hal_adc.c
18  * @file hal_adc.c
19  * @brief ADC Driver code.
21  * @addtogroup ADC
27 #if (HAL_USE_ADC == TRUE) || defined(__DOXYGEN__)
38 /* Driver local variables and types. */
46 /* Driver exported functions. */
49 /**
50  * @brief ADC Driver initialization.
51  * @note This function is implicitly invoked by @p halInit(), there is
52  * no need to explicitly initialize the driver.
53  *
54  * @init
55  */
56 void adcInit(void) {
57
58  adc_lld_init();
59 }
60
61 /**
62  * @brief Initializes the standard part of a @p ADCDriver structure.
63  *
64  * @param[out] adcp pointer to the @p ADCDriver object
65  *
66  * @init
67  */
68 void adcObjectInit(ADCDriver *adcp) {
69
70  adcp->state = ADC_STOP;
71  adcp->config = NULL;
72  adcp->samples = NULL;
73  adcp->depth = 0;
74  adcp->grpp = NULL;
75 #if ADC_USE_WAIT == TRUE
76  adcp->thread = NULL;
77 #endif
78 #if ADC_USE_MUTUAL_EXCLUSION == TRUE
79  osalMutexObjectInit(&adcp->mutex);
80 #endif
81 #if defined(ADC_DRIVER_EXT_INIT_HOOK)
82  ADC_DRIVER_EXT_INIT_HOOK(adcp);
83 #endif
84 }
85
86 /**
87  * @brief Configures and activates the ADC peripheral.
88  *
89  * @param[in] adcp pointer to the @p ADCDriver object
90  * @param[in] config pointer to the @p ADCConfig object. Depending on
91  * the implementation the value can be @p NULL.
92  *
93  * @api
94  */
95 void adcStart(ADCDriver *adcp, const ADCConfig *config) {
96
97  osalDbgCheck(adcp != NULL);
98
99  osalSysLock();
100  osalDbgAssert((adcp->state == ADC_STOP) || (adcp->state == ADC_READY),
101  "invalid state");
102  adcp->config = config;
103  adc_lld_start(adcp);
104  adcp->state = ADC_READY;
105  osalSysUnlock();
106 }
107
108 /**
109  * @brief Deactivates the ADC peripheral.
110  *
111  * @param[in] adcp pointer to the @p ADCDriver object
112  *
113  * @api
114  */
115 void adcStop(ADCDriver *adcp) {
116
117  osalDbgCheck(adcp != NULL);
118
119  osalSysLock();
120
121  osalDbgAssert((adcp->state == ADC_STOP) || (adcp->state == ADC_READY),
122  "invalid state");
123
124  adc_lld_stop(adcp);
125  adcp->config = NULL;
126  adcp->state = ADC_STOP;
127
128  osalSysUnlock();
129 }
130
131 /**
132  * @brief Starts an ADC conversion.
133  * @details Starts an asynchronous conversion operation.
134  * @note The buffer is organized as a matrix of M*N elements where M is the
135  * channels number configured into the conversion group and N is the
136  * buffer depth. The samples are sequentially written into the buffer
137  * with no gaps.
138  *
139  * @param[in] adcp pointer to the @p ADCDriver object
140  * @param[in] grpp pointer to a @p ADCConversionGroup object
141  * @param[out] samples pointer to the samples buffer
142  * @param[in] depth buffer depth (matrix rows number). The buffer depth
143  * must be one or an even number.
144  *
145  * @api
146  */
148  const ADCConversionGroup *grpp,
149  adcsample_t *samples,
150  size_t depth) {
151
152  osalSysLock();
153  adcStartConversionI(adcp, grpp, samples, depth);
154  osalSysUnlock();
155 }
156
157 /**
158  * @brief Starts an ADC conversion.
159  * @details Starts an asynchronous conversion operation.
160  * @post The callbacks associated to the conversion group will be invoked
161  * on buffer fill and error events.
162  * @note The buffer is organized as a matrix of M*N elements where M is the
163  * channels number configured into the conversion group and N is the
164  * buffer depth. The samples are sequentially written into the buffer
165  * with no gaps.
166  *
167  * @param[in] adcp pointer to the @p ADCDriver object
168  * @param[in] grpp pointer to a @p ADCConversionGroup object
169  * @param[out] samples pointer to the samples buffer
170  * @param[in] depth buffer depth (matrix rows number). The buffer depth
171  * must be one or an even number.
172  *
173  * @iclass
174  */
176  const ADCConversionGroup *grpp,
177  adcsample_t *samples,
178  size_t depth) {
179
181  osalDbgCheck((adcp != NULL) && (grpp != NULL) && (samples != NULL) &&
182  (depth > 0U) && ((depth == 1U) || ((depth & 1U) == 0U)));
183  osalDbgAssert((adcp->state == ADC_READY) ||
184  (adcp->state == ADC_COMPLETE) ||
185  (adcp->state == ADC_ERROR),
186  "not ready");
187
188  adcp->samples = samples;
189  adcp->depth = depth;
190  adcp->grpp = grpp;
191  adcp->state = ADC_ACTIVE;
193 }
194
195 /**
196  * @brief Stops an ongoing conversion.
197  * @details This function stops the currently ongoing conversion and returns
198  * the driver in the @p ADC_READY state. If there was no conversion
199  * being processed then the function does nothing.
200  *
201  * @param[in] adcp pointer to the @p ADCDriver object
202  *
203  * @api
204  */
206
207  osalDbgCheck(adcp != NULL);
208
209  osalSysLock();
210  osalDbgAssert((adcp->state == ADC_READY) || (adcp->state == ADC_ACTIVE),
211  "invalid state");
212  if (adcp->state != ADC_READY) {
214  adcp->grpp = NULL;
215  adcp->state = ADC_READY;
216  _adc_reset_s(adcp);
217  }
218  osalSysUnlock();
219 }
220
221 /**
222  * @brief Stops an ongoing conversion.
223  * @details This function stops the currently ongoing conversion and returns
224  * the driver in the @p ADC_READY state. If there was no conversion
225  * being processed then the function does nothing.
226  *
227  * @param[in] adcp pointer to the @p ADCDriver object
228  *
229  * @iclass
230  */
232
234  osalDbgCheck(adcp != NULL);
235  osalDbgAssert((adcp->state == ADC_READY) ||
236  (adcp->state == ADC_ACTIVE) ||
237  (adcp->state == ADC_COMPLETE),
238  "invalid state");
239
240  if (adcp->state != ADC_READY) {
242  adcp->grpp = NULL;
243  adcp->state = ADC_READY;
244  _adc_reset_i(adcp);
245  }
246 }
247
248 #if (ADC_USE_WAIT == TRUE) || defined(__DOXYGEN__)
249 /**
250  * @brief Performs an ADC conversion.
251  * @details Performs a synchronous conversion operation.
252  * @note The buffer is organized as a matrix of M*N elements where M is the
253  * channels number configured into the conversion group and N is the
254  * buffer depth. The samples are sequentially written into the buffer
255  * with no gaps.
256  *
257  * @param[in] adcp pointer to the @p ADCDriver object
258  * @param[in] grpp pointer to a @p ADCConversionGroup object
259  * @param[out] samples pointer to the samples buffer
260  * @param[in] depth buffer depth (matrix rows number). The buffer depth
261  * must be one or an even number.
262  * @return The operation result.
263  * @retval MSG_OK Conversion finished.
264  * @retval MSG_RESET The conversion has been stopped using
265  * @p acdStopConversion() or @p acdStopConversionI(),
266  * the result buffer may contain incorrect data.
267  * @retval MSG_TIMEOUT The conversion has been stopped because an hardware
268  * error.
269  *
270  * @api
271  */
273  const ADCConversionGroup *grpp,
274  adcsample_t *samples,
275  size_t depth) {
276  msg_t msg;
277
278  osalSysLock();
279  osalDbgAssert(adcp->thread == NULL, "already waiting");
280  adcStartConversionI(adcp, grpp, samples, depth);
281  msg = osalThreadSuspendS(&adcp->thread);
282  osalSysUnlock();
283  return msg;
284 }
285 #endif /* ADC_USE_WAIT == TRUE */
286
287 #if (ADC_USE_MUTUAL_EXCLUSION == TRUE) || defined(__DOXYGEN__)
288 /**
289  * @brief Gains exclusive access to the ADC peripheral.
290  * @details This function tries to gain ownership to the ADC bus, if the bus
291  * is already being used then the invoking thread is queued.
292  * @pre In order to use this function the option
293  * @p ADC_USE_MUTUAL_EXCLUSION must be enabled.
294  *
295  * @param[in] adcp pointer to the @p ADCDriver object
296  *
297  * @api
298  */
300
301  osalDbgCheck(adcp != NULL);
302
303  osalMutexLock(&adcp->mutex);
304 }
305
306 /**
307  * @brief Releases exclusive access to the ADC peripheral.
308  * @pre In order to use this function the option
309  * @p ADC_USE_MUTUAL_EXCLUSION must be enabled.
310  *
311  * @param[in] adcp pointer to the @p ADCDriver object
312  *
313  * @api
314  */
316
317  osalDbgCheck(adcp != NULL);
318
319  osalMutexUnlock(&adcp->mutex);
320 }
321 #endif /* ADC_USE_MUTUAL_EXCLUSION == TRUE */
322
323 #endif /* HAL_USE_ADC == TRUE */
324
325 /** @} */
static void osalMutexObjectInit(mutex_t *mp)
Initializes s mutex_t object.
Definition: osal.h:681
Initializes the standard part of a ADCDriver structure.
Definition: hal_adc.c:68
msg_t osalThreadSuspendS(thread_reference_t *trp)
Sends the current thread sleeping and sets a reference variable.
Definition: osal.c:185
#define _adc_reset_i(adcp)
Resumes a thread waiting for a conversion completion.
Definition: hal_adc.h:97
void adcStartConversion(ADCDriver *adcp, const ADCConversionGroup *grpp, adcsample_t *samples, size_t depth)
Definition: hal_adc.c:147
Definition: hal_adc.c:115
void adcAcquireBus(ADCDriver *adcp)
Definition: hal_adc.c:299
const ADCConversionGroup * grpp
Current conversion group pointer or NULL.
Definition: hal_adc_lld.h:164
#define osalDbgCheckClassI()
I-Class state check.
Definition: osal.h:292
void adc_lld_start(ADCDriver *adcp)
Definition: hal_adc_lld.c:80
void osalMutexLock(mutex_t *mp)
Locks the specified mutex.
Definition: osal.c:384
Definition: osal.h:540
thread_reference_t thread
Waiting thread.
Definition: hal_adc_lld.h:169
void adcReleaseBus(ADCDriver *adcp)
Definition: hal_adc.c:315
Conversion group configuration structure.
Definition: hal_adc_lld.h:113
#define _adc_reset_s(adcp)
Definition: hal_adc.h:107
Definition: hal_adc.c:95
void adc_lld_stop_conversion(ADCDriver *adcp)
Definition: hal_adc_lld.c:134
Structure representing an ADC driver.
Definition: hal_adc_lld.h:144
msg_t adcConvert(ADCDriver *adcp, const ADCConversionGroup *grpp, adcsample_t *samples, size_t depth)
Definition: hal_adc.c:272
adcstate_t state
Definition: hal_adc_lld.h:148
void adcStopConversion(ADCDriver *adcp)
Definition: hal_adc.c:205
void adcStartConversionI(ADCDriver *adcp, const ADCConversionGroup *grpp, adcsample_t *samples, size_t depth)
Definition: hal_adc.c:175
uint16_t adcsample_t
ADC sample data type.
Definition: hal_adc_lld.h:63
mutex_t mutex
Mutex protecting the peripheral.
Definition: hal_adc_lld.h:175
static void osalSysLock(void)
Definition: osal.h:530
void adcStopConversionI(ADCDriver *adcp)
Definition: hal_adc.c:231
void adc_lld_stop(ADCDriver *adcp)
Definition: hal_adc_lld.c:101
void adc_lld_init(void)
Low level ADC driver initialization.
Definition: hal_adc_lld.c:65
void osalMutexUnlock(mutex_t *mp)
Unlocks the specified mutex.
Definition: osal.c:404
size_t depth
Current samples buffer depth or 0.
Definition: hal_adc_lld.h:160
Definition: hal_adc_lld.h:137
adcsample_t * samples
Current samples buffer pointer or NULL.
Definition: hal_adc_lld.h:156
void adc_lld_start_conversion(ADCDriver *adcp)
Definition: hal_adc_lld.c:122
int32_t msg_t
Definition: chtypes.h:51
void adcInit(void)
Definition: hal_adc.c:56
const ADCConfig * config
Current configuration data.
Definition: hal_adc_lld.h:152
