hal_streams.h File Reference
Data streams. More...
struct  BaseSequentialStreamVMT
 BaseSequentialStream virtual methods table. More...
 Base stream class. More...
#define _base_sequential_stream_methods
 BaseSequentialStream specific methods. More...
#define _base_sequential_stream_data   _base_object_data
 BaseSequentialStream specific data. More...
Streams return codes
#define STM_OK   MSG_OK
#define STM_TIMEOUT   MSG_TIMEOUT
#define STM_RESET   MSG_RESET
Macro Functions (BaseSequentialStream)
#define streamWrite(ip, bp, n)   ((ip)->vmt->write(ip, bp, n))
 Sequential Stream write. More...
#define streamRead(ip, bp, n)   ((ip)->vmt->read(ip, bp, n))
 Sequential Stream read. More...
#define streamPut(ip, b)   ((ip)->vmt->put(ip, b))
 Sequential Stream blocking byte write. More...
#define streamGet(ip)   ((ip)->vmt->get(ip))
 Sequential Stream blocking byte read. More...
Data streams.
This header defines abstract interfaces useful to access generic data streams in a standardized way.
Definition in file hal_streams.h.
