Scheduler macros and structures. More...
struct | ch_threads_list |
Generic threads single link list, it works like a stack. More... | |
struct | ch_threads_queue |
Generic threads bidirectional linked list header and element. More... | |
struct | ch_thread |
Structure representing a thread. More... | |
struct | ch_virtual_timer |
Virtual Timer descriptor structure. More... | |
struct | ch_virtual_timers_list |
Virtual timers list header. More... | |
struct | ch_system_debug |
System debug data structure. More... | |
struct | ch_system |
System data structure. More... | |
#define | firstprio(rlp) ((rlp)->next->prio) |
Returns the priority of the first thread on the given ready list. More... | |
#define | currp ch.rlist.current |
Current thread pointer access macro. More... | |
Wakeup status codes | |
#define | MSG_OK (msg_t)0 |
Normal wakeup message. More... | |
#define | MSG_TIMEOUT (msg_t)-1 |
Wakeup caused by a timeout condition. More... | |
#define | MSG_RESET (msg_t)-2 |
Wakeup caused by a reset condition. More... | |
Priority constants | |
#define | NOPRIO (tprio_t)0 |
Ready list header priority. More... | |
#define | IDLEPRIO (tprio_t)1 |
Idle priority. More... | |
#define | LOWPRIO (tprio_t)2 |
Lowest priority. More... | |
#define | NORMALPRIO (tprio_t)128 |
Normal priority. More... | |
#define | HIGHPRIO (tprio_t)255 |
Highest priority. More... | |
Thread states | |
#define | CH_STATE_READY (tstate_t)0 |
Waiting on the ready list. More... | |
#define | CH_STATE_CURRENT (tstate_t)1 |
Currently running. More... | |
#define | CH_STATE_WTSTART (tstate_t)2 |
Just created. More... | |
#define | CH_STATE_SUSPENDED (tstate_t)3 |
Suspended state. More... | |
#define | CH_STATE_QUEUED (tstate_t)4 |
On an I/O queue. More... | |
#define | CH_STATE_WTSEM (tstate_t)5 |
On a semaphore. More... | |
#define | CH_STATE_WTMTX (tstate_t)6 |
On a mutex. More... | |
#define | CH_STATE_WTCOND (tstate_t)7 |
On a cond.variable. More... | |
#define | CH_STATE_SLEEPING (tstate_t)8 |
Sleeping. More... | |
#define | CH_STATE_WTEXIT (tstate_t)9 |
Waiting a thread. More... | |
#define | CH_STATE_WTOREVT (tstate_t)10 |
One event. More... | |
#define | CH_STATE_WTANDEVT (tstate_t)11 |
Several events. More... | |
#define | CH_STATE_SNDMSGQ (tstate_t)12 |
Sending a message, in queue. More... | |
#define | CH_STATE_SNDMSG (tstate_t)13 |
Sent a message, waiting answer. More... | |
#define | CH_STATE_WTMSG (tstate_t)14 |
Waiting for a message. More... | |
#define | CH_STATE_FINAL (tstate_t)15 |
Thread terminated. More... | |
#define | CH_STATE_NAMES |
Thread states as array of strings. More... | |
Thread flags and attributes | |
#define | CH_FLAG_MODE_MASK (tmode_t)3U |
Thread memory mode mask. More... | |
#define | CH_FLAG_MODE_STATIC (tmode_t)0U |
Static thread. More... | |
#define | CH_FLAG_MODE_HEAP (tmode_t)1U |
Thread allocated from a Memory Heap. More... | |
#define | CH_FLAG_MODE_MPOOL (tmode_t)2U |
Thread allocated from a Memory Pool. More... | |
#define | CH_FLAG_TERMINATE (tmode_t)4U |
Termination requested flag. More... | |
void | _scheduler_init (void) |
Scheduler initialization. More... | |
thread_t * | chSchReadyI (thread_t *tp) |
Inserts a thread in the Ready List placing it behind its peers. More... | |
thread_t * | chSchReadyAheadI (thread_t *tp) |
Inserts a thread in the Ready List placing it ahead its peers. More... | |
void | chSchGoSleepS (tstate_t newstate) |
Puts the current thread to sleep into the specified state. More... | |
msg_t | chSchGoSleepTimeoutS (tstate_t newstate, sysinterval_t timeout) |
Puts the current thread to sleep into the specified state with timeout specification. More... | |
void | chSchWakeupS (thread_t *ntp, msg_t msg) |
Wakes up a thread. More... | |
void | chSchRescheduleS (void) |
Performs a reschedule if a higher priority thread is runnable. More... | |
bool | chSchIsPreemptionRequired (void) |
Evaluates if preemption is required. More... | |
void | chSchDoRescheduleBehind (void) |
Switches to the first thread on the runnable queue. More... | |
void | chSchDoRescheduleAhead (void) |
void | chSchDoReschedule (void) |
void | queue_prio_insert (thread_t *tp, threads_queue_t *tqp) |
Inserts a thread into a priority ordered queue. More... | |
void | queue_insert (thread_t *tp, threads_queue_t *tqp) |
Inserts a thread into a queue. More... | |
thread_t * | queue_fifo_remove (threads_queue_t *tqp) |
Removes the first-out thread from a queue and returns it. More... | |
thread_t * | queue_lifo_remove (threads_queue_t *tqp) |
Removes the last-out thread from a queue and returns it. More... | |
thread_t * | queue_dequeue (thread_t *tp) |
Removes a thread from a queue and returns it. More... | |
void | list_insert (thread_t *tp, threads_list_t *tlp) |
Pushes a thread_t on top of a stack list. More... | |
thread_t * | list_remove (threads_list_t *tlp) |
Pops a thread from the top of a stack list and returns it. More... | |
static void | list_init (threads_list_t *tlp) |
Threads list initialization. More... | |
static bool | list_isempty (threads_list_t *tlp) |
Evaluates to true if the specified threads list is empty. More... | |
static bool | list_notempty (threads_list_t *tlp) |
Evaluates to true if the specified threads list is not empty. More... | |
static void | queue_init (threads_queue_t *tqp) |
Threads queue initialization. More... | |
static bool | queue_isempty (const threads_queue_t *tqp) |
Evaluates to true if the specified threads queue is empty. More... | |
static bool | queue_notempty (const threads_queue_t *tqp) |
Evaluates to true if the specified threads queue is not empty. More... | |
static bool | chSchIsRescRequiredI (void) |
Determines if the current thread must reschedule. More... | |
static bool | chSchCanYieldS (void) |
Determines if yielding is possible. More... | |
static void | chSchDoYieldS (void) |
Yields the time slot. More... | |
static void | chSchPreemption (void) |
Inline-able preemption code. More... | |
Definition in file chschd.h.
