hal_rtc_lld.c
16 /*
17  Concepts and parts of this file have been contributed by Uladzimir Pylinsky
18  aka barthess.
19  */
20
21 /**
22  * @file hal_rtc_lld.c
23  * @brief PLATFORM RTC subsystem low level driver source.
24  *
25  * @addtogroup RTC
26  * @{
27  */
29 #include "hal.h"
30
31 #if (HAL_USE_RTC == TRUE) || defined(__DOXYGEN__)
34 /* Driver local definitions. */
38 /* Driver exported variables. */
41 /**
42  * @brief RTC driver identifier.
43  */
44 #if (PLATFORM_RTC_USE_RTC1 == TRUE) && !defined(__DOXYGEN__)
45 RTCDriver RTCD1;
46 #endif
47
49 /* Driver local variables and types. */
51
53 /* Driver local functions. */
55
57 /* Driver interrupt handlers. */
59
60 /*===========================================================================*/
61 /* Driver exported functions. */
62 /*===========================================================================*/
63
64 /**
65  * @brief Enable access to registers.
66  *
67  * @notapi
68  */
69 void rtc_lld_init(void) {
70
71  /* RTC object initialization.*/
72 #if PLATFORM_RTC_USE_RTC1 == TRUE
73  rtcObjectInit(&RTCD1);
74 #endif
75 }
76
77 /**
78  * @brief Set current time.
79  * @note Fractional part will be silently ignored. There is no possibility
80  * to set it on PLATFORM platform.
81  * @note The function can be called from any context.
82  *
83  * @param[in] rtcp pointer to RTC driver structure
84  * @param[in] timespec pointer to a @p RTCDateTime structure
85  *
86  * @notapi
87  */
88 void rtc_lld_set_time(RTCDriver *rtcp, const RTCDateTime *timespec) {
89
90  (void)rtcp;
91  (void)timespec;
92 }
93
94 /**
95  * @brief Get current time.
96  * @note The function can be called from any context.
97  *
98  * @param[in] rtcp pointer to RTC driver structure
99  * @param[out] timespec pointer to a @p RTCDateTime structure
100  *
101  * @notapi
102  */
103 void rtc_lld_get_time(RTCDriver *rtcp, RTCDateTime *timespec) {
104
105  (void)rtcp;
106  (void)timespec;
107 }
108
109 #if (RTC_ALARMS > 0) || defined(__DOXYGEN__)
110 /**
111  * @brief Set alarm time.
112  * @note Default value after BKP domain reset for both comparators is 0.
113  * @note Function does not performs any checks of alarm time validity.
114  * @note The function can be called from any context.
115  *
116  * @param[in] rtcp pointer to RTC driver structure.
117  * @param[in] alarm alarm identifier. Can be 1 or 2.
118  * @param[in] alarmspec pointer to a @p RTCAlarm structure.
119  *
120  * @notapi
121  */
123  rtcalarm_t alarm,
124  const RTCAlarm *alarmspec) {
125
126  (void)rtcp;
127  (void)alarm;
128  (void)alarmspec;
129 }
130
131 /**
132  * @brief Get alarm time.
133  * @note The function can be called from any context.
134  *
135  * @param[in] rtcp pointer to RTC driver structure
136  * @param[in] alarm alarm identifier
137  * @param[out] alarmspec pointer to a @p RTCAlarm structure
138  *
139  * @notapi
140  */
142  rtcalarm_t alarm,
143  RTCAlarm *alarmspec) {
144
145  (void)rtcp;
146  (void)alarm;
147  (void)alarmspec;
148 }
149 #endif /* RTC_ALARMS > 0 */
150
151 #endif /* HAL_USE_RTC */
152
153 /** @} */
Get current time.
Definition: hal_rtc_lld.c:103
void rtcObjectInit(RTCDriver *rtcp)
Initializes a generic RTC driver object.
Definition: hal_rtc.c:81
void rtc_lld_set_alarm(RTCDriver *rtcp, rtcalarm_t alarm, const RTCAlarm *alarmspec)
Set alarm time.
Definition: hal_rtc_lld.c:122
Type of a structure representing an RTC alarm time stamp.
Definition: hal_rtc_lld.h:111
Definition: hal_rtc_lld.c:69
void rtc_lld_get_alarm(RTCDriver *rtcp, rtcalarm_t alarm, RTCAlarm *alarmspec)
Get alarm time.
Definition: hal_rtc_lld.c:141
uint32_t rtcalarm_t
Type of an RTC alarm number.
Definition: hal_rtc_lld.h:92
Type of a structure representing an RTC date/time stamp.
Definition: hal_rtc.h:93
Set current time.
Definition: hal_rtc_lld.c:88
Structure representing an RTC driver.
Definition: hal_rtc_lld.h:130
