 #endif
367
368 /** @} */
void spiUnselect(SPIDriver *spip)
Deasserts the slave select signal.
Definition: hal_spi.c:154
void spiSelect(SPIDriver *spip)
Asserts the slave select signal and prepares for transfers.
Definition: hal_spi.c:136
void spiReceive(SPIDriver *spip, size_t n, void *rxbuf)
Receives data from the SPI bus.
Definition: hal_spi.c:418
void spiStart(SPIDriver *spip, const SPIConfig *config)
Configures and activates the SPI peripheral.
Definition: hal_spi.c:91
void qspiReleaseBus(QSPIDriver *qspip)
Releases exclusive access to the QSPI bus.
Definition: hal_qspi.c:382
void spiReleaseBus(SPIDriver *spip)
Releases exclusive access to the SPI bus.
Definition: hal_spi.c:461
JESD216 compliant flash driver class header.
void spiAcquireBus(SPIDriver *spip)
Gains exclusive access to the SPI bus.
Definition: hal_spi.c:445
void qspiStart(QSPIDriver *qspip, const QSPIConfig *config)
Configures and activates the QSPI peripheral.
Definition: hal_qspi.c:91
void qspiReceive(QSPIDriver *qspip, const qspi_command_t *cmdp, size_t n, uint8_t *rxbuf)
Sends a command then receives data over the QSPI bus.
Definition: hal_qspi.c:281
void qspiSend(QSPIDriver *qspip, const qspi_command_t *cmdp, size_t n, const uint8_t *txbuf)
Sends a command with data over the QSPI bus.
Definition: hal_qspi.c:249
uint32_t flash_offset_t
Type of a flash offset.
Definition: hal_flash.h:83
void qspiAcquireBus(QSPIDriver *qspip)
Gains exclusive access to the QSPI bus.
Definition: hal_qspi.c:366
void qspiCommand(QSPIDriver *qspip, const qspi_command_t *cmdp)
Sends a command without data phase.
Definition: hal_qspi.c:219
void spiSend(SPIDriver *spip, size_t n, const void *txbuf)
Sends data over the SPI bus.
Definition: hal_spi.c:388
void qspiStop(QSPIDriver *qspip)
Deactivates the QSPI peripheral.
Definition: hal_qspi.c:116
void spiStop(SPIDriver *spip)
Deactivates the SPI peripheral.
Definition: hal_spi.c:113
Type of a QSPI command descriptor.
Definition: hal_qspi.h:125
