hal_spi.h File Reference
SPI Driver macros and structures. More...
#include "hal_spi_lld.h"
Chip Select modes
#define SPI_SELECT_MODE_NONE
#define SPI_SELECT_MODE_PAD   1 /** @brief Legacy mode. */
#define SPI_SELECT_MODE_PORT   2 /** @brief Fastest mode. */
#define SPI_SELECT_MODE_LINE   3 /** @brief Packed mode. */
#define SPI_SELECT_MODE_LLD   4 /** @brief LLD-defined mode.*/
SPI configuration options
#define SPI_USE_WAIT   TRUE
 Enables synchronous APIs. More...
#define SPI_USE_CIRCULAR   FALSE
 Enables circular transfers APIs. More...
#define SPI_USE_MUTUAL_EXCLUSION   TRUE
 Enables the spiAcquireBus() and spiReleaseBus() APIs. More...
#define SPI_SELECT_MODE   SPI_SELECT_MODE_PAD
 Handling method for SPI CS line. More...
Macro Functions
#define spiSelectI(spip)
 Asserts the slave select signal and prepares for transfers. More...
#define spiUnselectI(spip)
 Deasserts the slave select signal. More...
#define spiStartIgnoreI(spip, n)
 Ignores data on the SPI bus. More...
#define spiStartExchangeI(spip, n, txbuf, rxbuf)
 Exchanges data on the SPI bus. More...
#define spiStartSendI(spip, n, txbuf)
 Sends data over the SPI bus. More...
#define spiStartReceiveI(spip, n, rxbuf)
 Receives data from the SPI bus. More...
#define spiPolledExchange(spip, frame)   spi_lld_polled_exchange(spip, frame)
 Exchanges one frame using a polled wait. More...
Low level driver helper macros
#define _spi_wakeup_isr(spip)
 Wakes up the waiting thread. More...
#define _spi_isr_code(spip)
 Common ISR code. More...
#define _spi_isr_code_half1(spip)
 Common ISR code in circular mode. More...
#define _spi_isr_code_half2(spip)
Enumerations
void spiInit (void)
 SPI Driver initialization. More...
void spiObjectInit (SPIDriver *spip)
 Initializes the standard part of a SPIDriver structure. More...
void spiStart (SPIDriver *spip, const SPIConfig *config)
 Configures and activates the SPI peripheral. More...
void spiStop (SPIDriver *spip)
 Deactivates the SPI peripheral. More...
void spiSelect (SPIDriver *spip)
void spiUnselect (SPIDriver *spip)
void spiStartIgnore (SPIDriver *spip, size_t n)
void spiStartExchange (SPIDriver *spip, size_t n, const void *txbuf, void *rxbuf)
void spiStartSend (SPIDriver *spip, size_t n, const void *txbuf)
void spiStartReceive (SPIDriver *spip, size_t n, void *rxbuf)
void spiAbortI (SPIDriver *spip)
 Aborts the ongoing SPI operation. More...
void spiAbort (SPIDriver *spip)
 Aborts the ongoing SPI operation, if any. More...
void spiIgnore (SPIDriver *spip, size_t n)
void spiExchange (SPIDriver *spip, size_t n, const void *txbuf, void *rxbuf)
void spiSend (SPIDriver *spip, size_t n, const void *txbuf)
void spiReceive (SPIDriver *spip, size_t n, void *rxbuf)
void spiAcquireBus (SPIDriver *spip)
 Gains exclusive access to the SPI bus. More...
void spiReleaseBus (SPIDriver *spip)
 Releases exclusive access to the SPI bus. More...
Definition in file hal_spi.h.
