nil/templates/chconf.h File Reference
Configuration file template. More...
Kernel parameters and options
#define CH_CFG_NUM_THREADS   3
 Number of user threads in the application. More...
System timer settings
#define CH_CFG_ST_RESOLUTION   32
 System time counter resolution. More...
#define CH_CFG_ST_FREQUENCY   1000
 System tick frequency. More...
#define CH_CFG_ST_TIMEDELTA   0
 Time delta constant for the tick-less mode. More...
Subsystem options
#define CH_CFG_USE_SEMAPHORES   TRUE
 Semaphores APIs. More...
#define CH_CFG_USE_MUTEXES   FALSE
 Mutexes APIs. More...
#define CH_CFG_USE_EVENTS   TRUE
 Events Flags APIs. More...
#define CH_CFG_USE_MAILBOXES   TRUE
 Mailboxes APIs. More...
#define CH_CFG_USE_MEMCORE   TRUE
 Core Memory Manager APIs. More...
#define CH_CFG_USE_HEAP   TRUE
 Heap Allocator APIs. More...
#define CH_CFG_USE_MEMPOOLS   TRUE
 Memory Pools Allocator APIs. More...
#define CH_CFG_USE_OBJ_FIFOS   TRUE
 Objects FIFOs APIs. More...
#define CH_CFG_MEMCORE_SIZE   0
 Managed RAM size. More...
Objects factory options
#define CH_CFG_USE_FACTORY   TRUE
 Objects Factory APIs. More...
#define CH_CFG_FACTORY_MAX_NAMES_LENGTH   8
 Maximum length for object names. More...
#define CH_CFG_FACTORY_OBJECTS_REGISTRY   TRUE
 Enables the registry of generic objects. More...
#define CH_CFG_FACTORY_GENERIC_BUFFERS   TRUE
 Enables factory for generic buffers. More...
#define CH_CFG_FACTORY_SEMAPHORES   TRUE
 Enables factory for semaphores. More...
#define CH_CFG_FACTORY_MAILBOXES   TRUE
 Enables factory for mailboxes. More...
#define CH_CFG_FACTORY_OBJ_FIFOS   TRUE
 Enables factory for objects FIFOs. More...
Debug options
#define CH_DBG_STATISTICS   FALSE
 Debug option, kernel statistics. More...
#define CH_DBG_SYSTEM_STATE_CHECK   TRUE
 Debug option, system state check. More...
#define CH_DBG_ENABLE_CHECKS   TRUE
 Debug option, parameters checks. More...
#define CH_DBG_ENABLE_ASSERTS   TRUE
 System assertions. More...
#define CH_DBG_ENABLE_STACK_CHECK   TRUE
 Stack check. More...
Kernel hooks
#define CH_CFG_SYSTEM_INIT_HOOK()
 System initialization hook. More...
#define CH_CFG_THREAD_EXT_FIELDS   /* Add threads custom fields here.*/
 Threads descriptor structure extension. More...
#define CH_CFG_THREAD_EXT_INIT_HOOK(tr)
 Threads initialization hook. More...
#define CH_CFG_IDLE_ENTER_HOOK()
 Idle thread enter hook. More...
#define CH_CFG_IDLE_LEAVE_HOOK()
 Idle thread leave hook. More...
#define CH_CFG_SYSTEM_HALT_HOOK(reason)
 System halt hook. More...
A copy of this file must be placed in each project directory, it contains the application specific kernel settings.
Definition in file nil/templates/chconf.h.
