Counting Semaphores
Collaboration diagram for Counting Semaphores:
Semaphores related APIs and services.
Operation mode
Semaphores are a flexible synchronization primitive, ChibiOS/RT implements semaphores in their "counting semaphores" variant as defined by Edsger Dijkstra plus several enhancements like:
The binary semaphores variant can be easily implemented using counting semaphores.
Operations defined for semaphores:
Semaphores can be used as guards for mutual exclusion zones (note that mutexes are recommended for this kind of use) but also have other uses, queues guards and counters for example.
Semaphores usually use a FIFO queuing strategy but it is possible to make them order threads by priority by enabling CH_CFG_USE_SEMAPHORES_PRIORITY in chconf.h.
Precondition
In order to use the semaphore APIs the CH_CFG_USE_SEMAPHORES option must be enabled in chconf.h.
#define _SEMAPHORE_DATA(name, n)   {_THREADS_QUEUE_DATA(name.queue), n}
 Data part of a static semaphore initializer. More...
#define SEMAPHORE_DECL(name, n)   semaphore_t name = _SEMAPHORE_DATA(name, n)
 Static semaphore initializer. More...
typedef struct ch_semaphore semaphore_t
 Semaphore structure. More...
struct  ch_semaphore
void chSemObjectInit (semaphore_t *sp, cnt_t n)
 Initializes a semaphore with the specified counter value. More...
void chSemReset (semaphore_t *sp, cnt_t n)
 Performs a reset operation on the semaphore. More...
void chSemResetI (semaphore_t *sp, cnt_t n)
msg_t chSemWait (semaphore_t *sp)
 Performs a wait operation on a semaphore. More...
msg_t chSemWaitS (semaphore_t *sp)
msg_t chSemWaitTimeout (semaphore_t *sp, sysinterval_t timeout)
 Performs a wait operation on a semaphore with timeout specification. More...
msg_t chSemWaitTimeoutS (semaphore_t *sp, sysinterval_t timeout)
void chSemSignal (semaphore_t *sp)
 Performs a signal operation on a semaphore. More...
void chSemSignalI (semaphore_t *sp)
void chSemAddCounterI (semaphore_t *sp, cnt_t n)
 Adds the specified value to the semaphore counter. More...
msg_t chSemSignalWait (semaphore_t *sps, semaphore_t *spw)
 Performs atomic signal and wait operations on two semaphores. More...
static void chSemFastWaitI (semaphore_t *sp)
 Decreases the semaphore counter. More...
static void chSemFastSignalI (semaphore_t *sp)
 Increases the semaphore counter. More...
static cnt_t chSemGetCounterI (const semaphore_t *sp)
 Returns the semaphore counter current value. More...
#define _SEMAPHORE_DATA (   name,
This macro should be used when statically initializing a semaphore that is part of a bigger structure.
Parameters
[in]namethe name of the semaphore variable
[in]nthe counter initial value, this value must be non-negative
Definition at line 71 of file chsem.h.
#define SEMAPHORE_DECL (   name,
Statically initialized semaphores require no explicit initialization using chSemInit().
Parameters
Definition at line 82 of file chsem.h.
Typedef Documentation
Function Documentation
void chSemObjectInit ( semaphore_t sp,
cnt_t  n
Parameters
[out]sppointer to a semaphore_t structure
[in]ninitial value of the semaphore counter. Must be non-negative.
Definition at line 97 of file chsem.c.
References chDbgCheck, ch_semaphore::cnt, ch_semaphore::queue, and queue_init().
Referenced by _factory_init(), _heap_init(), chBSemObjectInit(), chFactoryCreateSemaphore(), chGuardedPoolObjectInitAligned(), and chHeapObjectInit().
void chSemReset ( semaphore_t sp,
cnt_t  n
Postcondition
After invoking this function all the threads waiting on the semaphore, if any, are released and the semaphore counter is set to the specified, non negative, value.
The released threads can recognize they were waked up by a reset rather than a signal because the chSemWait() will return MSG_RESET instead of MSG_OK.
Parameters
[in]sppointer to a semaphore_t structure
[in]nthe new value of the semaphore counter. The value must be non-negative.
Definition at line 120 of file chsem.c.
References chSchRescheduleS(), chSemResetI(), chSysLock, and chSysUnlock.
Referenced by chBSemReset().
void chSemResetI ( semaphore_t sp,
cnt_t  n
Postcondition
This function does not reschedule so a call to a rescheduling function must be performed before unlocking the kernel. Note that interrupt handlers always reschedule on exit so an explicit reschedule must not be performed in ISRs.
Parameters
Function Class:This is an I-Class API, this function can be invoked from within a system lock zone by both threads and interrupt handlers.
Definition at line 147 of file chsem.c.
References chDbgAssert, chDbgCheck, chSchReadyI(), ch_semaphore::cnt, MSG_RESET, ch_semaphore::queue, queue_isempty(), queue_lifo_remove(), queue_notempty(), ch_thread::rdymsg, and ch_thread::u.
Referenced by chBSemResetI(), and chSemReset().
msg_t chSemWait ( semaphore_t sp)
Parameters
Returns
A message specifying how the invoking thread has been released from the semaphore.
Return values
MSG_OKif the thread has not stopped on the semaphore or the semaphore has been signaled.
MSG_RESETif the semaphore has been reset using chSemReset().
Definition at line 175 of file chsem.c.
References chSemWaitS(), chSysLock, and chSysUnlock.
Referenced by chBSemWait().
msg_t chSemWaitS ( semaphore_t sp)
Parameters
Returns
Return values
Function Class:This is an S-Class API, this function can be invoked from within a system lock zone by threads only.
Definition at line 197 of file chsem.c.
References CH_STATE_WTSEM, chDbgAssert, chDbgCheck, chSchGoSleepS(), ch_semaphore::cnt, currp, MSG_OK, ch_semaphore::queue, queue_isempty(), and queue_notempty().
Referenced by chBSemWaitS(), and chSemWait().
msg_t chSemWaitTimeout ( semaphore_t sp,
Parameters
[in]timeoutthe number of ticks before the operation timeouts, the following special values are allowed:
  • TIME_IMMEDIATE immediate timeout.
  • TIME_INFINITE no timeout.
Returns
Return values
MSG_TIMEOUTif the semaphore has not been signaled or reset within the specified timeout.
Definition at line 235 of file chsem.c.
References chSemWaitTimeoutS(), chSysLock, and chSysUnlock.
Referenced by chBSemWaitTimeout().
msg_t chSemWaitTimeoutS ( semaphore_t sp,
Parameters
Returns
Return values
Definition at line 264 of file chsem.c.
References CH_STATE_WTSEM, chDbgAssert, chDbgCheck, chSchGoSleepTimeoutS(), ch_semaphore::cnt, currp, MSG_OK, MSG_TIMEOUT, ch_semaphore::queue, queue_isempty(), queue_notempty(), and TIME_IMMEDIATE.
Referenced by chBSemWaitTimeoutS(), chGuardedPoolAllocTimeoutS(), and chSemWaitTimeout().
void chSemSignal ( semaphore_t sp)
Parameters
Definition at line 294 of file chsem.c.
References chDbgAssert, chDbgCheck, chSchWakeupS(), chSysLock, chSysUnlock, ch_semaphore::cnt, MSG_OK, ch_semaphore::queue, queue_fifo_remove(), queue_isempty(), and queue_notempty().
void chSemSignalI ( semaphore_t sp)
Postcondition
Parameters
Definition at line 319 of file chsem.c.
References chDbgAssert, chDbgCheck, chSchReadyI(), ch_semaphore::cnt, MSG_OK, ch_semaphore::queue, queue_fifo_remove(), queue_isempty(), queue_notempty(), ch_thread::rdymsg, and ch_thread::u.
Referenced by chBSemSignalI(), and chGuardedPoolFreeI().
void chSemAddCounterI ( semaphore_t sp,
cnt_t  n
Postcondition
Parameters
[in]nvalue to be added to the semaphore counter. The value must be positive.
Definition at line 349 of file chsem.c.
msg_t chSemSignalWait ( semaphore_t sps,
semaphore_t spw
Parameters
[in]spspointer to a semaphore_t structure to be signaled
[in]spwpointer to a semaphore_t structure to wait on
Returns
Return values
Definition at line 378 of file chsem.c.
References CH_STATE_WTSEM, chDbgAssert, chDbgCheck, chSchGoSleepS(), chSchReadyI(), chSchRescheduleS(), chSysLock, chSysUnlock, ch_semaphore::cnt, currp, MSG_OK, ch_semaphore::queue, queue_fifo_remove(), queue_isempty(), queue_notempty(), ch_thread::rdymsg, ch_thread::u, and ch_thread::wtsemp.
static void chSemFastWaitI ( semaphore_t sp)
inlinestatic
This macro can be used when the counter is known to be positive.
Parameters
Definition at line 118 of file chsem.h.
References ch_semaphore::cnt.
static void chSemFastSignalI ( semaphore_t sp)
inlinestatic
This macro can be used when the counter is known to be not negative.
Parameters
Definition at line 134 of file chsem.h.
static cnt_t chSemGetCounterI ( const semaphore_t sp)
inlinestatic
Parameters
Returns
The semaphore counter value.
Definition at line 149 of file chsem.h.
