hal_i2s_lld.h
18  * @file hal_i2s_lld.h
19  * @brief PLATFORM I2S subsystem low level driver header.
21  * @addtogroup I2S
25 #ifndef HAL_I2S_LLD_H
26 #define HAL_I2S_LLD_H
28 #if (HAL_USE_I2S == TRUE) || defined(__DOXYGEN__)
31 /* Driver constants. */
37
38 /**
39  * @name PLATFORM configuration options
40  * @{
41  */
42 /**
43  * @brief I2SD1 driver enable switch.
44  * @details If set to @p TRUE the support for I2S1 is included.
45  * @note The default is @p FALSE.
46  */
47 #if !defined(PLATFORM_I2S_USE_I2S1) || defined(__DOXYGEN__)
48 #define PLATFORM_I2S_USE_I2S1 FALSE
49 #endif
50 /** @} */
51
53 /* Derived constants and error checks. */
55
57 /* Driver data structures and types. */
59
60 /**
61  * @brief Type of a structure representing an I2S driver.
62  */
63 typedef struct I2SDriver I2SDriver;
64
65 /**
66  * @brief I2S notification callback type.
67  *
68  * @param[in] i2sp pointer to the @p I2SDriver object
69  * @param[in] offset offset in buffers of the data to read/write
70  * @param[in] n number of samples to read/write
71  */
72 typedef void (*i2scallback_t)(I2SDriver *i2sp, size_t offset, size_t n);
73
74 /**
75  * @brief Driver configuration structure.
76  * @note It could be empty on some architectures.
77  */
78 typedef struct {
79  /**
80  * @brief Transmission buffer pointer.
81  * @note Can be @p NULL if TX is not required.
82  */
83  const void *tx_buffer;
84  /**
85  * @brief Receive buffer pointer.
86  * @note Can be @p NULL if RX is not required.
87  */
88  void *rx_buffer;
89  /**
90  * @brief TX and RX buffers size as number of samples.
91  */
92  size_t size;
93  /**
94  * @brief Callback function called during streaming.
95  */
97  /* End of the mandatory fields.*/
98 } I2SConfig;
99
100 /**
101  * @brief Structure representing an I2S driver.
102  */
103 struct I2SDriver {
104  /**
105  * @brief Driver state.
106  */
108  /**
109  * @brief Current configuration data.
110  */
112  /* End of the mandatory fields.*/
113 };
114
115 /*===========================================================================*/
116 /* Driver macros. */
117 /*===========================================================================*/
118
119 /*===========================================================================*/
120 /* External declarations. */
121 /*===========================================================================*/
122
123 #if (PLATFORM_I2S_USE_I2S1 == TRUE) && !defined(__DOXYGEN__)
124 extern I2SDriver I2SD1;
125 #endif
126
127 #ifdef __cplusplus
128 extern "C" {
129 #endif
130  void i2s_lld_init(void);
131  void i2s_lld_start(I2SDriver *i2sp);
132  void i2s_lld_stop(I2SDriver *i2sp);
133  void i2s_lld_start_exchange(I2SDriver *i2sp);
134  void i2s_lld_stop_exchange(I2SDriver *i2sp);
135 #ifdef __cplusplus
136 }
137 #endif
138
139 #endif /* HAL_USE_I2S == TRUE */
140
141 #endif /* HAL_I2S_LLD_H */
142
143 /** @} */
I2SDriver I2SD1
I2S2 driver identifier.
Definition: hal_i2s_lld.c:39
i2sstate_t
Definition: hal_i2s.h:57
Low level I2S driver initialization.
Definition: hal_i2s_lld.c:63
Deactivates the I2S peripheral.
Definition: hal_i2s_lld.c:97
Definition: hal_i2s_lld.h:78
void(* i2scallback_t)(I2SDriver *i2sp, size_t offset, size_t n)
Definition: hal_i2s_lld.h:72
const void * tx_buffer
Definition: hal_i2s_lld.h:83
Definition: hal_i2s_lld.h:103
i2sstate_t state
Definition: hal_i2s_lld.h:107
Starts a I2S data exchange.
Definition: hal_i2s_lld.c:116
void * rx_buffer
Definition: hal_i2s_lld.h:88
i2scallback_t end_cb
Definition: hal_i2s_lld.h:96
const I2SConfig * config
Definition: hal_i2s_lld.h:111
Stops the ongoing data exchange.
Definition: hal_i2s_lld.c:130
Configures and activates the I2S peripheral.
Definition: hal_i2s_lld.c:77
size_t size
Definition: hal_i2s_lld.h:92
