Collaboration diagram for Options:
Kernel related settings and hooks.
System timers settings
#define CH_CFG_ST_RESOLUTION   32
 System time counter resolution. More...
#define CH_CFG_ST_FREQUENCY   10000
 System tick frequency. More...
#define CH_CFG_INTERVALS_SIZE   32
 Time intervals data size. More...
#define CH_CFG_TIME_TYPES_SIZE   32
 Time types data size. More...
#define CH_CFG_ST_TIMEDELTA   2
 Time delta constant for the tick-less mode. More...
Kernel parameters and options
#define CH_CFG_TIME_QUANTUM   0
 Round robin interval. More...
#define CH_CFG_MEMCORE_SIZE   0
 Managed RAM size. More...
#define CH_CFG_NO_IDLE_THREAD   FALSE
 Idle thread automatic spawn suppression. More...
Performance options
#define CH_CFG_OPTIMIZE_SPEED   TRUE
 OS optimization. More...
Subsystem options
#define CH_CFG_USE_TM   TRUE
 Time Measurement APIs. More...
#define CH_CFG_USE_REGISTRY   TRUE
 Threads registry APIs. More...
#define CH_CFG_USE_WAITEXIT   TRUE
 Threads synchronization APIs. More...
#define CH_CFG_USE_SEMAPHORES   TRUE
 Semaphores APIs. More...
#define CH_CFG_USE_SEMAPHORES_PRIORITY   FALSE
 Semaphores queuing mode. More...
#define CH_CFG_USE_MUTEXES   TRUE
 Mutexes APIs. More...
#define CH_CFG_USE_MUTEXES_RECURSIVE   FALSE
 Enables recursive behavior on mutexes. More...
#define CH_CFG_USE_CONDVARS   TRUE
 Conditional Variables APIs. More...
#define CH_CFG_USE_CONDVARS_TIMEOUT   TRUE
 Conditional Variables APIs with timeout. More...
#define CH_CFG_USE_EVENTS   TRUE
 Events Flags APIs. More...
#define CH_CFG_USE_EVENTS_TIMEOUT   TRUE
 Events Flags APIs with timeout. More...
#define CH_CFG_USE_MESSAGES   TRUE
 Synchronous Messages APIs. More...
#define CH_CFG_USE_MESSAGES_PRIORITY   FALSE
 Synchronous Messages queuing mode. More...
#define CH_CFG_USE_MAILBOXES   TRUE
 Mailboxes APIs. More...
#define CH_CFG_USE_MEMCORE   TRUE
 Core Memory Manager APIs. More...
#define CH_CFG_USE_HEAP   TRUE
 Heap Allocator APIs. More...
#define CH_CFG_USE_MEMPOOLS   TRUE
 Memory Pools Allocator APIs. More...
#define CH_CFG_USE_OBJ_FIFOS   TRUE
 Objects FIFOs APIs. More...
#define CH_CFG_USE_DYNAMIC   TRUE
 Dynamic Threads APIs. More...
Objects factory options
#define CH_CFG_USE_FACTORY   TRUE
 Objects Factory APIs. More...
#define CH_CFG_FACTORY_MAX_NAMES_LENGTH   8
 Maximum length for object names. More...
#define CH_CFG_FACTORY_OBJECTS_REGISTRY   TRUE
 Enables the registry of generic objects. More...
#define CH_CFG_FACTORY_GENERIC_BUFFERS   TRUE
 Enables factory for generic buffers. More...
#define CH_CFG_FACTORY_SEMAPHORES   TRUE
 Enables factory for semaphores. More...
#define CH_CFG_FACTORY_MAILBOXES   TRUE
 Enables factory for mailboxes. More...
#define CH_CFG_FACTORY_OBJ_FIFOS   TRUE
 Enables factory for objects FIFOs. More...
Debug options
#define CH_DBG_STATISTICS   FALSE
 Debug option, kernel statistics. More...
#define CH_DBG_SYSTEM_STATE_CHECK   TRUE
 Debug option, system state check. More...
#define CH_DBG_ENABLE_CHECKS   TRUE
 Debug option, parameters checks. More...
#define CH_DBG_ENABLE_ASSERTS   TRUE
 Debug option, consistency checks. More...
#define CH_DBG_TRACE_MASK   CH_DBG_TRACE_MASK_ALL
 Debug option, trace buffer. More...
#define CH_DBG_TRACE_BUFFER_SIZE   128
 Trace buffer entries. More...
#define CH_DBG_ENABLE_STACK_CHECK   TRUE
 Debug option, stack checks. More...
#define CH_DBG_FILL_THREADS   TRUE
 Debug option, stacks initialization. More...
#define CH_DBG_THREADS_PROFILING   FALSE
 Debug option, threads profiling. More...
Kernel hooks
#define CH_CFG_SYSTEM_EXTRA_FIELDS   /* Add threads custom fields here.*/
 System structure extension. More...
#define CH_CFG_SYSTEM_INIT_HOOK(tp)
 System initialization hook. More...
#define CH_CFG_THREAD_EXTRA_FIELDS   /* Add threads custom fields here.*/
 Threads descriptor structure extension. More...
#define CH_CFG_THREAD_INIT_HOOK(tp)
 Threads initialization hook. More...
#define CH_CFG_THREAD_EXIT_HOOK(tp)
 Threads finalization hook. More...
#define CH_CFG_CONTEXT_SWITCH_HOOK(ntp, otp)
 Context switch hook. More...
#define CH_CFG_IRQ_PROLOGUE_HOOK()
 ISR enter hook. More...
#define CH_CFG_IRQ_EPILOGUE_HOOK()
 ISR exit hook. More...
#define CH_CFG_IDLE_ENTER_HOOK()
 Idle thread enter hook. More...
#define CH_CFG_IDLE_LEAVE_HOOK()
 Idle thread leave hook. More...
#define CH_CFG_IDLE_LOOP_HOOK()
 Idle Loop hook. More...
#define CH_CFG_SYSTEM_TICK_HOOK()
 System tick event hook. More...
#define CH_CFG_SYSTEM_HALT_HOOK(reason)
 System halt hook. More...
#define CH_CFG_TRACE_HOOK(tep)
 Trace hook. More...
Allowed values are 16 or 32 bits.
Definition at line 45 of file rt/templates/chconf.h.
Frequency of the system timer that drives the system ticks. This setting also defines the system tick time unit.
Definition at line 52 of file rt/templates/chconf.h.
Referenced by chTimeI2MS(), chTimeI2S(), chTimeI2US(), chTimeMS2I(), chTimeS2I(), and chTimeUS2I().
Allowed values are 16, 32 or 64 bits.
Definition at line 58 of file rt/templates/chconf.h.
Definition at line 64 of file rt/templates/chconf.h.
If this value is zero then the system uses the classic periodic tick. This value represents the minimum number of ticks that is safe to specify in a timeout directive. The value one is not valid, timeouts are rounded up to this value.
Definition at line 74 of file rt/templates/chconf.h.
This constant is the number of system ticks allowed for the threads before preemption occurs. Setting this value to zero disables the preemption for threads with equal priority and the round robin becomes cooperative. Note that higher priority threads can still preempt, the kernel is always preemptive.
Disabling the round robin preemption makes the kernel more compact and generally faster.
The round robin preemption is not supported in tickless mode and must be set to zero in that case.
Definition at line 97 of file rt/templates/chconf.h.
Referenced by _thread_init(), chSchDoReschedule(), chSchDoRescheduleBehind(), and chSchGoSleepS().
Managed RAM size.
Size of the RAM area to be managed by the OS. If set to zero then the whole available RAM is used. The core memory is made available to the heap allocator and/or can be used directly through the simplified core memory allocator.
In order to let the OS manage the whole RAM the linker script must provide the heap_base and heap_end symbols.
Requires CH_CFG_USE_MEMCORE.
Definition at line 110 of file rt/templates/chconf.h.
Referenced by _core_init().
When this option is activated the function chSysInit() does not spawn the idle thread. The application main() function becomes the idle thread and must implement an infinite loop.
Definition at line 119 of file rt/templates/chconf.h.
OS optimization.
If enabled then time efficient rather than space efficient code is used when two possible implementations exist.
This is not related to the compiler optimization options.
The default is TRUE.
Definition at line 138 of file rt/templates/chconf.h.
If enabled then the time measurement APIs are included in the kernel.
Definition at line 156 of file rt/templates/chconf.h.
If enabled then the registry APIs are included in the kernel.
Definition at line 164 of file rt/templates/chconf.h.
If enabled then the chThdWait() function is included in the kernel.
Definition at line 173 of file rt/templates/chconf.h.
Semaphores APIs.
If enabled then the Semaphores APIs are included in the kernel.
Definition at line 181 of file rt/templates/chconf.h.
If enabled then the threads are enqueued on semaphores by priority rather than in FIFO order.
The default is FALSE. Enable this if you have special requirements.
Requires CH_CFG_USE_SEMAPHORES.
Definition at line 192 of file rt/templates/chconf.h.
Mutexes APIs.
If enabled then the mutexes APIs are included in the kernel.
Definition at line 200 of file rt/templates/chconf.h.
Recursive mutexes are heavier and have an increased memory footprint.
Requires CH_CFG_USE_MUTEXES.
Definition at line 210 of file rt/templates/chconf.h.
If enabled then the conditional variables APIs are included in the kernel.
Definition at line 220 of file rt/templates/chconf.h.
If enabled then the conditional variables APIs with timeout specification are included in the kernel.
Requires CH_CFG_USE_CONDVARS.
Definition at line 230 of file rt/templates/chconf.h.
Events Flags APIs.
If enabled then the event flags APIs are included in the kernel.
Definition at line 238 of file rt/templates/chconf.h.
If enabled then the events APIs with timeout specification are included in the kernel.
Requires CH_CFG_USE_EVENTS.
Definition at line 248 of file rt/templates/chconf.h.
If enabled then the synchronous messages APIs are included in the kernel.
Definition at line 257 of file rt/templates/chconf.h.
If enabled then messages are served by priority rather than in FIFO order.
Requires CH_CFG_USE_MESSAGES.
Definition at line 268 of file rt/templates/chconf.h.
Mailboxes APIs.
If enabled then the asynchronous messages (mailboxes) APIs are included in the kernel.
Definition at line 278 of file rt/templates/chconf.h.
If enabled then the core memory manager APIs are included in the kernel.
Definition at line 287 of file rt/templates/chconf.h.
If enabled then the memory heap allocator APIs are included in the kernel.
Requires CH_CFG_USE_MEMCORE and either CH_CFG_USE_MUTEXES or CH_CFG_USE_SEMAPHORES.
Mutexes are recommended.
Definition at line 299 of file rt/templates/chconf.h.
If enabled then the memory pools allocator APIs are included in the kernel.
Definition at line 308 of file rt/templates/chconf.h.
Objects FIFOs APIs.
If enabled then the objects FIFOs APIs are included in the kernel.
Definition at line 317 of file rt/templates/chconf.h.
If enabled then the dynamic threads creation APIs are included in the kernel.
Requires CH_CFG_USE_WAITEXIT.
Requires CH_CFG_USE_HEAP and/or CH_CFG_USE_MEMPOOLS.
Definition at line 328 of file rt/templates/chconf.h.
If enabled then the objects factory APIs are included in the kernel.
Definition at line 346 of file rt/templates/chconf.h.
If the specified length is zero then the name is stored by pointer but this could have unintended side effects.
Definition at line 353 of file rt/templates/chconf.h.
Definition at line 358 of file rt/templates/chconf.h.
Definition at line 363 of file rt/templates/chconf.h.
Definition at line 368 of file rt/templates/chconf.h.
Definition at line 373 of file rt/templates/chconf.h.
Definition at line 378 of file rt/templates/chconf.h.
Definition at line 394 of file rt/templates/chconf.h.
If enabled the correct call protocol for system APIs is checked at runtime.
Definition at line 403 of file rt/templates/chconf.h.
If enabled then the checks on the API functions input parameters are activated.
Definition at line 412 of file rt/templates/chconf.h.
If enabled then all the assertions in the kernel code are activated. This includes consistency checks inside the kernel, runtime anomalies and port-defined checks.
Definition at line 422 of file rt/templates/chconf.h.
If enabled then the trace buffer is activated.
The default is CH_DBG_TRACE_MASK_DISABLED.
Definition at line 430 of file rt/templates/chconf.h.
The trace buffer is only allocated if CH_DBG_TRACE_MASK is different from CH_DBG_TRACE_MASK_DISABLED.
Definition at line 437 of file rt/templates/chconf.h.
If enabled then a runtime stack check is performed.
The stack check is performed in a architecture/port dependent way. It may not be implemented or some ports.
The default failure mode is to halt the system with the global panic_msg variable set to NULL.
Definition at line 449 of file rt/templates/chconf.h.
If enabled then the threads working area is filled with a byte value when a thread is created. This can be useful for the runtime measurement of the used stack.
Definition at line 459 of file rt/templates/chconf.h.
If enabled then a field is added to the thread_t structure that counts the system ticks occurred while executing the thread.
This debug option is not currently compatible with the tickless mode.
Definition at line 470 of file rt/templates/chconf.h.
User fields added to the end of the ch_system_t structure.
Definition at line 485 of file rt/templates/chconf.h.
#define CH_CFG_SYSTEM_INIT_HOOK (   tp)
Value:
/* Add threads initialization code here.*/ \
User initialization code added to the chSysInit() function just before interrupts are enabled globally.
Definition at line 493 of file rt/templates/chconf.h.
Referenced by chSysInit().
User fields added to the end of the thread_t structure.
Definition at line 501 of file rt/templates/chconf.h.
#define CH_CFG_THREAD_INIT_HOOK (   tp)
Value:
User initialization code added to the _thread_init() function.
It is invoked from within _thread_init() and implicitly from all the threads creation APIs.
Definition at line 511 of file rt/templates/chconf.h.
Referenced by _thread_init().
#define CH_CFG_THREAD_EXIT_HOOK (   tp)
Value:
/* Add threads finalization code here.*/ \
User finalization code added to the chThdExit() API.
Definition at line 519 of file rt/templates/chconf.h.
Referenced by chThdExitS().
#define CH_CFG_CONTEXT_SWITCH_HOOK (   ntp,
  otp
Value:
/* Context switch code here.*/ \
This hook is invoked just before switching between threads.
Definition at line 527 of file rt/templates/chconf.h.
#define CH_CFG_IRQ_PROLOGUE_HOOK ( )
Value:
/* IRQ prologue code here.*/ \
ISR enter hook.
Definition at line 534 of file rt/templates/chconf.h.
#define CH_CFG_IRQ_EPILOGUE_HOOK ( )
Value:
/* IRQ epilogue code here.*/ \
ISR exit hook.
Definition at line 541 of file rt/templates/chconf.h.
#define CH_CFG_IDLE_ENTER_HOOK ( )
Value:
/* Idle-enter code here.*/ \
This hook is invoked within a critical zone, no OS functions should be invoked from here.
This macro can be used to activate a power saving mode.
Definition at line 551 of file rt/templates/chconf.h.
Referenced by chSchGoSleepS(), and chSchGoSleepTimeoutS().
#define CH_CFG_IDLE_LEAVE_HOOK ( )
Value:
/* Idle-leave code here.*/ \
This macro can be used to deactivate a power saving mode.
Definition at line 561 of file rt/templates/chconf.h.
Referenced by chSchDoReschedule(), chSchDoRescheduleAhead(), chSchDoRescheduleBehind(), and chSchWakeupS().
#define CH_CFG_IDLE_LOOP_HOOK ( )
Value:
/* Idle loop code here.*/ \
Idle Loop hook.
This hook is continuously invoked by the idle thread loop.
Definition at line 569 of file rt/templates/chconf.h.
Referenced by _idle_thread().
#define CH_CFG_SYSTEM_TICK_HOOK ( )
Value:
/* System tick event code here.*/ \
This hook is invoked in the system tick handler immediately after processing the virtual timers queue.
Definition at line 578 of file rt/templates/chconf.h.
Referenced by chSysTimerHandlerI().
#define CH_CFG_SYSTEM_HALT_HOOK (   reason)
Value:
/* System halt code here.*/ \
System halt hook.
This hook is invoked in case to a system halting error before the system is halted.
Definition at line 587 of file rt/templates/chconf.h.
Referenced by chSysHalt().
#define CH_CFG_TRACE_HOOK (   tep)
Value:
/* Trace code here.*/ \
Trace hook.
This hook is invoked each time a new record is written in the trace buffer.
Definition at line 596 of file rt/templates/chconf.h.
Referenced by trace_next().
