Time and Intervals
Collaboration diagram for Time and Intervals:
This module is responsible for handling of system time and time intervals.
Special time constants
#define TIME_IMMEDIATE   ((sysinterval_t)0)
 Zero interval specification for some functions with a timeout specification. More...
#define TIME_INFINITE   ((sysinterval_t)-1)
 Infinite interval specification for all functions with a timeout specification. More...
#define TIME_MAX_INTERVAL   ((sysinterval_t)-2)
 Maximum interval constant usable as timeout. More...
#define TIME_MAX_SYSTIME   ((systime_t)-1)
 Maximum system of system time before it wraps. More...
Fast time conversion utilities
#define TIME_S2I(secs)   ((sysinterval_t)((time_conv_t)(secs) * (time_conv_t)CH_CFG_ST_FREQUENCY))
 Seconds to time interval. More...
#define TIME_MS2I(msecs)
 Milliseconds to time interval. More...
#define TIME_US2I(usecs)
 Microseconds to time interval. More...
#define TIME_I2S(interval)
 Time interval to seconds. More...
#define TIME_I2MS(interval)
 Time interval to milliseconds. More...
#define TIME_I2US(interval)
 Time interval to microseconds. More...
Secure time conversion utilities
static sysinterval_t chTimeS2I (time_secs_t secs)
static sysinterval_t chTimeMS2I (time_msecs_t msec)
static sysinterval_t chTimeUS2I (time_usecs_t usec)
static time_secs_t chTimeI2S (sysinterval_t interval)
static time_msecs_t chTimeI2MS (sysinterval_t interval)
static time_usecs_t chTimeI2US (sysinterval_t interval)
static systime_t chTimeAddX (systime_t systime, sysinterval_t interval)
 Adds an interval to a system time returning a system time. More...
static sysinterval_t chTimeDiffX (systime_t start, systime_t end)
 Subtracts two system times returning an interval. More...
static bool chTimeIsInRangeX (systime_t time, systime_t start, systime_t end)
 Checks if the specified time is within the specified time range. More...
typedef uint64_t systime_t
 Type of system time. More...
typedef uint64_t sysinterval_t
 Type of time interval. More...
typedef uint32_t time_secs_t
 Type of seconds. More...
typedef uint32_t time_msecs_t
 Type of milliseconds. More...
typedef uint32_t time_usecs_t
 Type of microseconds. More...
typedef uint64_t time_conv_t
 Type of time conversion variable. More...
Not all functions accept TIME_IMMEDIATE as timeout parameter, see the specific function documentation.
Definition at line 47 of file chtime.h.
Referenced by chCondWaitTimeoutS(), chEvtWaitAllTimeout(), chEvtWaitAnyTimeout(), chEvtWaitOneTimeout(), chFifoSendObject(), chFifoSendObjectS(), chSemWaitTimeoutS(), chThdEnqueueTimeoutS(), chThdSleepS(), chThdSuspendTimeoutS(), chVTDoSetI(), i2cMasterReceiveTimeout(), i2cMasterTransmitTimeout(), ibqReadTimeout(), and obqWriteTimeout().
Definition at line 60 of file chtime.h.
Referenced by chTimeMS2I(), chTimeS2I(), and chTimeUS2I().
Definition at line 65 of file chtime.h.
Referenced by chVTDoResetI(), chVTDoSetI(), and chVTDoTickI().
#define TIME_S2I (   secs)    ((sysinterval_t)((time_conv_t)(secs) * (time_conv_t)CH_CFG_ST_FREQUENCY))
Converts from seconds to system ticks number.
The result is rounded upward to the next tick boundary.
Use of this macro for large values is not secure because integer overflows, make sure your value can be correctly converted.
Parameters
[in]secsnumber of seconds
Returns
The number of ticks.
Definition at line 181 of file chtime.h.
#define TIME_MS2I (   msecs)
Value:
((sysinterval_t)((((time_conv_t)(msecs) * \
(time_conv_t)999) / (time_conv_t)1000))
Definition: chtime.h:119
Definition: chtime.h:150
#define CH_CFG_ST_FREQUENCY
System tick frequency.
Converts from milliseconds to system ticks number.
Parameters
[in]msecsnumber of milliseconds
Returns
Definition at line 197 of file chtime.h.
#define TIME_US2I (   usecs)
Value:
((sysinterval_t)((((time_conv_t)(usecs) * \
(time_conv_t)999999) / (time_conv_t)1000000))
Converts from microseconds to system ticks number.
Parameters
[in]usecsnumber of microseconds
Returns
Definition at line 215 of file chtime.h.
#define TIME_I2S (   interval)
Value:
(time_secs_t)(((time_conv_t)(interval) + \
Type of seconds.
Definition: chtime.h:131
Converts from system ticks number to seconds.
The result is rounded up to the next second boundary.
Parameters
[in]intervalinterval in ticks
Returns
The number of seconds.
Definition at line 233 of file chtime.h.
#define TIME_I2MS (   interval)
Value:
(time_msecs_t)((((time_conv_t)(interval) * (time_conv_t)1000) + \
Definition: chtime.h:137
Converts from system ticks number to milliseconds.
The result is rounded up to the next millisecond boundary.
Parameters
Returns
The number of milliseconds.
Definition at line 251 of file chtime.h.
#define TIME_I2US (   interval)
Value:
(time_msecs_t)((((time_conv_t)(interval) * (time_conv_t)1000000) + \
Converts from system ticks number to microseconds.
The result is rounded up to the next microsecond boundary.
Parameters
Returns
The number of microseconds.
Definition at line 269 of file chtime.h.
Typedef Documentation
It is selectable in configuration between 16, 32 or 64 bits.
Definition at line 107 of file chtime.h.
Definition at line 119 of file chtime.h.
Type of seconds.
It is selectable in configuration between 16 or 32 bits.
Definition at line 131 of file chtime.h.
Definition at line 137 of file chtime.h.
Definition at line 143 of file chtime.h.
This type must have double width than other time types, it is only used internally for conversions.
Definition at line 150 of file chtime.h.
Function Documentation
static sysinterval_t chTimeS2I ( time_secs_t  secs)
inlinestatic
Parameters
Returns
Function Class:Special function, this function has special requirements see the notes.
Definition at line 308 of file chtime.h.
References CH_CFG_ST_FREQUENCY, chDbgAssert, and TIME_MAX_INTERVAL.
static sysinterval_t chTimeMS2I ( time_msecs_t  msec)
inlinestatic
Parameters
[in]msecnumber of milliseconds
Returns
Definition at line 329 of file chtime.h.
static sysinterval_t chTimeUS2I ( time_usecs_t  usec)
inlinestatic
Parameters
[in]usecnumber of microseconds
Returns
Definition at line 351 of file chtime.h.
static time_secs_t chTimeI2S ( sysinterval_t  interval)
inlinestatic
Converts from system interval to seconds.
Parameters
Returns
Definition at line 373 of file chtime.h.
References CH_CFG_ST_FREQUENCY, and chDbgAssert.
static time_msecs_t chTimeI2MS ( sysinterval_t  interval)
inlinestatic
Converts from system interval to milliseconds.
Parameters
Returns
Definition at line 396 of file chtime.h.
static time_usecs_t chTimeI2US ( sysinterval_t  interval)
inlinestatic
Converts from system interval to microseconds.
Parameters
Returns
Definition at line 419 of file chtime.h.
static systime_t chTimeAddX ( systime_t  systime,
inlinestatic
Parameters
[in]systimebase system time
[in]intervalinterval to be added
Returns
The new system time.
Function Class:This is an X-Class API, this function can be invoked from any context.
Definition at line 441 of file chtime.h.
References chDbgCheck.
static sysinterval_t chTimeDiffX ( systime_t  start,
systime_t  end
inlinestatic
Parameters
[in]startfirst system time
[in]endsecond system time
Returns
The interval representing the time difference.
Definition at line 460 of file chtime.h.
static bool chTimeIsInRangeX ( systime_t  time,
systime_t  start,
systime_t  end
inlinestatic
When start==end then the function returns always true because the whole time range is specified.
Parameters
[in]timethe time to be verified
[in]startthe start of the time window (inclusive)
[in]endthe end of the time window (non inclusive)
Return values
truecurrent time within the specified time window.
falsecurrent time not within the specified time window.
Definition at line 481 of file chtime.h.
