hal_pwm.h
18  * @file hal_pwm.h
19  * @brief PWM Driver macros and structures.
21  * @addtogroup PWM
25 #ifndef HAL_PWM_H
26 #define HAL_PWM_H
28 #if (HAL_USE_PWM == TRUE) || defined(__DOXYGEN__)
31 /* Driver constants. */
34 /**
35  * @name PWM output mode macros
36  * @{
37  */
38 /**
39  * @brief Standard output modes mask.
40  */
41 #define PWM_OUTPUT_MASK 0x0FU
42
43 /**
44  * @brief Output not driven, callback only.
45  */
46 #define PWM_OUTPUT_DISABLED 0x00U
47
48 /**
49  * @brief Positive PWM logic, active is logic level one.
50  */
51 #define PWM_OUTPUT_ACTIVE_HIGH 0x01U
52
53 /**
54  * @brief Inverse PWM logic, active is logic level zero.
55  */
56 #define PWM_OUTPUT_ACTIVE_LOW 0x02U
57 /** @} */
58
60 /* Driver pre-compile time settings. */
61 /*===========================================================================*/
62
63 /*===========================================================================*/
64 /* Derived constants and error checks. */
65 /*===========================================================================*/
66
67 /*===========================================================================*/
68 /* Driver data structures and types. */
69 /*===========================================================================*/
70
71 /**
72  * @brief Driver state machine possible states.
73  */
74 typedef enum {
75  PWM_UNINIT = 0, /**< Not initialized. */
76  PWM_STOP = 1, /**< Stopped. */
77  PWM_READY = 2 /**< Ready. */
78 } pwmstate_t;
79
80 /**
81  * @brief Type of a structure representing a PWM driver.
82  */
83 typedef struct PWMDriver PWMDriver;
84
85 /**
86  * @brief Type of a PWM notification callback.
87  *
88  * @param[in] pwmp pointer to a @p PWMDriver object
89  */
90 typedef void (*pwmcallback_t)(PWMDriver *pwmp);
91
92 #include "hal_pwm_lld.h"
93
94 /*===========================================================================*/
95 /* Driver macros. */
96 /*===========================================================================*/
97
98 /**
99  * @name PWM duty cycle conversion
100  * @{
101  */
102 /**
103  * @brief Converts from fraction to pulse width.
104  * @note Be careful with rounding errors, this is integer math not magic.
105  * You can specify tenths of thousandth but make sure you have the
106  * proper hardware resolution by carefully choosing the clock source
107  * and prescaler settings, see @p PWM_COMPUTE_PSC.
108  *
109  * @param[in] pwmp pointer to a @p PWMDriver object
110  * @param[in] denominator denominator of the fraction
111  * @param[in] numerator numerator of the fraction
112  * @return The pulse width to be passed to @p pwmEnableChannel().
113  *
114  * @api
115  */
116 #define PWM_FRACTION_TO_WIDTH(pwmp, denominator, numerator) \
117  ((pwmcnt_t)((((pwmcnt_t)(pwmp)->period) * \
118  (pwmcnt_t)(numerator)) / (pwmcnt_t)(denominator)))
119
120 /**
121  * @brief Converts from degrees to pulse width.
122  * @note Be careful with rounding errors, this is integer math not magic.
123  * You can specify hundredths of degrees but make sure you have the
124  * proper hardware resolution by carefully choosing the clock source
125  * and prescaler settings, see @p PWM_COMPUTE_PSC.
126  *
127  * @param[in] pwmp pointer to a @p PWMDriver object
128  * @param[in] degrees degrees as an integer between 0 and 36000
129  * @return The pulse width to be passed to @p pwmEnableChannel().
130  *
131  * @api
132  */
133 #define PWM_DEGREES_TO_WIDTH(pwmp, degrees) \
134  PWM_FRACTION_TO_WIDTH(pwmp, 36000, degrees)
135
136 /**
137  * @brief Converts from percentage to pulse width.
138  * @note Be careful with rounding errors, this is integer math not magic.
139  * You can specify tenths of thousandth but make sure you have the
140  * proper hardware resolution by carefully choosing the clock source
141  * and prescaler settings, see @p PWM_COMPUTE_PSC.
142  *
143  * @param[in] pwmp pointer to a @p PWMDriver object
144  * @param[in] percentage percentage as an integer between 0 and 10000
145  * @return The pulse width to be passed to @p pwmEnableChannel().
146  *
147  * @api
148  */
149 #define PWM_PERCENTAGE_TO_WIDTH(pwmp, percentage) \
150  PWM_FRACTION_TO_WIDTH(pwmp, 10000, percentage)
151 /** @} */
152
153 /**
154  * @name Macro Functions
155  * @{
156  */
157 /**
158  * @brief Changes the period the PWM peripheral.
159  * @details This function changes the period of a PWM unit that has already
160  * been activated using @p pwmStart().
161  * @pre The PWM unit must have been activated using @p pwmStart().
162  * @post The PWM unit period is changed to the new value.
163  * @note If a period is specified that is shorter than the pulse width
164  * programmed in one of the channels then the behavior is not
165  * guaranteed.
166  *
167  * @param[in] pwmp pointer to a @p PWMDriver object
168  * @param[in] value new cycle time in ticks
169  *
170  * @iclass
171  */
172 #define pwmChangePeriodI(pwmp, value) { \
173  (pwmp)->period = (value); \
174  pwm_lld_change_period(pwmp, value); \
175 }
176
177 /**
178  * @brief Enables a PWM channel.
179  * @pre The PWM unit must have been activated using @p pwmStart().
180  * @post The channel is active using the specified configuration.
181  * @note Depending on the hardware implementation this function has
182  * effect starting on the next cycle (recommended implementation)
183  * or immediately (fallback implementation).
184  *
185  * @param[in] pwmp pointer to a @p PWMDriver object
186  * @param[in] channel PWM channel identifier (0...channels-1)
187  * @param[in] width PWM pulse width as clock pulses number
188  *
189  * @iclass
190  */
191 #define pwmEnableChannelI(pwmp, channel, width) do { \
192  (pwmp)->enabled |= ((pwmchnmsk_t)1U << (pwmchnmsk_t)(channel)); \
193  pwm_lld_enable_channel(pwmp, channel, width); \
194 } while (false)
195
196 /**
197  * @brief Disables a PWM channel.
198  * @pre The PWM unit must have been activated using @p pwmStart().
199  * @post The channel is disabled and its output line returned to the
200  * idle state.
201  * @note Depending on the hardware implementation this function has
202  * effect starting on the next cycle (recommended implementation)
203  * or immediately (fallback implementation).
204  *
205  * @param[in] pwmp pointer to a @p PWMDriver object
206  * @param[in] channel PWM channel identifier (0...channels-1)
207  *
208  * @iclass
209  */
210 #define pwmDisableChannelI(pwmp, channel) do { \
211  (pwmp)->enabled &= ~((pwmchnmsk_t)1U << (pwmchnmsk_t)(channel)); \
212  pwm_lld_disable_channel(pwmp, channel); \
213 } while (false)
214
215 /**
216  * @brief Returns a PWM channel status.
217  * @pre The PWM unit must have been activated using @p pwmStart().
218  *
219  * @param[in] pwmp pointer to a @p PWMDriver object
220  * @param[in] channel PWM channel identifier (0...channels-1)
221  *
222  * @iclass
223  */
224 #define pwmIsChannelEnabledI(pwmp, channel) \
225  (((pwmp)->enabled & ((pwmchnmsk_t)1U << (pwmchnmsk_t)(channel))) != 0U)
226
227 /**
228  * @brief Enables the periodic activation edge notification.
229  * @pre The PWM unit must have been activated using @p pwmStart().
230  * @note If the notification is already enabled then the call has no effect.
231  *
232  * @param[in] pwmp pointer to a @p PWMDriver object
233  *
234  * @iclass
235  */
236 #define pwmEnablePeriodicNotificationI(pwmp) \
237  pwm_lld_enable_periodic_notification(pwmp)
238
239 /**
240  * @brief Disables the periodic activation edge notification.
241  * @pre The PWM unit must have been activated using @p pwmStart().
242  * @note If the notification is already disabled then the call has no effect.
243  *
244  * @param[in] pwmp pointer to a @p PWMDriver object
245  *
246  * @iclass
247  */
248 #define pwmDisablePeriodicNotificationI(pwmp) \
249  pwm_lld_disable_periodic_notification(pwmp)
250
251 /**
252  * @brief Enables a channel de-activation edge notification.
253  * @pre The PWM unit must have been activated using @p pwmStart().
254  * @pre The channel must have been activated using @p pwmEnableChannel().
255  * @note If the notification is already enabled then the call has no effect.
256  *
257  * @param[in] pwmp pointer to a @p PWMDriver object
258  * @param[in] channel PWM channel identifier (0...channels-1)
259  *
260  * @iclass
261  */
262 #define pwmEnableChannelNotificationI(pwmp, channel) \
263  pwm_lld_enable_channel_notification(pwmp, channel)
264
265 /**
266  * @brief Disables a channel de-activation edge notification.
267  * @pre The PWM unit must have been activated using @p pwmStart().
268  * @pre The channel must have been activated using @p pwmEnableChannel().
269  * @note If the notification is already disabled then the call has no effect.
270  *
271  * @param[in] pwmp pointer to a @p PWMDriver object
272  * @param[in] channel PWM channel identifier (0...channels-1)
273  *
274  * @iclass
275  */
276 #define pwmDisableChannelNotificationI(pwmp, channel) \
277  pwm_lld_disable_channel_notification(pwmp, channel)
278 /** @} */
279
280 /*===========================================================================*/
281 /* External declarations. */
282 /*===========================================================================*/
283
284 #ifdef __cplusplus
285 extern "C" {
286 #endif
287  void pwmInit(void);
288  void pwmObjectInit(PWMDriver *pwmp);
289  void pwmStart(PWMDriver *pwmp, const PWMConfig *config);
290  void pwmStop(PWMDriver *pwmp);
292  void pwmEnableChannel(PWMDriver *pwmp,
293  pwmchannel_t channel,
294  pwmcnt_t width);
295  void pwmDisableChannel(PWMDriver *pwmp, pwmchannel_t channel);
300 #ifdef __cplusplus
301 }
302 #endif
303
304 #endif /* HAL_USE_PWM == TRUE */
305
306 #endif /* HAL_PWM_H */
307
308 /** @} */
void pwmEnableChannel(PWMDriver *pwmp, pwmchannel_t channel, pwmcnt_t width)
Definition: hal_pwm.c:167
const PWMConfig * config
Current driver configuration data.
Definition: hal_pwm_lld.h:142
void pwmChangePeriod(PWMDriver *pwmp, pwmcnt_t period)
Definition: hal_pwm.c:143
PLATFORM PWM subsystem low level driver header.
Type of a PWM driver configuration structure.
Definition: hal_pwm_lld.h:105
uint32_t pwmcnt_t
Type of a PWM counter.
Definition: hal_pwm_lld.h:83
void pwmEnablePeriodicNotification(PWMDriver *pwmp)
Definition: hal_pwm.c:218
Deactivates the PWM peripheral.
Definition: hal_pwm.c:111
Configures and activates the PWM peripheral.
Definition: hal_pwm.c:89
pwmstate_t
Definition: hal_pwm.h:74
Structure representing a PWM driver.
Definition: hal_pwm_lld.h:134
void pwmInit(void)
PWM Driver initialization.
Definition: hal_pwm.c:56
Disables a PWM channel and its notification.
Definition: hal_pwm.c:196
void pwmDisablePeriodicNotification(PWMDriver *pwmp)
Definition: hal_pwm.c:241
void(* pwmcallback_t)(PWMDriver *pwmp)
Definition: hal_pwm.h:90
uint8_t pwmchannel_t
Type of a PWM channel.
Definition: hal_pwm_lld.h:73
void pwmEnableChannelNotification(PWMDriver *pwmp, pwmchannel_t channel)
Definition: hal_pwm.c:266
Initializes the standard part of a PWMDriver structure.
Definition: hal_pwm.c:68
void pwmDisableChannelNotification(PWMDriver *pwmp, pwmchannel_t channel)
Definition: hal_pwm.c:294
pwmcnt_t period
Current PWM period in ticks.
Definition: hal_pwm_lld.h:146
