hal_gpt_lld.h
18  * @file hal_gpt_lld.h
19  * @brief PLATFORM GPT subsystem low level driver header.
21  * @addtogroup GPT
25 #ifndef HAL_GPT_LLD_H
26 #define HAL_GPT_LLD_H
28 #if (HAL_USE_GPT == TRUE) || defined(__DOXYGEN__)
31 /* Driver constants. */
37
38 /**
39  * @name PLATFORM configuration options
40  * @{
41  */
42 /**
43  * @brief GPTD1 driver enable switch.
44  * @details If set to @p TRUE the support for GPTD1 is included.
45  * @note The default is @p FALSE.
46  */
47 #if !defined(PLATFORM_GPT_USE_GPT1) || defined(__DOXYGEN__)
48 #define PLATFORM_GPT_USE_GPT1 FALSE
49 #endif
50 /** @} */
51
53 /* Derived constants and error checks. */
55
57 /* Driver data structures and types. */
59
60 /**
61  * @brief GPT frequency type.
62  */
63 typedef uint32_t gptfreq_t;
64
65 /**
66  * @brief GPT counter type.
67  */
68 typedef uint16_t gptcnt_t;
69
70 /**
71  * @brief Driver configuration structure.
72  * @note It could be empty on some architectures.
73  */
74 typedef struct {
75  /**
76  * @brief Timer clock in Hz.
77  * @note The low level can use assertions in order to catch invalid
78  * frequency specifications.
79  */
81  /**
82  * @brief Timer callback pointer.
83  * @note This callback is invoked on GPT counter events.
84  */
86  /* End of the mandatory fields.*/
87 } GPTConfig;
88
89 /**
90  * @brief Structure representing a GPT driver.
91  */
92 struct GPTDriver {
93  /**
94  * @brief Driver state.
95  */
97  /**
98  * @brief Current configuration data.
99  */
101 #if defined(GPT_DRIVER_EXT_FIELDS)
102  GPT_DRIVER_EXT_FIELDS
103 #endif
104  /* End of the mandatory fields.*/
105 };
106
107 /*===========================================================================*/
108 /* Driver macros. */
109 /*===========================================================================*/
110
111 /**
112  * @brief Changes the interval of GPT peripheral.
113  * @details This function changes the interval of a running GPT unit.
114  * @pre The GPT unit must have been activated using @p gptStart().
115  * @pre The GPT unit must have been running in continuous mode using
116  * @p gptStartContinuous().
117  * @post The GPT unit interval is changed to the new value.
118  * @note The function has effect at the next cycle start.
119  *
120  * @param[in] gptp pointer to a @p GPTDriver object
121  * @param[in] interval new cycle time in timer ticks
122  * @notapi
123  */
124 #define gpt_lld_change_interval(gptp, interval) { \
125  (void)gptp; \
126  (void)interval; \
127 }
128
129 /*===========================================================================*/
130 /* External declarations. */
131 /*===========================================================================*/
132
133 #if (PLATFORM_GPT_USE_GPT1 == TRUE) && !defined(__DOXYGEN__)
134 extern GPTDriver GPTD1;
135 #endif
136
137 #ifdef __cplusplus
138 extern "C" {
139 #endif
140  void gpt_lld_init(void);
141  void gpt_lld_start(GPTDriver *gptp);
142  void gpt_lld_stop(GPTDriver *gptp);
143  void gpt_lld_start_timer(GPTDriver *gptp, gptcnt_t interval);
144  void gpt_lld_stop_timer(GPTDriver *gptp);
145  void gpt_lld_polled_delay(GPTDriver *gptp, gptcnt_t interval);
146 #ifdef __cplusplus
147 }
148 #endif
149
150 #endif /* HAL_USE_GPT == TRUE */
151
152 #endif /* HAL_GPT_LLD_H */
153
154 /** @} */
Starts the timer in one shot mode and waits for completion.
Definition: hal_gpt_lld.c:154
Low level GPT driver initialization.
Definition: hal_gpt_lld.c:65
GPTDriver GPTD1
GPTD1 driver identifier.
Definition: hal_gpt_lld.c:41
Deactivates the GPT peripheral.
Definition: hal_gpt_lld.c:101
Configures and activates the GPT peripheral.
Definition: hal_gpt_lld.c:80
Definition: hal_gpt_lld.h:92
gptcallback_t callback
Definition: hal_gpt_lld.h:85
Definition: hal_gpt_lld.h:74
const GPTConfig * config
Definition: hal_gpt_lld.h:100
uint32_t gptfreq_t
GPT frequency type.
Definition: hal_gpt_lld.h:63
uint16_t gptcnt_t
GPT counter type.
Definition: hal_gpt_lld.h:68
gptstate_t state
Definition: hal_gpt_lld.h:96
Starts the timer in continuous mode.
Definition: hal_gpt_lld.c:123
void(* gptcallback_t)(GPTDriver *gptp)
GPT notification callback type.
Definition: hal_gpt.h:67
gptstate_t
Definition: hal_gpt.h:49
Stops the timer.
Definition: hal_gpt_lld.c:137
gptfreq_t frequency
Timer clock in Hz.
Definition: hal_gpt_lld.h:80
