hal_mmc_spi.c
16 /*
17  Parts of this file have been contributed by Matthias Blaicher.
18  */
19
20 /**
21  * @file hal_mmc_spi.c
22  * @brief MMC over SPI driver code.
23  *
24  * @addtogroup MMC_SPI
25  * @{
26  */
28 #include <string.h>
30 #include "hal.h"
31
32 #if (HAL_USE_MMC_SPI == TRUE) || defined(__DOXYGEN__)
35 /* Driver local definitions. */
37
38 /*===========================================================================*/
39 /* Driver exported variables. */
40 /*===========================================================================*/
41
43 /* Driver local variables and types. */
45
46 /* Forward declarations required by mmc_vmt.*/
47 static bool mmc_read(void *instance, uint32_t startblk,
48  uint8_t *buffer, uint32_t n);
49 static bool mmc_write(void *instance, uint32_t startblk,
50  const uint8_t *buffer, uint32_t n);
51
52 /**
53  * @brief Virtual methods table.
54  */
55 static const struct MMCDriverVMT mmc_vmt = {
56  (size_t)0,
57  (bool (*)(void *))mmc_lld_is_card_inserted,
58  (bool (*)(void *))mmc_lld_is_write_protected,
59  (bool (*)(void *))mmcConnect,
60  (bool (*)(void *))mmcDisconnect,
61  mmc_read,
62  mmc_write,
63  (bool (*)(void *))mmcSync,
64  (bool (*)(void *, BlockDeviceInfo *))mmcGetInfo
65 };
66
67 /**
68  * @brief Lookup table for CRC-7 ( based on polynomial x^7 + x^3 + 1).
69  */
70 static const uint8_t crc7_lookup_table[256] = {
71  0x00, 0x09, 0x12, 0x1b, 0x24, 0x2d, 0x36, 0x3f, 0x48, 0x41, 0x5a, 0x53,
72  0x6c, 0x65, 0x7e, 0x77, 0x19, 0x10, 0x0b, 0x02, 0x3d, 0x34, 0x2f, 0x26,
73  0x51, 0x58, 0x43, 0x4a, 0x75, 0x7c, 0x67, 0x6e, 0x32, 0x3b, 0x20, 0x29,
74  0x16, 0x1f, 0x04, 0x0d, 0x7a, 0x73, 0x68, 0x61, 0x5e, 0x57, 0x4c, 0x45,
75  0x2b, 0x22, 0x39, 0x30, 0x0f, 0x06, 0x1d, 0x14, 0x63, 0x6a, 0x71, 0x78,
76  0x47, 0x4e, 0x55, 0x5c, 0x64, 0x6d, 0x76, 0x7f, 0x40, 0x49, 0x52, 0x5b,
77  0x2c, 0x25, 0x3e, 0x37, 0x08, 0x01, 0x1a, 0x13, 0x7d, 0x74, 0x6f, 0x66,
78  0x59, 0x50, 0x4b, 0x42, 0x35, 0x3c, 0x27, 0x2e, 0x11, 0x18, 0x03, 0x0a,
79  0x56, 0x5f, 0x44, 0x4d, 0x72, 0x7b, 0x60, 0x69, 0x1e, 0x17, 0x0c, 0x05,
80  0x3a, 0x33, 0x28, 0x21, 0x4f, 0x46, 0x5d, 0x54, 0x6b, 0x62, 0x79, 0x70,
81  0x07, 0x0e, 0x15, 0x1c, 0x23, 0x2a, 0x31, 0x38, 0x41, 0x48, 0x53, 0x5a,
82  0x65, 0x6c, 0x77, 0x7e, 0x09, 0x00, 0x1b, 0x12, 0x2d, 0x24, 0x3f, 0x36,
83  0x58, 0x51, 0x4a, 0x43, 0x7c, 0x75, 0x6e, 0x67, 0x10, 0x19, 0x02, 0x0b,
84  0x34, 0x3d, 0x26, 0x2f, 0x73, 0x7a, 0x61, 0x68, 0x57, 0x5e, 0x45, 0x4c,
85  0x3b, 0x32, 0x29, 0x20, 0x1f, 0x16, 0x0d, 0x04, 0x6a, 0x63, 0x78, 0x71,
86  0x4e, 0x47, 0x5c, 0x55, 0x22, 0x2b, 0x30, 0x39, 0x06, 0x0f, 0x14, 0x1d,
87  0x25, 0x2c, 0x37, 0x3e, 0x01, 0x08, 0x13, 0x1a, 0x6d, 0x64, 0x7f, 0x76,
88  0x49, 0x40, 0x5b, 0x52, 0x3c, 0x35, 0x2e, 0x27, 0x18, 0x11, 0x0a, 0x03,
89  0x74, 0x7d, 0x66, 0x6f, 0x50, 0x59, 0x42, 0x4b, 0x17, 0x1e, 0x05, 0x0c,
90  0x33, 0x3a, 0x21, 0x28, 0x5f, 0x56, 0x4d, 0x44, 0x7b, 0x72, 0x69, 0x60,
91  0x0e, 0x07, 0x1c, 0x15, 0x2a, 0x23, 0x38, 0x31, 0x46, 0x4f, 0x54, 0x5d,
92  0x62, 0x6b, 0x70, 0x79
93 };
94
95 /*===========================================================================*/
96 /* Driver local functions. */
97 /*===========================================================================*/
98
99 static bool mmc_read(void *instance, uint32_t startblk,
100  uint8_t *buffer, uint32_t n) {
101
102  if (mmcStartSequentialRead((MMCDriver *)instance, startblk)) {
103  return HAL_FAILED;
104  }
105
106  while (n > 0U) {
107  if (mmcSequentialRead((MMCDriver *)instance, buffer)) {
108  return HAL_FAILED;
109  }
110  buffer += MMCSD_BLOCK_SIZE;
111  n--;
112  }
113
114  if (mmcStopSequentialRead((MMCDriver *)instance)) {
115  return HAL_FAILED;
116  }
117  return HAL_SUCCESS;
118 }
119
120 static bool mmc_write(void *instance, uint32_t startblk,
121  const uint8_t *buffer, uint32_t n) {
122
123  if (mmcStartSequentialWrite((MMCDriver *)instance, startblk)) {
124  return HAL_FAILED;
125  }
126
127  while (n > 0U) {
128  if (mmcSequentialWrite((MMCDriver *)instance, buffer)) {
129  return HAL_FAILED;
130  }
131  buffer += MMCSD_BLOCK_SIZE;
132  n--;
133  }
134
135  if (mmcStopSequentialWrite((MMCDriver *)instance)) {
136  return HAL_FAILED;
137  }
138  return HAL_SUCCESS;
139 }
140
141 /**
142  * @brief Calculate the MMC standard CRC-7 based on a lookup table.
143  *
144  * @param[in] crc start value for CRC
145  * @param[in] buffer pointer to data buffer
146  * @param[in] len length of data
147  * @return Calculated CRC
148  */
149 static uint8_t crc7(uint8_t crc, const uint8_t *buffer, size_t len) {
150
151  while (len > 0U) {
152  crc = crc7_lookup_table[(crc << 1) ^ (*buffer++)];
153  len--;
154  }
155  return crc;
156 }
157
158 /**
159  * @brief Waits an idle condition.
160  *
161  * @param[in] mmcp pointer to the @p MMCDriver object
162  *
163  * @notapi
164  */
165 static void wait(MMCDriver *mmcp) {
166  int i;
167  uint8_t buf[4];
168
169  for (i = 0; i < 16; i++) {
170  spiReceive(mmcp->config->spip, 1, buf);
171  if (buf[0] == 0xFFU) {
172  return;
173  }
174  }
175  /* Looks like it is a long wait.*/
176  while (true) {
177  spiReceive(mmcp->config->spip, 1, buf);
178  if (buf[0] == 0xFFU) {
179  break;
180  }
181 #if MMC_NICE_WAITING == TRUE
182  /* Trying to be nice with the other threads.*/
184 #endif
185  }
186 }
187
188 /**
189  * @brief Sends a command header.
190  *
191  * @param[in] mmcp pointer to the @p MMCDriver object
192  * @param[in] cmd the command id
193  * @param[in] arg the command argument
194  *
195  * @notapi
196  */
197 static void send_hdr(MMCDriver *mmcp, uint8_t cmd, uint32_t arg) {
198  uint8_t buf[6];
199
200  /* Wait for the bus to become idle if a write operation was in progress.*/
201  wait(mmcp);
202
203  buf[0] = (uint8_t)0x40U | cmd;
204  buf[1] = (uint8_t)(arg >> 24U);
205  buf[2] = (uint8_t)(arg >> 16U);
206  buf[3] = (uint8_t)(arg >> 8U);
207  buf[4] = (uint8_t)arg;
208  /* Calculate CRC for command header, shift to right position, add stop bit.*/
209  buf[5] = ((crc7(0, buf, 5U) & 0x7FU) << 1U) | 0x01U;
210
211  spiSend(mmcp->config->spip, 6, buf);
212 }
213
214 /**
215  * @brief Receives a single byte response.
216  *
217  * @param[in] mmcp pointer to the @p MMCDriver object
218  * @return The response as an @p uint8_t value.
219  * @retval 0xFF timed out.
220  *
221  * @notapi
222  */
223 static uint8_t recvr1(MMCDriver *mmcp) {
224  int i;
225  uint8_t r1[1];
226
227  for (i = 0; i < 9; i++) {
228  spiReceive(mmcp->config->spip, 1, r1);
229  if (r1[0] != 0xFFU) {
230  return r1[0];
231  }
232  }
233  return 0xFFU;
234 }
235
236 /**
237  * @brief Receives a three byte response.
238  *
239  * @param[in] mmcp pointer to the @p MMCDriver object
240  * @param[out] buffer pointer to four bytes wide buffer
241  * @return First response byte as an @p uint8_t value.
242  * @retval 0xFF timed out.
243  *
244  * @notapi
245  */
246 static uint8_t recvr3(MMCDriver *mmcp, uint8_t* buffer) {
247  uint8_t r1;
248
249  r1 = recvr1(mmcp);
250  spiReceive(mmcp->config->spip, 4, buffer);
251
252  return r1;
253 }
254
255 /**
256  * @brief Sends a command an returns a single byte response.
257  *
258  * @param[in] mmcp pointer to the @p MMCDriver object
259  * @param[in] cmd the command id
260  * @param[in] arg the command argument
261  * @return The response as an @p uint8_t value.
262  * @retval 0xFF timed out.
263  *
264  * @notapi
265  */
266 static uint8_t send_command_R1(MMCDriver *mmcp, uint8_t cmd, uint32_t arg) {
267  uint8_t r1;
268
269  spiSelect(mmcp->config->spip);
270  send_hdr(mmcp, cmd, arg);
271  r1 = recvr1(mmcp);
272  spiUnselect(mmcp->config->spip);
273  return r1;
274 }
275
276 /**
277  * @brief Sends a command which returns a five bytes response (R3).
278  *
279  * @param[in] mmcp pointer to the @p MMCDriver object
280  * @param[in] cmd the command id
281  * @param[in] arg the command argument
282  * @param[out] response pointer to four bytes wide uint8_t buffer
283  * @return The first byte of the response (R1) as an @p
284  * uint8_t value.
285  * @retval 0xFF timed out.
286  *
287  * @notapi
288  */
289 static uint8_t send_command_R3(MMCDriver *mmcp, uint8_t cmd, uint32_t arg,
290  uint8_t *response) {
291  uint8_t r1;
292
293  spiSelect(mmcp->config->spip);
294  send_hdr(mmcp, cmd, arg);
295  r1 = recvr3(mmcp, response);
296  spiUnselect(mmcp->config->spip);
297  return r1;
298 }
299
300 /**
301  * @brief Reads the CSD.
302  *
303  * @param[in] mmcp pointer to the @p MMCDriver object
304  * @param[out] cmd command
305  * @param[out] cxd pointer to the CSD/CID buffer
306  *
307  * @return The operation status.
308  * @retval HAL_SUCCESS the operation succeeded.
309  * @retval HAL_FAILED the operation failed.
310  *
311  * @notapi
312  */
313 static bool read_CxD(MMCDriver *mmcp, uint8_t cmd, uint32_t cxd[4]) {
314  unsigned i;
315  uint8_t *bp, buf[16];
316
317  spiSelect(mmcp->config->spip);
318  send_hdr(mmcp, cmd, 0);
319  if (recvr1(mmcp) != 0x00U) {
320  spiUnselect(mmcp->config->spip);
321  return HAL_FAILED;
322  }
323
324  /* Wait for data availability.*/
325  for (i = 0U; i < MMC_WAIT_DATA; i++) {
326  spiReceive(mmcp->config->spip, 1, buf);
327  if (buf[0] == 0xFEU) {
328  uint32_t *wp;
329
330  spiReceive(mmcp->config->spip, 16, buf);
331  bp = buf;
332  for (wp = &cxd[3]; wp >= cxd; wp--) {
333  *wp = ((uint32_t)bp[0] << 24U) | ((uint32_t)bp[1] << 16U) |
334  ((uint32_t)bp[2] << 8U) | (uint32_t)bp[3];
335  bp += 4;
336  }
337
338  /* CRC ignored then end of transaction. */
339  spiIgnore(mmcp->config->spip, 2);
340  spiUnselect(mmcp->config->spip);
341
342  return HAL_SUCCESS;
343  }
344  }
345  return HAL_FAILED;
346 }
347
348 /**
349  * @brief Waits that the card reaches an idle state.
350  *
351  * @param[in] mmcp pointer to the @p MMCDriver object
352  *
353  * @notapi
354  */
355 static void sync(MMCDriver *mmcp) {
356  uint8_t buf[1];
357
358  spiSelect(mmcp->config->spip);
359  while (true) {
360  spiReceive(mmcp->config->spip, 1, buf);
361  if (buf[0] == 0xFFU) {
362  break;
363  }
364 #if MMC_NICE_WAITING == TRUE
365  /* Trying to be nice with the other threads.*/
367 #endif
368  }
369  spiUnselect(mmcp->config->spip);
370 }
371
372 /*===========================================================================*/
373 /* Driver exported functions. */
374 /*===========================================================================*/
375
376 /**
377  * @brief MMC over SPI driver initialization.
378  * @note This function is implicitly invoked by @p halInit(), there is
379  * no need to explicitly initialize the driver.
380  *
381  * @init
382  */
383 void mmcInit(void) {
384
385 }
386
387 /**
388  * @brief Initializes an instance.
389  *
390  * @param[out] mmcp pointer to the @p MMCDriver object
391  *
392  * @init
393  */
395
396  mmcp->vmt = &mmc_vmt;
397  mmcp->state = BLK_STOP;
398  mmcp->config = NULL;
399  mmcp->block_addresses = false;
400 }
401
402 /**
403  * @brief Configures and activates the MMC peripheral.
404  *
405  * @param[in] mmcp pointer to the @p MMCDriver object
406  * @param[in] config pointer to the @p MMCConfig object.
407  *
408  * @api
409  */
410 void mmcStart(MMCDriver *mmcp, const MMCConfig *config) {
411
412  osalDbgCheck((mmcp != NULL) && (config != NULL));
413  osalDbgAssert((mmcp->state == BLK_STOP) || (mmcp->state == BLK_ACTIVE),
414  "invalid state");
415
416  mmcp->config = config;
417  mmcp->state = BLK_ACTIVE;
418 }
419
420 /**
421  * @brief Disables the MMC peripheral.
422  *
423  * @param[in] mmcp pointer to the @p MMCDriver object
424  *
425  * @api
426  */
427 void mmcStop(MMCDriver *mmcp) {
428
429  osalDbgCheck(mmcp != NULL);
430  osalDbgAssert((mmcp->state == BLK_STOP) || (mmcp->state == BLK_ACTIVE),
431  "invalid state");
432
433  spiStop(mmcp->config->spip);
434  mmcp->config = NULL;
435  mmcp->state = BLK_STOP;
436 }
437
438 /**
439  * @brief Performs the initialization procedure on the inserted card.
440  * @details This function should be invoked when a card is inserted and
441  * brings the driver in the @p MMC_READY state where it is possible
442  * to perform read and write operations.
443  * @note It is possible to invoke this function from the insertion event
444  * handler.
445  *
446  * @param[in] mmcp pointer to the @p MMCDriver object
447  *
448  * @return The operation status.
449  * @retval HAL_SUCCESS the operation succeeded and the driver is now
450  * in the @p MMC_READY state.
451  * @retval HAL_FAILED the operation failed.
452  *
453  * @api
454  */
455 bool mmcConnect(MMCDriver *mmcp) {
456  unsigned i;
457  uint8_t r3[4];
458
459  osalDbgCheck(mmcp != NULL);
460
461  osalDbgAssert((mmcp->state == BLK_ACTIVE) || (mmcp->state == BLK_READY),
462  "invalid state");
463
464  /* Connection procedure in progress.*/
465  mmcp->state = BLK_CONNECTING;
466  mmcp->block_addresses = false;
467
468  /* Slow clock mode and 128 clock pulses.*/
469  spiStart(mmcp->config->spip, mmcp->config->lscfg);
470  spiIgnore(mmcp->config->spip, 16);
471
472  /* SPI mode selection.*/
473  i = 0;
474  while (true) {
475  if (send_command_R1(mmcp, MMCSD_CMD_GO_IDLE_STATE, 0) == 0x01U) {
476  break;
477  }
478  if (++i >= MMC_CMD0_RETRY) {
479  goto failed;
480  }
482  }
483
484  /* Try to detect if this is a high capacity card and switch to block
485  addresses if possible.
486  This method is based on "How to support SDC Ver2 and high capacity cards"
487  by ElmChan.*/
488  if (send_command_R3(mmcp, MMCSD_CMD_SEND_IF_COND,
489  MMCSD_CMD8_PATTERN, r3) != 0x05U) {
490
491  /* Switch to SDHC mode.*/
492  i = 0;
493  while (true) {
494  /*lint -save -e9007 [13.5] Side effect unimportant.*/
495  if ((send_command_R1(mmcp, MMCSD_CMD_APP_CMD, 0) == 0x01U) &&
496  (send_command_R3(mmcp, MMCSD_CMD_APP_OP_COND, 0x400001AAU, r3) == 0x00U)) {
497  /*lint -restore*/
498  break;
499  }
500
501  if (++i >= MMC_ACMD41_RETRY) {
502  goto failed;
503  }
505  }
506
507  /* Execute dedicated read on OCR register */
508  (void) send_command_R3(mmcp, MMCSD_CMD_READ_OCR, 0, r3);
509
510  /* Check if CCS is set in response. Card operates in block mode if set.*/
511  if ((r3[0] & 0x40U) != 0U) {
512  mmcp->block_addresses = true;
513  }
514  }
515
516  /* Initialization.*/
517  i = 0;
518  while (true) {
519  uint8_t b = send_command_R1(mmcp, MMCSD_CMD_INIT, 0);
520  if (b == 0x00U) {
521  break;
522  }
523  if (b != 0x01U) {
524  goto failed;
525  }
526  if (++i >= MMC_CMD1_RETRY) {
527  goto failed;
528  }
530  }
531
532  /* Initialization complete, full speed.*/
533  spiStart(mmcp->config->spip, mmcp->config->hscfg);
534
535  /* Setting block size.*/
536  if (send_command_R1(mmcp, MMCSD_CMD_SET_BLOCKLEN,
537  MMCSD_BLOCK_SIZE) != 0x00U) {
538  goto failed;
539  }
540
541  /* Determine capacity.*/
542  if (read_CxD(mmcp, MMCSD_CMD_SEND_CSD, mmcp->csd)) {
543  goto failed;
544  }
545
546  mmcp->capacity = _mmcsd_get_capacity(mmcp->csd);
547  if (mmcp->capacity == 0U) {
548  goto failed;
549  }
550
551  if (read_CxD(mmcp, MMCSD_CMD_SEND_CID, mmcp->cid)) {
552  goto failed;
553  }
554
555  mmcp->state = BLK_READY;
556  return HAL_SUCCESS;
557
558  /* Connection failed, state reset to BLK_ACTIVE.*/
559 failed:
560  spiStop(mmcp->config->spip);
561  mmcp->state = BLK_ACTIVE;
562  return HAL_FAILED;
563 }
564
565 /**
566  * @brief Brings the driver in a state safe for card removal.
567  *
568  * @param[in] mmcp pointer to the @p MMCDriver object
569  * @return The operation status.
570  *
571  * @retval HAL_SUCCESS the operation succeeded and the driver is now
572  * in the @p MMC_INSERTED state.
573  * @retval HAL_FAILED the operation failed.
574  *
575  * @api
576  */
578
579  osalDbgCheck(mmcp != NULL);
580
581  osalSysLock();
582  osalDbgAssert((mmcp->state == BLK_ACTIVE) || (mmcp->state == BLK_READY),
583  "invalid state");
584  if (mmcp->state == BLK_ACTIVE) {
585  osalSysUnlock();
586  return HAL_SUCCESS;
587  }
588  mmcp->state = BLK_DISCONNECTING;
589  osalSysUnlock();
590
591  /* Wait for the pending write operations to complete.*/
592  spiStart(mmcp->config->spip, mmcp->config->hscfg);
593  sync(mmcp);
594
595  spiStop(mmcp->config->spip);
596  mmcp->state = BLK_ACTIVE;
597  return HAL_SUCCESS;
598 }
599
600 /**
601  * @brief Starts a sequential read.
602  *
603  * @param[in] mmcp pointer to the @p MMCDriver object
604  * @param[in] startblk first block to read
605  *
606  * @return The operation status.
607  * @retval HAL_SUCCESS the operation succeeded.
608  * @retval HAL_FAILED the operation failed.
609  *
610  * @api
611  */
612 bool mmcStartSequentialRead(MMCDriver *mmcp, uint32_t startblk) {
613
614  osalDbgCheck(mmcp != NULL);
615  osalDbgAssert(mmcp->state == BLK_READY, "invalid state");
616
617  /* Read operation in progress.*/
618  mmcp->state = BLK_READING;
619
620  /* (Re)starting the SPI in case it has been reprogrammed externally, it can
621  happen if the SPI bus is shared among multiple peripherals.*/
622  spiStart(mmcp->config->spip, mmcp->config->hscfg);
623  spiSelect(mmcp->config->spip);
624
625  if (mmcp->block_addresses) {
626  send_hdr(mmcp, MMCSD_CMD_READ_MULTIPLE_BLOCK, startblk);
627  }
628  else {
629  send_hdr(mmcp, MMCSD_CMD_READ_MULTIPLE_BLOCK, startblk * MMCSD_BLOCK_SIZE);
630  }
631
632  if (recvr1(mmcp) != 0x00U) {
633  spiStop(mmcp->config->spip);
634  mmcp->state = BLK_READY;
635  return HAL_FAILED;
636  }
637  return HAL_SUCCESS;
638 }
639
640 /**
641  * @brief Reads a block within a sequential read operation.
642  *
643  * @param[in] mmcp pointer to the @p MMCDriver object
644  * @param[out] buffer pointer to the read buffer
645  *
646  * @return The operation status.
647  * @retval HAL_SUCCESS the operation succeeded.
648  * @retval HAL_FAILED the operation failed.
649  *
650  * @api
651  */
652 bool mmcSequentialRead(MMCDriver *mmcp, uint8_t *buffer) {
653  unsigned i;
654
655  osalDbgCheck((mmcp != NULL) && (buffer != NULL));
656
657  if (mmcp->state != BLK_READING) {
658  return HAL_FAILED;
659  }
660
661  for (i = 0; i < MMC_WAIT_DATA; i++) {
662  spiReceive(mmcp->config->spip, 1, buffer);
663  if (buffer[0] == 0xFEU) {
664  spiReceive(mmcp->config->spip, MMCSD_BLOCK_SIZE, buffer);
665  /* CRC ignored. */
666  spiIgnore(mmcp->config->spip, 2);
667  return HAL_SUCCESS;
668  }
669  }
670  /* Timeout.*/
671  spiUnselect(mmcp->config->spip);
672  spiStop(mmcp->config->spip);
673  mmcp->state = BLK_READY;
674  return HAL_FAILED;
675 }
676
677 /**
678  * @brief Stops a sequential read gracefully.
679  *
680  * @param[in] mmcp pointer to the @p MMCDriver object
681  *
682  * @return The operation status.
683  * @retval HAL_SUCCESS the operation succeeded.
684  * @retval HAL_FAILED the operation failed.
685  *
686  * @api
687  */
689  static const uint8_t stopcmd[] = {
690  (uint8_t)(0x40U | MMCSD_CMD_STOP_TRANSMISSION), 0, 0, 0, 0, 1, 0xFF
691  };
692
693  osalDbgCheck(mmcp != NULL);
694
695  if (mmcp->state != BLK_READING) {
696  return HAL_FAILED;
697  }
698
699  spiSend(mmcp->config->spip, sizeof(stopcmd), stopcmd);
700 /* result = recvr1(mmcp) != 0x00U;*/
701  /* Note, ignored r1 response, it can be not zero, unknown issue.*/
702  (void) recvr1(mmcp);
703
704  /* Read operation finished.*/
705  spiUnselect(mmcp->config->spip);
706  mmcp->state = BLK_READY;
707  return HAL_SUCCESS;
708 }
709
710 /**
711  * @brief Starts a sequential write.
712  *
713  * @param[in] mmcp pointer to the @p MMCDriver object
714  * @param[in] startblk first block to write
715  *
716  * @return The operation status.
717  * @retval HAL_SUCCESS the operation succeeded.
718  * @retval HAL_FAILED the operation failed.
719  *
720  * @api
721  */
722 bool mmcStartSequentialWrite(MMCDriver *mmcp, uint32_t startblk) {
723
724  osalDbgCheck(mmcp != NULL);
725  osalDbgAssert(mmcp->state == BLK_READY, "invalid state");
726
727  /* Write operation in progress.*/
728  mmcp->state = BLK_WRITING;
729
730  spiStart(mmcp->config->spip, mmcp->config->hscfg);
731  spiSelect(mmcp->config->spip);
732  if (mmcp->block_addresses) {
733  send_hdr(mmcp, MMCSD_CMD_WRITE_MULTIPLE_BLOCK, startblk);
734  }
735  else {
736  send_hdr(mmcp, MMCSD_CMD_WRITE_MULTIPLE_BLOCK,
737  startblk * MMCSD_BLOCK_SIZE);
738  }
739
740  if (recvr1(mmcp) != 0x00U) {
741  spiStop(mmcp->config->spip);
742  mmcp->state = BLK_READY;
743  return HAL_FAILED;
744  }
745  return HAL_SUCCESS;
746 }
747
748 /**
749  * @brief Writes a block within a sequential write operation.
750  *
751  * @param[in] mmcp pointer to the @p MMCDriver object
752  * @param[out] buffer pointer to the write buffer
753  *
754  * @return The operation status.
755  * @retval HAL_SUCCESS the operation succeeded.
756  * @retval HAL_FAILED the operation failed.
757  *
758  * @api
759  */
760 bool mmcSequentialWrite(MMCDriver *mmcp, const uint8_t *buffer) {
761  static const uint8_t start[] = {0xFF, 0xFC};
762  uint8_t b[1];
763
764  osalDbgCheck((mmcp != NULL) && (buffer != NULL));
765
766  if (mmcp->state != BLK_WRITING) {
767  return HAL_FAILED;
768  }
769
770  spiSend(mmcp->config->spip, sizeof(start), start); /* Data prologue. */
771  spiSend(mmcp->config->spip, MMCSD_BLOCK_SIZE, buffer);/* Data. */
772  spiIgnore(mmcp->config->spip, 2); /* CRC ignored. */
773  spiReceive(mmcp->config->spip, 1, b);
774  if ((b[0] & 0x1FU) == 0x05U) {
775  wait(mmcp);
776  return HAL_SUCCESS;
777  }
778
779  /* Error.*/
780  spiUnselect(mmcp->config->spip);
781  spiStop(mmcp->config->spip);
782  mmcp->state = BLK_READY;
783  return HAL_FAILED;
784 }
785
786 /**
787  * @brief Stops a sequential write gracefully.
788  *
789  * @param[in] mmcp pointer to the @p MMCDriver object
790  *
791  * @return The operation status.
792  * @retval HAL_SUCCESS the operation succeeded.
793  * @retval HAL_FAILED the operation failed.
794  *
795  * @api
796  */
798  static const uint8_t stop[] = {0xFD, 0xFF};
799
800  osalDbgCheck(mmcp != NULL);
801
802  if (mmcp->state != BLK_WRITING) {
803  return HAL_FAILED;
804  }
805
806  spiSend(mmcp->config->spip, sizeof(stop), stop);
807  spiUnselect(mmcp->config->spip);
808
809  /* Write operation finished.*/
810  mmcp->state = BLK_READY;
811  return HAL_SUCCESS;
812 }
813
814 /**
815  * @brief Waits for card idle condition.
816  *
817  * @param[in] mmcp pointer to the @p MMCDriver object
818  *
819  * @return The operation status.
820  * @retval HAL_SUCCESS the operation succeeded.
821  * @retval HAL_FAILED the operation failed.
822  *
823  * @api
824  */
825 bool mmcSync(MMCDriver *mmcp) {
826
827  osalDbgCheck(mmcp != NULL);
828
829  if (mmcp->state != BLK_READY) {
830  return HAL_FAILED;
831  }
832
833  /* Synchronization operation in progress.*/
834  mmcp->state = BLK_SYNCING;
835
836  spiStart(mmcp->config->spip, mmcp->config->hscfg);
837  sync(mmcp);
838
839  /* Synchronization operation finished.*/
840  mmcp->state = BLK_READY;
841  return HAL_SUCCESS;
842 }
843
844 /**
845  * @brief Returns the media info.
846  *
847  * @param[in] mmcp pointer to the @p MMCDriver object
848  * @param[out] bdip pointer to a @p BlockDeviceInfo structure
849  *
850  * @return The operation status.
851  * @retval HAL_SUCCESS the operation succeeded.
852  * @retval HAL_FAILED the operation failed.
853  *
854  * @api
855  */
857
858  osalDbgCheck((mmcp != NULL) && (bdip != NULL));
859
860  if (mmcp->state != BLK_READY) {
861  return HAL_FAILED;
862  }
863
864  bdip->blk_num = mmcp->capacity;
865  bdip->blk_size = MMCSD_BLOCK_SIZE;
866
867  return HAL_SUCCESS;
868 }
869
870 /**
871  * @brief Erases blocks.
872  *
873  * @param[in] mmcp pointer to the @p MMCDriver object
874  * @param[in] startblk starting block number
875  * @param[in] endblk ending block number
876  *
877  * @return The operation status.
878  * @retval HAL_SUCCESS the operation succeeded.
879  * @retval HAL_FAILED the operation failed.
880  *
881  * @api
882  */
883 bool mmcErase(MMCDriver *mmcp, uint32_t startblk, uint32_t endblk) {
884
885  osalDbgCheck((mmcp != NULL));
886
887  /* Erase operation in progress.*/
888  mmcp->state = BLK_WRITING;
889
890  /* Handling command differences between HC and normal cards.*/
891  if (!mmcp->block_addresses) {
892  startblk *= MMCSD_BLOCK_SIZE;
893  endblk *= MMCSD_BLOCK_SIZE;
894  }
895
896  if (send_command_R1(mmcp, MMCSD_CMD_ERASE_RW_BLK_START, startblk) != 0x00U) {
897  goto failed;
898  }
899
900  if (send_command_R1(mmcp, MMCSD_CMD_ERASE_RW_BLK_END, endblk) != 0x00U) {
901  goto failed;
902  }
903
904  if (send_command_R1(mmcp, MMCSD_CMD_ERASE, 0) != 0x00U) {
905  goto failed;
906  }
907
908  mmcp->state = BLK_READY;
909  return HAL_SUCCESS;
910
911  /* Command failed, state reset to BLK_ACTIVE.*/
912 failed:
913  spiStop(mmcp->config->spip);
914  mmcp->state = BLK_READY;
915  return HAL_FAILED;
916 }
917
918 #endif /* HAL_USE_MMC_SPI == TRUE */
919
920 /** @} */
Structure representing a MMC/SD over SPI driver.
Definition: hal_mmc_spi.h:110
Definition: hal_mmc_spi.c:612
void spiUnselect(SPIDriver *spip)
Deasserts the slave select signal.
Definition: hal_spi.c:154
Definition: hal_mmc_spi.c:197
void spiSelect(SPIDriver *spip)
Asserts the slave select signal and prepares for transfers.
Definition: hal_spi.c:136
void spiReceive(SPIDriver *spip, size_t n, void *rxbuf)
Receives data from the SPI bus.
Definition: hal_spi.c:418
bool mmcStopSequentialWrite(MMCDriver *mmcp)
Definition: hal_mmc_spi.c:797
void spiStart(SPIDriver *spip, const SPIConfig *config)
Configures and activates the SPI peripheral.
Definition: hal_spi.c:91
Definition: hal_mmc_spi.c:455
#define MMCSD_BLOCK_SIZE
Fixed block size for MMC/SD block devices.
Definition: hal_mmcsd.h:39
Definition: hal_mmc_spi.c:410
MMC/SD over SPI driver configuration structure.
Definition: hal_mmc_spi.h:75
bool mmcStopSequentialRead(MMCDriver *mmcp)
Definition: hal_mmc_spi.c:688
Definition: osal.h:540
Definition: hal_mmc_spi.c:427
const SPIConfig * lscfg
SPI low speed configuration used during initialization.
Definition: hal_mmc_spi.h:83
#define MMCSD_CMD8_PATTERN
Fixed pattern for CMD8.
Definition: hal_mmcsd.h:49
Definition: hal_mmc_spi.c:149
bool mmcGetInfo(MMCDriver *mmcp, BlockDeviceInfo *bdip)
Definition: hal_mmc_spi.c:856
Erases blocks.
Definition: hal_mmc_spi.c:883
Definition: hal_mmc_spi.c:55
Definition: hal_mmc_spi.c:825
#define osalThreadSleepMilliseconds(msecs)
Delays the invoking thread for the specified number of milliseconds.
Definition: osal.h:451
Reads the CSD.
Definition: hal_mmc_spi.c:313
_mmcsd_block_device_data const MMCConfig * config
Current configuration data.
Definition: hal_mmc_spi.h:119
const struct MMCDriverVMT * vmt
Virtual Methods Table.
Definition: hal_mmc_spi.h:114
Definition: hal_mmc_spi.c:722
Block device info.
Definition: hal_ioblock.h:55
uint32_t blk_num
Total number of blocks.
Definition: hal_ioblock.h:57
void mmcObjectInit(MMCDriver *mmcp)
Definition: hal_mmc_spi.c:394
Definition: hal_mmc_spi.c:760
Definition: hal_mmc_spi.c:355
SPIDriver * spip
SPI driver associated to this MMC driver.
Definition: hal_mmc_spi.h:79
Definition: hal_mmc_spi.c:165
MMCDriver virtual methods table.
Definition: hal_mmc_spi.h:101
void spiIgnore(SPIDriver *spip, size_t n)
Ignores data on the SPI bus.
Definition: hal_spi.c:324
void mmcInit(void)
Definition: hal_mmc_spi.c:383
static void osalSysLock(void)
Definition: osal.h:530
Definition: hal_mmc_spi.c:223
static uint8_t send_command_R3(MMCDriver *mmcp, uint8_t cmd, uint32_t arg, uint8_t *response)
Definition: hal_mmc_spi.c:289
void spiSend(SPIDriver *spip, size_t n, const void *txbuf)
Sends data over the SPI bus.
Definition: hal_spi.c:388
uint32_t blk_size
Block size in bytes.
Definition: hal_ioblock.h:56
uint32_t _mmcsd_get_capacity(const uint32_t *csd)
Extract card capacity from a CSD.
Definition: hal_mmcsd.c:93
static uint8_t recvr3(MMCDriver *mmcp, uint8_t *buffer)
Definition: hal_mmc_spi.c:246
bool mmcDisconnect(MMCDriver *mmcp)
Definition: hal_mmc_spi.c:577
void spiStop(SPIDriver *spip)
Deactivates the SPI peripheral.
Definition: hal_spi.c:113
const SPIConfig * hscfg
SPI high speed configuration used during transfers.
Definition: hal_mmc_spi.h:87
Definition: hal_mmc_spi.c:70
Definition: hal_mmc_spi.c:266
Definition: hal_mmc_spi.c:652
