Event Flags, Event Sources and Event Listeners.
Each thread has a mask of pending events inside its thread_t
structure. Operations defined for events:
An Event Source is a special object that can be "broadcasted" by a thread or an interrupt service routine. Broadcasting an Event Source has the effect that all the threads registered on the Event Source will be signaled with an events mask.
An unlimited number of Event Sources can exists in a system and each thread can be listening on an unlimited number of them.
CH_CFG_USE_EVENTS
option must be enabled in chconf.h
. thread_t
structure. Macros | |
#define | ALL_EVENTS ((eventmask_t)-1) |
All events allowed mask. More... | |
#define | EVENT_MASK(eid) ((eventmask_t)1 << (eventmask_t)(eid)) |
Returns an event mask from an event identifier. More... | |
#define | _EVENTSOURCE_DATA(name) {(event_listener_t *)(&name)} |
Data part of a static event source initializer. More... | |
#define | EVENTSOURCE_DECL(name) event_source_t name = _EVENTSOURCE_DATA(name) |
Static event source initializer. More... | |
Typedefs | |
typedef struct event_source | event_source_t |
Event Source structure. More... | |
typedef void(* | evhandler_t) (eventid_t id) |
Event Handler callback function. More... | |
struct | event_listener |
Event Listener structure. More... | |
struct | event_source |
void | chEvtRegisterMaskWithFlags (event_source_t *esp, event_listener_t *elp, eventmask_t events, eventflags_t wflags) |
Registers an Event Listener on an Event Source. More... | |
void | chEvtUnregister (event_source_t *esp, event_listener_t *elp) |
Unregisters an Event Listener from its Event Source. More... | |
eventmask_t | chEvtGetAndClearEventsI (eventmask_t events) |
Clears the pending events specified in the events mask. More... | |
eventmask_t | chEvtGetAndClearEvents (eventmask_t events) |
eventmask_t | chEvtAddEvents (eventmask_t events) |
Adds (OR) a set of events to the current thread, this is much faster than using chEvtBroadcast() or chEvtSignal() . More... | |
void | chEvtBroadcastFlagsI (event_source_t *esp, eventflags_t flags) |
Signals all the Event Listeners registered on the specified Event Source. More... | |
eventflags_t | chEvtGetAndClearFlags (event_listener_t *elp) |
Returns the flags associated to an event_listener_t . More... | |
void | chEvtSignal (thread_t *tp, eventmask_t events) |
Adds a set of event flags directly to the specified thread_t . More... | |
void | chEvtSignalI (thread_t *tp, eventmask_t events) |
void | chEvtBroadcastFlags (event_source_t *esp, eventflags_t flags) |
eventflags_t | chEvtGetAndClearFlagsI (event_listener_t *elp) |
void | chEvtDispatch (const evhandler_t *handlers, eventmask_t events) |
Invokes the event handlers associated to an event flags mask. More... | |
eventmask_t | chEvtWaitOne (eventmask_t events) |
Waits for exactly one of the specified events. More... | |
eventmask_t | chEvtWaitAny (eventmask_t events) |
Waits for any of the specified events. More... | |
eventmask_t | chEvtWaitAll (eventmask_t events) |
Waits for all the specified events. More... | |
eventmask_t | chEvtWaitOneTimeout (eventmask_t events, sysinterval_t timeout) |
eventmask_t | chEvtWaitAnyTimeout (eventmask_t events, sysinterval_t timeout) |
eventmask_t | chEvtWaitAllTimeout (eventmask_t events, sysinterval_t timeout) |
static void | chEvtObjectInit (event_source_t *esp) |
Initializes an Event Source. More... | |
static void | chEvtRegisterMask (event_source_t *esp, event_listener_t *elp, eventmask_t events) |
static void | chEvtRegister (event_source_t *esp, event_listener_t *elp, eventid_t event) |
static bool | chEvtIsListeningI (event_source_t *esp) |
Verifies if there is at least one event_listener_t registered. More... | |
static void | chEvtBroadcast (event_source_t *esp) |
static void | chEvtBroadcastI (event_source_t *esp) |
static eventmask_t | chEvtAddEventsI (eventmask_t events) |
static eventmask_t | chEvtGetEventsX (void) |
Returns the events mask. More... | |
#define ALL_EVENTS ((eventmask_t)-1) |
Definition at line 92 of file chevents.h.
#define EVENT_MASK | ( | eid | ) | ((eventmask_t)1 << (eventmask_t)(eid)) |
Definition at line 97 of file chevents.h.
Referenced by chEvtDispatch(), and chEvtRegister().
#define _EVENTSOURCE_DATA | ( | name | ) | {(event_listener_t *)(&name)} |
This macro should be used when statically initializing an event source that is part of a bigger structure.
name | the name of the event source variable |
Definition at line 105 of file chevents.h.
#define EVENTSOURCE_DECL | ( | name | ) | event_source_t name = _EVENTSOURCE_DATA(name) |
Statically initialized event sources require no explicit initialization using chEvtInit()
Definition at line 114 of file chevents.h.
typedef struct event_source event_source_t |
typedef void(* evhandler_t) (eventid_t id) |
Definition at line 83 of file chevents.h.
void chEvtRegisterMaskWithFlags | ( | event_source_t * | esp, |
event_listener_t * | elp, | ||
eventmask_t | events, | ||
eventflags_t | wflags | ||
Once a thread has registered as listener on an event source it will be notified of all events broadcasted there.
[in] | esp | pointer to the event_source_t structure |
[in] | elp | pointer to the event_listener_t structure |
[in] | events | events to be ORed to the thread when the event source is broadcasted |
[in] | wflags | mask of flags the listening thread is interested in |
Definition at line 103 of file chevents.c.
References chDbgCheck, chSysLock, chSysUnlock, currp, event_listener::events, event_listener::flags, event_listener::listener, event_listener::next, event_source::next, and event_listener::wflags.
Referenced by chEvtRegisterMask().
void chEvtUnregister | ( | event_source_t * | esp, |
event_listener_t * | elp | ||
Definition at line 133 of file chevents.c.
References chDbgCheck, chSysLock, chSysUnlock, and event_listener::next.
eventmask_t chEvtGetAndClearEventsI | ( | eventmask_t | events | ) |
[in] | events | the events to be cleared |
Definition at line 162 of file chevents.c.
References currp.
Referenced by chEvtGetAndClearEvents().
eventmask_t chEvtGetAndClearEvents | ( | eventmask_t | events | ) |
Definition at line 179 of file chevents.c.
References chEvtGetAndClearEventsI(), chSysLock, and chSysUnlock.
eventmask_t chEvtAddEvents | ( | eventmask_t | events | ) |
or chEvtSignal()
[in] | events | the events to be added |
Definition at line 198 of file chevents.c.
References chEvtAddEventsI(), chSysLock, and chSysUnlock.
void chEvtBroadcastFlagsI | ( | event_source_t * | esp, |
eventflags_t | flags | ||
This function variants ORs the specified event flags to all the threads registered on the event_source_t
in addition to the event flags specified by the threads themselves in the event_listener_t
objects.
[in] | flags | the flags set to be added to the listener flags mask |
Definition at line 225 of file chevents.c.
References chDbgCheck, chEvtSignalI(), event_listener::events, event_listener::flags, event_listener::listener, event_listener::next, event_source::next, and event_listener::wflags.
Referenced by chEvtBroadcastFlags(), and chEvtBroadcastI().
eventflags_t chEvtGetAndClearFlags | ( | event_listener_t * | elp | ) |
The flags are returned and the event_listener_t
flags mask is cleared.
Definition at line 257 of file chevents.c.
References chSysLock, chSysUnlock, and event_listener::flags.
void chEvtSignal | ( | thread_t * | tp, |
eventmask_t | events | ||
[in] | tp | the thread to be signaled |
[in] | events | the events set to be ORed |
Definition at line 276 of file chevents.c.
References chDbgCheck, chEvtSignalI(), chSchRescheduleS(), chSysLock, and chSysUnlock.
void chEvtSignalI | ( | thread_t * | tp, |
Definition at line 298 of file chevents.c.
References CH_STATE_WTANDEVT, CH_STATE_WTOREVT, chDbgCheck, chSchReadyI(), ch_thread::epending, ch_thread::ewmask, MSG_OK, ch_thread::rdymsg, ch_thread::state, and ch_thread::u.
Referenced by chEvtBroadcastFlagsI(), and chEvtSignal().
void chEvtBroadcastFlags | ( | event_source_t * | esp, |
objects.
Definition at line 327 of file chevents.c.
References chEvtBroadcastFlagsI(), chSchRescheduleS(), chSysLock, and chSysUnlock.
Referenced by chEvtBroadcast().
eventflags_t chEvtGetAndClearFlagsI | ( | event_listener_t * | elp | ) |
Definition at line 346 of file chevents.c.
References event_listener::flags.
void chEvtDispatch | ( | const evhandler_t * | handlers, |
[in] | events | mask of events to be dispatched |
[in] | handlers | an array of evhandler_t . The array must have size equal to the number of bits in eventmask_t. |
Definition at line 364 of file chevents.c.
References chDbgAssert, chDbgCheck, and EVENT_MASK.
eventmask_t chEvtWaitOne | ( | eventmask_t | events | ) |
The function waits for one event among those specified in events
to become pending then the event is cleared and returned.
[in] | events | events that the function should wait for, ALL_EVENTS enables all the events |
Definition at line 399 of file chevents.c.
References CH_STATE_WTOREVT, chSchGoSleepS(), chSysLock, chSysUnlock, currp, ch_thread::epending, ch_thread::ewmask, and ch_thread::u.
eventmask_t chEvtWaitAny | ( | eventmask_t | events | ) |
The function waits for any event among those specified in events
to become pending then the events are cleared and returned.
Definition at line 429 of file chevents.c.
eventmask_t chEvtWaitAll | ( | eventmask_t | events | ) |
The function waits for all the events specified in events
[in] | events | events that the function should wait for, ALL_EVENTS requires all the events |
Definition at line 457 of file chevents.c.
References CH_STATE_WTANDEVT, chSchGoSleepS(), chSysLock, chSysUnlock, currp, ch_thread::epending, ch_thread::ewmask, and ch_thread::u.
eventmask_t chEvtWaitOneTimeout | ( | eventmask_t | events, |
sysinterval_t | timeout | ||
[in] | timeout | the number of ticks before the operation timeouts, the following special values are allowed:
0 | if the operation has timed out. |
Definition at line 495 of file chevents.c.
References CH_STATE_WTOREVT, chSchGoSleepTimeoutS(), chSysLock, chSysUnlock, currp, ch_thread::epending, ch_thread::ewmask, MSG_OK, TIME_IMMEDIATE, and ch_thread::u.
eventmask_t chEvtWaitAnyTimeout | ( | eventmask_t | events, |
Definition at line 538 of file chevents.c.
eventmask_t chEvtWaitAllTimeout | ( | eventmask_t | events, |
Definition at line 579 of file chevents.c.
References CH_STATE_WTANDEVT, chSchGoSleepTimeoutS(), chSysLock, chSysUnlock, currp, ch_thread::epending, ch_thread::ewmask, MSG_OK, TIME_IMMEDIATE, and ch_thread::u.
inlinestatic |
event_source_t
structure.[in] | esp | pointer to the event_source_t structure |
Definition at line 171 of file chevents.h.
References event_source::next.
inlinestatic |
[out] | elp | pointer to the event_listener_t structure |
[in] | events | the mask of events to be ORed to the thread when the event source is broadcasted |
Definition at line 190 of file chevents.h.
References chEvtRegisterMaskWithFlags().
Referenced by chEvtRegister().
inlinestatic |
[in] | event | numeric identifier assigned to the Event Listener. The value must range between zero and the size, in bit, of the eventmask_t type minus one. |
Definition at line 210 of file chevents.h.
References chEvtRegisterMask(), and EVENT_MASK.
inlinestatic |
registered.
Definition at line 225 of file chevents.h.
inlinestatic |
Definition at line 238 of file chevents.h.
References chEvtBroadcastFlags().
inlinestatic |
Definition at line 255 of file chevents.h.
References chEvtBroadcastFlagsI().
inlinestatic |
or chEvtSignal()
Definition at line 269 of file chevents.h.
References currp, and event_listener::events.
Referenced by chEvtAddEvents().
inlinestatic |
The pending events mask is returned but not altered in any way.
Definition at line 282 of file chevents.h.
References currp.
