hal_mmcsd.h
18  * @file hal_mmcsd.h
19  * @brief MMC/SD cards common header.
20  * @details This header defines an abstract interface useful to access MMC/SD
21  * I/O block devices in a standardized way.
22  *
23  * @addtogroup MMCSD
24  * @{
25  */
27 #ifndef HAL_MMCSD_H
28 #define HAL_MMCSD_H
30 #if (HAL_USE_MMC_SPI == TRUE) || (HAL_USE_SDC == TRUE) || defined(__DOXYGEN__)
31
33 /* Driver constants. */
35
36 /**
37  * @brief Fixed block size for MMC/SD block devices.
38  */
39 #define MMCSD_BLOCK_SIZE 512U
41 /**
42  * @brief Mask of error bits in R1 responses.
43  */
44 #define MMCSD_R1_ERROR_MASK 0xFDFFE008U
45
46 /**
47  * @brief Fixed pattern for CMD8.
48  */
49 #define MMCSD_CMD8_PATTERN 0x000001AAU
50
51 /**
52  * @name SD/MMC status conditions
53  * @{
54  */
55 #define MMCSD_STS_IDLE 0U
56 #define MMCSD_STS_READY 1U
57 #define MMCSD_STS_IDENT 2U
58 #define MMCSD_STS_STBY 3U
59 #define MMCSD_STS_TRAN 4U
60 #define MMCSD_STS_DATA 5U
61 #define MMCSD_STS_RCV 6U
62 #define MMCSD_STS_PRG 7U
63 #define MMCSD_STS_DIS 8U
64 /** @} */
65
66 /**
67  * @name SD/MMC commands
68  * @{
69  */
70 #define MMCSD_CMD_GO_IDLE_STATE 0U
71 #define MMCSD_CMD_INIT 1U
72 #define MMCSD_CMD_ALL_SEND_CID 2U
73 #define MMCSD_CMD_SEND_RELATIVE_ADDR 3U
74 #define MMCSD_CMD_SET_BUS_WIDTH 6U
75 #define MMCSD_CMD_SWITCH MMCSD_CMD_SET_BUS_WIDTH
76 #define MMCSD_CMD_SEL_DESEL_CARD 7U
77 #define MMCSD_CMD_SEND_IF_COND 8U
78 #define MMCSD_CMD_SEND_EXT_CSD MMCSD_CMD_SEND_IF_COND
79 #define MMCSD_CMD_SEND_CSD 9U
80 #define MMCSD_CMD_SEND_CID 10U
81 #define MMCSD_CMD_STOP_TRANSMISSION 12U
82 #define MMCSD_CMD_SEND_STATUS 13U
83 #define MMCSD_CMD_SET_BLOCKLEN 16U
84 #define MMCSD_CMD_READ_SINGLE_BLOCK 17U
85 #define MMCSD_CMD_READ_MULTIPLE_BLOCK 18U
86 #define MMCSD_CMD_SET_BLOCK_COUNT 23U
87 #define MMCSD_CMD_WRITE_BLOCK 24U
88 #define MMCSD_CMD_WRITE_MULTIPLE_BLOCK 25U
89 #define MMCSD_CMD_ERASE_RW_BLK_START 32U
90 #define MMCSD_CMD_ERASE_RW_BLK_END 33U
91 #define MMCSD_CMD_ERASE 38U
92 #define MMCSD_CMD_APP_OP_COND 41U
93 #define MMCSD_CMD_LOCK_UNLOCK 42U
94 #define MMCSD_CMD_APP_CMD 55U
95 #define MMCSD_CMD_READ_OCR 58U
96 /** @} */
97
98 /**
99  * @name CSD record offsets
100  */
101 /**
102  * @brief Slice position of values in CSD register.
103  */
104 /* CSD for MMC */
105 #define MMCSD_CSD_MMC_CSD_STRUCTURE_SLICE 127U,126U
106 #define MMCSD_CSD_MMC_SPEC_VERS_SLICE 125U,122U
107 #define MMCSD_CSD_MMC_TAAC_SLICE 119U,112U
108 #define MMCSD_CSD_MMC_NSAC_SLICE 111U,104U
109 #define MMCSD_CSD_MMC_TRAN_SPEED_SLICE 103U,96U
110 #define MMCSD_CSD_MMC_CCC_SLICE 95U,84U
111 #define MMCSD_CSD_MMC_READ_BL_LEN_SLICE 83U,80U
112 #define MMCSD_CSD_MMC_READ_BL_PARTIAL_SLICE 79U,79U
113 #define MMCSD_CSD_MMC_WRITE_BLK_MISALIGN_SLICE 78U,78U
114 #define MMCSD_CSD_MMC_READ_BLK_MISALIGN_SLICE 77U,77U
115 #define MMCSD_CSD_MMC_DSR_IMP_SLICE 76U,76U
116 #define MMCSD_CSD_MMC_C_SIZE_SLICE 73U,62U
117 #define MMCSD_CSD_MMC_VDD_R_CURR_MIN_SLICE 61U,59U
118 #define MMCSD_CSD_MMC_VDD_R_CURR_MAX_SLICE 58U,56U
119 #define MMCSD_CSD_MMC_VDD_W_CURR_MIN_SLICE 55U,53U
120 #define MMCSD_CSD_MMC_VDD_W_CURR_MAX_SLICE 52U,50U
121 #define MMCSD_CSD_MMC_C_SIZE_MULT_SLICE 49U,47U
122 #define MMCSD_CSD_MMC_ERASE_GRP_SIZE_SLICE 46U,42U
123 #define MMCSD_CSD_MMC_ERASE_GRP_MULT_SLICE 41U,37U
124 #define MMCSD_CSD_MMC_WP_GRP_SIZE_SLICE 36U,32U
125 #define MMCSD_CSD_MMC_WP_GRP_ENABLE_SLICE 31U,31U
126 #define MMCSD_CSD_MMC_DEFAULT_ECC_SLICE 30U,29U
127 #define MMCSD_CSD_MMC_R2W_FACTOR_SLICE 28U,26U
128 #define MMCSD_CSD_MMC_WRITE_BL_LEN_SLICE 25U,22U
129 #define MMCSD_CSD_MMC_WRITE_BL_PARTIAL_SLICE 21U,21U
130 #define MMCSD_CSD_MMC_CONTENT_PROT_APP_SLICE 16U,16U
131 #define MMCSD_CSD_MMC_FILE_FORMAT_GRP_SLICE 15U,15U
132 #define MMCSD_CSD_MMC_COPY_SLICE 14U,14U
133 #define MMCSD_CSD_MMC_PERM_WRITE_PROTECT_SLICE 13U,13U
134 #define MMCSD_CSD_MMC_TMP_WRITE_PROTECT_SLICE 12U,12U
135 #define MMCSD_CSD_MMC_FILE_FORMAT_SLICE 11U,10U
136 #define MMCSD_CSD_MMC_ECC_SLICE 9U,8U
137 #define MMCSD_CSD_MMC_CRC_SLICE 7U,1U
138
139 /* CSD version 2.0 */
140 #define MMCSD_CSD_20_CRC_SLICE 7U,1U
141 #define MMCSD_CSD_20_FILE_FORMAT_SLICE 11U,10U
142 #define MMCSD_CSD_20_TMP_WRITE_PROTECT_SLICE 12U,12U
143 #define MMCSD_CSD_20_PERM_WRITE_PROTECT_SLICE 13U,13U
144 #define MMCSD_CSD_20_COPY_SLICE 14U,14U
145 #define MMCSD_CSD_20_FILE_FORMAT_GRP_SLICE 15U,15U
146 #define MMCSD_CSD_20_WRITE_BL_PARTIAL_SLICE 21U,21U
147 #define MMCSD_CSD_20_WRITE_BL_LEN_SLICE 25U,12U
148 #define MMCSD_CSD_20_R2W_FACTOR_SLICE 28U,26U
149 #define MMCSD_CSD_20_WP_GRP_ENABLE_SLICE 31U,31U
150 #define MMCSD_CSD_20_WP_GRP_SIZE_SLICE 38U,32U
151 #define MMCSD_CSD_20_ERASE_SECTOR_SIZE_SLICE 45U,39U
152 #define MMCSD_CSD_20_ERASE_BLK_EN_SLICE 46U,46U
153 #define MMCSD_CSD_20_C_SIZE_SLICE 69U,48U
154 #define MMCSD_CSD_20_DSR_IMP_SLICE 76U,76U
155 #define MMCSD_CSD_20_READ_BLK_MISALIGN_SLICE 77U,77U
156 #define MMCSD_CSD_20_WRITE_BLK_MISALIGN_SLICE 78U,78U
157 #define MMCSD_CSD_20_READ_BL_PARTIAL_SLICE 79U,79U
158 #define MMCSD_CSD_20_READ_BL_LEN_SLICE 83U,80U
159 #define MMCSD_CSD_20_CCC_SLICE 95U,84U
160 #define MMCSD_CSD_20_TRANS_SPEED_SLICE 103U,96U
161 #define MMCSD_CSD_20_NSAC_SLICE 111U,104U
162 #define MMCSD_CSD_20_TAAC_SLICE 119U,112U
163 #define MMCSD_CSD_20_CSD_STRUCTURE_SLICE 127U,126U
164
165 /* CSD version 1.0 */
166 #define MMCSD_CSD_10_CRC_SLICE MMCSD_CSD_20_CRC_SLICE
167 #define MMCSD_CSD_10_FILE_FORMAT_SLICE MMCSD_CSD_20_FILE_FORMAT_SLICE
168 #define MMCSD_CSD_10_TMP_WRITE_PROTECT_SLICE MMCSD_CSD_20_TMP_WRITE_PROTECT_SLICE
169 #define MMCSD_CSD_10_PERM_WRITE_PROTECT_SLICE MMCSD_CSD_20_PERM_WRITE_PROTECT_SLICE
170 #define MMCSD_CSD_10_COPY_SLICE MMCSD_CSD_20_COPY_SLICE
171 #define MMCSD_CSD_10_FILE_FORMAT_GRP_SLICE MMCSD_CSD_20_FILE_FORMAT_GRP_SLICE
172 #define MMCSD_CSD_10_WRITE_BL_PARTIAL_SLICE MMCSD_CSD_20_WRITE_BL_PARTIAL_SLICE
173 #define MMCSD_CSD_10_WRITE_BL_LEN_SLICE MMCSD_CSD_20_WRITE_BL_LEN_SLICE
174 #define MMCSD_CSD_10_R2W_FACTOR_SLICE MMCSD_CSD_20_R2W_FACTOR_SLICE
175 #define MMCSD_CSD_10_WP_GRP_ENABLE_SLICE MMCSD_CSD_20_WP_GRP_ENABLE_SLICE
176 #define MMCSD_CSD_10_WP_GRP_SIZE_SLICE MMCSD_CSD_20_WP_GRP_SIZE_SLICE
177 #define MMCSD_CSD_10_ERASE_SECTOR_SIZE_SLICE MMCSD_CSD_20_ERASE_SECTOR_SIZE_SLICE
178 #define MMCSD_CSD_10_ERASE_BLK_EN_SLICE MMCSD_CSD_20_ERASE_BLK_EN_SLICE
179 #define MMCSD_CSD_10_C_SIZE_MULT_SLICE 49U,47U
180 #define MMCSD_CSD_10_VDD_W_CURR_MAX_SLICE 52U,50U
181 #define MMCSD_CSD_10_VDD_W_CURR_MIN_SLICE 55U,53U
182 #define MMCSD_CSD_10_VDD_R_CURR_MAX_SLICE 58U,56U
183 #define MMCSD_CSD_10_VDD_R_CURR_MIX_SLICE 61U,59U
184 #define MMCSD_CSD_10_C_SIZE_SLICE 73U,62U
185 #define MMCSD_CSD_10_DSR_IMP_SLICE MMCSD_CSD_20_DSR_IMP_SLICE
186 #define MMCSD_CSD_10_READ_BLK_MISALIGN_SLICE MMCSD_CSD_20_READ_BLK_MISALIGN_SLICE
187 #define MMCSD_CSD_10_WRITE_BLK_MISALIGN_SLICE MMCSD_CSD_20_WRITE_BLK_MISALIGN_SLICE
188 #define MMCSD_CSD_10_READ_BL_PARTIAL_SLICE MMCSD_CSD_20_READ_BL_PARTIAL_SLICE
189 #define MMCSD_CSD_10_READ_BL_LEN_SLICE 83U,80U
190 #define MMCSD_CSD_10_CCC_SLICE MMCSD_CSD_20_CCC_SLICE
191 #define MMCSD_CSD_10_TRANS_SPEED_SLICE MMCSD_CSD_20_TRANS_SPEED_SLICE
192 #define MMCSD_CSD_10_NSAC_SLICE MMCSD_CSD_20_NSAC_SLICE
193 #define MMCSD_CSD_10_TAAC_SLICE MMCSD_CSD_20_TAAC_SLICE
194 #define MMCSD_CSD_10_CSD_STRUCTURE_SLICE MMCSD_CSD_20_CSD_STRUCTURE_SLICE
195 /** @} */
196
197 /**
198  * @name CID record offsets
199  */
200 /**
201  * @brief Slice position of values in CID register.
202  */
203 /* CID for SDC */
204 #define MMCSD_CID_SDC_CRC_SLICE 7U,1U
205 #define MMCSD_CID_SDC_MDT_M_SLICE 11U,8U
206 #define MMCSD_CID_SDC_MDT_Y_SLICE 19U,12U
207 #define MMCSD_CID_SDC_PSN_SLICE 55U,24U
208 #define MMCSD_CID_SDC_PRV_M_SLICE 59U,56U
209 #define MMCSD_CID_SDC_PRV_N_SLICE 63U,60U
210 #define MMCSD_CID_SDC_PNM0_SLICE 71U,64U
211 #define MMCSD_CID_SDC_PNM1_SLICE 79U,72U
212 #define MMCSD_CID_SDC_PNM2_SLICE 87U,80U
213 #define MMCSD_CID_SDC_PNM3_SLICE 95U,88U
214 #define MMCSD_CID_SDC_PNM4_SLICE 103U,96U
215 #define MMCSD_CID_SDC_OID_SLICE 119U,104U
216 #define MMCSD_CID_SDC_MID_SLICE 127U,120U
217
218 /* CID for MMC */
219 #define MMCSD_CID_MMC_CRC_SLICE 7U,1U
220 #define MMCSD_CID_MMC_MDT_Y_SLICE 11U,8U
221 #define MMCSD_CID_MMC_MDT_M_SLICE 15U,12U
222 #define MMCSD_CID_MMC_PSN_SLICE 47U,16U
223 #define MMCSD_CID_MMC_PRV_M_SLICE 51U,48U
224 #define MMCSD_CID_MMC_PRV_N_SLICE 55U,52U
225 #define MMCSD_CID_MMC_PNM0_SLICE 63U,56U
226 #define MMCSD_CID_MMC_PNM1_SLICE 71U,64U
227 #define MMCSD_CID_MMC_PNM2_SLICE 79U,72U
228 #define MMCSD_CID_MMC_PNM3_SLICE 87U,80U
229 #define MMCSD_CID_MMC_PNM4_SLICE 95U,88U
230 #define MMCSD_CID_MMC_PNM5_SLICE 103U,96U
231 #define MMCSD_CID_MMC_OID_SLICE 119U,104U
232 #define MMCSD_CID_MMC_MID_SLICE 127U,120U
233 /** @} */
234
235 /*===========================================================================*/
236 /* Driver pre-compile time settings. */
237 /*===========================================================================*/
238
239 /*===========================================================================*/
240 /* Derived constants and error checks. */
241 /*===========================================================================*/
242
243 /*===========================================================================*/
244 /* Driver data structures and types. */
245 /*===========================================================================*/
246
247 /**
248  * @brief @p MMCSDBlockDevice specific methods.
249  */
250 #define _mmcsd_block_device_methods \
251  _base_block_device_methods
252
253 /**
254  * @brief @p MMCSDBlockDevice specific data.
255  * @note It is empty because @p MMCSDBlockDevice is only an interface
256  * without implementation.
257  */
258 #define _mmcsd_block_device_data \
259  _base_block_device_data \
260  /* Card CID.*/ \
261  uint32_t cid[4]; \
262  /* Card CSD.*/ \
263  uint32_t csd[4]; \
264  /* Total number of blocks in card.*/ \
265  uint32_t capacity;
266
267 /**
268  * @extends BaseBlockDeviceVMT
269  *
270  * @brief @p MMCSDBlockDevice virtual methods table.
271  */
274 };
275
276 /**
277  * @extends BaseBlockDevice
278  *
279  * @brief MCC/SD block device class.
280  * @details This class represents a, block-accessible, MMC/SD device.
281  */
282 typedef struct {
283  /** @brief Virtual Methods Table.*/
284  const struct MMCSDBlockDeviceVMT *vmt;
287
288 /**
289  * @brief Unpacked CID register from SDC.
290  */
291 typedef struct {
292  uint8_t mid;
293  uint16_t oid;
294  char pnm[5];
295  uint8_t prv_n;
296  uint8_t prv_m;
297  uint32_t psn;
298  uint8_t mdt_m;
299  uint16_t mdt_y;
300  uint8_t crc;
302
303 /**
304  * @brief Unpacked CID register from MMC.
305  */
306 typedef struct {
307  uint8_t mid;
308  uint16_t oid;
309  char pnm[6];
310  uint8_t prv_n;
311  uint8_t prv_m;
312  uint32_t psn;
313  uint8_t mdt_m;
314  uint16_t mdt_y;
315  uint8_t crc;
317
318 /**
319  * @brief Unpacked CSD v1.0 register from SDC.
320  */
321 typedef struct {
322  uint8_t csd_structure;
323  uint8_t taac;
324  uint8_t nsac;
325  uint8_t tran_speed;
326  uint16_t ccc;
327  uint8_t read_bl_len;
328  uint8_t read_bl_partial;
329  uint8_t write_blk_misalign;
330  uint8_t read_blk_misalign;
331  uint8_t dsr_imp;
332  uint16_t c_size;
333  uint8_t vdd_r_curr_min;
334  uint8_t vdd_r_curr_max;
335  uint8_t vdd_w_curr_min;
336  uint8_t vdd_w_curr_max;
337  uint8_t c_size_mult;
338  uint8_t erase_blk_en;
339  uint8_t erase_sector_size;
340  uint8_t wp_grp_size;
341  uint8_t wp_grp_enable;
342  uint8_t r2w_factor;
343  uint8_t write_bl_len;
344  uint8_t write_bl_partial;
345  uint8_t file_format_grp;
346  uint8_t copy;
347  uint8_t perm_write_protect;
348  uint8_t tmp_write_protect;
349  uint8_t file_format;
350  uint8_t crc;
352
353 /**
354  * @brief Unpacked CSD v2.0 register from SDC.
355  */
356 typedef struct {
357  uint8_t csd_structure;
358  uint8_t taac;
359  uint8_t nsac;
360  uint8_t tran_speed;
361  uint16_t ccc;
362  uint8_t read_bl_len;
363  uint8_t read_bl_partial;
364  uint8_t write_blk_misalign;
365  uint8_t read_blk_misalign;
366  uint8_t dsr_imp;
367  uint32_t c_size;
368  uint8_t erase_blk_en;
369  uint8_t erase_sector_size;
370  uint8_t wp_grp_size;
371  uint8_t wp_grp_enable;
372  uint8_t r2w_factor;
373  uint8_t write_bl_len;
374  uint8_t write_bl_partial;
375  uint8_t file_format_grp;
376  uint8_t copy;
377  uint8_t perm_write_protect;
378  uint8_t tmp_write_protect;
379  uint8_t file_format;
380  uint8_t crc;
382
383 /**
384  * @brief Unpacked CSD register from MMC.
385  */
386 typedef struct {
387  uint8_t csd_structure;
388  uint8_t spec_vers;
389  uint8_t taac;
390  uint8_t nsac;
391  uint8_t tran_speed;
392  uint16_t ccc;
393  uint8_t read_bl_len;
394  uint8_t read_bl_partial;
395  uint8_t write_blk_misalign;
396  uint8_t read_blk_misalign;
397  uint8_t dsr_imp;
398  uint16_t c_size;
399  uint8_t vdd_r_curr_min;
400  uint8_t vdd_r_curr_max;
401  uint8_t vdd_w_curr_min;
402  uint8_t vdd_w_curr_max;
403  uint8_t c_size_mult;
404  uint8_t erase_grp_size;
405  uint8_t erase_grp_mult;
406  uint8_t wp_grp_size;
407  uint8_t wp_grp_enable;
408  uint8_t default_ecc;
409  uint8_t r2w_factor;
410  uint8_t write_bl_len;
411  uint8_t write_bl_partial;
412  uint8_t content_prot_app;
413  uint8_t file_format_grp;
414  uint8_t copy;
415  uint8_t perm_write_protect;
416  uint8_t tmp_write_protect;
417  uint8_t file_format;
418  uint8_t ecc;
419  uint8_t crc;
421
422 /*===========================================================================*/
423 /* Driver macros. */
424 /*===========================================================================*/
425
426 /**
427  * @name R1 response utilities
428  * @{
429  */
430 /**
431  * @brief Evaluates to @p true if the R1 response contains error flags.
432  *
433  * @param[in] r1 the r1 response
434  */
435 #define MMCSD_R1_ERROR(r1) (((r1) & MMCSD_R1_ERROR_MASK) != 0U)
436
437 /**
438  * @brief Returns the status field of an R1 response.
439  *
440  * @param[in] r1 the r1 response
441  */
442 #define MMCSD_R1_STS(r1) (((r1) >> 9U) & 15U)
443
444 /**
445  * @brief Evaluates to @p true if the R1 response indicates a locked card.
446  *
447  * @param[in] r1 the r1 response
448  */
449 #define MMCSD_R1_IS_CARD_LOCKED(r1) ((((r1) >> 21U) & 1U) != 0U)
450 /** @} */
451
452 /**
453  * @name Macro Functions
454  * @{
455  */
456 /**
457  * @brief Returns the card capacity in blocks.
458  *
459  * @param[in] ip pointer to a @p MMCSDBlockDevice or derived class
460  *
461  * @return The card capacity.
462  *
463  * @api
464  */
465 #define mmcsdGetCardCapacity(ip) ((ip)->capacity)
466 /** @} */
467
468 /*===========================================================================*/
469 /* External declarations. */
470 /*===========================================================================*/
471
472 #ifdef __cplusplus
473 extern "C" {
474 #endif
475  uint32_t _mmcsd_get_slice(const uint32_t *data,
476  uint32_t end,
477  uint32_t start);
478  uint32_t _mmcsd_get_capacity(const uint32_t *csd);
479  uint32_t _mmcsd_get_capacity_ext(const uint8_t *ext_csd);
480  void _mmcsd_unpack_sdc_cid(const MMCSDBlockDevice *sdcp,
481  unpacked_sdc_cid_t *cidsdc);
482  void _mmcsd_unpack_mmc_cid(const MMCSDBlockDevice *sdcp,
483  unpacked_mmc_cid_t *cidmmc);
484  void _mmcsd_unpack_csd_mmc(const MMCSDBlockDevice *sdcp,
485  unpacked_mmc_csd_t *csdmmc);
486  void _mmcsd_unpack_csd_v10(const MMCSDBlockDevice *sdcp,
487  unpacked_sdc_csd_10_t *csd10);
488  void _mmcsd_unpack_csd_v20(const MMCSDBlockDevice *sdcp,
489  unpacked_sdc_csd_20_t *csd20);
490 #ifdef __cplusplus
491 }
492 #endif
493
494 #endif /* HAL_USE_MMC_SPI == TRUE || HAL_USE_MMC_SDC == TRUE */
495
496 #endif /* HAL_MMCSD_H */
497
498 /** @} */
Definition: hal_mmcsd.h:282
Extract MMC card capacity from EXT_CSD.
Definition: hal_mmcsd.c:125
Definition: hal_mmcsd.h:258
void _mmcsd_unpack_csd_mmc(const MMCSDBlockDevice *sdcp, unpacked_mmc_csd_t *csdmmc)
Unpacks MMC CSD array in structure.
Definition: hal_mmcsd.c:206
Definition: hal_mmcsd.h:321
Definition: hal_mmcsd.h:386
void _mmcsd_unpack_csd_v20(const MMCSDBlockDevice *sdcp, unpacked_sdc_csd_20_t *csd20)
Unpacks SDC CSD v2.0 array in structure.
Definition: hal_mmcsd.c:296
Definition: hal_mmcsd.h:306
Definition: hal_mmcsd.h:272
const struct MMCSDBlockDeviceVMT * vmt
Definition: hal_mmcsd.h:284
void _mmcsd_unpack_sdc_cid(const MMCSDBlockDevice *sdcp, unpacked_sdc_cid_t *cidsdc)
Unpacks SDC CID array in structure.
Definition: hal_mmcsd.c:143
#define _base_block_device_methods
BaseBlockDevice specific methods.
Definition: hal_ioblock.h:63
uint32_t _mmcsd_get_slice(const uint32_t *data, uint32_t end, uint32_t start)
Gets a bit field from a words array.
Definition: hal_mmcsd.c:61
Definition: hal_mmcsd.h:291
void _mmcsd_unpack_csd_v10(const MMCSDBlockDevice *sdcp, unpacked_sdc_csd_10_t *csd10)
Unpacks SDC CSD v1.0 array in structure.
Definition: hal_mmcsd.c:254
void _mmcsd_unpack_mmc_cid(const MMCSDBlockDevice *sdcp, unpacked_mmc_cid_t *cidmmc)
Unpacks MMC CID array in structure.
Definition: hal_mmcsd.c:174
Definition: hal_mmcsd.h:356
Extract card capacity from a CSD.
Definition: hal_mmcsd.c:93
