hal_gpt_lld.c
18  * @file hal_gpt_lld.c
19  * @brief PLATFORM GPT subsystem low level driver source.
21  * @addtogroup GPT
27 #if (HAL_USE_GPT == TRUE) || defined(__DOXYGEN__)
37 /**
38  * @brief GPTD1 driver identifier.
39  */
40 #if (PLATFORM_GPT_USE_GPT1 == TRUE) || defined(__DOXYGEN__)
42 #endif
43
45 /* Driver local variables and types. */
47
49 /* Driver local functions. */
51
53 /* Driver interrupt handlers. */
55
57 /* Driver exported functions. */
59
60 /**
61  * @brief Low level GPT driver initialization.
62  *
63  * @notapi
64  */
65 void gpt_lld_init(void) {
66
67 #if PLATFORM_GPT_USE_GPT1 == TRUE
68  /* Driver initialization.*/
69  gptObjectInit(&GPTD1);
70 #endif
71 }
72
73 /**
74  * @brief Configures and activates the GPT peripheral.
75  *
76  * @param[in] gptp pointer to the @p GPTDriver object
77  *
78  * @notapi
79  */
80 void gpt_lld_start(GPTDriver *gptp) {
81
82  if (gptp->state == GPT_STOP) {
83  /* Enables the peripheral.*/
84 #if PLATFORM_GPT_USE_GPT1 == TRUE
85  if (&GPTD1 == gptp) {
86
87  }
88 #endif
89  }
90  /* Configures the peripheral.*/
91
92 }
93
94 /**
95  * @brief Deactivates the GPT peripheral.
96  *
97  * @param[in] gptp pointer to the @p GPTDriver object
98  *
99  * @notapi
100  */
101 void gpt_lld_stop(GPTDriver *gptp) {
102
103  if (gptp->state == GPT_READY) {
104  /* Resets the peripheral.*/
105
106  /* Disables the peripheral.*/
107 #if PLATFORM_GPT_USE_GPT1 == TRUE
108  if (&GPTD1 == gptp) {
109
110  }
111 #endif
112  }
113 }
114
115 /**
116  * @brief Starts the timer in continuous mode.
117  *
118  * @param[in] gptp pointer to the @p GPTDriver object
119  * @param[in] interval period in ticks
120  *
121  * @notapi
122  */
123 void gpt_lld_start_timer(GPTDriver *gptp, gptcnt_t interval) {
124
125  (void)gptp;
126  (void)interval;
127
128 }
129
130 /**
131  * @brief Stops the timer.
132  *
133  * @param[in] gptp pointer to the @p GPTDriver object
134  *
135  * @notapi
136  */
138
139  (void)gptp;
140
141 }
142
143 /**
144  * @brief Starts the timer in one shot mode and waits for completion.
145  * @details This function specifically polls the timer waiting for completion
146  * in order to not have extra delays caused by interrupt servicing,
147  * this function is only recommended for short delays.
148  *
149  * @param[in] gptp pointer to the @p GPTDriver object
150  * @param[in] interval time interval in ticks
151  *
152  * @notapi
153  */
154 void gpt_lld_polled_delay(GPTDriver *gptp, gptcnt_t interval) {
155
156  (void)gptp;
157  (void)interval;
158
159 }
160
161 #endif /* HAL_USE_GPT == TRUE */
162
163 /** @} */
Definition: hal_gpt_lld.c:154
Definition: hal_gpt_lld.c:65
GPTDriver GPTD1
Definition: hal_gpt_lld.c:41
Definition: hal_gpt_lld.c:101
Definition: hal_gpt_lld.c:80
Structure representing a GPT driver.
Definition: hal_gpt_lld.h:92
uint16_t gptcnt_t
GPT counter type.
Definition: hal_gpt_lld.h:68
gptstate_t state
Definition: hal_gpt_lld.h:96
Definition: hal_gpt_lld.c:123
void gptObjectInit(GPTDriver *gptp)
Initializes the standard part of a GPTDriver structure.
Definition: hal_gpt.c:68
void gpt_lld_stop_timer(GPTDriver *gptp)
Stops the timer.
Definition: hal_gpt_lld.c:137
