hal_icu_lld.h
18  * @file hal_icu_lld.h
19  * @brief PLATFORM ICU subsystem low level driver header.
21  * @addtogroup ICU
25 #ifndef HAL_ICU_LLD_H
26 #define HAL_ICU_LLD_H
28 #if (HAL_USE_ICU == TRUE) || defined(__DOXYGEN__)
31 /* Driver constants. */
37
38 /**
39  * @name PLATFORM configuration options
40  * @{
41  */
42 /**
43  * @brief ICUD1 driver enable switch.
44  * @details If set to @p TRUE the support for ICUD1 is included.
45  * @note The default is @p FALSE.
46  */
47 #if !defined(PLATFORM_ICU_USE_ICU1) || defined(__DOXYGEN__)
48 #define PLATFORM_ICU_USE_ICU1 FALSE
49 #endif
50 /** @} */
51
53 /* Derived constants and error checks. */
55
57 /* Driver data structures and types. */
59
60 /**
61  * @brief ICU driver mode.
62  */
63 typedef enum {
64  ICU_INPUT_ACTIVE_HIGH = 0, /**< Trigger on rising edge. */
65  ICU_INPUT_ACTIVE_LOW = 1 /**< Trigger on falling edge. */
66 } icumode_t;
67
68 /**
69  * @brief ICU frequency type.
70  */
71 typedef uint32_t icufreq_t;
72
73 /**
74  * @brief ICU counter type.
75  */
76 typedef uint32_t icucnt_t;
77
78 /**
79  * @brief Driver configuration structure.
80  * @note It could be empty on some architectures.
81  */
82 typedef struct {
83  /**
84  * @brief Driver mode.
85  */
87  /**
88  * @brief Timer clock in Hz.
89  * @note The low level can use assertions in order to catch invalid
90  * frequency specifications.
91  */
93  /**
94  * @brief Callback for pulse width measurement.
95  */
97  /**
98  * @brief Callback for cycle period measurement.
99  */
101  /**
102  * @brief Callback for timer overflow.
103  */
105  /* End of the mandatory fields.*/
106 } ICUConfig;
107
108 /**
109  * @brief Structure representing an ICU driver.
110  */
111 struct ICUDriver {
112  /**
113  * @brief Driver state.
114  */
116  /**
117  * @brief Current configuration data.
118  */
120 #if defined(ICU_DRIVER_EXT_FIELDS)
121  ICU_DRIVER_EXT_FIELDS
122 #endif
123  /* End of the mandatory fields.*/
124 };
125
126 /*===========================================================================*/
127 /* Driver macros. */
128 /*===========================================================================*/
129
130 /**
131  * @brief Returns the width of the latest pulse.
132  * @details The pulse width is defined as number of ticks between the start
133  * edge and the stop edge.
134  *
135  * @param[in] icup pointer to the @p ICUDriver object
136  * @return The number of ticks.
137  *
138  * @notapi
139  */
140 #define icu_lld_get_width(icup) 0
141
142 /**
143  * @brief Returns the width of the latest cycle.
144  * @details The cycle width is defined as number of ticks between a start
145  * edge and the next start edge.
146  *
147  * @param[in] icup pointer to the @p ICUDriver object
148  * @return The number of ticks.
149  *
150  * @notapi
151  */
152 #define icu_lld_get_period(icup) 0
153
154 /**
155  * @brief Check on notifications status.
156  *
157  * @param[in] icup pointer to the @p ICUDriver object
158  * @return The notifications status.
159  * @retval false if notifications are not enabled.
160  * @retval true if notifications are enabled.
161  *
162  * @notapi
163  */
164 #define icu_lld_are_notifications_enabled(icup) false
165
166 /*===========================================================================*/
167 /* External declarations. */
168 /*===========================================================================*/
169
170 #if (PLATFORM_ICU_USE_ICU1 == TRUE) && !defined(__DOXYGEN__)
171 extern ICUDriver ICUD1;
172 #endif
173
174 #ifdef __cplusplus
175 extern "C" {
176 #endif
177  void icu_lld_init(void);
178  void icu_lld_start(ICUDriver *icup);
179  void icu_lld_stop(ICUDriver *icup);
180  void icu_lld_start_capture(ICUDriver *icup);
181  bool icu_lld_wait_capture(ICUDriver *icup);
182  void icu_lld_stop_capture(ICUDriver *icup);
185 #ifdef __cplusplus
186 }
187 #endif
188
189 #endif /* HAL_USE_ICU == TRUE */
190
191 #endif /* HAL_ICU_LLD_H */
192
193 /** @} */
icumode_t
ICU driver mode.
Definition: hal_icu_lld.h:63
Configures and activates the ICU peripheral.
Definition: hal_icu_lld.c:81
Waits for a completed capture.
Definition: hal_icu_lld.c:136
Stops the input capture.
Definition: hal_icu_lld.c:150
ICUDriver ICUD1
ICUD1 driver identifier.
Definition: hal_icu_lld.c:42
Definition: hal_icu_lld.h:82
void icu_lld_enable_notifications(ICUDriver *icup)
Enables notifications.
Definition: hal_icu_lld.c:165
Definition: hal_icu_lld.h:111
icustate_t
Definition: hal_icu.h:49
icucallback_t width_cb
Definition: hal_icu_lld.h:96
Deactivates the ICU peripheral.
Definition: hal_icu_lld.c:100
icufreq_t frequency
Timer clock in Hz.
Definition: hal_icu_lld.h:92
uint32_t icufreq_t
ICU frequency type.
Definition: hal_icu_lld.h:71
const ICUConfig * config
Definition: hal_icu_lld.h:119
icumode_t mode
Driver mode.
Definition: hal_icu_lld.h:86
void(* icucallback_t)(ICUDriver *icup)
ICU notification callback type.
Definition: hal_icu.h:67
uint32_t icucnt_t
ICU counter type.
Definition: hal_icu_lld.h:76
icustate_t state
Definition: hal_icu_lld.h:115
Starts the input capture.
Definition: hal_icu_lld.c:119
Low level ICU driver initialization.
Definition: hal_icu_lld.c:66
icucallback_t overflow_cb
Definition: hal_icu_lld.h:104
void icu_lld_disable_notifications(ICUDriver *icup)
Disables notifications.
Definition: hal_icu_lld.c:180
icucallback_t period_cb
Definition: hal_icu_lld.h:100
