HTS221 MEMS interface module code. More...
static msg_t | hts221I2CReadRegister (I2CDriver *i2cp, uint8_t reg, uint8_t *rxbuf, size_t n) |
Reads registers value using I2C. More... | |
static msg_t | hts221I2CWriteRegister (I2CDriver *i2cp, uint8_t *txbuf, size_t n) |
Writes a value into a register using I2C. More... | |
static msg_t | hts221Calibrate (HTS221Driver *devp) |
Computes biases and sensitivities starting from data stored in calibration registers. More... | |
static size_t | hygro_get_axes_number (void *ip) |
Return the number of axes of the BaseHygrometer. More... | |
static msg_t | hygro_read_raw (void *ip, int32_t axes[]) |
Retrieves raw data from the BaseHygrometer. More... | |
static msg_t | hygro_read_cooked (void *ip, float axes[]) |
Retrieves cooked data from the BaseHygrometer. More... | |
static msg_t | hygro_set_bias (void *ip, float *bp) |
Set bias values for the BaseHygrometer. More... | |
static msg_t | hygro_reset_bias (void *ip) |
Reset bias values for the BaseHygrometer. More... | |
static msg_t | hygro_set_sensitivity (void *ip, float *sp) |
Set sensitivity values for the BaseHygrometer. More... | |
static msg_t | hygro_reset_sensitivity (void *ip) |
Reset sensitivity values for the BaseHygrometer. More... | |
static size_t | thermo_get_axes_number (void *ip) |
Return the number of axes of the BaseThermometer. More... | |
static msg_t | thermo_read_raw (void *ip, int32_t axes[]) |
Retrieves raw data from the BaseThermometer. More... | |
static msg_t | thermo_read_cooked (void *ip, float *axis) |
Retrieves cooked data from the BaseThermometer. More... | |
static msg_t | thermo_set_bias (void *ip, float *bp) |
Set bias values for the BaseThermometer. More... | |
static msg_t | thermo_reset_bias (void *ip) |
Reset bias values for the BaseThermometer. More... | |
static msg_t | thermo_set_sensitivity (void *ip, float *sp) |
Set sensitivity values for the BaseThermometer. More... | |
static msg_t | thermo_reset_sensitivity (void *ip) |
Reset sensitivity values for the BaseThermometer. More... | |
void | hts221ObjectInit (HTS221Driver *devp) |
Initializes an instance. More... | |
void | hts221Start (HTS221Driver *devp, const HTS221Config *config) |
Configures and activates HTS221 Complex Driver peripheral. More... | |
void | hts221Stop (HTS221Driver *devp) |
Deactivates the HTS221 Complex Driver peripheral. More... | |
Definition in file hts221.c.
