hal_crypto.c
18  * @file hal_crypto.c
19  * @brief Cryptographic Driver code.
21  * @addtogroup CRYPTO
27 #if (HAL_USE_CRY == TRUE) || defined(__DOXYGEN__)
38 /* Driver local variables and types. */
46 /* Driver exported functions. */
49 /**
50  * @brief Cryptographic Driver initialization.
51  * @note This function is implicitly invoked by @p halInit(), there is
52  * no need to explicitly initialize the driver.
53  *
54  * @init
55  */
56 void cryInit(void) {
57
58 #if HAL_CRY_ENFORCE_FALLBACK == FALSE
59  cry_lld_init();
60 #endif
61 }
62
63 /**
64  * @brief Initializes the standard part of a @p CRYDriver structure.
65  *
66  * @param[out] cryp pointer to the @p CRYDriver object
67  *
68  * @init
69  */
70 void cryObjectInit(CRYDriver *cryp) {
71
72  cryp->state = CRY_STOP;
73  cryp->config = NULL;
74 #if defined(CRY_DRIVER_EXT_INIT_HOOK)
75  CRY_DRIVER_EXT_INIT_HOOK(cryp);
76 #endif
77 }
78
79 /**
80  * @brief Configures and activates the cryptographic peripheral.
81  *
82  * @param[in] cryp pointer to the @p CRYDriver object
83  * @param[in] config pointer to the @p CRYConfig object. Depending
84  * on the implementation the value can be @p NULL.
85  *
86  * @api
87  */
88 void cryStart(CRYDriver *cryp, const CRYConfig *config) {
89
90  osalDbgCheck(cryp != NULL);
91
92  osalSysLock();
93  osalDbgAssert((cryp->state == CRY_STOP) || (cryp->state == CRY_READY),
94  "invalid state");
95  cryp->config = config;
96 #if HAL_CRY_ENFORCE_FALLBACK == FALSE
97  cry_lld_start(cryp);
98 #endif
99  cryp->state = CRY_READY;
100  osalSysUnlock();
101 }
102
103 /**
104  * @brief Deactivates the cryptographic peripheral.
105  *
106  * @param[in] cryp pointer to the @p CRYDriver object
107  *
108  * @api
109  */
110 void cryStop(CRYDriver *cryp) {
111
112  osalDbgCheck(cryp != NULL);
113
114  osalSysLock();
115
116  osalDbgAssert((cryp->state == CRY_STOP) || (cryp->state == CRY_READY),
117  "invalid state");
118
119 #if HAL_CRY_ENFORCE_FALLBACK == FALSE
120  cry_lld_stop(cryp);
121 #endif
122  cryp->config = NULL;
123  cryp->state = CRY_STOP;
124
125  osalSysUnlock();
126 }
127
128 /**
129  * @brief Initializes the transient key for a specific algorithm.
130  * @note It is the underlying implementation to decide which combinations
131  * of algorithm and key size are allowable.
132  *
133  * @param[in] cryp pointer to the @p CRYDriver object
134  * @param[in] algorithm the algorithm identifier
135  * @param[in] size key size in bytes
136  * @param[in] keyp pointer to the key data
137  * @return The operation status.
138  * @retval CRY_NOERROR if the operation succeeded.
139  * @retval CRY_ERR_INV_ALGO if the specified algorithm is unknown or
140  * unsupported.
141  * @retval CRY_ERR_INV_KEY_SIZE if the specified key size is invalid for
142  * the specified algorithm.
143  *
144  * @api
145  */
147  cryalgorithm_t algorithm,
148  size_t size,
149  const uint8_t *keyp) {
150  cryerror_t err;
151
152  osalDbgCheck((cryp != NULL) && (size <= HAL_CRY_MAX_KEY_SIZE) &&
153  (keyp != NULL));
154
155
156 #if HAL_CRY_ENFORCE_FALLBACK == FALSE
157  /* Key setup in the low level driver.*/
158  err = cry_lld_loadkey(cryp, algorithm, size, keyp);
159 #else
160  err = CRY_ERR_INV_ALGO;
161 #endif
162
163 #if HAL_CRY_USE_FALLBACK == TRUE
164  if (err == CRY_ERR_INV_ALGO) {
165  err = cry_fallback_loadkey(cryp, algorithm, size, keyp);
166  }
167 #endif
168
169  if (err == CRY_NOERROR) {
170  /* Storing the transient key info.*/
171  cryp->key0_type = algorithm;
172  cryp->key0_size = size;
173  }
174
175  return err;
176 }
177
178 /**
179  * @brief Encryption of a single block using AES.
180  * @note The implementation of this function must guarantee that it can
181  * be called from any context.
182  *
183  * @param[in] cryp pointer to the @p CRYDriver object
184  * @param[in] key_id the key to be used for the operation, zero is
185  * the transient key, other values are keys stored
186  * in an unspecified way
187  * @param[in] in buffer containing the input plaintext
188  * @param[out] out buffer for the output cyphertext
189  * @return The operation status.
190  * @retval CRY_NOERROR if the operation succeeded.
191  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
192  * device instance.
193  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
194  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
195  * or refers to an empty key slot.
196  *
197  * @special
198  */
200  crykey_t key_id,
201  const uint8_t *in,
202  uint8_t *out) {
203
204  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL));
205
206  osalDbgAssert(cryp->state == CRY_READY, "not ready");
207
208 #if CRY_LLD_SUPPORTS_AES == TRUE
209  return cry_lld_encrypt_AES(cryp, key_id, in, out);
210 #elif HAL_CRY_USE_FALLBACK == TRUE
211  return cry_fallback_encrypt_AES(cryp, key_id, in, out);
212 #else
213  (void)cryp;
214  (void)key_id;
215  (void)in;
216  (void)out;
217
218  return CRY_ERR_INV_ALGO;
219 #endif
220 }
221
222 /**
223  * @brief Decryption of a single block using AES.
224  * @note The implementation of this function must guarantee that it can
225  * be called from any context.
226  *
227  * @param[in] cryp pointer to the @p CRYDriver object
228  * @param[in] key_id the key to be used for the operation, zero is
229  * the transient key, other values are keys stored
230  * in an unspecified way
231  * @param[in] in buffer containing the input cyphertext
232  * @param[out] out buffer for the output plaintext
233  * @return The operation status.
234  * @retval CRY_NOERROR if the operation succeeded.
235  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
236  * device instance.
237  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
238  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
239  * or refers to an empty key slot.
240  *
241  * @special
242  */
244  crykey_t key_id,
245  const uint8_t *in,
246  uint8_t *out) {
247
248  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL));
249
250  osalDbgAssert(cryp->state == CRY_READY, "not ready");
251
252 #if CRY_LLD_SUPPORTS_AES == TRUE
253  return cry_lld_decrypt_AES(cryp, key_id, in, out);
254 #elif HAL_CRY_USE_FALLBACK == TRUE
255  return cry_fallback_decrypt_AES(cryp, key_id, in, out);
256 #else
257  (void)cryp;
258  (void)key_id;
259  (void)in;
260  (void)out;
261
262  return CRY_ERR_INV_ALGO;
263 #endif
264 }
265
266 /**
267  * @brief Encryption operation using AES-ECB.
268  * @note The function operates on data buffers whose length is a multiple
269  * of an AES block, this means that padding must be done by the
270  * caller.
271  *
272  * @param[in] cryp pointer to the @p CRYDriver object
273  * @param[in] key_id the key to be used for the operation, zero is
274  * the transient key, other values are keys stored
275  * in an unspecified way
276  * @param[in] size size of both buffers, this number must be a
277  * multiple of 16
278  * @param[in] in buffer containing the input plaintext
279  * @param[out] out buffer for the output cyphertext
280  * @return The operation status.
281  * @retval CRY_NOERROR if the operation succeeded.
282  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
283  * device instance.
284  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
285  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
286  * or refers to an empty key slot.
287  *
288  * @api
289  */
291  crykey_t key_id,
292  size_t size,
293  const uint8_t *in,
294  uint8_t *out) {
295
296  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
297  ((size & (size_t)15) == (size_t)0));
298
299  osalDbgAssert(cryp->state == CRY_READY, "not ready");
300
301 #if CRY_LLD_SUPPORTS_AES_ECB == TRUE
302  return cry_lld_encrypt_AES_ECB(cryp, key_id, size, in, out);
303 #elif HAL_CRY_USE_FALLBACK == TRUE
304  return cry_fallback_encrypt_AES_ECB(cryp, key_id, size, in, out);
305 #else
306  (void)cryp;
307  (void)key_id;
308  (void)size;
309  (void)in;
310  (void)out;
311
312  return CRY_ERR_INV_ALGO;
313 #endif
314 }
315
316 /**
317  * @brief Decryption operation using AES-ECB.
318  * @note The function operates on data buffers whose length is a multiple
319  * of an AES block, this means that padding must be done by the
320  * caller.
321  *
322  * @param[in] cryp pointer to the @p CRYDriver object
323  * @param[in] key_id the key to be used for the operation, zero is
324  * the transient key, other values are keys stored
325  * in an unspecified way
326  * @param[in] size size of both buffers, this number must be a
327  * multiple of 16
328  * @param[in] in buffer containing the input cyphertext
329  * @param[out] out buffer for the output plaintext
330  * @return The operation status.
331  * @retval CRY_NOERROR if the operation succeeded.
332  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
333  * device instance.
334  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
335  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
336  * or refers to an empty key slot.
337  *
338  * @api
339  */
341  crykey_t key_id,
342  size_t size,
343  const uint8_t *in,
344  uint8_t *out) {
345
346  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
347  ((size & (size_t)15) == (size_t)0));
348
349  osalDbgAssert(cryp->state == CRY_READY, "not ready");
350
351 #if CRY_LLD_SUPPORTS_AES_ECB == TRUE
352  return cry_lld_decrypt_AES_ECB(cryp, key_id, size, in, out);
353 #elif HAL_CRY_USE_FALLBACK == TRUE
354  return cry_fallback_decrypt_AES_ECB(cryp, key_id, size, in, out);
355 #else
356  (void)cryp;
357  (void)key_id;
358  (void)size;
359  (void)in;
360  (void)out;
361
362  return CRY_ERR_INV_ALGO;
363 #endif
364 }
365
366 /**
367  * @brief Encryption operation using AES-CBC.
368  * @note The function operates on data buffers whose length is a multiple
369  * of an AES block, this means that padding must be done by the
370  * caller.
371  *
372  * @param[in] cryp pointer to the @p CRYDriver object
373  * @param[in] key_id the key to be used for the operation, zero is
374  * the transient key, other values are keys stored
375  * in an unspecified way
376  * @param[in] size size of both buffers, this number must be a
377  * multiple of 16
378  * @param[in] in buffer containing the input plaintext
379  * @param[out] out buffer for the output cyphertext
380  * @param[in] iv 128 bits input vector
381  * @return The operation status.
382  * @retval CRY_NOERROR if the operation succeeded.
383  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
384  * device instance.
385  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
386  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
387  * or refers to an empty key slot.
388  *
389  * @api
390  */
392  crykey_t key_id,
393  size_t size,
394  const uint8_t *in,
395  uint8_t *out,
396  const uint8_t *iv) {
397
398  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
399  (iv != NULL) && ((size & (size_t)15) == (size_t)0));
400
401  osalDbgAssert(cryp->state == CRY_READY, "not ready");
402
403 #if CRY_LLD_SUPPORTS_AES_CBC == TRUE
404  return cry_lld_encrypt_AES_CBC(cryp, key_id, size, in, out, iv);
405 #elif HAL_CRY_USE_FALLBACK == TRUE
406  return cry_fallback_encrypt_AES_CBC(cryp, key_id, size, in, out, iv);
407 #else
408  (void)cryp;
409  (void)key_id;
410  (void)size;
411  (void)in;
412  (void)out;
413  (void)iv;
414
415  return CRY_ERR_INV_ALGO;
416 #endif
417 }
418
419 /**
420  * @brief Decryption operation using AES-CBC.
421  * @note The function operates on data buffers whose length is a multiple
422  * of an AES block, this means that padding must be done by the
423  * caller.
424  *
425  * @param[in] cryp pointer to the @p CRYDriver object
426  * @param[in] key_id the key to be used for the operation, zero is
427  * the transient key, other values are keys stored
428  * in an unspecified way
429  * @param[in] size size of both buffers, this number must be a
430  * multiple of 16
431  * @param[in] in buffer containing the input cyphertext
432  * @param[out] out buffer for the output plaintext
433  * @param[in] iv 128 bits input vector
434  * @return The operation status.
435  * @retval CRY_NOERROR if the operation succeeded.
436  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
437  * device instance.
438  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
439  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
440  * or refers to an empty key slot.
441  *
442  * @api
443  */
445  crykey_t key_id,
446  size_t size,
447  const uint8_t *in,
448  uint8_t *out,
449  const uint8_t *iv) {
450
451  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
452  (iv != NULL) && ((size & (size_t)15) == (size_t)0));
453
454  osalDbgAssert(cryp->state == CRY_READY, "not ready");
455
456 #if CRY_LLD_SUPPORTS_AES_CBC == TRUE
457  return cry_lld_decrypt_AES_CBC(cryp, key_id, size, in, out, iv);
458 #elif HAL_CRY_USE_FALLBACK == TRUE
459  return cry_fallback_decrypt_AES_CBC(cryp, key_id, size, in, out, iv);
460 #else
461  (void)cryp;
462  (void)key_id;
463  (void)size;
464  (void)in;
465  (void)out;
466  (void)iv;
467
468  return CRY_ERR_INV_ALGO;
469 #endif
470 }
471
472 /**
473  * @brief Encryption operation using AES-CFB.
474  * @note The function operates on data buffers whose length is a multiple
475  * of an AES block, this means that padding must be done by the
476  * caller.
477  *
478  * @param[in] cryp pointer to the @p CRYDriver object
479  * @param[in] key_id the key to be used for the operation, zero is
480  * the transient key, other values are keys stored
481  * in an unspecified way
482  * @param[in] size size of both buffers, this number must be a
483  * multiple of 16
484  * @param[in] in buffer containing the input plaintext
485  * @param[out] out buffer for the output cyphertext
486  * @param[in] iv 128 bits input vector
487  * @return The operation status.
488  * @retval CRY_NOERROR if the operation succeeded.
489  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
490  * device instance.
491  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
492  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
493  * or refers to an empty key slot.
494  *
495  * @api
496  */
498  crykey_t key_id,
499  size_t size,
500  const uint8_t *in,
501  uint8_t *out,
502  const uint8_t *iv) {
503
504  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
505  (iv != NULL) && ((size & (size_t)15) == (size_t)0));
506
507  osalDbgAssert(cryp->state == CRY_READY, "not ready");
508
509 #if CRY_LLD_SUPPORTS_AES_CFB == TRUE
510  return cry_lld_encrypt_AES_CFB(cryp, key_id, size, in, out, iv);
511 #elif HAL_CRY_USE_FALLBACK == TRUE
512  return cry_fallback_encrypt_AES_CFB(cryp, key_id, size, in, out, iv);
513 #else
514  (void)cryp;
515  (void)key_id;
516  (void)size;
517  (void)in;
518  (void)out;
519  (void)iv;
520
521  return CRY_ERR_INV_ALGO;
522 #endif
523 }
524
525 /**
526  * @brief Decryption operation using AES-CFB.
527  * @note The function operates on data buffers whose length is a multiple
528  * of an AES block, this means that padding must be done by the
529  * caller.
530  *
531  * @param[in] cryp pointer to the @p CRYDriver object
532  * @param[in] key_id the key to be used for the operation, zero is
533  * the transient key, other values are keys stored
534  * in an unspecified way
535  * @param[in] size size of both buffers, this number must be a
536  * multiple of 16
537  * @param[in] in buffer containing the input cyphertext
538  * @param[out] out buffer for the output plaintext
539  * @param[in] iv 128 bits input vector
540  * @return The operation status.
541  * @retval CRY_NOERROR if the operation succeeded.
542  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
543  * device instance.
544  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
545  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
546  * or refers to an empty key slot.
547  *
548  * @api
549  */
551  crykey_t key_id,
552  size_t size,
553  const uint8_t *in,
554  uint8_t *out,
555  const uint8_t *iv) {
556
557  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
558  (iv != NULL) && ((size & (size_t)15) == (size_t)0));
559
560  osalDbgAssert(cryp->state == CRY_READY, "not ready");
561
562 #if CRY_LLD_SUPPORTS_AES_CFB == TRUE
563  return cry_lld_decrypt_AES_CFB(cryp, key_id, size, in, out, iv);
564 #elif HAL_CRY_USE_FALLBACK == TRUE
565  return cry_fallback_decrypt_AES_CFB(cryp, key_id, size, in, out, iv);
566 #else
567  (void)cryp;
568  (void)key_id;
569  (void)size;
570  (void)in;
571  (void)out;
572  (void)iv;
573
574  return CRY_ERR_INV_ALGO;
575 #endif
576 }
577
578 /**
579  * @brief Encryption operation using AES-CTR.
580  * @note The function operates on data buffers whose length is a multiple
581  * of an AES block, this means that padding must be done by the
582  * caller.
583  *
584  * @param[in] cryp pointer to the @p CRYDriver object
585  * @param[in] key_id the key to be used for the operation, zero is
586  * the transient key, other values are keys stored
587  * in an unspecified way
588  * @param[in] size size of both buffers, this number must be a
589  * multiple of 16
590  * @param[in] in buffer containing the input plaintext
591  * @param[out] out buffer for the output cyphertext
592  * @param[in] iv 128 bits input vector + counter, it contains
593  * a 96 bits IV and a 32 bits counter
594  * @return The operation status.
595  * @retval CRY_NOERROR if the operation succeeded.
596  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
597  * device instance.
598  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
599  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
600  * or refers to an empty key slot.
601  *
602  * @api
603  */
605  crykey_t key_id,
606  size_t size,
607  const uint8_t *in,
608  uint8_t *out,
609  const uint8_t *iv) {
610
611  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
612  (iv != NULL) && ((size & (size_t)15) == (size_t)0));
613
614  osalDbgAssert(cryp->state == CRY_READY, "not ready");
615
616 #if CRY_LLD_SUPPORTS_AES_CTR == TRUE
617  return cry_lld_encrypt_AES_CTR(cryp, key_id, size, in, out, iv);
618 #elif HAL_CRY_USE_FALLBACK == TRUE
619  return cry_fallback_encrypt_AES_CTR(cryp, key_id, size, in, out, iv);
620 #else
621  (void)cryp;
622  (void)key_id;
623  (void)size;
624  (void)in;
625  (void)out;
626  (void)nonce;
627  (void)cnt;
628
629  return CRY_ERR_INV_ALGO;
630 #endif
631 }
632
633 /**
634  * @brief Decryption operation using AES-CTR.
635  * @note The function operates on data buffers whose length is a multiple
636  * of an AES block, this means that padding must be done by the
637  * caller.
638  *
639  * @param[in] cryp pointer to the @p CRYDriver object
640  * @param[in] key_id the key to be used for the operation, zero is
641  * the transient key, other values are keys stored
642  * in an unspecified way
643  * @param[in] size size of both buffers, this number must be a
644  * multiple of 16
645  * @param[in] in buffer containing the input cyphertext
646  * @param[out] out buffer for the output plaintext
647  * @param[in] iv 128 bits input vector + counter, it contains
648  * a 96 bits IV and a 32 bits counter
649  * @return The operation status.
650  * @retval CRY_NOERROR if the operation succeeded.
651  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
652  * device instance.
653  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
654  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
655  * or refers to an empty key slot.
656  *
657  * @api
658  */
660  crykey_t key_id,
661  size_t size,
662  const uint8_t *in,
663  uint8_t *out,
664  const uint8_t *iv) {
665
666  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
667  (iv != NULL) && ((size & (size_t)15) == (size_t)0));
668
669  osalDbgAssert(cryp->state == CRY_READY, "not ready");
670
671 #if CRY_LLD_SUPPORTS_AES_CTR == TRUE
672  return cry_lld_decrypt_AES_CTR(cryp, key_id, size, in, out, iv);
673 #elif HAL_CRY_USE_FALLBACK == TRUE
674  return cry_fallback_decrypt_AES_CTR(cryp, key_id, size, in, out, iv);
675 #else
676  (void)cryp;
677  (void)key_id;
678  (void)size;
679  (void)in;
680  (void)out;
681  (void)nonce;
682  (void)cnt;
683
684  return CRY_ERR_INV_ALGO;
685 #endif
686 }
687
688 /**
689  * @brief Encryption operation using AES-GCM.
690  * @note The function operates on data buffers whose length is a multiple
691  * of an AES block, this means that padding must be done by the
692  * caller.
693  *
694  * @param[in] cryp pointer to the @p CRYDriver object
695  * @param[in] key_id the key to be used for the operation, zero is
696  * the transient key, other values are keys stored
697  * in an unspecified way
698  * @param[in] size size of the text buffers, this number must be a
699  * multiple of 16
700  * @param[in] in buffer containing the input plaintext
701  * @param[out] out buffer for the output cyphertext
702  * @param[in] iv 128 bits input vector + counter, it contains
703  * a 96 bits IV and a 32 bits counter
704  * @param[in] aadsize size of the authentication data, this number
705  * must be a multiple of 16
706  * @param[in] aad buffer containing the authentication data
707  * @param[in] authtag 128 bits buffer for the generated authentication
708  * tag
709  * @return The operation status.
710  * @retval CRY_NOERROR if the operation succeeded.
711  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
712  * device instance.
713  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
714  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
715  * or refers to an empty key slot.
716  *
717  * @api
718  */
720  crykey_t key_id,
721  size_t size,
722  const uint8_t *in,
723  uint8_t *out,
724  const uint8_t *iv,
725  size_t aadsize,
726  const uint8_t *aad,
727  uint8_t *authtag) {
728
729  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
730  (iv != NULL) && (aad != NULL) && (authtag != NULL) &&
731  ((size & (size_t)15) == (size_t)0) &&
732  ((aadsize & (size_t)15) == (size_t)0));
733
734  osalDbgAssert(cryp->state == CRY_READY, "not ready");
735
736 #if CRY_LLD_SUPPORTS_AES_GCM== TRUE
737  return cry_lld_encrypt_AES_GCM(cryp, key_id, size, in, out, iv,
738  aadsize, aad, authtag);
739 #elif HAL_CRY_USE_FALLBACK == TRUE
740  return cry_fallback_encrypt_AES_GCM(cryp, key_id, size, in, out, iv,
741  aadsize, aad, authtag);
742 #else
743  (void)cryp;
744  (void)key_id;
745  (void)size;
746  (void)in;
747  (void)out;
748  (void)iv;
749  (void)aadsize;
750  (void)aad;
751  (void)authtag;
752
753  return CRY_ERR_INV_ALGO;
754 #endif
755 }
756
757 /**
758  * @brief Decryption operation using AES-GCM.
759  * @note The function operates on data buffers whose length is a multiple
760  * of an AES block, this means that padding must be done by the
761  * caller.
762  *
763  * @param[in] cryp pointer to the @p CRYDriver object
764  * @param[in] key_id the key to be used for the operation, zero is
765  * the transient key, other values are keys stored
766  * in an unspecified way
767  * @param[in] size size of the text buffers, this number must be a
768  * multiple of 16
769  * @param[in] in buffer for the output cyphertext
770  * @param[out] out buffer containing the input plaintext
771  * @param[in] iv 128 bits input vector + counter, it contains
772  * a 96 bits IV and a 32 bits counter
773  * @param[in] aadsize size of the authentication data, this number
774  * must be a multiple of 16
775  * @param[in] aad buffer containing the authentication data
776  * @param[in] authtag 128 bits buffer for the generated authentication
777  * tag
778  * @return The operation status.
779  * @retval CRY_NOERROR if the operation succeeded.
780  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
781  * device instance.
782  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
783  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
784  * or refers to an empty key slot.
785  *
786  * @api
787  */
789  crykey_t key_id,
790  size_t size,
791  const uint8_t *in,
792  uint8_t *out,
793  const uint8_t *iv,
794  size_t aadsize,
795  const uint8_t *aad,
796  uint8_t *authtag) {
797
798  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
799  (iv != NULL) && (aad != NULL) && (authtag != NULL) &&
800  ((size & (size_t)15) == (size_t)0) &&
801  ((aadsize & (size_t)15) == (size_t)0));
802
803  osalDbgAssert(cryp->state == CRY_READY, "not ready");
804
805 #if CRY_LLD_SUPPORTS_AES_GCM== TRUE
806  return cry_lld_decrypt_AES_GCM(cryp, key_id, size, in, out, iv,
807  aadsize, aad, authtag);
808 #elif HAL_CRY_USE_FALLBACK == TRUE
809  return cry_fallback_decrypt_AES_GCM(cryp, key_id, size, in, out, iv,
810  aadsize, aad, authtag);
811 #else
812  (void)cryp;
813  (void)key_id;
814  (void)size;
815  (void)in;
816  (void)out;
817  (void)iv;
818  (void)aadsize;
819  (void)aad;
820  (void)authtag;
821
822  return CRY_ERR_INV_ALGO;
823 #endif
824 }
825
826 /**
827  * @brief Encryption of a single block using (T)DES.
828  * @note The implementation of this function must guarantee that it can
829  * be called from any context.
830  *
831  * @param[in] cryp pointer to the @p CRYDriver object
832  * @param[in] key_id the key to be used for the operation, zero is
833  * the transient key, other values are keys stored
834  * in an unspecified way
835  * @param[in] in buffer containing the input plaintext
836  * @param[out] out buffer for the output cyphertext
837  * @return The operation status.
838  * @retval CRY_NOERROR if the operation succeeded.
839  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
840  * device instance.
841  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
842  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
843  * or refers to an empty key slot.
844  *
845  * @special
846  */
848  crykey_t key_id,
849  const uint8_t *in,
850  uint8_t *out) {
851
852  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL));
853
854  osalDbgAssert(cryp->state == CRY_READY, "not ready");
855
856 #if CRY_LLD_SUPPORTS_DES == TRUE
857  return cry_lld_encrypt_DES(cryp, key_id, in, out);
858 #elif HAL_CRY_USE_FALLBACK == TRUE
859  return cry_fallback_encrypt_DES(cryp, key_id, in, out);
860 #else
861  (void)cryp;
862  (void)key_id;
863  (void)in;
864  (void)out;
865
866  return CRY_ERR_INV_ALGO;
867 #endif
868 }
869
870 /**
871  * @brief Decryption of a single block using (T)DES.
872  * @note The implementation of this function must guarantee that it can
873  * be called from any context.
874  *
875  *
876  * @param[in] cryp pointer to the @p CRYDriver object
877  * @param[in] key_id the key to be used for the operation, zero is
878  * the transient key, other values are keys stored
879  * in an unspecified way
880  * @param[in] in buffer containing the input cyphertext
881  * @param[out] out buffer for the output plaintext
882  * @return The operation status.
883  * @retval CRY_NOERROR if the operation succeeded.
884  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
885  * device instance.
886  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
887  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
888  * or refers to an empty key slot.
889  *
890  * @special
891  */
893  crykey_t key_id,
894  const uint8_t *in,
895  uint8_t *out) {
896
897  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL));
898
899  osalDbgAssert(cryp->state == CRY_READY, "not ready");
900
901 #if CRY_LLD_SUPPORTS_DES == TRUE
902  return cry_lld_decrypt_DES(cryp, key_id, in, out);
903 #elif HAL_CRY_USE_FALLBACK == TRUE
904  return cry_fallback_decrypt_DES(cryp, key_id, in, out);
905 #else
906  (void)cryp;
907  (void)key_id;
908  (void)in;
909  (void)out;
910
911  return CRY_ERR_INV_ALGO;
912 #endif
913 }
914
915 /**
916  * @brief Encryption operation using (T)DES-ECB.
917  * @note The function operates on data buffers whose length is a multiple
918  * of an DES block, this means that padding must be done by the
919  * caller.
920  *
921  * @param[in] cryp pointer to the @p CRYDriver object
922  * @param[in] key_id the key to be used for the operation, zero is
923  * the transient key, other values are keys stored
924  * in an unspecified way
925  * @param[in] size size of both buffers, this number must be a
926  * multiple of 8
927  * @param[in] in buffer containing the input plaintext
928  * @param[out] out buffer for the output cyphertext
929  * @return The operation status.
930  * @retval CRY_NOERROR if the operation succeeded.
931  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
932  * device instance.
933  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
934  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
935  * or refers to an empty key slot.
936  *
937  * @api
938  */
940  crykey_t key_id,
941  size_t size,
942  const uint8_t *in,
943  uint8_t *out) {
944
945  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
946  ((size & (size_t)7) == (size_t)0));
947
948  osalDbgAssert(cryp->state == CRY_READY, "not ready");
949
950 #if CRY_LLD_SUPPORTS_DES_ECB == TRUE
951  return cry_lld_encrypt_DES_ECB(cryp, key_id, size, in, out);
952 #elif HAL_CRY_USE_FALLBACK == TRUE
953  return cry_fallback_encrypt_DES_ECB(cryp, key_id, size, in, out);
954 #else
955  (void)cryp;
956  (void)key_id;
957  (void)size;
958  (void)in;
959  (void)out;
960
961  return CRY_ERR_INV_ALGO;
962 #endif
963 }
964
965 /**
966  * @brief Decryption operation using (T)DES-ECB.
967  * @note The function operates on data buffers whose length is a multiple
968  * of an DES block, this means that padding must be done by the
969  * caller.
970  *
971  * @param[in] cryp pointer to the @p CRYDriver object
972  * @param[in] key_id the key to be used for the operation, zero is
973  * the transient key, other values are keys stored
974  * in an unspecified way
975  * @param[in] size size of both buffers, this number must be a
976  * multiple of 8
977  * @param[in] in buffer containing the input cyphertext
978  * @param[out] out buffer for the output plaintext
979  * @return The operation status.
980  * @retval CRY_NOERROR if the operation succeeded.
981  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
982  * device instance.
983  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
984  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
985  * or refers to an empty key slot.
986  *
987  * @api
988  */
990  crykey_t key_id,
991  size_t size,
992  const uint8_t *in,
993  uint8_t *out) {
994
995  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
996  ((size & (size_t)7) == (size_t)0));
997
998  osalDbgAssert(cryp->state == CRY_READY, "not ready");
999
1000 #if CRY_LLD_SUPPORTS_DES_ECB == TRUE
1001  return cry_lld_decrypt_DES_ECB(cryp, key_id, size, in, out);
1002 #elif HAL_CRY_USE_FALLBACK == TRUE
1003  return cry_fallback_decrypt_DES_ECB(cryp, key_id, size, in, out);
1004 #else
1005  (void)cryp;
1006  (void)key_id;
1007  (void)size;
1008  (void)in;
1009  (void)out;
1010
1011  return CRY_ERR_INV_ALGO;
1012 #endif
1013 }
1014
1015 /**
1016  * @brief Encryption operation using (T)DES-CBC.
1017  * @note The function operates on data buffers whose length is a multiple
1018  * of an DES block, this means that padding must be done by the
1019  * caller.
1020  *
1021  * @param[in] cryp pointer to the @p CRYDriver object
1022  * @param[in] key_id the key to be used for the operation, zero is
1023  * the transient key, other values are keys stored
1024  * in an unspecified way
1025  * @param[in] size size of both buffers, this number must be a
1026  * multiple of 8
1027  * @param[in] in buffer containing the input plaintext
1028  * @param[out] out buffer for the output cyphertext
1029  * @param[in] iv 64 bits input vector
1030  * @return The operation status.
1031  * @retval CRY_NOERROR if the operation succeeded.
1032  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1033  * device instance.
1034  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
1035  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
1036  * or refers to an empty key slot.
1037  *
1038  * @api
1039  */
1041  crykey_t key_id,
1042  size_t size,
1043  const uint8_t *in,
1044  uint8_t *out,
1045  const uint8_t *iv) {
1046
1047  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
1048  (iv != NULL) && ((size & (size_t)7) == (size_t)0));
1049
1050  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1051
1052 #if CRY_LLD_SUPPORTS_DES_CBC == TRUE
1053  return cry_lld_encrypt_DES_CBC(cryp, key_id, size, in, out, iv);
1054 #elif HAL_CRY_USE_FALLBACK == TRUE
1055  return cry_fallback_encrypt_DES_CBC(cryp, key_id, size, in, out, iv);
1056 #else
1057  (void)cryp;
1058  (void)key_id;
1059  (void)size;
1060  (void)in;
1061  (void)out;
1062  (void)iv;
1063
1064  return CRY_ERR_INV_ALGO;
1065 #endif
1066 }
1067
1068 /**
1069  * @brief Decryption operation using (T)DES-CBC.
1070  * @note The function operates on data buffers whose length is a multiple
1071  * of an DES block, this means that padding must be done by the
1072  * caller.
1073  *
1074  * @param[in] cryp pointer to the @p CRYDriver object
1075  * @param[in] key_id the key to be used for the operation, zero is
1076  * the transient key, other values are keys stored
1077  * in an unspecified way
1078  * @param[in] size size of both buffers, this number must be a
1079  * multiple of 8
1080  * @param[in] in buffer containing the input cyphertext
1081  * @param[out] out buffer for the output plaintext
1082  * @param[in] iv 64 bits input vector
1083  * @return The operation status.
1084  * @retval CRY_NOERROR if the operation succeeded.
1085  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1086  * device instance.
1087  * @retval CRY_ERR_INV_KEY_TYPE the selected key is invalid for this operation.
1088  * @retval CRY_ERR_INV_KEY_ID if the specified key identifier is invalid
1089  * or refers to an empty key slot.
1090  *
1091  * @api
1092  */
1094  crykey_t key_id,
1095  size_t size,
1096  const uint8_t *in,
1097  uint8_t *out,
1098  const uint8_t *iv) {
1099
1100  osalDbgCheck((cryp != NULL) && (in != NULL) && (out != NULL) &&
1101  (iv != NULL) && ((size & (size_t)7) == (size_t)0));
1102
1103  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1104
1105 #if CRY_LLD_SUPPORTS_DES_CBC == TRUE
1106  return cry_lld_decrypt_DES_CBC(cryp, key_id, size, in, out, iv);
1107 #elif HAL_CRY_USE_FALLBACK == TRUE
1108  return cry_fallback_decrypt_DES_CBC(cryp, key_id, size, in, out, iv);
1109 #else
1110  (void)cryp;
1111  (void)key_id;
1112  (void)size;
1113  (void)in;
1114  (void)out;
1115  (void)iv;
1116
1117  return CRY_ERR_INV_ALGO;
1118 #endif
1119 }
1120
1121 /**
1122  * @brief Hash initialization using SHA1.
1123  * @note Use of this algorithm is not recommended because proven weak.
1124  *
1125  * @param[in] cryp pointer to the @p CRYDriver object
1126  * @param[out] sha1ctxp pointer to a SHA1 context to be initialized
1127  * @return The operation status.
1128  * @retval CRY_NOERROR if the operation succeeded.
1129  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1130  * device instance.
1131  *
1132  * @api
1133  */
1135
1136  osalDbgCheck((cryp != NULL) && (sha1ctxp != NULL));
1137
1138  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1139
1140 #if CRY_LLD_SUPPORTS_SHA1 == TRUE
1141  return cry_lld_SHA1_init(cryp, sha1ctxp);
1142 #elif HAL_CRY_USE_FALLBACK == TRUE
1143  return cry_fallback_SHA1_init(cryp, sha1ctxp);
1144 #else
1145  (void)cryp;
1146  (void)sha1ctxp;
1147
1148  return CRY_ERR_INV_ALGO;
1149 #endif
1150 }
1151
1152 /**
1153  * @brief Hash update using SHA1.
1154  * @note Use of this algorithm is not recommended because proven weak.
1155  *
1156  * @param[in] cryp pointer to the @p CRYDriver object
1157  * @param[in] sha1ctxp pointer to a SHA1 context
1158  * @param[in] size size of input buffer
1159  * @param[in] in buffer containing the input text
1160  * @return The operation status.
1161  * @retval CRY_NOERROR if the operation succeeded.
1162  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1163  * device instance.
1164  *
1165  * @api
1166  */
1168  size_t size, const uint8_t *in) {
1169
1170  osalDbgCheck((cryp != NULL) && (sha1ctxp != NULL) && (in != NULL));
1171
1172  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1173
1174 #if CRY_LLD_SUPPORTS_SHA1 == TRUE
1175  return cry_lld_SHA1_update(cryp, sha1ctxp, size, in);
1176 #elif HAL_CRY_USE_FALLBACK == TRUE
1177  return cry_fallback_SHA1_update(cryp, sha1ctxp, size, in);
1178 #else
1179  (void)cryp;
1180  (void)sha1ctxp;
1181  (void)size;
1182  (void)in;
1183
1184  return CRY_ERR_INV_ALGO;
1185 #endif
1186 }
1187
1188 /**
1189  * @brief Hash finalization using SHA1.
1190  * @note Use of this algorithm is not recommended because proven weak.
1191  *
1192  * @param[in] cryp pointer to the @p CRYDriver object
1193  * @param[in] sha1ctxp pointer to a SHA1 context
1194  * @param[out] out 160 bits output buffer
1195  * @return The operation status.
1196  * @retval CRY_NOERROR if the operation succeeded.
1197  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1198  * device instance.
1199  *
1200  * @api
1201  */
1202 cryerror_t crySHA1Final(CRYDriver *cryp, SHA1Context *sha1ctxp, uint8_t *out) {
1203
1204  osalDbgCheck((cryp != NULL) && (sha1ctxp != NULL) && (out != NULL));
1205
1206  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1207
1208 #if CRY_LLD_SUPPORTS_SHA1 == TRUE
1209  return cry_lld_SHA1_final(cryp, sha1ctxp, out);
1210 #elif HAL_CRY_USE_FALLBACK == TRUE
1211  return cry_fallback_SHA1_final(cryp, sha1ctxp, out);
1212 #else
1213  (void)cryp;
1214  (void)sha1ctxp;
1215  (void)out;
1216
1217  return CRY_ERR_INV_ALGO;
1218 #endif
1219 }
1220
1221 /**
1222  * @brief Hash initialization using SHA256.
1223  * @note Use of this algorithm is not recommended because proven weak.
1224  *
1225  * @param[in] cryp pointer to the @p CRYDriver object
1226  * @param[out] sha256ctxp pointer to a SHA256 context to be initialized
1227  * @return The operation status.
1228  * @retval CRY_NOERROR if the operation succeeded.
1229  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1230  * device instance.
1231  *
1232  * @api
1233  */
1235
1236  osalDbgCheck((cryp != NULL) && (sha256ctxp != NULL));
1237
1238  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1239
1240 #if CRY_LLD_SUPPORTS_SHA1 == TRUE
1241  return cry_lld_SHA256_init(cryp, sha256ctxp);
1242 #elif HAL_CRY_USE_FALLBACK == TRUE
1243  return cry_fallback_SHA256_init(cryp, sha256ctxp);
1244 #else
1245  (void)cryp;
1246  (void)sha256ctxp;
1247
1248  return CRY_ERR_INV_ALGO;
1249 #endif
1250 }
1251
1252 /**
1253  * @brief Hash update using SHA256.
1254  * @note Use of this algorithm is not recommended because proven weak.
1255  *
1256  * @param[in] cryp pointer to the @p CRYDriver object
1257  * @param[in] sha256ctxp pointer to a SHA256 context
1258  * @param[in] size size of input buffer
1259  * @param[in] in buffer containing the input text
1260  * @return The operation status.
1261  * @retval CRY_NOERROR if the operation succeeded.
1262  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1263  * device instance.
1264  *
1265  * @api
1266  */
1268  size_t size, const uint8_t *in) {
1269
1270  osalDbgCheck((cryp != NULL) && (sha256ctxp != NULL) && (in != NULL));
1271
1272  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1273
1274 #if CRY_LLD_SUPPORTS_SHA1 == TRUE
1275  return cry_lld_SHA256_update(cryp, sha256ctxp, size, in);
1276 #elif HAL_CRY_USE_FALLBACK == TRUE
1277  return cry_fallback_SHA256_update(cryp, sha256ctxp, size, in);
1278 #else
1279  (void)cryp;
1280  (void)sha256ctxp;
1281  (void)size;
1282  (void)in;
1283
1284  return CRY_ERR_INV_ALGO;
1285 #endif
1286 }
1287
1288 /**
1289  * @brief Hash finalization using SHA256.
1290  * @note Use of this algorithm is not recommended because proven weak.
1291  *
1292  * @param[in] cryp pointer to the @p CRYDriver object
1293  * @param[in] sha256ctxp pointer to a SHA256 context
1294  * @param[out] out 256 bits output buffer
1295  * @return The operation status.
1296  * @retval CRY_NOERROR if the operation succeeded.
1297  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1298  * device instance.
1299  *
1300  * @api
1301  */
1303  uint8_t *out) {
1304
1305  osalDbgCheck((cryp != NULL) && (sha256ctxp != NULL) && (out != NULL));
1306
1307  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1308
1309 #if CRY_LLD_SUPPORTS_SHA1 == TRUE
1310  return cry_lld_SHA256_final(cryp, sha256ctxp, out);
1311 #elif HAL_CRY_USE_FALLBACK == TRUE
1312  return cry_fallback_SHA256_final(cryp, sha256ctxp, out);
1313 #else
1314  (void)cryp;
1315  (void)sha256ctxp;
1316  (void)out;
1317
1318  return CRY_ERR_INV_ALGO;
1319 #endif
1320 }
1321
1322 /**
1323  * @brief Hash initialization using SHA512.
1324  * @note Use of this algorithm is not recommended because proven weak.
1325  *
1326  * @param[in] cryp pointer to the @p CRYDriver object
1327  * @param[out] sha512ctxp pointer to a SHA512 context to be initialized
1328  * @return The operation status.
1329  * @retval CRY_NOERROR if the operation succeeded.
1330  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1331  * device instance.
1332  *
1333  * @api
1334  */
1336
1337  osalDbgCheck((cryp != NULL) && (sha512ctxp != NULL));
1338
1339  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1340
1341 #if CRY_LLD_SUPPORTS_SHA1 == TRUE
1342  return cry_lld_SHA512_init(cryp, sha512ctxp);
1343 #elif HAL_CRY_USE_FALLBACK == TRUE
1344  return cry_fallback_SHA512_init(cryp, sha512ctxp);
1345 #else
1346  (void)cryp;
1347  (void)sha512ctxp;
1348
1349  return CRY_ERR_INV_ALGO;
1350 #endif
1351 }
1352
1353 /**
1354  * @brief Hash update using SHA512.
1355  * @note Use of this algorithm is not recommended because proven weak.
1356  *
1357  * @param[in] cryp pointer to the @p CRYDriver object
1358  * @param[in] sha512ctxp pointer to a SHA512 context
1359  * @param[in] size size of input buffer
1360  * @param[in] in buffer containing the input text
1361  * @return The operation status.
1362  * @retval CRY_NOERROR if the operation succeeded.
1363  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1364  * device instance.
1365  *
1366  * @api
1367  */
1369  size_t size, const uint8_t *in) {
1370
1371  osalDbgCheck((cryp != NULL) && (sha512ctxp != NULL) && (in != NULL));
1372
1373  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1374
1375 #if CRY_LLD_SUPPORTS_SHA1 == TRUE
1376  return cry_lld_SHA512_update(cryp, sha512ctxp, size, in);
1377 #elif HAL_CRY_USE_FALLBACK == TRUE
1378  return cry_fallback_SHA512_update(cryp, sha512ctxp, size, in);
1379 #else
1380  (void)cryp;
1381  (void)sha512ctxp;
1382  (void)size;
1383  (void)in;
1384
1385  return CRY_ERR_INV_ALGO;
1386 #endif
1387 }
1388
1389 /**
1390  * @brief Hash finalization using SHA512.
1391  * @note Use of this algorithm is not recommended because proven weak.
1392  *
1393  * @param[in] cryp pointer to the @p CRYDriver object
1394  * @param[in] sha512ctxp pointer to a SHA512 context
1395  * @param[out] out 512 bits output buffer
1396  * @return The operation status.
1397  * @retval CRY_NOERROR if the operation succeeded.
1398  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1399  * device instance.
1400  *
1401  * @api
1402  */
1404  uint8_t *out) {
1405
1406  osalDbgCheck((cryp != NULL) && (sha512ctxp != NULL) && (out != NULL));
1407
1408  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1409
1410 #if CRY_LLD_SUPPORTS_SHA1 == TRUE
1411  return cry_lld_SHA512_final(cryp, sha512ctxp, out);
1412 #elif HAL_CRY_USE_FALLBACK == TRUE
1413  return cry_fallback_SHA512_final(cryp, sha512ctxp, out);
1414 #else
1415  (void)cryp;
1416  (void)sha512ctxp;
1417  (void)out;
1418
1419  return CRY_ERR_INV_ALGO;
1420 #endif
1421 }
1422
1423 /**
1424  * @brief True random numbers generator.
1425  *
1426  * @param[in] cryp pointer to the @p CRYDriver object
1427  * @param[out] out 128 bits output buffer
1428  * @return The operation status.
1429  * @retval CRY_NOERROR if the operation succeeded.
1430  * @retval CRY_ERR_INV_ALGO if the operation is unsupported on this
1431  * device instance.
1432  *
1433  * @api
1434  */
1435 cryerror_t cryTRNG(CRYDriver *cryp, uint8_t *out) {
1436
1437  osalDbgCheck((cryp != NULL) && (out != NULL));
1438
1439  osalDbgAssert(cryp->state == CRY_READY, "not ready");
1440
1441 #if CRY_LLD_SUPPORTS_TRNG == TRUE
1442  return cry_lld_TRNG(cryp, out);
1443 #elif HAL_CRY_USE_FALLBACK == TRUE
1444  return cry_fallback_TRNG(cryp, out);
1445 #else
1446  (void)cryp;
1447  (void)out;
1448
1449  return CRY_ERR_INV_ALGO;
1450 #endif
1451 }
1452
1453 #endif /* HAL_USE_CRY == TRUE */
1454
1455 /** @} */
Definition: hal_crypto.c:1202
cryerror_t cry_lld_SHA1_init(CRYDriver *cryp, SHA1Context *sha1ctxp)
cryerror_t cry_lld_decrypt_AES_GCM(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv, size_t aadsize, const uint8_t *aad, uint8_t *authtag)
void cryInit(void)
Definition: hal_crypto.c:56
cryerror_t cry_lld_decrypt_AES_CFB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
cryerror_t cry_lld_encrypt_AES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
cryerror_t crySHA256Init(CRYDriver *cryp, SHA256Context *sha256ctxp)
Definition: hal_crypto.c:1234
cryerror_t crySHA1Update(CRYDriver *cryp, SHA1Context *sha1ctxp, size_t size, const uint8_t *in)
Definition: hal_crypto.c:1167
Definition: hal_crypto.c:88
cryerror_t cryEncryptAES_CFB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
Definition: hal_crypto.c:497
cryerror_t cry_lld_SHA1_final(CRYDriver *cryp, SHA1Context *sha1ctxp, uint8_t *out)
cryerror_t cry_lld_SHA1_update(CRYDriver *cryp, SHA1Context *sha1ctxp, size_t size, const uint8_t *in)
cryerror_t cryDecryptDES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
Definition: hal_crypto.c:892
cryerror_t cryDecryptAES_CTR(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
Definition: hal_crypto.c:659
Type of a SHA512 context.
Definition: hal_crypto.h:190
cryerror_t cry_lld_decrypt_DES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
cryerror_t cryEncryptAES_GCM(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv, size_t aadsize, const uint8_t *aad, uint8_t *authtag)
Definition: hal_crypto.c:719
cryerror_t cryDecryptAES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
Definition: hal_crypto.c:340
cryerror_t cry_lld_TRNG(CRYDriver *cryp, uint8_t *out)
Structure representing an CRY driver.
cryerror_t cryEncryptDES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
Definition: hal_crypto.c:847
cryerror_t cry_lld_encrypt_DES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
#define HAL_CRY_MAX_KEY_SIZE
Maximum size of a key for all supported algorithms.
Definition: hal_crypto.h:37
Definition: osal.h:540
cryerror_t cryDecryptDES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
Definition: hal_crypto.c:1093
void cry_lld_stop(CRYDriver *cryp)
Deactivates the crypto peripheral.
cryerror_t cryDecryptAES_GCM(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv, size_t aadsize, const uint8_t *aad, uint8_t *authtag)
Definition: hal_crypto.c:788
Definition: hal_crypto.c:110
cryerror_t cry_lld_encrypt_AES_CFB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
cryerror_t cryDecryptDES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
Definition: hal_crypto.c:989
cryerror_t crySHA1Init(CRYDriver *cryp, SHA1Context *sha1ctxp)
Definition: hal_crypto.c:1134
cryerror_t
Driver error codes.
Definition: hal_crypto.h:94
cryerror_t cry_lld_encrypt_AES_GCM(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv, size_t aadsize, const uint8_t *aad, uint8_t *authtag)
cryerror_t cry_lld_decrypt_AES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
cryerror_t cryEncryptAES_CTR(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
Definition: hal_crypto.c:604
cryalgorithm_t key0_type
Algorithm type of transient key.
cryerror_t crySHA256Update(CRYDriver *cryp, SHA256Context *sha256ctxp, size_t size, const uint8_t *in)
Definition: hal_crypto.c:1267
void cry_lld_start(CRYDriver *cryp)
Configures and activates the crypto peripheral.
uint32_t crykey_t
CRY key identifier type.
cryerror_t cry_lld_decrypt_AES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
cryerror_t crySHA512Init(CRYDriver *cryp, SHA512Context *sha512ctxp)
Definition: hal_crypto.c:1335
cryerror_t crySHA256Final(CRYDriver *cryp, SHA256Context *sha256ctxp, uint8_t *out)
Definition: hal_crypto.c:1302
cryerror_t cry_lld_SHA512_init(CRYDriver *cryp, SHA512Context *sha512ctxp)
cryerror_t cryDecryptAES_CFB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
Definition: hal_crypto.c:550
void cry_lld_init(void)
Low level crypto driver initialization.
cryerror_t cry_lld_SHA512_final(CRYDriver *cryp, SHA512Context *sha512ctxp, uint8_t *out)
cryerror_t cry_lld_decrypt_AES_CTR(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
cryerror_t crySHA512Final(CRYDriver *cryp, SHA512Context *sha512ctxp, uint8_t *out)
Definition: hal_crypto.c:1403
cryalgorithm_t
Type of an algorithm identifier.
Definition: hal_crypto.h:106
cryerror_t cry_lld_encrypt_AES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
cryerror_t cry_lld_decrypt_DES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
cryerror_t cry_lld_encrypt_DES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
cryerror_t cry_lld_decrypt_DES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
static void osalSysLock(void)
Definition: osal.h:530
size_t key0_size
Size of transient key.
cryerror_t cryEncryptAES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
Definition: hal_crypto.c:290
cryerror_t cryEncryptAES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
Definition: hal_crypto.c:391
cryerror_t cry_lld_encrypt_AES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
cryerror_t cry_lld_SHA512_update(CRYDriver *cryp, SHA512Context *sha512ctxp, size_t size, const uint8_t *in)
USBInEndpointState in
IN EP0 state.
Definition: hal_usb_lld.c:57
cryerror_t cryDecryptAES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
Definition: hal_crypto.c:444
cryerror_t cry_lld_SHA256_init(CRYDriver *cryp, SHA256Context *sha256ctxp)
cryerror_t cry_lld_decrypt_AES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
crystate_t state
cryerror_t crySHA512Update(CRYDriver *cryp, SHA512Context *sha512ctxp, size_t size, const uint8_t *in)
Definition: hal_crypto.c:1368
Type of a SHA1 context.
Definition: hal_crypto.h:174
USBOutEndpointState out
OUT EP0 state.
Definition: hal_usb_lld.c:61
cryerror_t cry_lld_encrypt_DES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
cryerror_t cry_lld_loadkey(CRYDriver *cryp, cryalgorithm_t algorithm, size_t size, const uint8_t *keyp)
cryerror_t cryLoadTransientKey(CRYDriver *cryp, cryalgorithm_t algorithm, size_t size, const uint8_t *keyp)
Definition: hal_crypto.c:146
cryerror_t cry_lld_SHA256_update(CRYDriver *cryp, SHA256Context *sha256ctxp, size_t size, const uint8_t *in)
Type of a SHA256 context.
Definition: hal_crypto.h:182
Definition: hal_crypto.c:1435
cryerror_t cry_lld_SHA256_final(CRYDriver *cryp, SHA256Context *sha256ctxp, uint8_t *out)
cryerror_t cryEncryptDES_ECB(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out)
Definition: hal_crypto.c:939
const CRYConfig * config
Current configuration data.
cryerror_t cryEncryptAES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
Definition: hal_crypto.c:199
cryerror_t cryDecryptAES(CRYDriver *cryp, crykey_t key_id, const uint8_t *in, uint8_t *out)
Definition: hal_crypto.c:243
cryerror_t cry_lld_encrypt_AES_CTR(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
Initializes the standard part of a CRYDriver structure.
Definition: hal_crypto.c:70
cryerror_t cryEncryptDES_CBC(CRYDriver *cryp, crykey_t key_id, size_t size, const uint8_t *in, uint8_t *out, const uint8_t *iv)
Definition: hal_crypto.c:1040
