hal_pal_lld.h
18  * @file hal_pal_lld.h
19  * @brief PLATFORM PAL subsystem low level driver header.
21  * @addtogroup PAL
25 #ifndef HAL_PAL_LLD_H
26 #define HAL_PAL_LLD_H
28 #if (HAL_USE_PAL == TRUE) || defined(__DOXYGEN__)
31 /* Unsupported modes and specific modes */
35 /* I/O Ports Types and constants. */
37
38 /**
39  * @name Port related definitions
40  * @{
41  */
42 /**
43  * @brief Width, in bits, of an I/O port.
44  */
45 #define PAL_IOPORTS_WIDTH 16U
46
47 /**
48  * @brief Whole port mask.
49  * @details This macro specifies all the valid bits into a port.
50  */
51 #define PAL_WHOLE_PORT ((ioportmask_t)0xFFFFU)
52 /** @} */
53
54 /**
55  * @name Line handling macros
56  * @{
57  */
58 /**
59  * @brief Forms a line identifier.
60  * @details A port/pad pair are encoded into an @p ioline_t type. The encoding
61  * of this type is platform-dependent.
62  */
63 #define PAL_LINE(port, pad) \
64  ((ioline_t)((uint32_t)(port)) | ((uint32_t)(pad)))
65
66 /**
67  * @brief Decodes a port identifier from a line identifier.
68  */
69 #define PAL_PORT(line) \
70  ((stm32_gpio_t *)(((uint32_t)(line)) & 0xFFFFFFF0U))
71
72 /**
73  * @brief Decodes a pad identifier from a line identifier.
74  */
75 #define PAL_PAD(line) \
76  ((uint32_t)((uint32_t)(line) & 0x0000000FU))
77
78 /**
79  * @brief Value identifying an invalid line.
80  */
81 #define PAL_NOLINE 0U
82 /** @} */
83
84 /**
85  * @brief Generic I/O ports static initializer.
86  * @details An instance of this structure must be passed to @p palInit() at
87  * system startup time in order to initialized the digital I/O
88  * subsystem. This represents only the initial setup, specific pads
89  * or whole ports can be reprogrammed at later time.
90  * @note Implementations may extend this structure to contain more,
91  * architecture dependent, fields.
92  */
93 typedef struct {
94
95 } PALConfig;
96
97 /**
98  * @brief Digital I/O port sized unsigned type.
99  */
100 typedef uint32_t ioportmask_t;
101
102 /**
103  * @brief Digital I/O modes.
104  */
105 typedef uint32_t iomode_t;
106
107 /**
108  * @brief Type of an I/O line.
109  */
110 typedef uint32_t ioline_t;
111
112 /**
113  * @brief Port Identifier.
114  * @details This type can be a scalar or some kind of pointer, do not make
115  * any assumption about it, use the provided macros when populating
116  * variables of this type.
117  */
118 typedef uint32_t ioportid_t;
119
120 /**
121  * @brief Type of an pad identifier.
122  */
123 typedef uint32_t iopadid_t;
124
125 /*===========================================================================*/
126 /* I/O Ports Identifiers. */
127 /*===========================================================================*/
128
129 /**
130  * @brief First I/O port identifier.
131  * @details Low level drivers can define multiple ports, it is suggested to
132  * use this naming convention.
133  */
134 #define IOPORT1 0
135
136 /*===========================================================================*/
137 /* Implementation, some of the following macros could be implemented as */
138 /* functions, if so please put them in pal_lld.c. */
139 /*===========================================================================*/
140
141 /**
142  * @brief Low level PAL subsystem initialization.
143  *
144  * @param[in] config architecture-dependent ports configuration
145  *
146  * @notapi
147  */
148 #define pal_lld_init(config) _pal_lld_init(config)
149
150 /**
151  * @brief Reads the physical I/O port states.
152  *
153  * @param[in] port port identifier
154  * @return The port bits.
155  *
156  * @notapi
157  */
158 #define pal_lld_readport(port) 0U
159
160 /**
161  * @brief Reads the output latch.
162  * @details The purpose of this function is to read back the latched output
163  * value.
164  *
165  * @param[in] port port identifier
166  * @return The latched logical states.
167  *
168  * @notapi
169  */
170 #define pal_lld_readlatch(port) 0U
171
172 /**
173  * @brief Writes a bits mask on a I/O port.
174  *
175  * @param[in] port port identifier
176  * @param[in] bits bits to be written on the specified port
177  *
178  * @notapi
179  */
180 #define pal_lld_writeport(port, bits) \
181  do { \
182  (void)port; \
183  (void)bits; \
184  } while (false)
185
186
187 /**
188  * @brief Sets a bits mask on a I/O port.
189  * @note The @ref PAL provides a default software implementation of this
190  * functionality, implement this function if can optimize it by using
191  * special hardware functionalities or special coding.
192  *
193  * @param[in] port port identifier
194  * @param[in] bits bits to be ORed on the specified port
195  *
196  * @notapi
197  */
198 #define pal_lld_setport(port, bits) \
199  do { \
200  (void)port; \
201  (void)bits; \
202  } while (false)
203
204
205 /**
206  * @brief Clears a bits mask on a I/O port.
207  * @note The @ref PAL provides a default software implementation of this
208  * functionality, implement this function if can optimize it by using
209  * special hardware functionalities or special coding.
210  *
211  * @param[in] port port identifier
212  * @param[in] bits bits to be cleared on the specified port
213  *
214  * @notapi
215  */
216 #define pal_lld_clearport(port, bits) \
217  do { \
218  (void)port; \
219  (void)bits; \
220  } while (false)
221
222
223 /**
224  * @brief Toggles a bits mask on a I/O port.
225  * @note The @ref PAL provides a default software implementation of this
226  * functionality, implement this function if can optimize it by using
227  * special hardware functionalities or special coding.
228  *
229  * @param[in] port port identifier
230  * @param[in] bits bits to be XORed on the specified port
231  *
232  * @notapi
233  */
234 #define pal_lld_toggleport(port, bits) \
235  do { \
236  (void)port; \
237  (void)bits; \
238  } while (false)
239
240
241 /**
242  * @brief Reads a group of bits.
243  * @note The @ref PAL provides a default software implementation of this
244  * functionality, implement this function if can optimize it by using
245  * special hardware functionalities or special coding.
246  *
247  * @param[in] port port identifier
248  * @param[in] mask group mask
249  * @param[in] offset group bit offset within the port
250  * @return The group logical states.
251  *
252  * @notapi
253  */
254 #define pal_lld_readgroup(port, mask, offset) 0U
255
256 /**
257  * @brief Writes a group of bits.
258  * @note The @ref PAL provides a default software implementation of this
259  * functionality, implement this function if can optimize it by using
260  * special hardware functionalities or special coding.
261  *
262  * @param[in] port port identifier
263  * @param[in] mask group mask
264  * @param[in] offset group bit offset within the port
265  * @param[in] bits bits to be written. Values exceeding the group width
266  * are masked.
267  *
268  * @notapi
269  */
270 #define pal_lld_writegroup(port, mask, offset, bits) \
271  do { \
272  (void)port; \
273  (void)mask; \
274  (void)offset; \
275  (void)bits; \
276  } while (false)
277
278 /**
279  * @brief Pads group mode setup.
280  * @details This function programs a pads group belonging to the same port
281  * with the specified mode.
282  * @note Programming an unknown or unsupported mode is silently ignored.
283  *
284  * @param[in] port port identifier
285  * @param[in] mask group mask
286  * @param[in] offset group bit offset within the port
287  * @param[in] mode group mode
288  *
289  * @notapi
290  */
291 #define pal_lld_setgroupmode(port, mask, offset, mode) \
292  _pal_lld_setgroupmode(port, mask << offset, mode)
293
294 /**
295  * @brief Reads a logical state from an I/O pad.
296  * @note The @ref PAL provides a default software implementation of this
297  * functionality, implement this function if can optimize it by using
298  * special hardware functionalities or special coding.
299  *
300  * @param[in] port port identifier
301  * @param[in] pad pad number within the port
302  * @return The logical state.
303  * @retval PAL_LOW low logical state.
304  * @retval PAL_HIGH high logical state.
305  *
306  * @notapi
307  */
308 #define pal_lld_readpad(port, pad) PAL_LOW
309
310 /**
311  * @brief Writes a logical state on an output pad.
312  * @note This function is not meant to be invoked directly by the
313  * application code.
314  * @note The @ref PAL provides a default software implementation of this
315  * functionality, implement this function if can optimize it by using
316  * special hardware functionalities or special coding.
317  *
318  * @param[in] port port identifier
319  * @param[in] pad pad number within the port
320  * @param[in] bit logical value, the value must be @p PAL_LOW or
321  * @p PAL_HIGH
322  *
323  * @notapi
324  */
325 #define pal_lld_writepad(port, pad, bit) \
326  do { \
327  (void)port; \
328  (void)pad; \
329  (void)bit; \
330  } while (false)
331
332 /**
333  * @brief Sets a pad logical state to @p PAL_HIGH.
334  * @note The @ref PAL provides a default software implementation of this
335  * functionality, implement this function if can optimize it by using
336  * special hardware functionalities or special coding.
337  *
338  * @param[in] port port identifier
339  * @param[in] pad pad number within the port
340  *
341  * @notapi
342  */
343 #define pal_lld_setpad(port, pad) \
344  do { \
345  (void)port; \
346  (void)pad; \
347  } while (false)
348
349
350 /**
351  * @brief Clears a pad logical state to @p PAL_LOW.
352  * @note The @ref PAL provides a default software implementation of this
353  * functionality, implement this function if can optimize it by using
354  * special hardware functionalities or special coding.
355  *
356  * @param[in] port port identifier
357  * @param[in] pad pad number within the port
358  *
359  * @notapi
360  */
361 #define pal_lld_clearpad(port, pad) \
362  do { \
363  (void)port; \
364  (void)pad; \
365  } while (false)
366
367
368 /**
369  * @brief Toggles a pad logical state.
370  * @note The @ref PAL provides a default software implementation of this
371  * functionality, implement this function if can optimize it by using
372  * special hardware functionalities or special coding.
373  *
374  * @param[in] port port identifier
375  * @param[in] pad pad number within the port
376  *
377  * @notapi
378  */
379 #define pal_lld_togglepad(port, pad) \
380  do { \
381  (void)port; \
382  (void)pad; \
383  } while (false)
384
385
386 /**
387  * @brief Pad mode setup.
388  * @details This function programs a pad with the specified mode.
389  * @note The @ref PAL provides a default software implementation of this
390  * functionality, implement this function if can optimize it by using
391  * special hardware functionalities or special coding.
392  * @note Programming an unknown or unsupported mode is silently ignored.
393  *
394  * @param[in] port port identifier
395  * @param[in] pad pad number within the port
396  * @param[in] mode pad mode
397  *
398  * @notapi
399  */
400 #define pal_lld_setpadmode(port, pad, mode) \
401  do { \
402  (void)port; \
403  (void)pad; \
404  (void)mode; \
405  } while (false)
406
407 /**
408  * @brief Returns a PAL event structure associated to a pad.
409  *
410  * @param[in] port port identifier
411  * @param[in] pad pad number within the port
412  *
413  * @notapi
414  */
415 #define pal_lld_get_pad_event(port, pad) \
416  &_pal_events[0]; (void)(port); (void)pad
417
418 /**
419  * @brief Returns a PAL event structure associated to a line.
420  *
421  * @param[in] line line identifier
422  *
423  * @notapi
424  */
425 #define pal_lld_get_line_event(line) \
426  &_pal_events[0]; (void)line
427
428 #if !defined(__DOXYGEN__)
429 extern const PALConfig pal_default_config;
430 extern palevent_t _pal_events[1];
431 #endif
432
433 #ifdef __cplusplus
434 extern "C" {
435 #endif
436  void _pal_lld_init(const PALConfig *config);
438  ioportmask_t mask,
439  iomode_t mode);
440 #ifdef __cplusplus
441 }
442 #endif
443
444 #endif /* HAL_USE_PAL == TRUE */
445
446 #endif /* HAL_PAL_LLD_H */
447
448 /** @} */
Type of a PAL event record.
Definition: hal_pal.h:153
Definition: hal_pal_lld.h:100
uint32_t iopadid_t
Definition: hal_pal_lld.h:123
uint32_t ioline_t
Definition: hal_pal_lld.h:110
STM32 I/O ports configuration.
Definition: hal_pal_lld.c:61
uint32_t ioportid_t
Port Identifier.
Definition: hal_pal_lld.h:118
void _pal_lld_setgroupmode(ioportid_t port, ioportmask_t mask, iomode_t mode)
Pads mode setup.
Definition: hal_pal_lld.c:78
uint32_t iomode_t
Digital I/O modes.
Definition: hal_pal_lld.h:105
Definition: hal_pal_lld.h:93
