hal_spi_lld.c
18  * @file hal_spi_lld.c
19  * @brief PLATFORM SPI subsystem low level driver source.
21  * @addtogroup SPI
27 #if (HAL_USE_SPI == TRUE) || defined(__DOXYGEN__)
37 /**
38  * @brief SPI1 driver identifier.
39  */
40 #if (PLATFORM_SPI_USE_SPI1 == TRUE) || defined(__DOXYGEN__)
42 #endif
43
45 /* Driver local variables and types. */
47
49 /* Driver local functions. */
51
53 /* Driver interrupt handlers. */
55
57 /* Driver exported functions. */
59
60 /**
61  * @brief Low level SPI driver initialization.
62  *
63  * @notapi
64  */
65 void spi_lld_init(void) {
66
67 #if PLATFORM_SPI_USE_SPI1 == TRUE
68  /* Driver initialization.*/
69  spiObjectInit(&SPID1);
70 #endif
71 }
72
73 /**
74  * @brief Configures and activates the SPI peripheral.
75  *
76  * @param[in] spip pointer to the @p SPIDriver object
77  *
78  * @notapi
79  */
80 void spi_lld_start(SPIDriver *spip) {
81
82  if (spip->state == SPI_STOP) {
83  /* Enables the peripheral.*/
84 #if PLATFORM_SPI_USE_SPI1 == TRUE
85  if (&SPID1 == spip) {
86
87  }
88 #endif
89  }
90  /* Configures the peripheral.*/
91
92 }
93
94 /**
95  * @brief Deactivates the SPI peripheral.
96  *
97  * @param[in] spip pointer to the @p SPIDriver object
98  *
99  * @notapi
100  */
101 void spi_lld_stop(SPIDriver *spip) {
102
103  if (spip->state == SPI_READY) {
104  /* Disables the peripheral.*/
105 #if PLATFORM_SPI_USE_SPI1 == TRUE
106  if (&SPID1 == spip) {
107
108  }
109 #endif
110  }
111 }
112
113 /**
114  * @brief Asserts the slave select signal and prepares for transfers.
115  *
116  * @param[in] spip pointer to the @p SPIDriver object
117  *
118  * @notapi
119  */
121
122  (void)spip;
123
124 }
125
126 /**
127  * @brief Deasserts the slave select signal.
128  * @details The previously selected peripheral is unselected.
129  *
130  * @param[in] spip pointer to the @p SPIDriver object
131  *
132  * @notapi
133  */
135
136  (void)spip;
137
138 }
139
140 /**
141  * @brief Ignores data on the SPI bus.
142  * @details This asynchronous function starts the transmission of a series of
143  * idle words on the SPI bus and ignores the received data.
144  * @post At the end of the operation the configured callback is invoked.
145  *
146  * @param[in] spip pointer to the @p SPIDriver object
147  * @param[in] n number of words to be ignored
148  *
149  * @notapi
150  */
151 void spi_lld_ignore(SPIDriver *spip, size_t n) {
152
153  (void)spip;
154  (void)n;
155
156 }
157
158 /**
159  * @brief Exchanges data on the SPI bus.
160  * @details This asynchronous function starts a simultaneous transmit/receive
161  * operation.
162  * @post At the end of the operation the configured callback is invoked.
163  * @note The buffers are organized as uint8_t arrays for data sizes below or
164  * equal to 8 bits else it is organized as uint16_t arrays.
165  *
166  * @param[in] spip pointer to the @p SPIDriver object
167  * @param[in] n number of words to be exchanged
168  * @param[in] txbuf the pointer to the transmit buffer
169  * @param[out] rxbuf the pointer to the receive buffer
170  *
171  * @notapi
172  */
173 void spi_lld_exchange(SPIDriver *spip, size_t n,
174  const void *txbuf, void *rxbuf) {
175
176  (void)spip;
177  (void)n;
178  (void)txbuf;
179  (void)rxbuf;
180
181 }
182
183 /**
184  * @brief Sends data over the SPI bus.
185  * @details This asynchronous function starts a transmit operation.
186  * @post At the end of the operation the configured callback is invoked.
187  * @note The buffers are organized as uint8_t arrays for data sizes below or
188  * equal to 8 bits else it is organized as uint16_t arrays.
189  *
190  * @param[in] spip pointer to the @p SPIDriver object
191  * @param[in] n number of words to send
192  * @param[in] txbuf the pointer to the transmit buffer
193  *
194  * @notapi
195  */
196 void spi_lld_send(SPIDriver *spip, size_t n, const void *txbuf) {
197
198  (void)spip;
199  (void)n;
200  (void)txbuf;
201
202 }
203
204 /**
205  * @brief Receives data from the SPI bus.
206  * @details This asynchronous function starts a receive operation.
207  * @post At the end of the operation the configured callback is invoked.
208  * @note The buffers are organized as uint8_t arrays for data sizes below or
209  * equal to 8 bits else it is organized as uint16_t arrays.
210  *
211  * @param[in] spip pointer to the @p SPIDriver object
212  * @param[in] n number of words to receive
213  * @param[out] rxbuf the pointer to the receive buffer
214  *
215  * @notapi
216  */
217 void spi_lld_receive(SPIDriver *spip, size_t n, void *rxbuf) {
218
219  (void)spip;
220  (void)n;
221  (void)rxbuf;
222
223 }
224
225 #if (SPI_SUPPORTS_CIRCULAR == TRUE) || defined(__DOXYGEN__)
226 /**
227  * @brief Aborts the ongoing SPI operation, if any.
228  *
229  * @param[in] spip pointer to the @p SPIDriver object
230  *
231  * @notapi
232  */
234
235  (void)spip;
236 }
237 #endif /* SPI_SUPPORTS_CIRCULAR == TRUE */
238
239 /**
240  * @brief Exchanges one frame using a polled wait.
241  * @details This synchronous function exchanges one frame using a polled
242  * synchronization method. This function is useful when exchanging
243  * small amount of data on high speed channels, usually in this
244  * situation is much more efficient just wait for completion using
245  * polling than suspending the thread waiting for an interrupt.
246  *
247  * @param[in] spip pointer to the @p SPIDriver object
248  * @param[in] frame the data frame to send over the SPI bus
249  * @return The received data frame from the SPI bus.
250  *
251  * @notapi
252  */
253 uint16_t spi_lld_polled_exchange(SPIDriver *spip, uint16_t frame) {
254
255  (void)spip;
256  (void)frame;
257
258  return 0;
259 }
260
261 #endif /* HAL_USE_SPI == TRUE */
262
263 /** @} */
Definition: hal_spi_lld.c:151
void spiObjectInit(SPIDriver *spip)
Initializes the standard part of a SPIDriver structure.
Definition: hal_spi.c:68
Definition: hal_spi_lld.c:217
Definition: hal_spi_lld.c:196
void spi_lld_exchange(SPIDriver *spip, size_t n, const void *txbuf, void *rxbuf)
Definition: hal_spi_lld.c:173
Definition: hal_spi_lld.c:101
void spi_lld_abort(SPIDriver *spip)
Definition: hal_spi_lld.c:233
Definition: hal_spi_lld.c:80
Definition: hal_spi_lld.c:65
void spi_lld_unselect(SPIDriver *spip)
Definition: hal_spi_lld.c:134
Definition: hal_spi_lld.c:253
void spi_lld_select(SPIDriver *spip)
Definition: hal_spi_lld.c:120
SPIDriver SPID1
Definition: hal_spi_lld.c:41
Definition: hal_spi_lld.h:128
spistate_t state
Definition: hal_spi_lld.h:132
