hal_ext_lld.h
18  * @file hal_ext_lld.h
19  * @brief PLATFORM EXT subsystem low level driver header.
21  * @addtogroup EXT
25 #ifndef HAL_EXT_LLD_H
26 #define HAL_EXT_LLD_H
28 #if (HAL_USE_EXT == TRUE) || defined(__DOXYGEN__)
31 /* Driver constants. */
34 /**
35  * @brief Available number of EXT channels.
36  */
37 #define EXT_MAX_CHANNELS 20
38
40 /* Driver pre-compile time settings. */
42
43 /**
44  * @name PLATFORM configuration options
45  * @{
46  */
47 /**
48  * @brief EXT driver enable switch.
49  * @details If set to @p TRUE the support for EXT1 is included.
50  * @note The default is @p FALSE.
51  */
52 #if !defined(PLATFORM_EXT_USE_EXT1) || defined(__DOXYGEN__)
53 #define PLATFORM_EXT_USE_EXT1 FALSE
54 #endif
55 /** @} */
56
58 /* Derived constants and error checks. */
60
61 /*===========================================================================*/
62 /* Driver data structures and types. */
63 /*===========================================================================*/
64
65 /**
66  * @brief EXT channel identifier.
67  */
68 typedef uint32_t expchannel_t;
69
70 /**
71  * @brief Type of an EXT generic notification callback.
72  *
73  * @param[in] extp pointer to the @p EXPDriver object triggering the
74  * callback
75  */
76 typedef void (*extcallback_t)(EXTDriver *extp, expchannel_t channel);
77
78 /**
79  * @brief Channel configuration structure.
80  */
81 typedef struct {
82  /**
83  * @brief Channel mode.
84  */
85  uint32_t mode;
86  /**
87  * @brief Channel callback.
88  * @details In the STM32 implementation a @p NULL callback pointer is
89  * valid and configures the channel as an event sources instead
90  * of an interrupt source.
91  */
94
95 /**
96  * @brief Driver configuration structure.
97  * @note It could be empty on some architectures.
98  */
99 typedef struct {
100  /**
101  * @brief Channel configurations.
102  */
104  /* End of the mandatory fields.*/
105 } EXTConfig;
106
107 /**
108  * @brief Structure representing an EXT driver.
109  */
110 struct EXTDriver {
111  /**
112  * @brief Driver state.
113  */
115  /**
116  * @brief Current configuration data.
117  */
119  /* End of the mandatory fields.*/
120 };
121
122 /*===========================================================================*/
123 /* Driver macros. */
124 /*===========================================================================*/
125
126 /*===========================================================================*/
127 /* External declarations. */
128 /*===========================================================================*/
129
130 #if (PLATFORM_EXT_USE_EXT1 == TRUE) && !defined(__DOXYGEN__)
131 extern EXTDriver EXTD1;
132 #endif
133
134 #ifdef __cplusplus
135 extern "C" {
136 #endif
137  void ext_lld_init(void);
138  void ext_lld_start(EXTDriver *extp);
139  void ext_lld_stop(EXTDriver *extp);
140  void ext_lld_channel_enable(EXTDriver *extp, expchannel_t channel);
141  void ext_lld_channel_disable(EXTDriver *extp, expchannel_t channel);
142 #ifdef __cplusplus
143 }
144 #endif
145
146 #endif /* HAL_USE_EXT == TRUE */
147
148 #endif /* HAL_EXT_LLD_H */
149
150 /** @} */
Definition: hal_ext_lld.h:81
Definition: hal_ext_lld.h:68
const EXTConfig * config
Definition: hal_ext_lld.h:118
Deactivates the EXT peripheral.
Definition: hal_ext_lld.c:101
uint32_t mode
Channel mode.
Definition: hal_ext_lld.h:85
Configures and activates the EXT peripheral.
Definition: hal_ext_lld.c:80
Definition: hal_ext_lld.h:37
extcallback_t cb
Channel callback.
Definition: hal_ext_lld.h:92
Low level EXT driver initialization.
Definition: hal_ext_lld.c:65
Disables an EXT channel.
Definition: hal_ext_lld.c:138
extstate_t state
Definition: hal_ext_lld.h:114
EXTDriver EXTD1
EXT1 driver identifier.
Definition: hal_ext_lld.c:41
void(* extcallback_t)(EXTDriver *extp, expchannel_t channel)
Definition: hal_ext_lld.h:76
extstate_t
Definition: hal_ext.h:65
Definition: hal_ext_lld.h:99
Definition: hal_ext_lld.h:110
Enables an EXT channel.
Definition: hal_ext_lld.c:123
