rt/templates/chconf.h
18  * @file rt/templates/chconf.h
19  * @brief Configuration file template.
20  * @details A copy of this file must be placed in each project directory, it
21  * contains the application specific kernel settings.
22  *
23  * @addtogroup config
24  * @details Kernel related settings and hooks.
25  * @{
26  */
28 #ifndef CHCONF_H
29 #define CHCONF_H
30
31 #define _CHIBIOS_RT_CONF_
32 #define _CHIBIOS_RT_CONF_VER_5_0_
35 /**
36  * @name System timers settings
37  * @{
38  */
41 /**
42  * @brief System time counter resolution.
43  * @note Allowed values are 16 or 32 bits.
44  */
45 #define CH_CFG_ST_RESOLUTION 32
46
47 /**
48  * @brief System tick frequency.
49  * @details Frequency of the system timer that drives the system ticks. This
50  * setting also defines the system tick time unit.
51  */
52 #define CH_CFG_ST_FREQUENCY 10000
53
54 /**
55  * @brief Time intervals data size.
56  * @note Allowed values are 16, 32 or 64 bits.
57  */
58 #define CH_CFG_INTERVALS_SIZE 32
59
60 /**
61  * @brief Time types data size.
62  * @note Allowed values are 16 or 32 bits.
63  */
64 #define CH_CFG_TIME_TYPES_SIZE 32
65
66 /**
67  * @brief Time delta constant for the tick-less mode.
68  * @note If this value is zero then the system uses the classic
69  * periodic tick. This value represents the minimum number
70  * of ticks that is safe to specify in a timeout directive.
71  * The value one is not valid, timeouts are rounded up to
72  * this value.
73  */
74 #define CH_CFG_ST_TIMEDELTA 2
75
76 /** @} */
77
78 /*===========================================================================*/
79 /**
80  * @name Kernel parameters and options
81  * @{
82  */
83 /*===========================================================================*/
84
85 /**
86  * @brief Round robin interval.
87  * @details This constant is the number of system ticks allowed for the
88  * threads before preemption occurs. Setting this value to zero
89  * disables the preemption for threads with equal priority and the
90  * round robin becomes cooperative. Note that higher priority
91  * threads can still preempt, the kernel is always preemptive.
92  * @note Disabling the round robin preemption makes the kernel more compact
93  * and generally faster.
94  * @note The round robin preemption is not supported in tickless mode and
95  * must be set to zero in that case.
96  */
97 #define CH_CFG_TIME_QUANTUM 0
98
99 /**
100  * @brief Managed RAM size.
101  * @details Size of the RAM area to be managed by the OS. If set to zero
102  * then the whole available RAM is used. The core memory is made
103  * available to the heap allocator and/or can be used directly through
104  * the simplified core memory allocator.
105  *
106  * @note In order to let the OS manage the whole RAM the linker script must
107  * provide the @p __heap_base__ and @p __heap_end__ symbols.
108  * @note Requires @p CH_CFG_USE_MEMCORE.
109  */
110 #define CH_CFG_MEMCORE_SIZE 0
111
112 /**
113  * @brief Idle thread automatic spawn suppression.
114  * @details When this option is activated the function @p chSysInit()
115  * does not spawn the idle thread. The application @p main()
116  * function becomes the idle thread and must implement an
117  * infinite loop.
118  */
119 #define CH_CFG_NO_IDLE_THREAD FALSE
120
121 /** @} */
122
123 /*===========================================================================*/
124 /**
125  * @name Performance options
126  * @{
127  */
128 /*===========================================================================*/
129
130 /**
131  * @brief OS optimization.
132  * @details If enabled then time efficient rather than space efficient code
133  * is used when two possible implementations exist.
134  *
135  * @note This is not related to the compiler optimization options.
136  * @note The default is @p TRUE.
137  */
138 #define CH_CFG_OPTIMIZE_SPEED TRUE
139
140 /** @} */
141
142 /*===========================================================================*/
143 /**
144  * @name Subsystem options
145  * @{
146  */
147 /*===========================================================================*/
148
149 /**
150  * @brief Time Measurement APIs.
151  * @details If enabled then the time measurement APIs are included in
152  * the kernel.
153  *
154  * @note The default is @p TRUE.
155  */
156 #define CH_CFG_USE_TM TRUE
157
158 /**
159  * @brief Threads registry APIs.
160  * @details If enabled then the registry APIs are included in the kernel.
161  *
162  * @note The default is @p TRUE.
163  */
164 #define CH_CFG_USE_REGISTRY TRUE
165
166 /**
167  * @brief Threads synchronization APIs.
168  * @details If enabled then the @p chThdWait() function is included in
169  * the kernel.
170  *
171  * @note The default is @p TRUE.
172  */
173 #define CH_CFG_USE_WAITEXIT TRUE
174
175 /**
176  * @brief Semaphores APIs.
177  * @details If enabled then the Semaphores APIs are included in the kernel.
178  *
179  * @note The default is @p TRUE.
180  */
181 #define CH_CFG_USE_SEMAPHORES TRUE
182
183 /**
184  * @brief Semaphores queuing mode.
185  * @details If enabled then the threads are enqueued on semaphores by
186  * priority rather than in FIFO order.
187  *
188  * @note The default is @p FALSE. Enable this if you have special
189  * requirements.
190  * @note Requires @p CH_CFG_USE_SEMAPHORES.
191  */
192 #define CH_CFG_USE_SEMAPHORES_PRIORITY FALSE
193
194 /**
195  * @brief Mutexes APIs.
196  * @details If enabled then the mutexes APIs are included in the kernel.
197  *
198  * @note The default is @p TRUE.
199  */
200 #define CH_CFG_USE_MUTEXES TRUE
201
202 /**
203  * @brief Enables recursive behavior on mutexes.
204  * @note Recursive mutexes are heavier and have an increased
205  * memory footprint.
206  *
207  * @note The default is @p FALSE.
208  * @note Requires @p CH_CFG_USE_MUTEXES.
209  */
210 #define CH_CFG_USE_MUTEXES_RECURSIVE FALSE
211
212 /**
213  * @brief Conditional Variables APIs.
214  * @details If enabled then the conditional variables APIs are included
215  * in the kernel.
216  *
217  * @note The default is @p TRUE.
218  * @note Requires @p CH_CFG_USE_MUTEXES.
219  */
220 #define CH_CFG_USE_CONDVARS TRUE
221
222 /**
223  * @brief Conditional Variables APIs with timeout.
224  * @details If enabled then the conditional variables APIs with timeout
225  * specification are included in the kernel.
226  *
227  * @note The default is @p TRUE.
228  * @note Requires @p CH_CFG_USE_CONDVARS.
229  */
230 #define CH_CFG_USE_CONDVARS_TIMEOUT TRUE
231
232 /**
233  * @brief Events Flags APIs.
234  * @details If enabled then the event flags APIs are included in the kernel.
235  *
236  * @note The default is @p TRUE.
237  */
238 #define CH_CFG_USE_EVENTS TRUE
239
240 /**
241  * @brief Events Flags APIs with timeout.
242  * @details If enabled then the events APIs with timeout specification
243  * are included in the kernel.
244  *
245  * @note The default is @p TRUE.
246  * @note Requires @p CH_CFG_USE_EVENTS.
247  */
248 #define CH_CFG_USE_EVENTS_TIMEOUT TRUE
249
250 /**
251  * @brief Synchronous Messages APIs.
252  * @details If enabled then the synchronous messages APIs are included
253  * in the kernel.
254  *
255  * @note The default is @p TRUE.
256  */
257 #define CH_CFG_USE_MESSAGES TRUE
258
259 /**
260  * @brief Synchronous Messages queuing mode.
261  * @details If enabled then messages are served by priority rather than in
262  * FIFO order.
263  *
264  * @note The default is @p FALSE. Enable this if you have special
265  * requirements.
266  * @note Requires @p CH_CFG_USE_MESSAGES.
267  */
268 #define CH_CFG_USE_MESSAGES_PRIORITY FALSE
269
270 /**
271  * @brief Mailboxes APIs.
272  * @details If enabled then the asynchronous messages (mailboxes) APIs are
273  * included in the kernel.
274  *
275  * @note The default is @p TRUE.
276  * @note Requires @p CH_CFG_USE_SEMAPHORES.
277  */
278 #define CH_CFG_USE_MAILBOXES TRUE
279
280 /**
281  * @brief Core Memory Manager APIs.
282  * @details If enabled then the core memory manager APIs are included
283  * in the kernel.
284  *
285  * @note The default is @p TRUE.
286  */
287 #define CH_CFG_USE_MEMCORE TRUE
288
289 /**
290  * @brief Heap Allocator APIs.
291  * @details If enabled then the memory heap allocator APIs are included
292  * in the kernel.
293  *
294  * @note The default is @p TRUE.
295  * @note Requires @p CH_CFG_USE_MEMCORE and either @p CH_CFG_USE_MUTEXES or
296  * @p CH_CFG_USE_SEMAPHORES.
297  * @note Mutexes are recommended.
298  */
299 #define CH_CFG_USE_HEAP TRUE
300
301 /**
302  * @brief Memory Pools Allocator APIs.
303  * @details If enabled then the memory pools allocator APIs are included
304  * in the kernel.
305  *
306  * @note The default is @p TRUE.
307  */
308 #define CH_CFG_USE_MEMPOOLS TRUE
309
310 /**
311  * @brief Objects FIFOs APIs.
312  * @details If enabled then the objects FIFOs APIs are included
313  * in the kernel.
314  *
315  * @note The default is @p TRUE.
316  */
317 #define CH_CFG_USE_OBJ_FIFOS TRUE
318
319 /**
320  * @brief Dynamic Threads APIs.
321  * @details If enabled then the dynamic threads creation APIs are included
322  * in the kernel.
323  *
324  * @note The default is @p TRUE.
325  * @note Requires @p CH_CFG_USE_WAITEXIT.
326  * @note Requires @p CH_CFG_USE_HEAP and/or @p CH_CFG_USE_MEMPOOLS.
327  */
328 #define CH_CFG_USE_DYNAMIC TRUE
329
330 /** @} */
331
332 /*===========================================================================*/
333 /**
334  * @name Objects factory options
335  * @{
336  */
337 /*===========================================================================*/
338
339 /**
340  * @brief Objects Factory APIs.
341  * @details If enabled then the objects factory APIs are included in the
342  * kernel.
343  *
344  * @note The default is @p FALSE.
345  */
346 #define CH_CFG_USE_FACTORY TRUE
347
348 /**
349  * @brief Maximum length for object names.
350  * @details If the specified length is zero then the name is stored by
351  * pointer but this could have unintended side effects.
352  */
353 #define CH_CFG_FACTORY_MAX_NAMES_LENGTH 8
354
355 /**
356  * @brief Enables the registry of generic objects.
357  */
358 #define CH_CFG_FACTORY_OBJECTS_REGISTRY TRUE
359
360 /**
361  * @brief Enables factory for generic buffers.
362  */
363 #define CH_CFG_FACTORY_GENERIC_BUFFERS TRUE
364
365 /**
366  * @brief Enables factory for semaphores.
367  */
368 #define CH_CFG_FACTORY_SEMAPHORES TRUE
369
370 /**
371  * @brief Enables factory for mailboxes.
372  */
373 #define CH_CFG_FACTORY_MAILBOXES TRUE
374
375 /**
376  * @brief Enables factory for objects FIFOs.
377  */
378 #define CH_CFG_FACTORY_OBJ_FIFOS TRUE
379
380 /** @} */
381
382 /*===========================================================================*/
383 /**
384  * @name Debug options
385  * @{
386  */
387 /*===========================================================================*/
388
389 /**
390  * @brief Debug option, kernel statistics.
391  *
392  * @note The default is @p FALSE.
393  */
394 #define CH_DBG_STATISTICS FALSE
395
396 /**
397  * @brief Debug option, system state check.
398  * @details If enabled the correct call protocol for system APIs is checked
399  * at runtime.
400  *
401  * @note The default is @p FALSE.
402  */
403 #define CH_DBG_SYSTEM_STATE_CHECK TRUE
404
405 /**
406  * @brief Debug option, parameters checks.
407  * @details If enabled then the checks on the API functions input
408  * parameters are activated.
409  *
410  * @note The default is @p FALSE.
411  */
412 #define CH_DBG_ENABLE_CHECKS TRUE
413
414 /**
415  * @brief Debug option, consistency checks.
416  * @details If enabled then all the assertions in the kernel code are
417  * activated. This includes consistency checks inside the kernel,
418  * runtime anomalies and port-defined checks.
419  *
420  * @note The default is @p FALSE.
421  */
422 #define CH_DBG_ENABLE_ASSERTS TRUE
423
424 /**
425  * @brief Debug option, trace buffer.
426  * @details If enabled then the trace buffer is activated.
427  *
428  * @note The default is @p CH_DBG_TRACE_MASK_DISABLED.
429  */
430 #define CH_DBG_TRACE_MASK CH_DBG_TRACE_MASK_ALL
431
432 /**
433  * @brief Trace buffer entries.
434  * @note The trace buffer is only allocated if @p CH_DBG_TRACE_MASK is
435  * different from @p CH_DBG_TRACE_MASK_DISABLED.
436  */
437 #define CH_DBG_TRACE_BUFFER_SIZE 128
438
439 /**
440  * @brief Debug option, stack checks.
441  * @details If enabled then a runtime stack check is performed.
442  *
443  * @note The default is @p FALSE.
444  * @note The stack check is performed in a architecture/port dependent way.
445  * It may not be implemented or some ports.
446  * @note The default failure mode is to halt the system with the global
447  * @p panic_msg variable set to @p NULL.
448  */
449 #define CH_DBG_ENABLE_STACK_CHECK TRUE
450
451 /**
452  * @brief Debug option, stacks initialization.
453  * @details If enabled then the threads working area is filled with a byte
454  * value when a thread is created. This can be useful for the
455  * runtime measurement of the used stack.
456  *
457  * @note The default is @p FALSE.
458  */
459 #define CH_DBG_FILL_THREADS TRUE
460
461 /**
462  * @brief Debug option, threads profiling.
463  * @details If enabled then a field is added to the @p thread_t structure that
464  * counts the system ticks occurred while executing the thread.
465  *
466  * @note The default is @p FALSE.
467  * @note This debug option is not currently compatible with the
468  * tickless mode.
469  */
470 #define CH_DBG_THREADS_PROFILING FALSE
471
472 /** @} */
473
474 /*===========================================================================*/
475 /**
476  * @name Kernel hooks
477  * @{
478  */
479 /*===========================================================================*/
480
481 /**
482  * @brief System structure extension.
483  * @details User fields added to the end of the @p ch_system_t structure.
484  */
485 #define CH_CFG_SYSTEM_EXTRA_FIELDS \
486  /* Add threads custom fields here.*/
487
488 /**
489  * @brief System initialization hook.
490  * @details User initialization code added to the @p chSysInit() function
491  * just before interrupts are enabled globally.
492  */
493 #define CH_CFG_SYSTEM_INIT_HOOK(tp) { \
494  /* Add threads initialization code here.*/ \
495 }
496
497 /**
498  * @brief Threads descriptor structure extension.
499  * @details User fields added to the end of the @p thread_t structure.
500  */
501 #define CH_CFG_THREAD_EXTRA_FIELDS \
502  /* Add threads custom fields here.*/
503
504 /**
505  * @brief Threads initialization hook.
506  * @details User initialization code added to the @p _thread_init() function.
507  *
508  * @note It is invoked from within @p _thread_init() and implicitly from all
509  * the threads creation APIs.
510  */
511 #define CH_CFG_THREAD_INIT_HOOK(tp) { \
512  /* Add threads initialization code here.*/ \
513 }
514
515 /**
516  * @brief Threads finalization hook.
517  * @details User finalization code added to the @p chThdExit() API.
518  */
519 #define CH_CFG_THREAD_EXIT_HOOK(tp) { \
520  /* Add threads finalization code here.*/ \
521 }
522
523 /**
524  * @brief Context switch hook.
525  * @details This hook is invoked just before switching between threads.
526  */
527 #define CH_CFG_CONTEXT_SWITCH_HOOK(ntp, otp) { \
528  /* Context switch code here.*/ \
529 }
530
531 /**
532  * @brief ISR enter hook.
533  */
534 #define CH_CFG_IRQ_PROLOGUE_HOOK() { \
535  /* IRQ prologue code here.*/ \
536 }
537
538 /**
539  * @brief ISR exit hook.
540  */
541 #define CH_CFG_IRQ_EPILOGUE_HOOK() { \
542  /* IRQ epilogue code here.*/ \
543 }
544
545 /**
546  * @brief Idle thread enter hook.
547  * @note This hook is invoked within a critical zone, no OS functions
548  * should be invoked from here.
549  * @note This macro can be used to activate a power saving mode.
550  */
551 #define CH_CFG_IDLE_ENTER_HOOK() { \
552  /* Idle-enter code here.*/ \
553 }
554
555 /**
556  * @brief Idle thread leave hook.
557  * @note This hook is invoked within a critical zone, no OS functions
558  * should be invoked from here.
559  * @note This macro can be used to deactivate a power saving mode.
560  */
561 #define CH_CFG_IDLE_LEAVE_HOOK() { \
562  /* Idle-leave code here.*/ \
563 }
564
565 /**
566  * @brief Idle Loop hook.
567  * @details This hook is continuously invoked by the idle thread loop.
568  */
569 #define CH_CFG_IDLE_LOOP_HOOK() { \
570  /* Idle loop code here.*/ \
571 }
572
573 /**
574  * @brief System tick event hook.
575  * @details This hook is invoked in the system tick handler immediately
576  * after processing the virtual timers queue.
577  */
578 #define CH_CFG_SYSTEM_TICK_HOOK() { \
579  /* System tick event code here.*/ \
580 }
581
582 /**
583  * @brief System halt hook.
584  * @details This hook is invoked in case to a system halting error before
585  * the system is halted.
586  */
587 #define CH_CFG_SYSTEM_HALT_HOOK(reason) { \
588  /* System halt code here.*/ \
589 }
590
591 /**
592  * @brief Trace hook.
593  * @details This hook is invoked each time a new record is written in the
594  * trace buffer.
595  */
596 #define CH_CFG_TRACE_HOOK(tep) { \
597  /* Trace code here.*/ \
598 }
599
600 /** @} */
601
602 /*===========================================================================*/
603 /* Port-specific settings (override port settings defaulted in chcore.h). */
604 /*===========================================================================*/
605
606 #endif /* CHCONF_H */
607
608 /** @} */
