Generic accelerometer interface header. More...
#include "hal_sensors.h"Go to the source code of this file.
| struct | BaseAccelerometerVMT |
BaseAccelerometer virtual methods table. More... | |
| struct | BaseAccelerometer |
| Base accelerometer class. More... | |
| #define | _base_accelerometer_methods_alone |
| BaseAccelerometer specific methods. More... | |
| #define | _base_accelerometer_methods |
| BaseAccelerometer specific methods with inherited ones. More... | |
| #define | _base_accelerometer_data _base_sensor_data |
BaseAccelerometer specific data. More... | |
Macro Functions (BaseAccelerometer) | |
| #define | accelerometerGetAxesNumber(ip) (ip)->vmt->get_channels_number(ip) |
| Accelerometer get axes number. More... | |
| #define | accelerometerReadRaw(ip, dp) (ip)->vmt->read_raw(ip, dp) |
| Accelerometer read raw data. More... | |
| #define | accelerometerReadCooked(ip, dp) (ip)->vmt->read_cooked(ip, dp) |
| Accelerometer read cooked data. More... | |
| #define | accelerometerSetBias(ip, bp) (ip)->vmt->set_bias(ip, bp) |
| Updates accelerometer bias data from received buffer. More... | |
| #define | accelerometerResetBias(ip) (ip)->vmt->reset_bias(ip) |
| Reset accelerometer bias data restoring it to zero. More... | |
| #define | accelerometerSetSensitivity(ip, sp) (ip)->vmt->set_sensitivity(ip, sp) |
| Updates accelerometer sensitivity data from received buffer. More... | |
| #define | accelerometerResetSensitivity(ip) (ip)->vmt->reset_sensitivity(ip) |
| Reset accelerometer sensitivity data restoring it to its typical value. More... | |
Definition in file hal_accelerometer.h.
