osal.c
18  * @file osal.c
19  * @brief OSAL module code.
21  * @addtogroup OSAL
25 #include "osal.h"
27 /*===========================================================================*/
28 /* Module local definitions. */
30
32 /* Module exported variables. */
34
35 /**
36  * @brief Pointer to a halt error message.
37  * @note The message is meant to be retrieved by the debugger after the
38  * system halt caused by an unexpected error.
39  */
40 const char *osal_halt_msg;
41
43 /* Module local types. */
45
47 /* Module local variables. */
49
51 /* Module local functions. */
53
55 /* Module exported functions. */
57
58 /**
59  * @brief OSAL module initialization.
60  *
61  * @api
62  */
63 void osalInit(void) {
64
65 }
66
67 /**
68  * @brief System halt with error message.
69  *
70  * @param[in] reason the halt message pointer
71  *
72  * @api
73  */
74 #if !defined(__DOXYGEN__)
75 __attribute__((weak, noreturn))
76 #endif
77 void osalSysHalt(const char *reason) {
78
80  osal_halt_msg = reason;
81  while (true) {
82  }
83 }
84
85 /**
86  * @brief Polled delay.
87  * @note The real delay is always few cycles in excess of the specified
88  * value.
89  *
90  * @param[in] cycles number of cycles
91  *
92  * @xclass
93  */
95
96  (void)cycles;
97 }
98
99 /**
100  * @brief System timer handler.
101  * @details The handler is used for scheduling and Virtual Timers management.
102  *
103  * @iclass
104  */
106
108 }
109
110 /**
111  * @brief Checks if a reschedule is required and performs it.
112  * @note I-Class functions invoked from thread context must not reschedule
113  * by themselves, an explicit reschedule using this function is
114  * required in this scenario.
115  * @note Not implemented in this simplified OSAL.
116  *
117  * @sclass
118  */
119 void osalOsRescheduleS(void) {
120
121 }
122
123 /**
124  * @brief Current system time.
125  * @details Returns the number of system ticks since the @p osalInit()
126  * invocation.
127  * @note The counter can reach its maximum and then restart from zero.
128  * @note This function can be called from any context but its atomicity
129  * is not guaranteed on architectures whose word size is less than
130  * @p systime_t size.
131  *
132  * @return The system time in ticks.
133  *
134  * @xclass
135  */
137
138  return (systime_t)0;
139 }
140
141 /**
142  * @brief Suspends the invoking thread for the specified time.
143  *
144  * @param[in] time the delay in system ticks, the special values are
145  * handled as follow:
146  * - @a TIME_INFINITE is allowed but interpreted as a
147  * normal time specification.
148  * - @a TIME_IMMEDIATE this value is not allowed.
149  * .
150  *
151  * @sclass
152  */
154
155  (void)time;
156 }
157
158 /**
159  * @brief Suspends the invoking thread for the specified time.
160  *
161  * @param[in] time the delay in system ticks, the special values are
162  * handled as follow:
163  * - @a TIME_INFINITE is allowed but interpreted as a
164  * normal time specification.
165  * - @a TIME_IMMEDIATE this value is not allowed.
166  * .
167  *
168  * @api
169  */
171
172  (void)time;
173 }
174
175 /**
176  * @brief Sends the current thread sleeping and sets a reference variable.
177  * @note This function must reschedule, it can only be called from thread
178  * context.
179  *
180  * @param[in] trp a pointer to a thread reference object
181  * @return The wake up message.
182  *
183  * @sclass
184  */
186
187  osalDbgCheck(trp != NULL);
188
189  return MSG_OK;
190 }
191
192 /**
193  * @brief Sends the current thread sleeping and sets a reference variable.
194  * @note This function must reschedule, it can only be called from thread
195  * context.
196  *
197  * @param[in] trp a pointer to a thread reference object
198  * @param[in] timeout the timeout in system ticks, the special values are
199  * handled as follow:
200  * - @a TIME_INFINITE the thread enters an infinite sleep
201  * state.
202  * - @a TIME_IMMEDIATE the thread is not enqueued and
203  * the function returns @p MSG_TIMEOUT as if a timeout
204  * occurred.
205  * .
206  * @return The wake up message.
207  * @retval MSG_TIMEOUT if the operation timed out.
208  *
209  * @sclass
210  */
212
213  osalDbgCheck(trp != NULL);
214
215  (void)timeout;
216
217  return MSG_OK;
218 }
219
220 /**
221  * @brief Wakes up a thread waiting on a thread reference object.
222  * @note This function must not reschedule because it can be called from
223  * ISR context.
224  *
225  * @param[in] trp a pointer to a thread reference object
226  * @param[in] msg the message code
227  *
228  * @iclass
229  */
231
232  osalDbgCheck(trp != NULL);
233
234  (void)msg;
235 }
236
237 /**
238  * @brief Wakes up a thread waiting on a thread reference object.
239  * @note This function must reschedule, it can only be called from thread
240  * context.
241  *
242  * @param[in] trp a pointer to a thread reference object
243  * @param[in] msg the message code
244  *
245  * @iclass
246  */
248
249  osalDbgCheck(trp != NULL);
250
251  (void)msg;
252 }
253
254 /**
255  * @brief Enqueues the caller thread.
256  * @details The caller thread is enqueued and put to sleep until it is
257  * dequeued or the specified timeouts expires.
258  *
259  * @param[in] tqp pointer to the threads queue object
260  * @param[in] timeout the timeout in system ticks, the special values are
261  * handled as follow:
262  * - @a TIME_INFINITE the thread enters an infinite sleep
263  * state.
264  * - @a TIME_IMMEDIATE the thread is not enqueued and
265  * the function returns @p MSG_TIMEOUT as if a timeout
266  * occurred.
267  * .
268  * @return The message from @p osalQueueWakeupOneI() or
269  * @p osalQueueWakeupAllI() functions.
270  * @retval MSG_TIMEOUT if the thread has not been dequeued within the
271  * specified timeout or if the function has been
272  * invoked with @p TIME_IMMEDIATE as timeout
273  * specification.
274  *
275  * @sclass
276  */
278
279  osalDbgCheck(tqp != NULL);
280
281  (void)timeout;
282
283  return MSG_OK;
284 }
285
286 /**
287  * @brief Dequeues and wakes up one thread from the queue, if any.
288  *
289  * @param[in] tqp pointer to the threads queue object
290  * @param[in] msg the message code
291  *
292  * @iclass
293  */
295
296  osalDbgCheck(tqp != NULL);
297
298  (void)msg;
299 }
300
301 /**
302  * @brief Dequeues and wakes up all threads from the queue.
303  *
304  * @param[in] tqp pointer to the threads queue object
305  * @param[in] msg the message code
306  *
307  * @iclass
308  */
310
311  (void)tqp;
312  (void)msg;
313 }
314
315 /**
316  * @brief Add flags to an event source object.
317  *
318  * @param[in] esp pointer to the event flags object
319  * @param[in] flags flags to be ORed to the flags mask
320  *
321  * @iclass
322  */
324
325  osalDbgCheck(esp != NULL);
326
327  esp->flags |= flags;
328  if (esp->cb != NULL) {
329  esp->cb(esp);
330  }
331 }
332
333 /**
334  * @brief Add flags to an event source object.
335  *
336  * @param[in] esp pointer to the event flags object
337  * @param[in] flags flags to be ORed to the flags mask
338  *
339  * @iclass
340  */
342
343  osalDbgCheck(esp != NULL);
344
345  osalSysLock();
346  osalEventBroadcastFlagsI(esp, flags);
347  osalSysUnlock();
348 }
349
350 /**
351  * @brief Event callback setup.
352  * @note The callback is invoked from ISR context and can
353  * only invoke I-Class functions. The callback is meant
354  * to wakeup the task that will handle the event by
355  * calling @p osalEventGetAndClearFlagsI().
356  * @note This function is not part of the OSAL API and is provided
357  * exclusively as an example and for convenience.
358  *
359  * @param[in] esp pointer to the event flags object
360  * @param[in] cb pointer to the callback function
361  * @param[in] param parameter to be passed to the callback function
362  *
363  * @api
364  */
366  eventcallback_t cb,
367  void *param) {
368
369  osalDbgCheck(esp != NULL);
370
371  esp->cb = cb;
372  esp->param = param;
373 }
374
375 /**
376  * @brief Locks the specified mutex.
377  * @post The mutex is locked and inserted in the per-thread stack of owned
378  * mutexes.
379  *
380  * @param[in,out] mp pointer to the @p mutex_t object
381  *
382  * @api
383  */
385
386  osalDbgCheck(mp != NULL);
387
388  *mp = 1;
389 }
390
391 /**
392  * @brief Unlocks the specified mutex.
393  * @note The HAL guarantees to release mutex in reverse lock order. The
394  * mutex being unlocked is guaranteed to be the last locked mutex
395  * by the invoking thread.
396  * The implementation can rely on this behavior and eventually
397  * ignore the @p mp parameter which is supplied in order to support
398  * those OSes not supporting a stack of the owned mutexes.
399  *
400  * @param[in,out] mp pointer to the @p mutex_t object
401  *
402  * @api
403  */
405
406  osalDbgCheck(mp != NULL);
407
408  *mp = 0;
409 }
410
411 /** @} */
OSAL module header.
msg_t osalThreadSuspendS(thread_reference_t *trp)
Definition: osal.c:185
void osalThreadDequeueAllI(threads_queue_t *tqp, msg_t msg)
Definition: osal.c:309
uint64_t systime_t
Type of system time.
Definition: chtime.h:107
void osalThreadSleep(sysinterval_t time)
Definition: osal.c:170
uint64_t sysinterval_t
Type of time interval.
Definition: chtime.h:119
Definition: osal.c:77
Event Source structure.
Definition: chevents.h:74
void osalOsTimerHandlerI(void)
Definition: osal.c:105
static void osalSysDisable(void)
Disables interrupts globally.
Definition: osal.h:511
#define osalDbgCheckClassI()
I-Class state check.
Definition: osal.h:292
void osalMutexLock(mutex_t *mp)
Definition: osal.c:384
Definition: osal.h:540
Definition: osal.c:119
uint32_t rtcnt_t
Definition: chtypes.h:43
void osalSysPolledDelayX(rtcnt_t cycles)
Polled delay.
Definition: osal.c:94
Mutex structure.
Definition: chmtx.h:57
void osalEventBroadcastFlagsI(event_source_t *esp, eventflags_t flags)
Definition: osal.c:323
Type of a thread queue.
Definition: osal.h:232
void osalEventBroadcastFlags(event_source_t *esp, eventflags_t flags)
Definition: osal.c:341
void osalThreadSleepS(sysinterval_t time)
Definition: osal.c:153
void(* eventcallback_t)(event_source_t *esp)
Type of an event source callback.
Definition: osal.h:202
void osalEventSetCallback(event_source_t *esp, eventcallback_t cb, void *param)
Definition: osal.c:365
volatile eventflags_t flags
Stored event flags.
Definition: osal.h:213
#define MSG_OK
Normal wakeup message.
Definition: chschd.h:39
systime_t osalOsGetSystemTimeX(void)
Definition: osal.c:136
void osalThreadDequeueNextI(threads_queue_t *tqp, msg_t msg)
Definition: osal.c:294
void osalInit(void)
Definition: osal.c:63
msg_t osalThreadEnqueueTimeoutS(threads_queue_t *tqp, sysinterval_t timeout)
Definition: osal.c:277
void * param
User defined field.
Definition: osal.h:215
msg_t osalThreadSuspendTimeoutS(thread_reference_t *trp, sysinterval_t timeout)
Definition: osal.c:211
void osalThreadResumeS(thread_reference_t *trp, msg_t msg)
Definition: osal.c:247
static void osalSysLock(void)
Definition: osal.h:530
const char * osal_halt_msg
Definition: osal.c:40
eventcallback_t cb
Event source callback.
Definition: osal.h:214
void osalMutexUnlock(mutex_t *mp)
Definition: osal.c:404
void osalThreadResumeI(thread_reference_t *trp, msg_t msg)
Definition: osal.c:230
uint32_t eventflags_t
Definition: chtypes.h:54
int32_t msg_t
Definition: chtypes.h:51
Definition: chschd.h:153
