hal_spi_lld.h File Reference
PLATFORM SPI subsystem low level driver header. More...
struct  SPIConfig
 Driver configuration structure. More...
struct  SPIDriver
 Structure representing an SPI driver. More...
#define SPI_SUPPORTS_CIRCULAR   TRUE
 Circular mode support flag. More...
PLATFORM configuration options
#define PLATFORM_SPI_USE_SPI1   FALSE
 SPI1 driver enable switch. More...
typedef struct SPIDriver SPIDriver
 Type of a structure representing an SPI driver. More...
typedef void(* spicallback_t) (SPIDriver *spip)
 SPI notification callback type. More...
void spi_lld_init (void)
 Low level SPI driver initialization. More...
void spi_lld_start (SPIDriver *spip)
 Configures and activates the SPI peripheral. More...
void spi_lld_stop (SPIDriver *spip)
 Deactivates the SPI peripheral. More...
void spi_lld_select (SPIDriver *spip)
 Asserts the slave select signal and prepares for transfers. More...
void spi_lld_unselect (SPIDriver *spip)
 Deasserts the slave select signal. More...
void spi_lld_ignore (SPIDriver *spip, size_t n)
 Ignores data on the SPI bus. More...
void spi_lld_exchange (SPIDriver *spip, size_t n, const void *txbuf, void *rxbuf)
 Exchanges data on the SPI bus. More...
void spi_lld_send (SPIDriver *spip, size_t n, const void *txbuf)
 Sends data over the SPI bus. More...
void spi_lld_receive (SPIDriver *spip, size_t n, void *rxbuf)
 Receives data from the SPI bus. More...
void spi_lld_abort (SPIDriver *spip)
 Aborts the ongoing SPI operation, if any. More...
uint16_t spi_lld_polled_exchange (SPIDriver *spip, uint16_t frame)
 Exchanges one frame using a polled wait. More...
Definition in file hal_spi_lld.h.
