I/O Queues macros and structures. More...
struct | io_queue |
Generic I/O queue structure. More... | |
Queue functions returned status value | |
#define | Q_OK MSG_OK |
Operation successful. More... | |
#define | Q_TIMEOUT MSG_TIMEOUT |
Timeout condition. More... | |
#define | Q_RESET MSG_RESET |
Queue has been reset. More... | |
#define | Q_EMPTY MSG_TIMEOUT |
Queue empty. More... | |
#define | Q_FULL MSG_TIMEOUT |
Queue full,. More... | |
Macro Functions | |
#define | qSizeX(qp) |
Returns the queue's buffer size. More... | |
#define | qSpaceI(qp) ((qp)->q_counter) |
Queue space. More... | |
#define | qGetLink(qp) ((qp)->q_link) |
Returns the queue application-defined link. More... | |
#define | iqGetFullI(iqp) qSpaceI(iqp) |
Returns the filled space into an input queue. More... | |
#define | iqGetEmptyI(iqp) (qSizeX(iqp) - qSpaceI(iqp)) |
Returns the empty space into an input queue. More... | |
#define | iqIsEmptyI(iqp) ((bool)(qSpaceI(iqp) == 0U)) |
Evaluates to true if the specified input queue is empty. More... | |
#define | iqIsFullI(iqp) |
Evaluates to true if the specified input queue is full. More... | |
#define | iqGet(iqp) iqGetTimeout(iqp, TIME_INFINITE) |
Input queue read. More... | |
#define | oqGetFullI(oqp) (qSizeX(oqp) - qSpaceI(oqp)) |
Returns the filled space into an output queue. More... | |
#define | oqGetEmptyI(oqp) qSpaceI(oqp) |
Returns the empty space into an output queue. More... | |
#define | oqIsEmptyI(oqp) |
Evaluates to true if the specified output queue is empty. More... | |
#define | oqIsFullI(oqp) ((bool)(qSpaceI(oqp) == 0U)) |
Evaluates to true if the specified output queue is full. More... | |
#define | oqPut(oqp, b) oqPutTimeout(oqp, b, TIME_INFINITE) |
Output queue write. More... | |
Typedefs | |
typedef struct io_queue | io_queue_t |
Type of a generic I/O queue structure. More... | |
typedef void(* | qnotify_t) (io_queue_t *qp) |
Queue notification callback type. More... | |
typedef io_queue_t | input_queue_t |
Type of an input queue structure. More... | |
typedef io_queue_t | output_queue_t |
Type of an output queue structure. More... | |
void | iqObjectInit (input_queue_t *iqp, uint8_t *bp, size_t size, qnotify_t infy, void *link) |
Initializes an input queue. More... | |
void | iqResetI (input_queue_t *iqp) |
Resets an input queue. More... | |
msg_t | iqPutI (input_queue_t *iqp, uint8_t b) |
Input queue write. More... | |
msg_t | iqGetI (input_queue_t *iqp) |
Input queue non-blocking read. More... | |
msg_t | iqGetTimeout (input_queue_t *iqp, sysinterval_t timeout) |
Input queue read with timeout. More... | |
size_t | iqReadI (input_queue_t *iqp, uint8_t *bp, size_t n) |
size_t | iqReadTimeout (input_queue_t *iqp, uint8_t *bp, size_t n, sysinterval_t timeout) |
void | oqObjectInit (output_queue_t *oqp, uint8_t *bp, size_t size, qnotify_t onfy, void *link) |
Initializes an output queue. More... | |
void | oqResetI (output_queue_t *oqp) |
Resets an output queue. More... | |
msg_t | oqPutI (output_queue_t *oqp, uint8_t b) |
Output queue non-blocking write. More... | |
msg_t | oqPutTimeout (output_queue_t *oqp, uint8_t b, sysinterval_t timeout) |
Output queue write with timeout. More... | |
msg_t | oqGetI (output_queue_t *oqp) |
Output queue read. More... | |
size_t | oqWriteI (output_queue_t *oqp, const uint8_t *bp, size_t n) |
size_t | oqWriteTimeout (output_queue_t *oqp, const uint8_t *bp, size_t n, sysinterval_t timeout) |
Definition in file hal_queues.h.
