hal_i2s_lld.c
18  * @file hal_i2s_lld.c
19  * @brief PLATFORM I2S subsystem low level driver source.
21  * @addtogroup I2S
27 #if (HAL_USE_I2S == TRUE) || defined(__DOXYGEN__)
37 /** @brief I2S2 driver identifier.*/
38 #if (PLATFORM_I2S_USE_I2S1 == TRUE) || defined(__DOXYGEN__)
40 #endif
41
43 /* Driver local variables and types. */
45
47 /* Driver local functions. */
49
51 /* Driver interrupt handlers. */
53
55 /* Driver exported functions. */
57
58 /**
59  * @brief Low level I2S driver initialization.
60  *
61  * @notapi
62  */
63 void i2s_lld_init(void) {
64
65 #if PLATFORM_I2S_USE_I2S1
66  i2sObjectInit(&I2SD1);
67 #endif
68 }
69
70 /**
71  * @brief Configures and activates the I2S peripheral.
72  *
73  * @param[in] i2sp pointer to the @p I2SDriver object
74  *
75  * @notapi
76  */
77 void i2s_lld_start(I2SDriver *i2sp) {
78
79  /* If in stopped state then enables the SPI and DMA clocks.*/
80  if (i2sp->state == I2S_STOP) {
81
82 #if PLATFORM_I2S_USE_I2S1
83  if (&I2SD1 == i2sp) {
84
85  }
86 #endif
87  }
88 }
89
90 /**
91  * @brief Deactivates the I2S peripheral.
92  *
93  * @param[in] i2sp pointer to the @p I2SDriver object
94  *
95  * @notapi
96  */
97 void i2s_lld_stop(I2SDriver *i2sp) {
98
99  /* If in ready state then disables the SPI clock.*/
100  if (i2sp->state == I2S_READY) {
101 #if PLATFORM_I2S_USE_I2S1
102  if (&I2SD1 == i2sp) {
103
104  }
105 #endif
106  }
107 }
108
109 /**
110  * @brief Starts a I2S data exchange.
111  *
112  * @param[in] i2sp pointer to the @p I2SDriver object
113  *
114  * @notapi
115  */
117
118  (void)i2sp;
119 }
120
121 /**
122  * @brief Stops the ongoing data exchange.
123  * @details The ongoing data exchange, if any, is stopped, if the driver
124  * was not active the function does nothing.
125  *
126  * @param[in] i2sp pointer to the @p I2SDriver object
127  *
128  * @notapi
129  */
131
132  (void)i2sp;
133 }
134
135 #endif /* HAL_USE_I2S */
136
137 /** @} */
I2SDriver I2SD1
Definition: hal_i2s_lld.c:39
Definition: hal_i2s_lld.c:63
Definition: hal_i2s_lld.c:97
void i2sObjectInit(I2SDriver *i2sp)
Initializes the standard part of a I2SDriver structure.
Definition: hal_i2s.c:68
Structure representing an I2S driver.
Definition: hal_i2s_lld.h:103
i2sstate_t state
Definition: hal_i2s_lld.h:107
void i2s_lld_start_exchange(I2SDriver *i2sp)
Definition: hal_i2s_lld.c:116
void i2s_lld_stop_exchange(I2SDriver *i2sp)
Definition: hal_i2s_lld.c:130
Definition: hal_i2s_lld.c:77
