hal_usb_cdc.h
18  * @file hal_usb_cdc.h
19  * @brief USB CDC macros and structures.
21  * @addtogroup USB_CDC
25 #ifndef USB_CDC_H
26 #define USB_CDC_H
28 /*===========================================================================*/
29 /* Driver constants. */
31
32 /**
33  * @name CDC specific messages.
34  * @{
35  */
36 #define CDC_SEND_ENCAPSULATED_COMMAND 0x00U
37 #define CDC_GET_ENCAPSULATED_RESPONSE 0x01U
38 #define CDC_SET_COMM_FEATURE 0x02U
39 #define CDC_GET_COMM_FEATURE 0x03U
40 #define CDC_CLEAR_COMM_FEATURE 0x04U
41 #define CDC_SET_AUX_LINE_STATE 0x10U
42 #define CDC_SET_HOOK_STATE 0x11U
43 #define CDC_PULSE_SETUP 0x12U
44 #define CDC_SEND_PULSE 0x13U
45 #define CDC_SET_PULSE_TIME 0x14U
46 #define CDC_RING_AUX_JACK 0x15U
47 #define CDC_SET_LINE_CODING 0x20U
48 #define CDC_GET_LINE_CODING 0x21U
49 #define CDC_SET_CONTROL_LINE_STATE 0x22U
50 #define CDC_SEND_BREAK 0x23U
51 #define CDC_SET_RINGER_PARMS 0x30U
52 #define CDC_GET_RINGER_PARMS 0x31U
53 #define CDC_SET_OPERATION_PARMS 0x32U
54 #define CDC_GET_OPERATION_PARMS 0x33U
55 /** @} */
56
57 /**
58  * @name CDC classes
59  * @{
60  */
61 #define CDC_COMMUNICATION_INTERFACE_CLASS 0x02U
62 #define CDC_DATA_INTERFACE_CLASS 0x0AU
63 /** @} */
64
65 /**
66  * @name CDC subclasses
67  * @{
68  */
69 #define CDC_ABSTRACT_CONTROL_MODEL 0x02U
70 /** @} */
71
72 /**
73  * @name CDC descriptors
74  * @{
75  */
76 #define CDC_CS_INTERFACE 0x24U
77 /** @} */
78
79 /**
80  * @name CDC subdescriptors
81  * @{
82  */
83 #define CDC_HEADER 0x00U
84 #define CDC_CALL_MANAGEMENT 0x01U
85 #define CDC_ABSTRACT_CONTROL_MANAGEMENT 0x02U
86 #define CDC_UNION 0x06U
87 /** @} */
88
89 /**
90  * @name Line Control bit definitions.
91  * @{
92  */
93 #define LC_STOP_1 0U
94 #define LC_STOP_1P5 1U
95 #define LC_STOP_2 2U
96
97 #define LC_PARITY_NONE 0U
98 #define LC_PARITY_ODD 1U
99 #define LC_PARITY_EVEN 2U
100 #define LC_PARITY_MARK 3U
101 #define LC_PARITY_SPACE 4U
102 /** @} */
103
104 /*===========================================================================*/
105 /* Driver pre-compile time settings. */
106 /*===========================================================================*/
107
108 /*===========================================================================*/
109 /* Derived constants and error checks. */
110 /*===========================================================================*/
111
112 /*===========================================================================*/
113 /* Driver data structures and types. */
114 /*===========================================================================*/
115
116 /**
117  * @brief Type of Line Coding structure.
118  */
119 typedef struct {
120  uint8_t dwDTERate[4];
121  uint8_t bCharFormat;
122  uint8_t bParityType;
123  uint8_t bDataBits;
125
126 /*===========================================================================*/
127 /* Driver macros. */
128 /*===========================================================================*/
129
130 /*===========================================================================*/
131 /* External declarations. */
132 /*===========================================================================*/
133
134 #endif /* USB_CDC_H */
135
136 /** @} */
Definition: hal_usb_cdc.h:119
