hal_jesd216_flash.h
18  * @file hal_jesd216_flash.h
19  * @brief JESD216 compliant flash driver class header.
21  * @addtogroup HAL_JESD216_FLASH
25 #ifndef HAL_JESD216_FLASH_H
26 #define HAL_JESD216_FLASH_H
28 #include "hal_flash.h"
31 /* Driver constants. */
34 /**
35  * @name Common command codes
36  * @{
37  */
38 #define JESD216_CMD_READ_ID 0x9FU
39 #define JESD216_CMD_READ 0x03U
40 #define JESD216_CMD_WRITE_ENABLE 0x06U
41 #define JESD216_CMD_WRITE_DISABLE 0x04U
42 #define JESD216_CMD_READ_STATUS_REGISTER 0x05U
43 #define JESD216_CMD_WRITE_STATUS_REGISTER 0x01U
44 #define JESD216_CMD_PAGE_PROGRAM 0x02U
45 #define JESD216_CMD_ERASE_4K 0x20U
46 #define JESD216_CMD_ERASE_BULK 0xC7U
47 #define JESD216_CMD_PROGRAM_ERASE_RESUME 0x7AU
48 #define JESD216_CMD_PROGRAM_ERASE_SUSPEND 0x75U
49 #define JESD216_CMD_READ_OTP_ARRAY 0x4BU
50 #define JESD216_CMD_PROGRAM_OTP_ARRAY 0x42U
51 /** @} */
52
53 /**
54  * @name Command options
55  * @{
56  */
57 #define JESD216_CMD_EXTENDED_ADDRESSING 0x80000000U
58 /** @} */
59
60 /**
61  * @name Bus interface.
62  * @{
63  */
64 #define JESD216_BUS_MODE_SPI 0U
65 #define JESD216_BUS_MODE_QSPI1L 1U
66 #define JESD216_BUS_MODE_QSPI2L 2U
67 #define JESD216_BUS_MODE_QSPI4L 4U
68 /** @} */
69
70 /*===========================================================================*/
71 /* Driver pre-compile time settings. */
72 /*===========================================================================*/
73
74 /**
75  * @name Configuration options
76  * @{
77  */
78 /**
79  * @brief Physical transport interface.
80  */
81 #if !defined(JESD216_BUS_MODE) || defined(__DOXYGEN__)
82 #define JESD216_BUS_MODE JESD216_BUS_MODE_QSPI4L
83 #endif
84
85 /**
86  * @brief Shared bus switch.
87  * @details If set to @p TRUE the device acquires bus ownership
88  * on each transaction.
89  * @note Requires @p SPI_USE_MUTUAL_EXCLUSION or
90  * @p SPI_USE_MUTUAL_EXCLUSION.
91  */
92 #if !defined(JESD216_SHARED_BUS) || defined(__DOXYGEN__)
93 #define JESD216_SHARED_BUS TRUE
94 #endif
95 /** @} */
96
97 /*===========================================================================*/
98 /* Derived constants and error checks. */
99 /*===========================================================================*/
100
101 #if (JESD216_BUS_MODE == JESD216_BUS_MODE_SPI) && (HAL_USE_SPI == FALSE)
102 #error "JESD216_BUS_MODE_SPI requires HAL_USE_SPI"
103 #endif
104
105 #if (JESD216_BUS_MODE != JESD216_BUS_MODE_SPI) && (HAL_USE_QSPI == FALSE)
106 #error "JESD216_BUS_MODE_QSPIxL requires HAL_USE_QSPI"
107 #endif
108
109 #if (JESD216_BUS_MODE == JESD216_BUS_MODE_SPI) && \
110  (JESD216_SHARED_BUS == TRUE) && \
111  (SPI_USE_MUTUAL_EXCLUSION == FALSE)
112 #error "JESD216_SHARED_SPI requires SPI_USE_MUTUAL_EXCLUSION"
113 #endif
114
115 #if (JESD216_BUS_MODE != JESD216_BUS_MODE_SPI) && \
116  (JESD216_BUS_MODE != JESD216_BUS_MODE_QSPI1L) && \
117  (JESD216_BUS_MODE != JESD216_BUS_MODE_QSPI2L) && \
118  (JESD216_BUS_MODE != JESD216_BUS_MODE_QSPI4L)
119 #error "invalid JESD216_BUS_MODE selected"
120 #endif
121
122 /*===========================================================================*/
123 /* Driver data structures and types. */
124 /*===========================================================================*/
125
126 #if (JESD216_BUS_MODE != JESD216_BUS_MODE_SPI) || defined(__DOXYGEN__)
127 #define BUSConfig QSPIConfig
128 #define BUSDriver QSPIDriver
129 #else
130 #define BUSConfig SPIConfig
131 #define BUSDriver SPIDriver
132 #endif
133
134 #define _jesd216_config \
135  BUSDriver *busp; \
136  const BUSConfig *buscfg;
137
138 /**
139  * @brief @p JESD215Flash specific methods.
140  */
141 #define _jesd216_flash_methods_alone \
142  /* Read SFDP.*/ \
143  flash_error_t (*read_sfdp)(void *instance, \
144  flash_offset_t offset, \
145  size_t n, \
146  uint8_t *rp);
147
148 /**
149  * @brief @p JESD215Flash specific methods with inherited ones.
150  */
151 #define _jesd216_flash_methods \
152  _base_flash_methods \
153  _jesd216_flash_methods_alone
154
155 /**
156  * @brief @p JESD215Flash virtual methods table.
157  */
160 };
161
162 /**
163  * @brief @p JESD215Flash specific data.
164  */
165 #define _jesd216_flash_data \
166  _base_flash_data
167
168 /**
169  * @brief Base flash class.
170  */
171 typedef struct {
172  /** @brief Virtual Methods Table.*/
173  const struct JESD215FlashVMT *vmt;
175 } JESD215Flash;
176
177 /*===========================================================================*/
178 /* Driver macros. */
179 /*===========================================================================*/
180
181 /**
182  * @name Macro Functions (BaseFlash)
183  * @{
184  */
185 /** @} */
186
187 /*===========================================================================*/
188 /* External declarations. */
189 /*===========================================================================*/
190
191 #ifdef __cplusplus
192 extern "C" {
193 #endif
194  void jesd216_start(BUSDriver *busp, const BUSConfig *config);
195  void jesd216_stop(BUSDriver *busp);
196  void jesd216_cmd(BUSDriver *busp, uint32_t cmd);
197  void jesd216_cmd_receive(BUSDriver *busp, uint32_t cmd,
198  size_t n, uint8_t *p);
199  void jesd216_cmd_send(BUSDriver *busp, uint32_t cmd,
200  size_t n, const uint8_t *p);
201  void jesd216_cmd_addr(BUSDriver *busp, uint32_t cmd, flash_offset_t offset);
202  void jesd216_cmd_addr_send(BUSDriver *busp, uint32_t cmd,
203  flash_offset_t offset, size_t n, const uint8_t *p);
204  void jesd216_cmd_addr_receive(BUSDriver *busp, uint32_t cmd,
205  flash_offset_t offset, size_t n, uint8_t *p);
206 #if JESD216_BUS_MODE != JESD216_BUS_MODE_SPI
207  void jesd216_cmd_addr_dummy_receive(BUSDriver *busp, uint32_t cmd,
208  flash_offset_t offset, uint8_t dummy,
209  size_t n, uint8_t *p);
210 #endif /* JESD216_BUS_MODE != JESD216_BUS_MODE_SPI */
211 #if JESD216_SHARED_BUS == TRUE
212  void jesd216_bus_acquire(BUSDriver *busp, const BUSConfig *config);
213  void jesd216_bus_release(BUSDriver *busp);
214 #endif
215 #ifdef __cplusplus
216 }
217 #endif
218
219 #endif /* HAL_JESD216_FLASH_H */
220
221 /** @} */
uint32_t flash_offset_t
Type of a flash offset.
Definition: hal_flash.h:83
const struct JESD215FlashVMT * vmt
Base flash class.
Generic flash driver class header.
