#define | l3gd20GyroscopeGetAxesNumber(devp) gyroscopeGetAxesNumber(&((devp)->gyro_if)) |
| Return the number of axes of the BaseGyroscope. More...
#define | l3gd20GyroscopeReadRaw(devp, axes) gyroscopeReadRaw(&((devp)->gyro_if), axes) |
| Retrieves raw data from the BaseGyroscope. More...
#define | l3gd20GyroscopeReadCooked(devp, axes) gyroscopeReadCooked(&((devp)->gyro_if), axes) |
| Retrieves cooked data from the BaseGyroscope. More...
#define | l3gd20GyroscopeSampleBias(devp) gyroscopeSampleBias(&((devp)->gyro_if)) |
| Samples bias values for the BaseGyroscope. More...
#define | l3gd20GyroscopeSetBias(devp, bp) gyroscopeSetBias(&((devp)->gyro_if), bp) |
| Set bias values for the BaseGyroscope. More...
#define | l3gd20GyroscopeResetBias(devp) gyroscopeResetBias(&((devp)->gyro_if)) |
| Reset bias values for the BaseGyroscope. More...
#define | l3gd20GyroscopeSetSensitivity(devp, sp) gyroscopeSetSensitivity(&((devp)->gyro_if), sp) |
| Set sensitivity values for the BaseGyroscope. More...
#define | l3gd20GyroscopeResetSensitivity(devp) gyroscopeResetSensitivity(&((devp)->gyro_if)) |
| Reset sensitivity values for the BaseGyroscope. More...
#define | l3gd20GyroscopeSetFullScale(devp, fs) (devp)->vmt->acc_set_full_scale(devp, fs) |
| Changes the L3GD20Driver gyroscope fullscale value. More...
#define | L3GD20_AD_WHO_AM_I 0x0F |
#define | L3GD20_AD_CTRL_REG1 0x20 |
#define | L3GD20_AD_CTRL_REG2 0x21 |
#define | L3GD20_AD_CTRL_REG3 0x22 |
#define | L3GD20_AD_CTRL_REG4 0x23 |
#define | L3GD20_AD_CTRL_REG5 0x24 |
#define | L3GD20_AD_REFERENCE 0x25 |
#define | L3GD20_AD_OUT_TEMP 0x26 |
#define | L3GD20_AD_STATUS_REG 0x27 |
#define | L3GD20_AD_OUT_X_L 0x28 |
#define | L3GD20_AD_OUT_X_H 0x29 |
#define | L3GD20_AD_OUT_Y_L 0x2A |
#define | L3GD20_AD_OUT_Y_H 0x2B |
#define | L3GD20_AD_OUT_Z_L 0x2C |
#define | L3GD20_AD_OUT_Z_H 0x2D |
#define | L3GD20_AD_FIFO_CTRL_REG 0x2E |
#define | L3GD20_AD_FIFO_SRC_REG 0x2F |
#define | L3GD20_AD_INT1_CFG 0x30 |
#define | L3GD20_AD_INT1_SRC 0x31 |
#define | L3GD20_AD_INT1_THS_XH 0x32 |
#define | L3GD20_AD_INT1_THS_XL 0x33 |
#define | L3GD20_AD_INT1_THS_YH 0x34 |
#define | L3GD20_AD_INT1_THS_YL 0x35 |
#define | L3GD20_AD_INT1_THS_ZH 0x36 |
#define | L3GD20_AD_INT1_THS_ZL 0x37 |
#define | L3GD20_AD_INT1_DURATION 0x38 |
#define | L3GD20_CTRL_REG1_MASK 0xFF |
#define | L3GD20_CTRL_REG1_XEN (1 << 0) |
#define | L3GD20_CTRL_REG1_YEN (1 << 1) |
#define | L3GD20_CTRL_REG1_ZEN (1 << 2) |
#define | L3GD20_CTRL_REG1_PD (1 << 3) |
#define | L3GD20_CTRL_REG1_BW0 (1 << 4) |
#define | L3GD20_CTRL_REG1_BW1 (1 << 5) |
#define | L3GD20_CTRL_REG1_DR0 (1 << 6) |
#define | L3GD20_CTRL_REG1_DR1 (1 << 7) |
#define | L3GD20_CTRL_REG3_MASK 0xFF |
#define | L3GD20_CTRL_REG3_I2_EMPTY (1 << 0) |
#define | L3GD20_CTRL_REG3_I2_ORUN (1 << 1) |
#define | L3GD20_CTRL_REG3_I2_WTM (1 << 2) |
#define | L3GD20_CTRL_REG3_I2_DRDY (1 << 3) |
#define | L3GD20_CTRL_REG3_PP_OD (1 << 4) |
#define | L3GD20_CTRL_REG3_H_LACTIVE (1 << 5) |
#define | L3GD20_CTRL_REG3_I1_BOOT (1 << 6) |
#define | L3GD20_CTRL_REG3_I1_INT1 (1 << 7) |
#define | L3GD20_INT1_CFG_MASK 0xFF |
#define | L3GD20_INT1_CFG_XLIE (1 << 0) |
#define | L3GD20_INT1_CFG_XHIE (1 << 1) |
#define | L3GD20_INT1_CFG_YLIE (1 << 2) |
#define | L3GD20_INT1_CFG_YHIE (1 << 3) |
#define | L3GD20_INT1_CFG_ZLIE (1 << 4) |
#define | L3GD20_INT1_CFG_ZHIE (1 << 5) |
#define | L3GD20_INT1_CFG_LIR (1 << 6) |
#define | L3GD20_INT1_CFG_AND_OR (1 << 7) |
static void | l3gd20SPIReadRegister (SPIDriver *spip, uint8_t reg, size_t n, uint8_t *b) |
| Reads a generic register value using SPI. More...
static void | l3gd20SPIWriteRegister (SPIDriver *spip, uint8_t reg, size_t n, uint8_t *b) |
| Writes a value into a generic register using SPI. More...
static size_t | gyro_get_axes_number (void *ip) |
static msg_t | gyro_read_raw (void *ip, int32_t axes[L3GD20_GYRO_NUMBER_OF_AXES]) |
static msg_t | gyro_read_cooked (void *ip, float axes[]) |
static msg_t | gyro_sample_bias (void *ip) |
static msg_t | gyro_set_bias (void *ip, float *bp) |
static msg_t | gyro_reset_bias (void *ip) |
static msg_t | gyro_set_sensivity (void *ip, float *sp) |
static msg_t | gyro_reset_sensivity (void *ip) |
static msg_t | gyro_set_full_scale (L3GD20Driver *devp, l3gd20_fs_t fs) |
void | l3gd20ObjectInit (L3GD20Driver *devp) |
| Initializes an instance. More...
void | l3gd20Start (L3GD20Driver *devp, const L3GD20Config *config) |
| Configures and activates L3GD20 Complex Driver peripheral. More...
void | l3gd20Stop (L3GD20Driver *devp) |
| Deactivates the L3GD20 Complex Driver peripheral. More...
static msg_t gyro_read_raw |
void * |
ip, |
int32_t |
axes[L3GD20_GYRO_NUMBER_OF_AXES] |
static |
- Note
- This data is retrieved from MEMS register without any algebraical manipulation.
The axes array must be at least the same size of the BaseGyroscope axes number.
- Parameters
[in] | ip | pointer to BaseGyroscope interface. |
[out] | axes | a buffer which would be filled with raw data. |
- Returns
- The operation status.
- Return values
MSG_OK | if the function succeeded. |
Definition at line 115 of file l3gd20.c.
References L3GD20_GYRO_NUMBER_OF_AXES, L3GD20_READY, l3gd20SPIReadRegister(), MSG_OK, objGetInstance, osalDbgAssert, osalDbgCheck, SPI_READY, spiAcquireBus(), spiReleaseBus(), and spiStart().
Referenced by gyro_read_cooked(), gyro_sample_bias(), and gyro_set_full_scale().
static msg_t gyro_sample_bias |
void * |
ip | ) |
static |
- Note
- The L3GD20 shall not be moved during the whole procedure.
After this function internal bias is automatically updated.
The behavior of this function depends on
L3GD20_BIAS_ACQ_TIMES
and L3GD20_BIAS_SETTLING_US
- Parameters
- Returns
- Return values
Definition at line 200 of file l3gd20.c.
References gyro_read_raw(), L3GD20_BIAS_ACQ_TIMES, L3GD20_BIAS_SETTLING_US, L3GD20_GYRO_NUMBER_OF_AXES, L3GD20_READY, MSG_OK, objGetInstance, osalDbgAssert, osalDbgCheck, osalThreadSleepMicroseconds, and SPI_READY.
Referenced by gyro_set_full_scale().
- Note
- This function also rescale sensitivities and biases based on previous and next fullscale value.
A recalibration is highly suggested after calling this function.
- Parameters
[in] | devp | pointer to BaseGyroscope interface. |
[in] | fs | new fullscale value. |
- Returns
- Return values
MSG_RESET | otherwise. |
Definition at line 378 of file l3gd20.c.
References gyro_get_axes_number(), gyro_read_cooked(), gyro_read_raw(), gyro_reset_bias(), gyro_reset_sensivity(), gyro_sample_bias(), gyro_set_bias(), gyro_set_sensivity(), L3GD20_FS_2000DPS, L3GD20_FS_250DPS, L3GD20_FS_500DPS, L3GD20_GYRO_NUMBER_OF_AXES, L3GD20_READY, l3gd20SPIReadRegister(), l3gd20SPIWriteRegister(), MSG_OK, MSG_RESET, osalDbgAssert, osalDbgCheck, SPI_READY, spiAcquireBus(), spiReleaseBus(), and spiStart().
