hal_icu.h
18  * @file hal_icu.h
19  * @brief ICU Driver macros and structures.
21  * @addtogroup ICU
25 #ifndef HAL_ICU_H
26 #define HAL_ICU_H
28 #if (HAL_USE_ICU == TRUE) || defined(__DOXYGEN__)
31 /* Driver constants. */
37
38 /*===========================================================================*/
39 /* Derived constants and error checks. */
40 /*===========================================================================*/
41
43 /* Driver data structures and types. */
45
46 /**
47  * @brief Driver state machine possible states.
48  */
49 typedef enum {
50  ICU_UNINIT = 0, /**< Not initialized. */
51  ICU_STOP = 1, /**< Stopped. */
52  ICU_READY = 2, /**< Ready. */
53  ICU_WAITING = 3, /**< Waiting for first front. */
54  ICU_ACTIVE = 4 /**< First front detected. */
55 } icustate_t;
56
57 /**
58  * @brief Type of a structure representing an ICU driver.
59  */
60 typedef struct ICUDriver ICUDriver;
61
62 /**
63  * @brief ICU notification callback type.
64  *
65  * @param[in] icup pointer to a @p ICUDriver object
66  */
67 typedef void (*icucallback_t)(ICUDriver *icup);
68
69 #include "hal_icu_lld.h"
70
71 /*===========================================================================*/
72 /* Driver macros. */
73 /*===========================================================================*/
74
75 /**
76  * @name Macro Functions
77  * @{
78  */
79 /**
80  * @brief Starts the input capture.
81  *
82  * @param[in] icup pointer to the @p ICUDriver object
83  *
84  * @iclass
85  */
86 #define icuStartCaptureI(icup) do { \
87  icu_lld_start_capture(icup); \
88  (icup)->state = ICU_WAITING; \
89 } while (false)
90
91 /**
92  * @brief Stops the input capture.
93  *
94  * @param[in] icup pointer to the @p ICUDriver object
95  *
96  * @iclass
97  */
98 #define icuStopCaptureI(icup) do { \
99  icu_lld_stop_capture(icup); \
100  (icup)->state = ICU_READY; \
101 } while (false)
102
103 /**
104  * @brief Enables notifications.
105  * @pre The ICU unit must have been activated using @p icuStart() and the
106  * capture started using @p icuStartCapture().
107  * @note If the notification is already enabled then the call has no effect.
108  *
109  * @param[in] icup pointer to the @p ICUDriver object
110  *
111  * @iclass
112  */
113 #define icuEnableNotificationsI(icup) icu_lld_enable_notifications(icup)
114
115 /**
116  * @brief Disables notifications.
117  * @pre The ICU unit must have been activated using @p icuStart() and the
118  * capture started using @p icuStartCapture().
119  * @note If the notification is already disabled then the call has no effect.
120  *
121  * @param[in] icup pointer to the @p ICUDriver object
122  *
123  * @iclass
124  */
125 #define icuDisableNotificationsI(icup) icu_lld_disable_notifications(icup)
126
127 /**
128  * @brief Check on notifications status.
129  *
130  * @param[in] icup pointer to the @p ICUDriver object
131  * @return The notifications status.
132  * @retval false if notifications are not enabled.
133  * @retval true if notifications are enabled.
134  *
135  * @notapi
136  */
137 #define icuAreNotificationsEnabledX(icup) \
138  icu_lld_are_notifications_enabled(icup)
139
140 /**
141  * @brief Returns the width of the latest pulse.
142  * @details The pulse width is defined as number of ticks between the start
143  * edge and the stop edge.
144  * @note This function is meant to be invoked from the width capture
145  * callback.
146  *
147  * @param[in] icup pointer to the @p ICUDriver object
148  * @return The number of ticks.
149  *
150  * @xclass
151  */
152 #define icuGetWidthX(icup) icu_lld_get_width(icup)
153
154 /**
155  * @brief Returns the width of the latest cycle.
156  * @details The cycle width is defined as number of ticks between a start
157  * edge and the next start edge.
158  * @note This function is meant to be invoked from the width capture
159  * callback.
160  *
161  * @param[in] icup pointer to the @p ICUDriver object
162  * @return The number of ticks.
163  *
164  * @xclass
165  */
166 #define icuGetPeriodX(icup) icu_lld_get_period(icup)
167 /** @} */
168
169 /**
170  * @name Low level driver helper macros
171  * @{
172  */
173 /**
174  * @brief Common ISR code, ICU width event.
175  *
176  * @param[in] icup pointer to the @p ICUDriver object
177  *
178  * @notapi
179  */
180 #define _icu_isr_invoke_width_cb(icup) do { \
181  if (((icup)->state == ICU_ACTIVE) && \
182  ((icup)->config->width_cb != NULL)) \
183  (icup)->config->width_cb(icup); \
184 } while (0)
185
186 /**
187  * @brief Common ISR code, ICU period event.
188  * @note A period event brings the driver into the @p ICU_ACTIVE state.
189  *
190  * @param[in] icup pointer to the @p ICUDriver object
191  *
192  * @notapi
193  */
194 #define _icu_isr_invoke_period_cb(icup) do { \
195  if (((icup)->state == ICU_ACTIVE) && \
196  ((icup)->config->period_cb != NULL)) \
197  (icup)->config->period_cb(icup); \
198  (icup)->state = ICU_ACTIVE; \
199 } while (0)
200
201 /**
202  * @brief Common ISR code, ICU timer overflow event.
203  * @note An overflow always brings the driver back to the @p ICU_WAITING
204  * state.
205  *
206  * @param[in] icup pointer to the @p ICUDriver object
207  *
208  * @notapi
209  */
210 #define _icu_isr_invoke_overflow_cb(icup) do { \
211  (icup)->config->overflow_cb(icup); \
212  (icup)->state = ICU_WAITING; \
213 } while (0)
214 /** @} */
215
216 /*===========================================================================*/
217 /* External declarations. */
218 /*===========================================================================*/
219
220 #ifdef __cplusplus
221 extern "C" {
222 #endif
223  void icuInit(void);
224  void icuObjectInit(ICUDriver *icup);
225  void icuStart(ICUDriver *icup, const ICUConfig *config);
226  void icuStop(ICUDriver *icup);
227  void icuStartCapture(ICUDriver *icup);
228  bool icuWaitCapture(ICUDriver *icup);
229  void icuStopCapture(ICUDriver *icup);
230  void icuEnableNotifications(ICUDriver *icup);
232 #ifdef __cplusplus
233 }
234 #endif
235
236 #endif /* HAL_USE_ICU == TRUE */
237
238 #endif /* HAL_ICU_H */
239
240 /** @} */
Initializes the standard part of a ICUDriver structure.
Definition: hal_icu.c:68
PLATFORM ICU subsystem low level driver header.
void icuInit(void)
ICU Driver initialization.
Definition: hal_icu.c:56
Definition: hal_icu_lld.h:82
Structure representing an ICU driver.
Definition: hal_icu_lld.h:111
icustate_t
Definition: hal_icu.h:49
Definition: hal_icu.c:175
Definition: hal_icu.c:125
Waits for a completed capture.
Definition: hal_icu.c:151
const ICUConfig * config
Current configuration data.
Definition: hal_icu_lld.h:119
void icuDisableNotifications(ICUDriver *icup)
Definition: hal_icu.c:218
Configures and activates the ICU peripheral.
Definition: hal_icu.c:82
Definition: hal_icu.c:197
Deactivates the ICU peripheral.
Definition: hal_icu.c:102
void(* icucallback_t)(ICUDriver *icup)
Definition: hal_icu.h:67
