hal_qspi.c
18  * @file hal_qspi.c
19  * @brief QSPI Driver code.
21  * @addtogroup QSPI
27 #if (HAL_USE_QSPI == TRUE) || defined(__DOXYGEN__)
38 /* Driver local variables and types. */
46 /* Driver exported functions. */
49 /**
50  * @brief QSPI Driver initialization.
51  * @note This function is implicitly invoked by @p halInit(), there is
52  * no need to explicitly initialize the driver.
53  *
54  * @init
55  */
56 void qspiInit(void) {
57
58  qspi_lld_init();
59 }
60
61 /**
62  * @brief Initializes the standard part of a @p QSPIDriver structure.
63  *
64  * @param[out] qspip pointer to the @p QSPIDriver object
65  *
66  * @init
67  */
68 void qspiObjectInit(QSPIDriver *qspip) {
69
70  qspip->state = QSPI_STOP;
71  qspip->config = NULL;
72 #if QSPI_USE_WAIT == TRUE
73  qspip->thread = NULL;
74 #endif
75 #if QSPI_USE_MUTUAL_EXCLUSION == TRUE
76  osalMutexObjectInit(&qspip->mutex);
77 #endif
78 #if defined(QSPI_DRIVER_EXT_INIT_HOOK)
79  QSPI_DRIVER_EXT_INIT_HOOK(qspip);
80 #endif
81 }
82
83 /**
84  * @brief Configures and activates the QSPI peripheral.
85  *
86  * @param[in] qspip pointer to the @p QSPIDriver object
87  * @param[in] config pointer to the @p QSPIConfig object
88  *
89  * @api
90  */
91 void qspiStart(QSPIDriver *qspip, const QSPIConfig *config) {
92
93  osalDbgCheck((qspip != NULL) && (config != NULL));
94
95  osalSysLock();
96
97  osalDbgAssert((qspip->state == QSPI_STOP) || (qspip->state == QSPI_READY),
98  "invalid state");
99
100  qspip->config = config;
101  qspi_lld_start(qspip);
102  qspip->state = QSPI_READY;
103
104  osalSysUnlock();
105 }
106
107 /**
108  * @brief Deactivates the QSPI peripheral.
109  * @note Deactivating the peripheral also enforces a release of the slave
110  * select line.
111  *
112  * @param[in] qspip pointer to the @p QSPIDriver object
113  *
114  * @api
115  */
116 void qspiStop(QSPIDriver *qspip) {
117
118  osalDbgCheck(qspip != NULL);
119
120  osalSysLock();
121
122  osalDbgAssert((qspip->state == QSPI_STOP) || (qspip->state == QSPI_READY),
123  "invalid state");
124
125  qspi_lld_stop(qspip);
126  qspip->config = NULL;
127  qspip->state = QSPI_STOP;
128
129  osalSysUnlock();
130 }
131
132 /**
133  * @brief Sends a command without data phase.
134  * @post At the end of the operation the configured callback is invoked.
135  *
136  * @param[in] qspip pointer to the @p QSPIDriver object
137  * @param[in] cmdp pointer to the command descriptor
138  *
139  * @api
140  */
141 void qspiStartCommand(QSPIDriver *qspip, const qspi_command_t *cmdp) {
142
143  osalDbgCheck((qspip != NULL) && (cmdp != NULL));
144
145  osalSysLock();
146
147  osalDbgAssert(qspip->state == QSPI_READY, "not ready");
148
149  qspiStartCommandI(qspip, cmdp);
150
151  osalSysUnlock();
152 }
153
154 /**
155  * @brief Sends a command with data over the QSPI bus.
156  * @post At the end of the operation the configured callback is invoked.
157  *
158  * @param[in] qspip pointer to the @p QSPIDriver object
159  * @param[in] cmdp pointer to the command descriptor
160  * @param[in] n number of bytes to send
161  * @param[in] txbuf the pointer to the transmit buffer
162  *
163  * @api
164  */
165 void qspiStartSend(QSPIDriver *qspip, const qspi_command_t *cmdp,
166  size_t n, const uint8_t *txbuf) {
167
168  osalDbgCheck((qspip != NULL) && (cmdp != NULL));
169  osalDbgCheck((n > 0U) && (txbuf != NULL));
170
171  osalSysLock();
172
173  osalDbgAssert(qspip->state == QSPI_READY, "not ready");
174
175  qspiStartSendI(qspip, cmdp, n, txbuf);
176
177  osalSysUnlock();
178 }
179
180 /**
181  * @brief Sends a command then receives data over the QSPI bus.
182  * @post At the end of the operation the configured callback is invoked.
183  *
184  * @param[in] qspip pointer to the @p QSPIDriver object
185  * @param[in] cmdp pointer to the command descriptor
186  * @param[in] n number of bytes to send
187  * @param[out] rxbuf the pointer to the receive buffer
188  *
189  * @api
190  */
191 void qspiStartReceive(QSPIDriver *qspip, const qspi_command_t *cmdp,
192  size_t n, uint8_t *rxbuf) {
193
194  osalDbgCheck((qspip != NULL) && (cmdp != NULL));
195  osalDbgCheck((n > 0U) && (rxbuf != NULL));
196
197  osalSysLock();
198
199  osalDbgAssert(qspip->state == QSPI_READY, "not ready");
200
201  qspiStartReceiveI(qspip, cmdp, n, rxbuf);
202
203  osalSysUnlock();
204 }
205
206 #if (QSPI_USE_WAIT == TRUE) || defined(__DOXYGEN__)
207 /**
208  * @brief Sends a command without data phase.
209  * @pre In order to use this function the option @p QSPI_USE_WAIT must be
210  * enabled.
211  * @pre In order to use this function the driver must have been configured
212  * without callbacks (@p end_cb = @p NULL).
213  *
214  * @param[in] qspip pointer to the @p QSPIDriver object
215  * @param[in] cmdp pointer to the command descriptor
216  *
217  * @api
218  */
219 void qspiCommand(QSPIDriver *qspip, const qspi_command_t *cmdp) {
220
221  osalDbgCheck((qspip != NULL) && (cmdp != NULL));
222  osalDbgCheck((cmdp->cfg & QSPI_CFG_DATA_MODE_MASK) == QSPI_CFG_DATA_MODE_NONE);
223
224  osalSysLock();
225
226  osalDbgAssert(qspip->state == QSPI_READY, "not ready");
227  osalDbgAssert(qspip->config->end_cb == NULL, "has callback");
228
229  qspiStartCommandI(qspip, cmdp);
230  (void) osalThreadSuspendS(&qspip->thread);
231
232  osalSysUnlock();
233 }
234
235 /**
236  * @brief Sends a command with data over the QSPI bus.
237  * @pre In order to use this function the option @p QSPI_USE_WAIT must be
238  * enabled.
239  * @pre In order to use this function the driver must have been configured
240  * without callbacks (@p end_cb = @p NULL).
241  *
242  * @param[in] qspip pointer to the @p QSPIDriver object
243  * @param[in] cmdp pointer to the command descriptor
244  * @param[in] n number of bytes to send
245  * @param[in] txbuf the pointer to the transmit buffer
246  *
247  * @api
248  */
249 void qspiSend(QSPIDriver *qspip, const qspi_command_t *cmdp,
250  size_t n, const uint8_t *txbuf) {
251
252  osalDbgCheck((qspip != NULL) && (cmdp != NULL));
253  osalDbgCheck((n > 0U) && (txbuf != NULL));
254  osalDbgCheck((cmdp->cfg & QSPI_CFG_DATA_MODE_MASK) != QSPI_CFG_DATA_MODE_NONE);
255
256  osalSysLock();
257
258  osalDbgAssert(qspip->state == QSPI_READY, "not ready");
259  osalDbgAssert(qspip->config->end_cb == NULL, "has callback");
260
261  qspiStartSendI(qspip, cmdp, n, txbuf);
262  (void) osalThreadSuspendS(&qspip->thread);
263
264  osalSysUnlock();
265 }
266
267 /**
268  * @brief Sends a command then receives data over the QSPI bus.
269  * @pre In order to use this function the option @p QSPI_USE_WAIT must be
270  * enabled.
271  * @pre In order to use this function the driver must have been configured
272  * without callbacks (@p end_cb = @p NULL).
273  *
274  * @param[in] qspip pointer to the @p QSPIDriver object
275  * @param[in] cmdp pointer to the command descriptor
276  * @param[in] n number of bytes to send
277  * @param[out] rxbuf the pointer to the receive buffer
278  *
279  * @api
280  */
281 void qspiReceive(QSPIDriver *qspip, const qspi_command_t *cmdp,
282  size_t n, uint8_t *rxbuf) {
283
284  osalDbgCheck((qspip != NULL) && (cmdp != NULL));
285  osalDbgCheck((n > 0U) && (rxbuf != NULL));
286  osalDbgCheck((cmdp->cfg & QSPI_CFG_DATA_MODE_MASK) != QSPI_CFG_DATA_MODE_NONE);
287
288  osalSysLock();
289
290  osalDbgAssert(qspip->state == QSPI_READY, "not ready");
291  osalDbgAssert(qspip->config->end_cb == NULL, "has callback");
292
293  qspiStartReceiveI(qspip, cmdp, n, rxbuf);
294  (void) osalThreadSuspendS(&qspip->thread);
295
296  osalSysUnlock();
297 }
298 #endif /* QSPI_USE_WAIT == TRUE */
299
300 #if (QSPI_SUPPORTS_MEMMAP == TRUE) || defined(__DOXYGEN__)
301 /**
302  * @brief Maps in memory space a QSPI flash device.
303  * @pre The memory flash device must be initialized appropriately
304  * before mapping it in memory space.
305  *
306  * @param[in] qspip pointer to the @p QSPIDriver object
307  * @param[in] cmdp pointer to the command descriptor
308  * @param[out] addrp pointer to the memory start address of the mapped
309  * flash or @p NULL
310  *
311  * @api
312  */
314  const qspi_command_t *cmdp,
315  uint8_t **addrp) {
316
317  osalDbgCheck((qspip != NULL) && (cmdp != NULL));
318  osalDbgCheck((cmdp->cfg & QSPI_CFG_DATA_MODE_MASK) != QSPI_CFG_DATA_MODE_NONE);
319
320  osalSysLock();
321
322  osalDbgAssert(qspip->state == QSPI_READY, "not ready");
323
324  qspiMapFlashI(qspip, cmdp, addrp);
325  qspip->state = QSPI_MEMMAP;
326
327  osalSysUnlock();
328 }
329
330 /**
331  * @brief Unmaps from memory space a QSPI flash device.
332  * @post The memory flash device must be re-initialized for normal
333  * commands exchange.
334  *
335  * @param[in] qspip pointer to the @p QSPIDriver object
336  *
337  * @api
338  */
340
341  osalDbgCheck(qspip != NULL);
342
343  osalSysLock();
344
345  osalDbgAssert(qspip->state == QSPI_MEMMAP, "not ready");
346
347  qspiUnmapFlashI(qspip);
348  qspip->state = QSPI_READY;
349
350  osalSysUnlock();
351 }
352 #endif /* QSPI_SUPPORTS_MEMMAP == TRUE */
353
354 #if (QSPI_USE_MUTUAL_EXCLUSION == TRUE) || defined(__DOXYGEN__)
355 /**
356  * @brief Gains exclusive access to the QSPI bus.
357  * @details This function tries to gain ownership to the QSPI bus, if the bus
358  * is already being used then the invoking thread is queued.
359  * @pre In order to use this function the option @p QSPI_USE_MUTUAL_EXCLUSION
360  * must be enabled.
361  *
362  * @param[in] qspip pointer to the @p QSPIDriver object
363  *
364  * @api
365  */
367
368  osalDbgCheck(qspip != NULL);
369
370  osalMutexLock(&qspip->mutex);
371 }
372
373 /**
374  * @brief Releases exclusive access to the QSPI bus.
375  * @pre In order to use this function the option @p QSPI_USE_MUTUAL_EXCLUSION
376  * must be enabled.
377  *
378  * @param[in] qspip pointer to the @p QSPIDriver object
379  *
380  * @api
381  */
383
384  osalDbgCheck(qspip != NULL);
385
386  osalMutexUnlock(&qspip->mutex);
387 }
388 #endif /* QSPI_USE_MUTUAL_EXCLUSION == TRUE */
389
390 #endif /* HAL_USE_QSPI == TRUE */
391
392 /** @} */
static void osalMutexObjectInit(mutex_t *mp)
Initializes s mutex_t object.
Definition: osal.h:681
qspistate_t state
Definition: hal_qspi_lld.h:98
#define qspiStartReceiveI(qspip, cmdp, n, rxbuf)
Receives data from the QSPI bus.
Definition: hal_qspi.h:194
msg_t osalThreadSuspendS(thread_reference_t *trp)
Sends the current thread sleeping and sets a reference variable.
Definition: osal.c:185
void qspiStartSend(QSPIDriver *qspip, const qspi_command_t *cmdp, size_t n, const uint8_t *txbuf)
Definition: hal_qspi.c:165
void qspiUnmapFlash(QSPIDriver *qspip)
Definition: hal_qspi.c:339
qspicallback_t end_cb
Operation complete callback or NULL.
Definition: hal_qspi_lld.h:87
Initializes the standard part of a QSPIDriver structure.
Definition: hal_qspi.c:68
void qspiReleaseBus(QSPIDriver *qspip)
Definition: hal_qspi.c:382
void osalMutexLock(mutex_t *mp)
Locks the specified mutex.
Definition: osal.c:384
Definition: osal.h:540
void qspi_lld_init(void)
Low level QSPI driver initialization.
Definition: hal_qspi_lld.c:63
Definition: hal_qspi_lld.h:83
Definition: hal_qspi.c:141
Definition: hal_qspi.c:91
void qspi_lld_start(QSPIDriver *qspip)
Definition: hal_qspi_lld.c:77
void qspiReceive(QSPIDriver *qspip, const qspi_command_t *cmdp, size_t n, uint8_t *rxbuf)
Definition: hal_qspi.c:281
void qspiStartReceive(QSPIDriver *qspip, const qspi_command_t *cmdp, size_t n, uint8_t *rxbuf)
Definition: hal_qspi.c:191
const QSPIConfig * config
Current configuration data.
Definition: hal_qspi_lld.h:102
mutex_t mutex
Mutex protecting the peripheral.
Definition: hal_qspi_lld.h:113
void qspiSend(QSPIDriver *qspip, const qspi_command_t *cmdp, size_t n, const uint8_t *txbuf)
Definition: hal_qspi.c:249
void qspiAcquireBus(QSPIDriver *qspip)
Definition: hal_qspi.c:366
thread_reference_t thread
Waiting thread.
Definition: hal_qspi_lld.h:107
static void osalSysLock(void)
Definition: osal.h:530
Structure representing an QSPI driver.
Definition: hal_qspi_lld.h:94
#define qspiUnmapFlashI(qspip)
Definition: hal_qspi.h:227
void qspi_lld_stop(QSPIDriver *qspip)
Definition: hal_qspi_lld.c:99
void qspiMapFlash(QSPIDriver *qspip, const qspi_command_t *cmdp, uint8_t **addrp)
Definition: hal_qspi.c:313
Definition: hal_qspi.c:219
void osalMutexUnlock(mutex_t *mp)
Unlocks the specified mutex.
Definition: osal.c:404
#define qspiMapFlashI(qspip, cmdp, addrp)
Definition: hal_qspi.h:215
#define qspiStartSendI(qspip, cmdp, n, txbuf)
Sends data over the QSPI bus.
Definition: hal_qspi.h:174
Definition: hal_qspi.c:116
void qspiInit(void)
Definition: hal_qspi.c:56
Type of a QSPI command descriptor.
Definition: hal_qspi.h:125
#define qspiStartCommandI(qspip, cmdp)
Definition: hal_qspi.h:154
