hal_pwm_lld.h
18  * @file hal_pwm_lld.h
19  * @brief PLATFORM PWM subsystem low level driver header.
21  * @addtogroup PWM
25 #ifndef HAL_PWM_LLD_H
26 #define HAL_PWM_LLD_H
28 #if (HAL_USE_PWM == TRUE) || defined(__DOXYGEN__)
31 /* Driver constants. */
34 /**
35  * @brief Number of PWM channels per PWM driver.
36  */
37 #define PWM_CHANNELS 4
38
40 /* Driver pre-compile time settings. */
42
43 /**
44  * @name PLATFORM configuration options
45  * @{
46  */
47 /**
48  * @brief PWMD1 driver enable switch.
49  * @details If set to @p TRUE the support for PWM1 is included.
50  * @note The default is @p FALSE.
51  */
52 #if !defined(PLATFORM_PWM_USE_PWM1) || defined(__DOXYGEN__)
53 #define PLATFORM_PWM_USE_PWM1 FALSE
54 #endif
55 /** @} */
56
58 /* Configuration checks. */
60
61 /*===========================================================================*/
62 /* Driver data structures and types. */
63 /*===========================================================================*/
64
65 /**
66  * @brief Type of a PWM mode.
67  */
68 typedef uint32_t pwmmode_t;
69
70 /**
71  * @brief Type of a PWM channel.
72  */
73 typedef uint8_t pwmchannel_t;
74
75 /**
76  * @brief Type of a channels mask.
77  */
78 typedef uint32_t pwmchnmsk_t;
79
80 /**
81  * @brief Type of a PWM counter.
82  */
83 typedef uint32_t pwmcnt_t;
84
85 /**
86  * @brief Type of a PWM driver channel configuration structure.
87  */
88 typedef struct {
89  /**
90  * @brief Channel active logic level.
91  */
93  /**
94  * @brief Channel callback pointer.
95  * @note This callback is invoked on the channel compare event. If set to
96  * @p NULL then the callback is disabled.
97  */
99  /* End of the mandatory fields.*/
101
102 /**
103  * @brief Type of a PWM driver configuration structure.
104  */
105 typedef struct {
106  /**
107  * @brief Timer clock in Hz.
108  * @note The low level can use assertions in order to catch invalid
109  * frequency specifications.
110  */
111  uint32_t frequency;
112  /**
113  * @brief PWM period in ticks.
114  * @note The low level can use assertions in order to catch invalid
115  * period specifications.
116  */
118  /**
119  * @brief Periodic callback pointer.
120  * @note This callback is invoked on PWM counter reset. If set to
121  * @p NULL then the callback is disabled.
122  */
124  /**
125  * @brief Channels configurations.
126  */
128  /* End of the mandatory fields.*/
129 } PWMConfig;
130
131 /**
132  * @brief Structure representing a PWM driver.
133  */
134 struct PWMDriver {
135  /**
136  * @brief Driver state.
137  */
139  /**
140  * @brief Current driver configuration data.
141  */
143  /**
144  * @brief Current PWM period in ticks.
145  */
147  /**
148  * @brief Mask of the enabled channels.
149  */
151  /**
152  * @brief Number of channels in this instance.
153  */
155 #if defined(PWM_DRIVER_EXT_FIELDS)
156  PWM_DRIVER_EXT_FIELDS
157 #endif
158  /* End of the mandatory fields.*/
159 };
160
161 /*===========================================================================*/
162 /* Driver macros. */
163 /*===========================================================================*/
164
165 /**
166  * @brief Changes the period the PWM peripheral.
167  * @details This function changes the period of a PWM unit that has already
168  * been activated using @p pwmStart().
169  * @pre The PWM unit must have been activated using @p pwmStart().
170  * @post The PWM unit period is changed to the new value.
171  * @note The function has effect at the next cycle start.
172  * @note If a period is specified that is shorter than the pulse width
173  * programmed in one of the channels then the behavior is not
174  * guaranteed.
175  *
176  * @param[in] pwmp pointer to a @p PWMDriver object
177  * @param[in] period new cycle time in ticks
178  *
179  * @notapi
180  */
181 #define pwm_lld_change_period(pwmp, period)
182
183 /*===========================================================================*/
184 /* External declarations. */
185 /*===========================================================================*/
186
187 #if (PLATFORM_PWM_USE_PWM1 == TRUE) && !defined(__DOXYGEN__)
188 extern PWMDriver PWMD1;
189 #endif
190
191 #ifdef __cplusplus
192 extern "C" {
193 #endif
194  void pwm_lld_init(void);
195  void pwm_lld_start(PWMDriver *pwmp);
196  void pwm_lld_stop(PWMDriver *pwmp);
198  pwmchannel_t channel,
199  pwmcnt_t width);
200  void pwm_lld_disable_channel(PWMDriver *pwmp, pwmchannel_t channel);
204  pwmchannel_t channel);
206  pwmchannel_t channel);
207 #ifdef __cplusplus
208 }
209 #endif
210
211 #endif /* HAL_USE_PWM == TRUE */
212
213 #endif /* HAL_PWM_LLD_H */
214
215 /** @} */
const PWMConfig * config
Definition: hal_pwm_lld.h:142
pwmcnt_t period
Definition: hal_pwm_lld.h:117
void pwm_lld_enable_periodic_notification(PWMDriver *pwmp)
Enables the periodic activation edge notification.
Definition: hal_pwm_lld.c:163
uint32_t pwmmode_t
Type of a PWM mode.
Definition: hal_pwm_lld.h:68
pwmstate_t state
Definition: hal_pwm_lld.h:138
void pwm_lld_disable_channel_notification(PWMDriver *pwmp, pwmchannel_t channel)
Disables a channel de-activation edge notification.
Definition: hal_pwm_lld.c:211
pwmchnmsk_t enabled
Definition: hal_pwm_lld.h:150
Definition: hal_pwm_lld.h:105
uint32_t pwmcnt_t
Definition: hal_pwm_lld.h:83
pwmmode_t mode
Definition: hal_pwm_lld.h:92
pwmcallback_t callback
Definition: hal_pwm_lld.h:98
pwmchannel_t channels
Definition: hal_pwm_lld.h:154
pwmstate_t
Definition: hal_pwm.h:74
Definition: hal_pwm_lld.h:123
Definition: hal_pwm_lld.h:134
void pwm_lld_enable_channel(PWMDriver *pwmp, pwmchannel_t channel, pwmcnt_t width)
Enables a PWM channel.
Definition: hal_pwm_lld.c:127
Definition: hal_pwm_lld.h:78
Disables a PWM channel and its notification.
Definition: hal_pwm_lld.c:148
void pwm_lld_enable_channel_notification(PWMDriver *pwmp, pwmchannel_t channel)
Enables a channel de-activation edge notification.
Definition: hal_pwm_lld.c:193
void pwm_lld_disable_periodic_notification(PWMDriver *pwmp)
Disables the periodic activation edge notification.
Definition: hal_pwm_lld.c:177
PWMDriver PWMD1
PWMD1 driver identifier.
Definition: hal_pwm_lld.c:42
Deactivates the PWM peripheral.
Definition: hal_pwm_lld.c:102
Configures and activates the PWM peripheral.
Definition: hal_pwm_lld.c:83
void(* pwmcallback_t)(PWMDriver *pwmp)
Type of a PWM notification callback.
Definition: hal_pwm.h:90
Definition: hal_pwm_lld.h:73
uint32_t frequency
Timer clock in Hz.
Definition: hal_pwm_lld.h:111
Low level PWM driver initialization.
Definition: hal_pwm_lld.c:66
Definition: hal_pwm_lld.h:88
pwmcnt_t period
Definition: hal_pwm_lld.h:146
Definition: hal_pwm_lld.h:37
