EXT Driver
Generic EXT Driver. More...
Collaboration diagram for EXT Driver:
Generic EXT Driver.
This module implements a generic EXT (EXTernal) driver.
Precondition
In order to use the EXT driver the HAL_USE_EXT option must be enabled in halconf.h.
Driver State Machine
The driver implements a state machine internally, not all the driver functionalities can be used in any moment, any transition not explicitly shown in the following diagram has to be considered an error and shall be captured by an assertion (if enabled).
EXT Operations.
This driver abstracts generic external interrupt sources, a callback is invoked when a programmable transition is detected on one of the configured channels. Several channel modes are possible.
#define EXT_MAX_CHANNELS   20
 Available number of EXT channels. More...
EXT channel modes
#define EXT_CH_MODE_EDGES_MASK   3U
 Mask of edges field. More...
#define EXT_CH_MODE_DISABLED   0U
 Channel disabled. More...
#define EXT_CH_MODE_RISING_EDGE   1U
 Rising edge callback. More...
#define EXT_CH_MODE_FALLING_EDGE   2U
 Falling edge callback. More...
#define EXT_CH_MODE_BOTH_EDGES   3U
 Both edges callback. More...
#define EXT_CH_MODE_LOW_LEVEL   5U
 low level callback. More...
#define EXT_CH_MODE_AUTOSTART   4U
 Channel started automatically on driver start. More...
Macro Functions
#define extChannelEnableI(extp, channel)   ext_lld_channel_enable(extp, channel)
 Enables an EXT channel. More...
#define extChannelDisableI(extp, channel)   ext_lld_channel_disable(extp, channel)
 Disables an EXT channel. More...
#define extSetChannelMode(extp, channel, extcp)
 Changes the operation mode of a channel. More...
PLATFORM configuration options
#define PLATFORM_EXT_USE_EXT1   FALSE
 EXT driver enable switch. More...
typedef struct EXTDriver EXTDriver
 Type of a structure representing a EXT driver. More...
typedef uint32_t expchannel_t
 EXT channel identifier. More...
typedef void(* extcallback_t) (EXTDriver *extp, expchannel_t channel)
 Type of an EXT generic notification callback. More...
struct  EXTChannelConfig
 Channel configuration structure. More...
struct  EXTConfig
 Driver configuration structure. More...
struct  EXTDriver
 Structure representing an EXT driver. More...
void extInit (void)
 EXT Driver initialization. More...
void extObjectInit (EXTDriver *extp)
 Initializes the standard part of a EXTDriver structure. More...
void extStart (EXTDriver *extp, const EXTConfig *config)
 Configures and activates the EXT peripheral. More...
void extStop (EXTDriver *extp)
 Deactivates the EXT peripheral. More...
void extChannelEnable (EXTDriver *extp, expchannel_t channel)
void extChannelDisable (EXTDriver *extp, expchannel_t channel)
void extSetChannelModeI (EXTDriver *extp, expchannel_t channel, const EXTChannelConfig *extcp)
void ext_lld_init (void)
 Low level EXT driver initialization. More...
void ext_lld_start (EXTDriver *extp)
void ext_lld_stop (EXTDriver *extp)
void ext_lld_channel_enable (EXTDriver *extp, expchannel_t channel)
void ext_lld_channel_disable (EXTDriver *extp, expchannel_t channel)
Enumerations
Variables
EXTDriver EXTD1
 EXT1 driver identifier. More...
Definition at line 38 of file hal_ext.h.
Referenced by extChannelDisable(), and extChannelEnable().
Channel disabled.
Definition at line 39 of file hal_ext.h.
Definition at line 40 of file hal_ext.h.
Definition at line 41 of file hal_ext.h.
Definition at line 42 of file hal_ext.h.
low level callback.
Definition at line 43 of file hal_ext.h.
Definition at line 45 of file hal_ext.h.
#define extChannelEnableI (   extp,
  channel
Parameters
[in]extppointer to the EXTDriver object
[in]channelchannel to be enabled
Function Class:This is an I-Class API, this function can be invoked from within a system lock zone by both threads and interrupt handlers.
Definition at line 94 of file hal_ext.h.
Referenced by extChannelEnable().
#define extChannelDisableI (   extp,
  channel
Parameters
[in]channelchannel to be disabled
Definition at line 104 of file hal_ext.h.
Referenced by extChannelDisable().
#define extSetChannelMode (   extp,
  channel,
  extcp
Value:
extSetChannelModeI(extp, channel, extcp); \
Definition: osal.h:540
static void osalSysLock(void)
Definition: osal.h:530
void extSetChannelModeI(EXTDriver *extp, expchannel_t channel, const EXTChannelConfig *extcp)
Definition: hal_ext.c:181
This function attempts to write over the current configuration structure that must have been not declared constant. This violates the const qualifier in extStart() but it is intentional. This function cannot be used if the configuration structure is declared const.
Parameters
[in]channelchannel to be changed
[in]extcpnew configuration for the channel
Definition at line 120 of file hal_ext.h.
Definition at line 37 of file hal_ext_lld.h.
Referenced by extChannelDisable(), extChannelEnable(), and extSetChannelModeI().
If set to TRUE the support for EXT1 is included.
The default is FALSE.
Definition at line 53 of file hal_ext_lld.h.
Typedef Documentation
Definition at line 74 of file hal_ext.h.
Definition at line 68 of file hal_ext_lld.h.
Parameters
[in]extppointer to the EXPDriver object triggering the callback
Definition at line 76 of file hal_ext_lld.h.
Enumeration Type Documentation
enum extstate_t
Enumerator
EXT_UNINIT
Not initialized.
EXT_STOP
Stopped.
EXT_ACTIVE
Active.
Definition at line 65 of file hal_ext.h.
Function Documentation
void extInit ( void  )
This function is implicitly invoked by halInit(), there is no need to explicitly initialize the driver.
Definition at line 56 of file hal_ext.c.
References ext_lld_init().
Referenced by halInit().
void extObjectInit ( EXTDriver extp)
Parameters
[out]extppointer to the EXTDriver object
Definition at line 68 of file hal_ext.c.
References EXTDriver::config, EXT_STOP, and EXTDriver::state.
Referenced by ext_lld_init().
void extStart ( EXTDriver extp,
const EXTConfig config
Postcondition
After activation all EXT channels are in the disabled state, use extChannelEnable() in order to activate them.
Parameters
[in]configpointer to the EXTConfig object
Definition at line 84 of file hal_ext.c.
References EXTDriver::config, EXT_ACTIVE, ext_lld_start(), EXT_STOP, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), and EXTDriver::state.
void extStop ( EXTDriver extp)
Parameters
Definition at line 104 of file hal_ext.c.
References EXTDriver::config, EXT_ACTIVE, ext_lld_stop(), EXT_STOP, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), and EXTDriver::state.
void extChannelEnable ( EXTDriver extp,
Precondition
The channel must not be in EXT_CH_MODE_DISABLED mode.
Parameters
Definition at line 129 of file hal_ext.c.
References EXTConfig::channels, EXTDriver::config, EXT_ACTIVE, EXT_CH_MODE_DISABLED, EXT_CH_MODE_EDGES_MASK, EXT_MAX_CHANNELS, extChannelEnableI, EXTChannelConfig::mode, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), and EXTDriver::state.
void extChannelDisable ( EXTDriver extp,
Precondition
Parameters
Definition at line 151 of file hal_ext.c.
References EXTConfig::channels, EXTDriver::config, EXT_ACTIVE, EXT_CH_MODE_DISABLED, EXT_CH_MODE_EDGES_MASK, EXT_MAX_CHANNELS, extChannelDisableI, EXTChannelConfig::mode, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), and EXTDriver::state.
void extSetChannelModeI ( EXTDriver extp,
const EXTChannelConfig extcp
The effect of this function on constant configuration structures is not defined.
Parameters
Definition at line 181 of file hal_ext.c.
References EXTConfig::channels, EXTDriver::config, EXT_ACTIVE, ext_lld_channel_enable(), EXT_MAX_CHANNELS, osalDbgAssert, osalDbgCheck, and EXTDriver::state.
void ext_lld_init ( void  )
Function Class:Not an API, this function is for internal use only.
Definition at line 65 of file hal_ext_lld.c.
References extObjectInit().
Referenced by extInit().
void ext_lld_start ( EXTDriver extp)
Parameters
Definition at line 80 of file hal_ext_lld.c.
References EXT_STOP, and EXTDriver::state.
Referenced by extStart().
void ext_lld_stop ( EXTDriver extp)
Parameters
Definition at line 101 of file hal_ext_lld.c.
References EXT_ACTIVE, and EXTDriver::state.
Referenced by extStop().
void ext_lld_channel_enable ( EXTDriver extp,
Parameters
Definition at line 123 of file hal_ext_lld.c.
Referenced by extSetChannelModeI().
void ext_lld_channel_disable ( EXTDriver extp,
Parameters
Definition at line 138 of file hal_ext_lld.c.
Variable Documentation
EXTDriver EXTD1
Definition at line 41 of file hal_ext_lld.c.
