hal_accelerometer.h
18  * @file hal_accelerometer.h
19  * @brief Generic accelerometer interface header.
21  * @addtogroup HAL_ACCELEROMETER
25 #ifndef HAL_ACCELEROMETER_H
26 #define HAL_ACCELEROMETER_H
28 #include "hal_sensors.h"
31 /* Driver constants. */
37
38 /*===========================================================================*/
39 /* Derived constants and error checks. */
40 /*===========================================================================*/
41
43 /* Driver data structures and types. */
45
46 /**
47  * @brief BaseAccelerometer specific methods.
48  */
49 #define _base_accelerometer_methods_alone \
50  /* Invoke the set bias procedure.*/ \
51  msg_t (*set_bias)(void *instance, float biases[]); \
52  /* Remove bias stored data.*/ \
53  msg_t (*reset_bias)(void *instance); \
54  /* Invoke the set sensitivity procedure.*/ \
55  msg_t (*set_sensitivity)(void *instance, float sensitivities[]); \
56  /* Restore sensitivity stored data to default.*/ \
57  msg_t (*reset_sensitivity)(void *instance);
58
59 /**
60  * @brief BaseAccelerometer specific methods with inherited ones.
61  */
62 #define _base_accelerometer_methods \
63  _base_sensor_methods \
64  _base_accelerometer_methods_alone
65
66 /**
67  * @brief @p BaseAccelerometer virtual methods table.
68  */
71 };
72
73 /**
74  * @brief @p BaseAccelerometer specific data.
75  */
76 #define _base_accelerometer_data \
77  _base_sensor_data
78
79 /**
80  * @extends BaseSensor
81  *
82  * @brief Base accelerometer class.
83  * @details This class represents a generic a generic accelerometer.
84  */
85 typedef struct {
86  /** @brief Virtual Methods Table.*/
87  const struct BaseAccelerometerVMT *vmt;
90
91 /*===========================================================================*/
92 /* Driver macros. */
93 /*===========================================================================*/
94
95 /**
96  * @name Macro Functions (BaseAccelerometer)
97  * @{
98  */
99 /**
100  * @brief Accelerometer get axes number.
101  *
102  * @param[in] ip pointer to a @p BaseAccelerometer class.
103  * @return The number of axes of the BaseAccelerometer
104  *
105  * @api
106  */
107 #define accelerometerGetAxesNumber(ip) \
108  (ip)->vmt->get_channels_number(ip)
109
110 /**
111  * @brief Accelerometer read raw data.
112  *
113  * @param[in] ip pointer to a @p BaseAccelerometer class.
114  * @param[in] dp pointer to a data array.
115  *
116  * @return The operation status.
117  * @retval MSG_OK if the function succeeded.
118  * @retval MSG_RESET if one or more errors occurred.
119  *
120  * @api
121  */
122 #define accelerometerReadRaw(ip, dp) \
123  (ip)->vmt->read_raw(ip, dp)
124
125 /**
126  * @brief Accelerometer read cooked data.
127  *
128  * @param[in] ip pointer to a @p BaseAccelerometer class.
129  * @param[in] dp pointer to a data array.
130  *
131  * @return The operation status.
132  * @retval MSG_OK if the function succeeded.
133  * @retval MSG_RESET if one or more errors occurred.
134  *
135  * @api
136  */
137 #define accelerometerReadCooked(ip, dp) \
138  (ip)->vmt->read_cooked(ip, dp)
139
140 /**
141  * @brief Updates accelerometer bias data from received buffer.
142  * @note The bias buffer must have the same length of the
143  * the accelerometer axes number.
144  *
145  *
146  * @param[in] ip pointer to a @p BaseAccelerometer class.
147  * @param[in] bp pointer to a buffer of bias values.
148  *
149  * @return The operation status.
150  * @retval MSG_OK if the function succeeded.
151  * @retval MSG_RESET if one or more errors occurred.
152  *
153  * @api
154  */
155 #define accelerometerSetBias(ip, bp) \
156  (ip)->vmt->set_bias(ip, bp)
157
158 /**
159  * @brief Reset accelerometer bias data restoring it to zero.
160  *
161  * @param[in] ip pointer to a @p BaseAccelerometer class.
162  *
163  * @return The operation status.
164  * @retval MSG_OK if the function succeeded.
165  * @retval MSG_RESET if one or more errors occurred.
166  *
167  * @api
168  */
169 #define accelerometerResetBias(ip) \
170  (ip)->vmt->reset_bias(ip)
171
172 /**
173  * @brief Updates accelerometer sensitivity data from received buffer.
174  * @note The sensitivity buffer must have the same length of the
175  * the accelerometer axes number.
176  *
177  * @param[in] ip pointer to a @p BaseAccelerometer class.
178  * @param[in] sp pointer to a buffer of sensitivity values.
179  *
180  * @return The operation status.
181  * @retval MSG_OK if the function succeeded.
182  * @retval MSG_RESET if one or more errors occurred.
183  *
184  * @api
185  */
186 #define accelerometerSetSensitivity(ip, sp) \
187  (ip)->vmt->set_sensitivity(ip, sp)
188
189 /**
190  * @brief Reset accelerometer sensitivity data restoring it to its typical
191  * value.
192  *
193  * @param[in] ip pointer to a @p BaseAccelerometer class.
194  *
195  * @return The operation status.
196  * @retval MSG_OK if the function succeeded.
197  * @retval MSG_RESET if one or more errors occurred.
198  *
199  * @api
200  */
201 #define accelerometerResetSensitivity(ip) \
202  (ip)->vmt->reset_sensitivity(ip)
203 /** @} */
204
205 /*===========================================================================*/
206 /* External declarations. */
207 /*===========================================================================*/
208
209 #ifdef __cplusplus
210 extern "C" {
211 #endif
212
213 #ifdef __cplusplus
214 }
215 #endif
216
217 #endif /* HAL_ACCELEROMETER_H */
218
219 /** @} */
Generic sensors interface header.
const struct BaseAccelerometerVMT * vmt
