lsm6dsl.c File Reference
LSM6DSL MEMS interface module code. More...
#include "hal.h"
#include "lsm6dsl.h"
#define lsm6dslI2CWriteRegister(i2cp, sad, txbuf, n)
 Writes a value into a register using I2C. More...
msg_t lsm6dslI2CReadRegister (I2CDriver *i2cp, lsm6dsl_sad_t sad, uint8_t reg, uint8_t *rxbuf, size_t n)
 Reads registers value using I2C. More...
static size_t acc_get_axes_number (void *ip)
 Return the number of axes of the BaseAccelerometer. More...
static msg_t acc_read_raw (void *ip, int32_t axes[])
 Retrieves raw data from the BaseAccelerometer. More...
static msg_t acc_read_cooked (void *ip, float axes[])
 Retrieves cooked data from the BaseAccelerometer. More...
static msg_t acc_set_bias (void *ip, float *bp)
 Set bias values for the BaseAccelerometer. More...
static msg_t acc_reset_bias (void *ip)
 Reset bias values for the BaseAccelerometer. More...
static msg_t acc_set_sensivity (void *ip, float *sp)
 Set sensitivity values for the BaseAccelerometer. More...
static msg_t acc_reset_sensivity (void *ip)
 Reset sensitivity values for the BaseAccelerometer. More...
static msg_t acc_set_full_scale (LSM6DSLDriver *devp, lsm6dsl_acc_fs_t fs)
 Changes the LSM6DSLDriver accelerometer fullscale value. More...
static size_t gyro_get_axes_number (void *ip)
 Return the number of axes of the BaseGyroscope. More...
static msg_t gyro_read_raw (void *ip, int32_t axes[LSM6DSL_GYRO_NUMBER_OF_AXES])
 Retrieves raw data from the BaseGyroscope. More...
static msg_t gyro_read_cooked (void *ip, float axes[])
 Retrieves cooked data from the BaseGyroscope. More...
static msg_t gyro_sample_bias (void *ip)
 Samples bias values for the BaseGyroscope. More...
static msg_t gyro_set_bias (void *ip, float *bp)
 Set bias values for the BaseGyroscope. More...
static msg_t gyro_reset_bias (void *ip)
 Reset bias values for the BaseGyroscope. More...
static msg_t gyro_set_sensivity (void *ip, float *sp)
 Set sensitivity values for the BaseGyroscope. More...
static msg_t gyro_reset_sensivity (void *ip)
 Reset sensitivity values for the BaseGyroscope. More...
static msg_t gyro_set_full_scale (LSM6DSLDriver *devp, lsm6dsl_gyro_fs_t fs)
 Changes the LSM6DSLDriver gyroscope fullscale value. More...
void lsm6dslObjectInit (LSM6DSLDriver *devp)
 Initializes an instance. More...
void lsm6dslStart (LSM6DSLDriver *devp, const LSM6DSLConfig *config)
 Configures and activates LSM6DSL Complex Driver peripheral. More...
void lsm6dslStop (LSM6DSLDriver *devp)
 Deactivates the LSM6DSL Complex Driver peripheral. More...
Definition in file lsm6dsl.c.
