hal_rtc_lld.h
16 /*
17  Concepts and parts of this file have been contributed by Uladzimir Pylinsky
18  aka barthess.
19  */
20
21 /**
22  * @file hal_rtc_lld.h
23  * @brief PLATFORM RTC subsystem low level driver header.
24  *
25  * @addtogroup RTC
26  * @{
27  */
29 #ifndef HAL_RTC_LLD_H
30 #define HAL_RTC_LLD_H
31
32 #if (HAL_USE_RTC == TRUE) || defined(__DOXYGEN__)
35 /* Driver constants. */
37
38 /**
39  * @name Implementation capabilities
40  */
41 /**
42  * @brief Callback support int the driver.
43  */
44 #define RTC_SUPPORTS_CALLBACKS TRUE
45
46 /**
47  * @brief Number of alarms available.
48  */
49 #define RTC_ALARMS 2
50
51 /**
52  * @brief Presence of a local persistent storage.
53  */
54 #define RTC_HAS_STORAGE FALSE
55 /** @} */
56
58 /* Driver pre-compile time settings. */
60
61 /**
62  * @name PLATFORM configuration options
63  * @{
64  */
65 /**
66  * @brief RTCD1 driver enable switch.
67  * @details If set to @p TRUE the support for RTC1 is included.
68  * @note The default is @p FALSE.
69  */
70 #if !defined(PLATFORM_RTC_USE_RTC1) || defined(__DOXYGEN__)
71 #define PLATFORM_RTC_USE_RTC1 FALSE
72 #endif
73 /** @} */
74
75 /*===========================================================================*/
76 /* Derived constants and error checks. */
77 /*===========================================================================*/
78
79 /*===========================================================================*/
80 /* Driver data structures and types. */
81 /*===========================================================================*/
82
83 /**
84  * @brief FileStream specific methods.
85  */
86 #define _rtc_driver_methods \
87  _file_stream_methods
88
89 /**
90  * @brief Type of an RTC alarm number.
91  */
92 typedef uint32_t rtcalarm_t;
93
94 #if (RTC_SUPPORTS_CALLBACKS == TRUE) || defined(__DOXYGEN__)
95 /**
96  * @brief Type of an RTC event.
97  */
98 typedef enum {
99  RTC_EVENT_SECOND = 0 /** Triggered every second. */
100 } rtcevent_t;
101
102 /**
103  * @brief Type of a generic RTC callback.
104  */
105 typedef void (*rtccb_t)(RTCDriver *rtcp, rtcevent_t event);
106 #endif
107
108 /**
109  * @brief Type of a structure representing an RTC alarm time stamp.
110  */
111 typedef struct {
112  /* End of the mandatory fields.*/
113  uint32_t dummy;
114 } RTCAlarm;
115
116 #if (RTC_HAS_STORAGE == TRUE) || defined(__DOXYGEN__)
117 /**
118  * @extends FileStream
119  *
120  * @brief @p RTCDriver virtual methods table.
121  */
122 struct RTCDriverVMT {
124 };
125 #endif
126
127 /**
128  * @brief Structure representing an RTC driver.
129  */
130 struct RTCDriver {
131 #if (RTC_HAS_STORAGE == TRUE) || defined(__DOXYGEN__)
132  /**
133  * @brief Virtual Methods Table.
134  */
135  const struct RTCDriverVMT *vmt;
136 #endif
137  /* End of the mandatory fields.*/
138  uint32_t dummy;
139 };
140
141 /*===========================================================================*/
142 /* Driver macros. */
143 /*===========================================================================*/
144
145 /*===========================================================================*/
146 /* External declarations. */
147 /*===========================================================================*/
148
149 #if (PLATFORM_RTC_USE_RTC1 == TRUE) && !defined(__DOXYGEN__)
150 extern RTCDriver RTCD1;
151 #endif
152
153 #if (RTC_HAS_STORAGE == TRUE) && !defined(__DOXYGEN__)
154 extern struct RTCDriverVMT _rtc_lld_vmt;
155 #endif
156
157 #ifdef __cplusplus
158 extern "C" {
159 #endif
160  void rtc_lld_init(void);
161  void rtc_lld_set_time(RTCDriver *rtcp, const RTCDateTime *timespec);
162  void rtc_lld_get_time(RTCDriver *rtcp, RTCDateTime *timespec);
163 #if RTC_ALARMS > 0
164  void rtc_lld_set_alarm(RTCDriver *rtcp,
165  rtcalarm_t alarm,
166  const RTCAlarm *alarmspec);
167  void rtc_lld_get_alarm(RTCDriver *rtcp,
168  rtcalarm_t alarm,
169  RTCAlarm *alarmspec);
170 #endif
171 #if RTC_SUPPORTS_CALLBACKS == TRUE
172  void rtc_lld_set_callback(RTCDriver *rtcp, rtccb_t callback);
173 #endif
174 #ifdef __cplusplus
175 }
176 #endif
177
178 #endif /* HAL_USE_RTC == TRUE */
179
180 #endif /* HAL_RTC_LLD_H */
181
182 /** @} */
Get current time.
Definition: hal_rtc_lld.c:103
Definition: hal_rtc_lld.h:122
void rtc_lld_set_alarm(RTCDriver *rtcp, rtcalarm_t alarm, const RTCAlarm *alarmspec)
Set alarm time.
Definition: hal_rtc_lld.c:122
rtcevent_t
Definition: hal_rtc_lld.h:98
Definition: hal_rtc_lld.h:111
RTC driver identifier.
Definition: hal_rtc_lld.c:69
void rtc_lld_get_alarm(RTCDriver *rtcp, rtcalarm_t alarm, RTCAlarm *alarmspec)
Get alarm time.
Definition: hal_rtc_lld.c:141
uint32_t rtcalarm_t
Definition: hal_rtc_lld.h:92
Type of a structure representing an RTC date/time stamp.
Definition: hal_rtc.h:93
const struct RTCDriverVMT * vmt
Definition: hal_rtc_lld.h:135
Set current time.
Definition: hal_rtc_lld.c:88
Definition: hal_rtc_lld.h:130
void(* rtccb_t)(RTCDriver *rtcp, rtcevent_t event)
Definition: hal_rtc_lld.h:105
Definition: hal_rtc_lld.h:86
